[参考译文] CCS:7.1 .0.0.0016万 安装问题
Guru**** 2577385 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/589241/ccs-ccs7-1-0-00016-installation-problem
工具/软件:Code Composer Studio
我无法安装7.1 .0.0.0016万
尝试联机和脱机,相同的错误。
我正在使用Windows 7。
"未找到可安装单元org.eclipse.equinox.p2.discovery.feature.feature.group "
日志文件显示:
!Session 2017年04月17日 14:31: 17.101 ----------------------------------
Eclipse.buildId=Eclipse.0.I2016.0606万-1100<xmt-block0>1100 4.6
java.version=java.0_112 1.8
java.vendor=Oracle Corporation
引导加载程序常量:OS=Win32,ARCH=x86,WS=Win32,NL=es_AR
框架参数:-application org.eclipse.equinox.p2.director -repository文件:/c:/ti/ccsv7/eclipse/downloads/featurerepo,文件:/C:/Instalar/Ccsasesie.0.0.0016万_Win32/baserepo/eclipserepo 7.1 -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group,org.eclipse.gmf.runtime.thirdparty.feature.group -roaming -uninstalliu org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group,org.eclipse.gmf.runtime.thirdparty.feature.group
命令行参数:-os Win32 -ws Win32 -arch x86 -data C:/Users/electronica1/AppData/local/Temp/CS_6420f0ca-1872-44a3-6b7a-64ai51973a/workspace -application1872 -application org.eclipse.equinox.p2.director5.1973万 org.eclipse.equinox.p2.director -basrepository文件:/c:/ti/44a3-6b7a-64aieclip/ini/secalli/ org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group,org.eclipse.gmf.runtime.thirdparty.feature.group安装/cru/cru/cru/cru/cru/cru/cuniusiusecu/cru/ipu/cru/cru/ 7.1 -ese-fiusecu/cru/cru/cru/cru/cru/ org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group,org.eclipse.gmf.runtime.thirdparty.feature.group
!entry org.eclipse.equinox.p2.ifact.repository 41000 2017年04月17日 14:31: 18.100
!消息未在file:/c:/ti/ccsv7/eclipse/downloads/featurerepo中找到存储库。
!条目org.eclipse.equinox.p2.metada.repository 41000 2017年04月17日 14:31:18.131
!entry org.eclipse.equinox.p2.director.app 4 0 2017年04月17日 14:31:18.583
!message The installable unit org.eclipse.equinox.p2.discovery.feature.feature.group has not been found.(未找到可安装单元)
请帮帮我。
    您好,Alejandro:
    能否将ccsv7/install_logs文件夹的内容压缩并将zip文件发布在此处?
    丹麦语
    是的。
    这是文件。
    e2e.ti.com/.../7563.install_5F00_logs.zip
    更新过程中似乎出现故障。 安装程序在尝试几次后很难恢复。 我建议删除CCS安装并从头开始安装7.1 0。 对此造成的不便,我们深表歉意。
