[参考译文] CODECOMPOSER:CODECOMPOSER
Guru**** 2935310 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/1016090/codecomposer-codecomposer
器件型号:CODECOMPOSER
我的 CCS 10出现应用程序错误。 错误如下(来自 metadata\.log)--
!entry org.eclipse.OSGi 4 0 2021-07-06 21:21:36.395
!消息应用程序错误
!堆栈1
java.lang.NoClassDefFoundError:org/eclipse/core/resources/IContainer
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native 方法)
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown 来源)
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown 来源)
java.lang.reflect.Method.invoke(Unknown 来源)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
在 org.eclipse.equinox.launcher.Main.basicRun (Main.java:594)
org.eclipse.equinox.launcher.Main.run(Main.java:1465)
原因:java.lang.ClassNotFoundException:自动激活 bundle org.eclipse.core.resources (285)时出错。
org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:126)
org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:571)
org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:346)
org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:398)
org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:41)
org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:472)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:425)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:171)
在 java.lang.classloader.loader.loadClass (未知来源)
(笑声) 13个以上
原因:bundle org.eclipse.core.resources.ResourcesPlugin.start()中的 org.osgi.framework.BundleException:异常。
org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:863)
org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:791)
org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1015)
org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:365)
在 org.eclipse.OSGi.container.Module.doStart (Module.Java:603)
在 org.eclipse.OSGi.container.Module.start (Module.Java:467)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:493)
org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:117)
(笑声) 22个以上
原因:org.eclipse.core.internal.resources.ResourceException:文件格式不兼容。 工作区保存的版本不兼容:0。
org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:62)
org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:70)
org.eclipse.core.internal.resources.SaveManager.restoreTree(SaveManager.java:1038)
org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:708)
org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1555)
org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2452)
org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2210)
在 org.eclipse.core.resources.ResourcesPlugin.start (ResourcesPlugin.java:489)
org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:842)
org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
java.security.AccessController.doPrivileged(Native 方法)
org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:834)
(笑声) 29个以上
原因:java.lang.exception:不兼容的文件格式。 工作区保存的版本不兼容:0。
org.eclipse.core.internal.resources.ResourceException.provideStackTrace(ResourceException.java:42)
请访问 org.eclipse.core.internal.resources.ResourceException。 (ResourceException.Java:38)
(笑声) 41个以上
