[参考译文] TMS320C6678:可以#39;t 在"/tmp/TI_MKLIBr78rCW/SRC/memory.c 和 quot 处查找源文件;找到该文件或编辑源查找路径以包含其位置。
Guru**** 2935310 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/999186/tms320c6678-can-t-find-a-source-file-at-tmp-ti_mklibr78rcw-src-memory-c-locate-the-file-or-edit-the-source-lookup-path-to-include-its-location
器件型号:TMS320C6678
运行多个内核时、主内核卡在该错误上
