[参考译文] CCS/LAUNCHXL-CC2640R2:CAN#39;t Build Project Zero
Guru**** 2522770 points
Other Parts Discussed in Thread: CC2650
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/896756/ccs-launchxl-cc2640r2-can-t-build-project-zero
器件型号:LAUNCHXL-CC2640R2
Thread 中讨论的其他器件:CC2650
工具/软件:Code Composer Studio
我刚刚收到 CC2640R2 Launchpad、并尝试对其上的 BLESTACK Project_ZERO 进行调试。
STACK_LIBRARY 部分构建良好、而 APP 部分构建不好。
我已经安装了 SDK 版本3.40.00.10、并通过专用的"Import to CSS"按钮导入该项目。
我应该怎么做?
提前感谢
这是 我的 project_zero_cc2640r2lp_app 构建日志:
****为项目 project_zero_cc2640r2lp_app 构建配置 FlashROM_StackLibrary ****
"C:\\ti\\ccs1000\\ccs\\utils\bin\\gmake"-k -j 8 all -O
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/icall_cc2650.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENT --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_EVENT_ENDAC=NUM=ICALL_WRAME_CONFIGN ---- define=UARTALL_UNIT_CONFIGN=NUM=ICALL_UNCH_ENDE-CONFIGN=ICALCR=NUM=ICALL_UNCH_ENDE-CONFIGING_UNESD-CONFIGINTRIBRATE=NUM------ CONFIGIN_END=NUM=ICALL_UNCH_END=ICALP=NUM=ICALP=ICALCK_CONFIGING_UNCH_ENDE-CONFIGING_UNCH_UNESD-CONFIGINTRIBRATE=NUM---------------- CONFIGINTRY=ICALCR=NUM=ICALP=ICALCR=ICALL_UNCH_UNES=NUM preproc_with_compile --preproc_Dependence="iCall/iCall_cc260.d_ray"--obj_directory="iCall"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/icall_cc2650.c
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/icall_cc2650.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/TRNGCC26XX.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENT --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_EVENT_ENDAC=NUM=ICALL_WATE_CONFIGN=END=UARTALL_CRIT_UNITY=ENDE-CONFIGN=NUM=ICALL_UNIT_CONFIGN=ENDE-CONFIGING_UNCH=ENDE-CONFIGRATE=ENDE-CONFIGRATE=END-CONFIGIN_ENDE-CONFIGIN_UNES=NUM=ICALL_UNESD-CONFIGING_CONFIGINTRENABLE_CONFIGRATE=ENDE-CONFIGING_CONFIGING_UNESD-CONFIDA-CONFIDA-DEVICALCR=ENABLE_CONFIGING_CONFIGING_UNESD-CONFIDA-CONFIGING_CONFIGING_CONFIGINTRENAB-END-CONFIGING_UNESD-CONFIG_UART- preproc_with_compile --preproc_dependence="Drivers/TRNG/TRNGCC26XX.d_ray"--obj_directory="Drivers/TRNG"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/TRNGCC26XX.c
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/TRNGCC26XX.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx/util.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENT --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_EVENT_ENDULES=6 --define=UARTALL_CRIT=UALL_CRITY=UARTALL_CRITY=NUM=END-CONFIDA-CONFIGIN_END-CONFIGIN_CONFIGIN=END-CONFIG_CONFIGIN_END-CONFIGIN=UAL=UALL_UNIT_CONFIG_UNCH=NUM=ENDE-CONFIG_CONFIG_ENDE-CONFIGINTRY=ENDE-CONFIDA-CONFIGINTRY=ENDE-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIG_UART=END-CONFIG_UART=END-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONF preproc_with_compile --preproc_dependence="Application/util.d_rain"--obj_directory="Application"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx/util.c "
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx/util.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/icall_user_config.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_EVENT_NUM=ICALL_SABLE_CONFIG_ENDE-CONFIG=ENDE-CONFIG_ENABLE_CONFIGRATE=ICALL_UNCH=ENDE-CONFIG-ENABLE_CONFIG-ENDE-CONFIG_ENABLE_CONFIG-ENABLE_CONFIG-ENABLE_CONFIG-ENABLE_CONFIG-CONFIG-ENTRY=ICALL_CONFIG-ENABLE_CONFIG-ENABLE_CONFIG_ENDE-CONFIG-ENABLE_CONFIG-ENABLE_CONFIG-ENABLE_CONFIG-ENABLE_CONFIG-CONFIG-CONFIG-CONFIG-ENABLE_CONFIG-CONFIG-CONFIG-CONFIG-CONFIG-ENTRIG-ENABLE_CONFIG-ENABLE_CONFIG-ENTRIG-ENTRIDA-CONFIG_UPD- preproc_with_compile --preproc_dependence="iCall/iCall_user_config.d_ray"--obj_directory="iCall"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/icall_user_config.c "
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/icall_user_config.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx/ecc/ECCROMCC26XX.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_ABCC_ENDULES=6 --define=ICALL_RATE=UARTALL_CRIT_ENDE-CONFIGIN=ENDE-CONFIGIN=END=UARTALL_UNES=NUM32_CONFIGIN_UNCH=ENDE-CONFIDA-CONFIDA-CONFIDA-CONFIGING_CONFIG_UNCH=ENDE-CONFIGING_RATE=ENDE-CONFIG_CONFIGING_CONFIGRATE=ENDE-CONFIGRATE=ENABLE_CONFIDA-CONFIG_UNESD-CONFIDA-CONFIG_CONFIG_UART-CONFIGRATE=ENDE-CONFIGENABLE_CONFIGRATE=END-CONFIGRATE=ENABLE_CONFIGRATE=END-CONFIDA-DEVICALP=ENABLE_CONFIDA-DEVICAL preproc_with_compile --preproc_Dependence="Drivers/ECC/ECCROMCC26XX.d_ray"--obj_directory="Drivers/ECC"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx/ecc/ECCROMCC26XX.c
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx/ecc/ECCROMCC26XX.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/app/icall_api_lite.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENT --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_EVCC_ENDULES=6 --define=ICALL_CASTACK_CONFIGN=UART=END=ENAB_UNIT_CONFIGRATE=NUM=ICALL_CRIT_END-CONFIGIN_CONFIGIN_END-CONFIGIN_ENABLED-CONFIGIN_CONFIGINTRIBRATE=NUM=ICAL=END-CONFIG_ENDE-CONFIG_END=ICALL_UNES=ICALL_CONFIGINTRIBRATE=NUM=ENDE-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIGEND-CONFIG_ENABLE=END-CONFIDA-CONFIG_CONFIG_ENABLE-ENABLE_CONFIG_EN preproc_with_compile --preproc_dependence="ICallBLE/iCall_API_lite.d_ray"--obj_directory="ICallBLE"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/app/icall_api_lite.c
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/app/icall_api_lite.c
编译文件:"../ICallBLE/ble_user_config.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_EVENT_ENDULES=NUM=ICALL_RATE=UART=ENAB_UNCH_ENABLE_CONFIGIN_CONFIG-END-CONFIG=NUM=ICALL_UNCH_CONFIGIN_END-CONFIG_END-CONFIG_ENABLE_CONFIG_ENABLE_CONFIG_END-CONFIG_END-CONFIG_END-CONFIG_ENABLE_CONFIG_ENABLE_CONFIG_UART-CONFIG_UART=ENABLE_CONFIG_UART=ENABLE_CONFIG_UART=ENABLE_CONFIG_CONFIG_CONFIG_CONFIG_UPDORT-CONFIG_CONFIG_CONFIG_UART-CONFIG_ENABLE_CONFIGENABLE_CONFIGENABLE_CONFIG_END-CONFIG_ENABLE_CONFIG_UPDORDER ---- preproc_with_compile --preproc_dependence="ICallBLE/ble_user_config.d_ray"--obj_directory="ICallBLE"--cmd_file="configPkg/compiler.opt""./ICallBLE/ble_user_config.c
已完成构建:"./ICallBLE/ble_user_config.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/host/gatt_uuid.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_ENTICODE-UART=UARTALL_SABLE_WARDE-ENDE-ENDE-NUM=UART=UART=UART_END=UARTA-CONFIGN=UALL_UNDE-CONFIGN=NUMA-CONFIGN=ENDE-CONFIDA-CONFIDA-CONFIDA-CONFIGRATE=END=END-CONFIG_END=END=END=UART=UALL_RATE_CONFIGING_RATE_CONFIGRATE=ENDE-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIG-END=END=END=ENDE-CONFIG-END=END=END=UALL_UNESD-CONFIDA-CONFIDA-CONFIG preproc_with_compile --preproc_dependence="profiles/gatt_uuid.d_ray"--obj_directory="profiles"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/host/gatt_uuid.c
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/host/gatt_uuid.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/drivers/rf/RFCC26XX_singleMode.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENT --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_ABLE_CRITY=6 --define=ICALL_RATED-CONFIGIN=END=UARTALL_UNCH_ENDE-CONFIDA-CONFIGN=NUM=END-CONFIDA-CONFIGIN_CONFIGING_CONFIG_CONFIGENDE-CONFIGRATE=ENDE-CONFIGENDE-CONFIGENDE-CONFIGENDE-CONFIGENDE-CONFIGENDE-CONFIGENDE-CONFIG_UNES=NUM=ENDE-CONFIGRATE=ENDE-CONFIDA-DEVICALP=ENABLE_CONFIG_UART-CONFIGRATE=ENABLE_CONFIG_UART-CONFIGRATE=ENABLE_CONFIGRATE=ENABLE_CONFIGRATE=ENABLE_CONFIGRATE=ENABLE_CONFIG_URATE=NU preproc_with_compile --preproc_Dependence="Drivers/RF/RFCC26XX_singlemode.d_ray"--obj_directory="Drivers/RF"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/drivers/rf/RFCC26XX_singleMode.c
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/drivers/rf/RFCC26XX_singleMode.c
编译文件:"../Application/project_zero.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_EVENT_ENDULES=6 --define=ICALL_RATE=UART12_END=UART=UART_LOG_WIT_END=UARTALL_CRIT_ENDE-CONFIGN=NUM=END-CONFIGIN_END-CONFIGIN_END=END=UART-CONFIDA-CONFIDA-CONFIG_CONFIG_END=END=END-CONFIGIN_CONFIG_CONFIGINTRY=END-CONFIGINTRY=ENDE-CONFIGIN_CONFIG_CONFIG_UART-CONFIG_UART=ENDE-CONFIDA-CONFIGINTRY=ENDE-CONFIGINTRY=ENDE-CONFIG_UART=ENDE-CONFIDA-CONFIG_UART=ENDE-CONFIGINTRY_ preproc_with_compile --preproc_dependence="Application/project_zero.d_rain"--obj_directory="Application"--cmd_file="configPkg/compiler.opt""./Application/project_zero.c
已完成构建:"./Application/project_zero.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/icall.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENT --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_UNCK_UNIVER=NUM=ICALL_CASTACK_CONFIGN=END-CONFIGN=ICALL_UNCH_CONFIGN=ENDE-CONFIGN=ICALL_CRY=NUME-CONFIGING_CONFIGINE-CONFIGING_CONFIGINE-CONFIGENABLE_CONFIGINE-CONFIGENTRENDE-CONFIGING_UNESD-CONFIG_UART-CONFIGN=ENDE-CONFIDA-CONFIDA-CONFIG_UART-CONFIGN=ICALL_UNCH_CONFIGING_RATED-CONFIG_UART=IDA-CONFIG_UART-CONFIG_UART=IDA-CONFIG_UART=IDA-CONFIGNE=IDA-CONFIGNE=IDA-CONFIGNE=IDA-CONFIG_UART-CONFIGNE=IDA-CONFIG preproc_with_compile --preproc_dependence="iCall/iCall.d_ray"--obj_directory="iCall"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/icall.c
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/icall.c
编译文件:"../PROFILES/button_service.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_EVENT_ENTIM=NUM=ICALL_RATE=UART=ENAB_UNCH_UNESTI-define=UART=UART=UART_CONFIG_CONFIG_RATE=END-CONFIGIN_CONFIG_UNCH=NUM=END-CONFIG_END-CONFIG_CONFIG_CONFIG_UNCH=END-CONFIGINTRY=ENDE-CONFIG_CONFIG_CONFIG_ENDE-CONFIGINTRY=ENDE-CONFIDA-CONFIG_UART=ENDE-CONFIG_UART=END=END=ENDE-CONFIG_UART=ENABLE_CONFIGNE=ENABLE_CONFIGRATE=ENABLE_TRY_ERENCE --CONFIGNE=ENABLE_CONFIGNE=ENABLE_CONFIGNE= preproc_with_compile --preproc_dependence="profiles/button_service.d_rain"--obj_directory="profiles"--cmd_file="configPkg/compiler.opt""./PROFILES/button_service.c
已完成构建:"./PROFILES/button_service.c
编译文件:"../PROFILES/data_service.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENT --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_EVENT_ENTIM=NUM=ICALL_RATE=UARTA-SAFERTIF=ENDE-CONFIGN=UALL_CRIT_ENDE-CONFIGN=ENDE-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIGEND=END-CONFIGING_RATE=END=END=UART=END=UART=ENABLE_CONFIG_RATE_CONFIG_RATE=END-CONFIDA-CONFIG_UART-CONFIGRATE=ENDE-CONFIGRATE=END-CONFIDA-CONFIG_UART=ENABLE_CONFIG_UART=END-CONFIDA-CONFIGRATE=END-CONFIDA-CONFIG_UART-CONFIG_URATE=END-CONFIDA-CONFIGNE=END-CONFIGNE preproc_with_compile --preproc_dependence="profiles/data_service.d_rain"--obj_directory="profiles"--cmd_file="configPkg/compiler.opt""./PROFILES/data_service.c
已完成构建:"./PROFILES/data_service.c
编译文件:"../PROFILES/devinfoservice.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENT --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_UNSABLE_SAFETY_FUNCK_CONFIGN=ENDE-CONFIGN=ENDE-CONFIGRATE=ENDE-CONFIGIN_ENABLE_CONFIGRATE=ENDE-CONFIGRATE=NUM=END=UALL_UNCH_UNES=NUM=ENDE-CONFIGIN_ENABLE_TRY_UNESD-CONFIGING_UNESD-CONFIGINTRUALL_CONFIGN=NUME-CONFIGN=ENDE-CONFIGINTRY=ENDE-CONFIGING_CONFIGINTRY_UNES=ENDE-CONFIDA-CONFIG_UART-CONFIG_UART=ENDE-CONFIDA-CONFIG_UART=ENABLE_TRY=ENDE-CONFIG_UART=ENABLE_TRY_UNES=ENABLE_TR preproc_with_compile --preproc_dependence="profiles/devinfoservice.d_ray"--obj_directory="profiles"--cmd_file="configPkg/compiler.opt""./PROFILES/devinfoservice.c
已完成构建:"./PROFILES/devinfoservice.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra/uartlog/UartLog.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_EVENT_ENDULES=6 --define=UARTALL_RATE=UART=UART_LOG_WIT=UART=UART=ENAB_UNIT_RATE=END-CONFIGIN_CONFIG_END-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIG_END-CONFIDA-CONFIDA-CONFIDA-CONFIG_END-CONFIG_ENCE=END-CONFIG_CONFIDA-CONFIG_CONFIG_CONFIG_CONFIG_CONFIGEND-CONFIG_CONFIG_CONFIGENCE=ENCE=END-CONFIG_UART-CONFIG_CONFIGENTRIDA-CONFIGENABLE_CONFIGEND-CONFIGEND-CONFIDA-CONFIG_UART-CONFIG_UART- preproc_with_compile --preproc_dependence="Startup/UartLog.d_ray"--obj_directory="Startup"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra/uartlog/UartLog.c
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra/uartlog/UartLog.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/host/gattservapp_util.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENT --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_ATTRY_ENDULESD=NUM=ICALL_SAFUNT_UNIT_CONFIGN=ENDE-CONFIGING_RATE=UARTA-CONFIGN=ENDE-CONFIGING_RATE=ENABLE_CONFIGRATE=END-CONFIGRATE=END-CONFIGIN_UNESD-CONFIG_UNCH=NUM=END-CONFIG_UART-CONFIDA-CONFIG_UART-CONFIGING_RATE=END-CONFIG_UART-CONFIGNE=ENABLE_CONFIGNE=END-CONFIG_UART-CONFIG_UART=ENABLE_CONFIG_UART=ENABLE_CONFIGNE=ENABLE_CONFIGNE=ENABLE_CONFIGRATED-CONFIDA-CONFIGNE=ENABLE_TRY_UNESD-CONFIG_UART= preproc_with_compile --preproc_dependence="profiles/gattservapp_util.d_ray"--obj_directory="profiles"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/host/gattservapp_util.c
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/host/gattservapp_util.c
编译文件:"../PROFILES/led_service.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_EVENT_ENTIM=NUM=ICALL_RATE=UART=ENABLE_WARDE-CONFIGN=ENDE-CONFIGN=ENDE-CONFIGING_RATE=END=UART0-CONFIGIN_CONFIGN=ENDE-CONFIGENDE-CONFIDA-CONFIDA-CONFIDA-CONFIGEND=END=END=END=END=UALL_UNESD-CONFIDA-CONFIG_CONFIG_UARTA-CONFIGRATE=END-CONFIGRATE=END-CONFIGRATE=END-CONFIG_UART=END=END=END=END=END=ICALL_RATE=UALP=ENABLE_CONFIGRATE=END-CONFIDA-DEVICALCR=NUM_TRY=ENABLE_CONFIG preproc_with_compile --preproc_dependence="profiles/led_service.d_rain"--obj_directory="profiles"--cmd_file="configPkg/compiler.opt""./PROFILES/led_service.c
已完成构建:"./PROFILES/led_service.c
编译文件:"../Startup/CC2640R2_LAUNCHXL.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_UNCHXINESD=6 --define=ICALL_RATE=UART12_UNCH_END=UART=UART_RATE_CONFIGIN_CONFIGINE-CONFIG_END-CONFIGINTRY=END=UALL_UNCH=ENDE-CONFIDA-CONFIDA-CONFIG_CONFIDA-CONFIGEND-CONFIG_CONFIGEND=END-CONFIG_CONFIDA-CONFIG_CONFIGEND=END=END=END=UALL_CONFIG_CONFIG_CONFIDA-CONFIGENDE-CONFIDA-CONFIG_CONFIDA-CONFIGENABLE_CONFIDA-CONFIG_UART=ENABLE_CONFIGENABLE_CONFIDA-CONFIDA-CONFIGENABLE_CONFIGENABLE_CONFIGRAP=ENTRUAL preproc_with_compile --preproc_dependence="Startup/CC2640R2_LAUNCHXL.d_ray"--obj_directory="Startup"--cmd_file="configPkg/compiler.opt""./Startup/CC2640R2_LAUNCHXL.c
已完成构建:"./Startup/CC2640R2_LAUNCHXL.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app/main.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENT --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_ABECTOR= 6 --define = ICALL_RATE=UARTALL_CRITY=ENDE-CONFIGING_UNITY=UARTA-CONFIDA-CONFIDA-CONFIG_ENDE-CONFIG_ENDE-CONFIDA-CONFIDA-CONFIGENDE-CONFIG_ENDE-CONFIDA-CONFIDA-CONFIGENDE-CONFIDA-CONFIG_ENTRUAL=ENDE-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIGENDE-CONFIGENDE-CONFIG_ENDE-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIDA-CONFIG_UART=END-CONFIDA-CONFIG_UART=ENABLE_CONFIDA-CONFIG_UART=ENAB_CONFIGENABLE_CONFIDA-CONFIG_URATE=EN preproc_with_compile --preproc_dependence="Startup/main.d_rain"--obj_directory="Startup"--cmd_file="configPkg/compiler.opt""C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app/main.c "
完工:"c:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app/main.c
编译文件:"../PROFILES/peripheral.c
调用:ARM 编译器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl --cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt /Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain /Users/milkj/Desktop/Brain Technologies/固件/工作区- ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-mv7M3 - code_firmware_track_up/cc2640p_track_up/track_up/cc1 -/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/extra -project_project_zero/track_project_track_up/cc40p_project_support=/Users/milkj/Desktop/Brain --track_project_project_zero/track_project_up/r40p_project_project_project_project_zero=---track_support_project_project_project_zero/cc40p_project_project_project_support_project_track_track_project_project_project_project_track_zero=---track_support_project_zeroup/cc40p_project_project_project_project_project_track_project /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /Users/milkj/Desktop/Brain include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/examples/rtos/CC2640R2_LAUNCHXL/blestack/project_zero/src/app --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/dev_info --include_display_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx --include_display_ctrad="/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile/cc26xx --include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common --include_display_ctrad.com.cn"--include_display_path=/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr --include_display_ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/simple_profile /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr --include_display_path=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include --include_ctrad.com.cn_display_.com.cn_be-.com.cn_.com.cn_cn_.com.cn"--include_display_cn_.com.cn_.com.cn_cn_cn_cn_cn_cn_.com.cn_cn_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn-cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_.com.cn_.com.cn_.com.cn_.com.cn.cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_cn_ define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENT --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_ABECT_ENABLE_RATE=6 --define=UARTALL_CRIT=UALL_UNITY=UARTA-CONFIDA-CONFIG_END-CONFIGIN=NUM=END-CONFIDA-CONFIG_CONFIDA-CONFIG_CONFIG_CONFIGEND-CONFIGEND-CONFIDA-CONFIG_END-CONFIG_CONFIG_ENCE=END-CONFIDA-CONFIG_CONFIG_UART-CONFIGENCE=ENCE=NUM=END-CONFIG_CONFIG_CONFIG_UART-CONFIGRATE=END-CONFIG_UART=END-CONFIG_CONFIG_CONFIG_CONFIG_CONFIG_UART-CONFIG_URATED-CONFIG_URATED-CONFIG_UART-CONFIGENTREND-CONFIG_CONFIG_URATE=EN preproc_with_compile --preproc_dependence="profiles/peripheral.d_rain"--obj_directory="profiles"--cmd_file="configPkg/compiler.opt""./PROFILES/peripheral.c
已完成构建:"./PROFILES/peripheral.c
构建目标:"project_zero_cc2640r2lp_app.out"
调用:ARM 链接器
"c:/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/bin/armcl - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/build_components.opt - cmd_file="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/config/factory_config.opt - cmd_file="C:/Users/milkj/Desktop/Brain Technologies/firmware/Workspace - ProjectZero_1/project_zero_cc2640r2lp_stack_library/tools/build_config.opt"-code_ctrade_define=cc2640r2_define=ctrad_define -define -c64x=ctrad_us_define -define -ctrad_define -c64_define =ctrad_us=uel_define -define -c64x=ctrad_define -ctrad_us=uel_define -define -c64_define -ctraduel_define -ctraduel_us=ctraduel_us=c64_define -define -ctraduel_us=ctraduel_define -define -ctraduel_us=ctraduel_define -define -c64_us=uel_c define=use_ICALL --define=xdc_runtime_assert_disable_all --define=xdc_runtime_Log_disable_all --define=UARTLOG_ENABLED-define=UARTLOG_NUM_EVT_BUF=32 --define=uartlog_file="\""-="--define=122-ine-d=2-intrab-region-d=2-d=102m=2-ine-region_d_d=2-from-region-region-region-d=10242-d=2-in-d=2-in-region-d=2-d=2-d=2-ful-d_bi-d_bi-dag-region-d=2-d_bi-dag-region-d=10242-d=2-d=2-in-d=2-d_bi-d=2-d_bi-d_bi-d_bi-dag-region-region-region-region-region-region-region-d=2-d=/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/include /ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_18.12.2.LTS/lib diag_wrap=off --display_error_number --warn_sections --xml_link_info="project_zero_cc2640r2lp_app_linkInfo.xml"-- rom_model -o "project_zero_cc2640r2lp_app.out""./Application/project_zero.obj ""./Application/util.obj ""./Drivers/TRNG/TRNGCC26XX.obj ""./ICall/icall.obj ""./ICall/icall_cc2650.obj "./Drivers/RF/RFCC26XX_singleMode.obj /ICallBLE/icall_api_lite.obj /PROFILES/devinfoservice.obj /PROFILES/led_service.obj /Startup/UartLog.obj /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2/driverlib/bin/ccs/driverlib.lib /ti/simplelink_cc2640r2_sdk_3_40_00_10/kernel/tirtos/packages/ti/dpl/lib/dpl_cc26x0r2.aem3 /Users/milkj/Desktop/Brain "./ICall/icall_user_config.obj "./PROFILES/button_service.obj /PROFILES/gatt_uuid.obj /PROFILES/peripheral.obj /Startup/ccfg_app_ble.obj /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/drivers/lib/drivers_cc26x0r2.aem3 /Users/milkj/Desktop/Brain "./Drivers/ECC/ECCROMCC26XX.obj "./ICallBLE/ble_user_config.obj ".cc40l_library -/PROFILES/data_service.obj ".track_dl_pruetooth_ecures"/"/PROFILES/gattservapp_util.obj -track_pruels"-/Startup/CC2640R2_LAUNCHXL.obj -track_track_ecures"/"/Startup/main.obj -l_tracknates"-/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/display/lib/display.aem3 ".track_ecures/r2l_track_rts"/Users/milkj/Desktop/Brain --track_track_ecures"/content/r40l.track_rts"-track_tracknes"/content/r40l.tracknecs"-tracknes"/content/r40l.tracknes"/content/rts"-track_track_rts"-tracknecs"-tracknates"/content/r40l.tracknates"/content/rts"-track_track_rts"-track_/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx/ccs/cc26xx_app.cmd
错误#10008-D:找不到文件"C:/Users/milkj/Desktop/Brain Technologies/firmware/Workspace - ProjectZero_1/project_zero_cc2640r2lp_stack_library/FlashROM_Library/ble_R2.symbols"
错误#10008-D:找不到文件"C:/Users/milkj/Desktop/Brain Technologies/firmware/Workspace - ProjectZero_1/project_zero_cc2640r2lp_stack_library/FlashROM_Library/lib_linker.cmd"
未定义的首次引用
符号
ATT_BuildErrorRsp
ATT_BuildExchangeMTURsp
ATT_BuildFindByTypeValueRsp
ATT_BuildFindInfoRsp
ATT_BuildHandleValueInd
ATT_BuildPrepareWriteRsp
ATT_BuildReadBlobRsp
ATT_BuildReadByGrpTypeRsp
ATT_BuildReadByTypeRsp
ATT_BuildReadMultiRsp
ATT_BuildReadRsp
ATT_CompareUUID
ATT_ConvertUIDto128
ATT_ErrorRsp
ATT_ExchangeMTUR
ATT_ExecuteWriteRsp
ATT_FindByTypeValueRsp
ATT_FindInfoRsp
ATT_GetMTU
ATT_HandleValueInd
ATT_HandleValueNoti
ATT_ParseExchangeMTUReq
ATT_ParseExecuteWriteReq
ATT_ParseFindByTypeValueReq
ATT_ParseFindInfoReq
ATT_ParsePacket
ATT_ParsePrepareWriteReq
ATT_ParseReadBlobReq
ATT_ParseReadByTypeReq
ATT_ParseReadMultiReq
ATT_ParseReadReq
ATT_ParseWriteReq
ATT_PrepareWriteRsp
ATT_ReadBlobRsp
ATT_ReadByGrpTypeRsp
ATT_ReadByTypeRsp
ATT_ReadMultiRsp
ATT_ReadRsp
ATT_RegisterServer
ATT_UpdateMTU
ATT_WriteRsp
GAP_Authenticate
GAP_Bond
GAP_EndDiscoverable
GAP_GetIRK
GAP_GetParamValue
GAP_Init
GAP_MakeDiscoverable
GAP_NumActiveConnections
GAP_ParametsInit
GAP_PasscodeUpdate
GAP_PeriConnRegister
GAP_PeriDevMgrInit
GAP_PrivacyInit
GAP_ProcessEvent
GAP_RegisterBondMgrCBs
GAP_RegisterConnEventCb
GAP_RegisterForMsgs.
GAP_SecParamsInit
GAP_SendSlaveSecurityRequest
GAP_SetParamValue
GAP_Signable
GAP_TerminateAuth
GAP_TerminateLinkReq
GAP_UpdateAddisingData
GAP_UpdateLinkParamReq
GAP_UpdateLinkParamReqReply
GAP_isPairing
GATTServApp_AddService
GATTServApp_Init
GATTServApp_ProcessEvent
GATTServApp_ReadAttr
GATTServApp_RegisterForMsg
GATTServApp_RegisterService
GATTServApp_UpdateCharCfg
GATTServApp_WriteAttr
GATT_AppCompletedMsg
GATT_FindHandle
GATT_FindHandleUUID
GATT_FindNextAttr
GATT_Indication
GATT_Init
GATT_InitServer
GATT_Notification
GATT_NotifyEvent
GATT_ProcessEvent
GATT_RegisterForMsgs
GATT_SendRsp
GATT_ServiceEncKeySize
GATT_ServiceNumAttrs
GATT_UpdateMTU
GATT_VerifyReadPermissions
GATT_VerifyWritePermissions
GATT_BM_alloc
GATT_BM_FREE
GGS_AddService
GGS_SetParameter
HCI_CommandCompleteEvent
HCI_CommandStatusEvent
HCI_DataBufferOverflowEvent
HCI_DisconnectCmd
HCI_GAPTaskRegister
HCI_HardwareErrorEvent
HCI_HostBufferSizeCmd
HCI_HostNumCompletPktCmd
HCI_Init
HCI_L2CAPTaskRegister
HCI_LE_AddDeviceToResolvingListCmd
HCI_LE_AddWhiteListCmd
HCI_LE_ClearResolvingListCmd
HCI_LE_ClearWhiteListCmd
HCI_LE_ConnUpdateCmd
HCI_LE_GenerateDHKeyCmd
HCI_LE_LtkReqNegReplyCmd.
HCI_LE_LtkReqReplyCmd.
HCI_LE_ReadBufSizeCmd
HCI_LE_ReadLocalP256PublicKeyCmd
HCI_LE_RemoteConnParamReqNegReplyCmd
HCI_LE_RemoteConnParamReqReplyCmd
HCI_LE_RemoveDeviceFromResolvingListCmd
HCI_LE_SetAddressResolutionEnableCmd
HCI_LE_SetAdvDataCmd
HCI_LE_SetAdvEnableCmd
HCI_LE_SetAdvParamCmd
HCI_LE_SetRandomAddressCmd
HCI_LE_SetResolvablePrivateAddressTimeoutCmd
HCI_LE_SetScanRspDataCmd
HCI_NumOfCompletedPacketsEvent
HCI_ProcessEvent
HCI_ReadBDADDRCmd
HCI_ResetCmd
HCI_ReverseBytes
HCI_SMPTaskRegister
HCI_SendCommandCompleteEvent
HCI_SendCommandStatusEvent
HCI_SendControllerToHostEvent
HCI_SendDataPkt
HCI_SetControllerToHostFlowCtrlCmd
HCI_ValidConnTimeParams
HCI_VendorSpecifcCommandCompleteEvent
HCI_BM_alloc
L2CAP_BuildCmdReject
L2CAP_BuildParamUpdateRsp
L2CAP_CmdReject
L2CAP_ConnParamUpdateReq
L2CAP_GetMTU
L2CAP_HostNumCompletedPkts
L2CAP_Init
L2CAP_ParseParamUpdateReq
L2CAP_ProcessEvent
L2CAP_RegisterApp
L2CAP_SendData
L2CAP_SendDataPkt
L2CAP_SetBufSize
L2CAP_SetControllerToHostFlowCtrl
L2CAP_SetUserConfig
L2CAP_BM_alloc
LL_AddDeviceToResolvingList
LL_AddWhiteListDevice
LL_AuthPayloadTimeoutExpiredBack
LL_ChanMapUpdate
LL_ClearResolvingList
LL_ClearWhiteList
LL_ConnActive
LL_ConnParamUpdateBack
LL_ConnUpdate
LL_CreateConn
LL_CreateConnCancel
LL_CtrlToHostFlowControl
LL_DataLengthChangeEventBack
LL_DirectTestEnd
LL_DirectTestEndDoneBack
LL_DirectTestRxTest
LL_DirectTestTxTest
LL_Disconnect
LL_DisconnectCback
LL_ENC_AES128_Decrypt
LL_ENC_AES128_Encrypt
LL_ENC_DecryptMsg
LL_ENC_Encrypt
LL_ENC_EncryptMsg_sPatch
LL_ENC_GenDeviceIV
LL_ENC_GenDeviceSKD
LL_ENC_GenerateNonce
LL_ENC_GeneratePseudRandNum
LL_ENC_GenerateTrueRandNum
LL_ENC_LoadKey
LL_ENC_ReverseBytes
LL_EXT_AdvEventNotice
LL_EXT_BuildRevision
LL_EXT_ClkDivOnHalt
LL_EXT_ConnEventNotice
LL_EXT_DeclareNvUsage
LL_EXT_Decrypt
LL_EXT_DisconnectImmed
LL_EXT_EndModemTest
LL_EXT_ExtendRfRange
LL_EXT_GetConnInfo
LL_EXT_HaltDuringRf
LL_EXT_MapPmIoPort
LL_EXT_ModemHopTestTx
LL_EXT_ModemTestRx
LL_EXT_ModemTestTx
LL_EXT_ComplNumPktsLimit
LL_EXT_OnePacketPerEvent
LL_EXT_OverlappedProcessing
LL_EXT_PERbyChan
LL_EXT_PacketErrorRate
LL_EXT_PacketErrorRateBack
LL_EXT_ResetSystem
LL_EXT_SaveFreqTune
LL_EXT_SetBDADDR
LL_EXT_SetFastTxResponse 时间
LL_EXT_SetFreqTune
LL_EXT_SetLocalSupportedFeatures
LL_EXT_SetMaxDataLen
LL_EXT_SetMaxDtmTxPower
LL_EXT_SetRxGain
LL_EXT_SetSCA
LL_EXT_SetSlaveLatencyOverride
LL_EXT_SetTxPower
LL_EncChangeBack
LL_EncKeyRefreshBack
LL_EncLtkNegReply
LL_EncLtkReply
LL_EncLtkReqBack
LL_Encrypt
LL_GenerateDHKeyCmd
LL_GenerateDHKeyCompleteEventBack
LL_GetActiveNumConns
LL_Init
LL_PRIV_Ah
LL_PRIV_ClearExtWL
LL_PRIV_FindPeerInRL
LL_PRIV_GenerateRPA
LL_PRIV_IsRPA
LL_PRIV_IsZeroIRK
LL_PRIV_ResolveRPA
LL_PRIV_SetWLSize
LL_PRIV_SetupPrivacy
LL_PRIV_Teardown 隐私
LL_ProcessEvent
LL_PseudoRand
LL_RX_BM_alloc
LL_Rand
LL_RandBack
LL_ReadAdvChanTxPower
LL_ReadAuthPayloadTimeout
LL_ReadBDADDR
LL_ReadChanMap
LL_ReadDefaultDataLen
LL_ReadLocalP256PublicKeyCmd
LL_ReadLocalP256PublicKeyCompleteEventBack
LL_ReadLocalResolvableAddress
LL_ReadLocalSupportedFeatures
LL_ReadLocalVersionInfo
LL_ReadMaxDataLen
LL_ReadPeerResolvableAddress
LL_ReadRemoteUsedFeatures
LL_ReadRemoteUsedCompleteFeaturesBack
LL_ReadRemoteVersionInfo
LL_ReadRemoteVersionInfoBack
LL_ReadResolvingListSize
LL_ReadRssi
LL_ReadSupportedStates
LL_ReadTxPowerLevel
LL_ReadWlSize
LL_RemoteConnParamReqBack
LL_RemoteConnParamReqNegReply
LL_RemoteConnParamReqReply
LL_RemoveDeviceFromResolvingList
LL_RemoveWhiteListDevice
LL_Reset
LL_RxDataCompleteBack
LL_SetAddressResolutionEnable_sPatch
LL_SetAdvControl
LL_SetAdvData
LL_SetAdvParam
LL_SetDataLen
LL_SetRandomAddress
LL_SetResolvablePrivateAddressTimeout
LL_SetScanControl
LL_SetScanParam
LL_SetScanRspData
LL_StartEncrypt
LL_TX_BM_ALLOC
LL_TxData
LL_WriteAuthPayloadTimeout
LL_WriteDefaultDataLen
NIST_Curve_P256_GX
NIST_Curve_P256_Gy
NIST_Curve_P256_A
NIST_Curve_P256_b
NIST_Curve_P256_p
NIST_Curve_P256_r
RAM_BASE_ADDR
RFHAL_FreeNextTxDataEntry
RFHAL_GetNextDataEntry
RFHAL_GetTempDataEntry
RFHAL_InitDataQueue
ROM_BASE_ADDR
SM_GenerateAuthenSig
SM_Init
sm_PasskeyUpdate
SM_ProcessEvent
SM_Response 初始化
SM_SetECCRegenationCount
SM_StartPairing
SM_VerifyAuthenSig
WL_AddEntry
WL_CLEAR
WL_ClearEntry
WL_ClearIgnoreList
WL_FindEntry
WL_GetNumFreeEntry
WL_GetSize
WL_Init
WL_RemoveEntry
连接 SendMsg
AttSendRspMsg
断开连接下一个
eccRom_genKeys
eccRom_genSharedSecret
eccRom_param_gx
eccRom_param_Gy
eccRom_param_a
eccRom_param_b
eccRom_param_p
eccRom_param_r
eccRom_windowSize
eccRom_Workzone
gapAddAddAddAddAddAddAddAddAddAddAddAddAddr 可
GapAddAdvToken
GapAllocAdvRecs
GapBuildADTokens
GapCalcAdvTokenDataLen
GapClrState
GapConnectCleanedUpAdvertising
GapDeleteAdvToken
GapFindADType
GapFindAdvToken
GapFreeAddertState
gapFreeAuthLink
GapFreeEstLink
GapGetDevAddress
gapGetDevAddressMode
GapGetSRK
GapGetSignCounter
gapHost2CtrlOwnAddrType
GapInSignCounter
GapIsAdvertising
GapIsScanning
gapL2ConncapParamUpdateReq
GapPairingCompleteCB
gapPasskeyNeedCB
gapPeriProcessConnUpdateCmd 状态
gapPeriProcessConnUpdateCompleteEvt
GapPeriProcessSignalEvt
gapProcessAddertisingTimeout
GapProcessBLEEvents
GapProcessCommandStatusEvt
GapProcessConnEvt
gapProcessConnectionCompleteEvt
gapProcessDisconnectCompleteEvt
gapProcessHCCmdCompleteEvt
GapProcessNewAddr
GapProcessOSALMsg
GapProcessRemoteConnParamReqEvt
GapReadBD_ADDRStatus
gapReadBufSizeCmdStatus
GapRegisterPeripheral
GapRegisterPeripheralConn
gapSendAdDataUpdateEvent
gapSendBondCompleteEvent
gapSendDeviceInitDoneEvent
gapSendEndDiscoverableEvent
gapSendLinkUpdateEvent
gapSendMakeDiscEvent
GapSendPairingReqEvent
gapSendSignUpdateEvent
GapSetAdvParams
gapSetAdvParamsStatus
GapSetState
GapState
GapUpdateConnSignCounter
GapValidADType
GapWriteAdvDataStatus
GapWriteAdvEnableStatus
gattFindServerInfo
GattFindService
gattGetPayload
gattGetServerStatus
GattNotifyEvent
GattParseReq
gattProcessExchangeMTUReq
gattProcessExecuteWriteReq
gattProcessFindByTypeValueReq
gattProcessFindInfoReq
GattProcessOSALMsg
gattProcessReadByGrpTypeReq
gattProcessReadByTypeReq
gattProcessReadMultiReq
GattProcessReadReq
GattProcessReq
gattProcessRxData
GattProcessWriteReq
GattRegisterServer
gattResetServerInfo
gattSendFlowCtrlEvt
gattServApp_ClearPrepareWriteQ
gattServApp_EnqueuePrepareWriteReq
gattServApp_FindAuthorizeAttrCB
gattServApp_FindPrepareWriteQ
GattServApp_FindServiceCB
gattServApp_IsWriteLong
gattServApp_ProcessExchangeMTUReq
gattServApp_ProcessExecuteWriteReq
gattServApp_ProcessFindByTypeValueReq
gattServApp_ProcessPrepareWriteReq
gattServApp_ProcessReadBlobReq
gattServApp_ProcessReadByGrpTypeReq
gattServApp_ProcessReadByTypeReq
gattServApp_ProcessReadMultiReq
gattServApp_ProcessReadReq
gattServApp_ProcessRelableWrites
gattServApp_ProcessWriteLong
gattServApp_ProcessWriteReq
gattServApp_buildReadByTypeRsp
GattServerHandleConnStatusCB
gattServerHandleTimerCB
gattServerNotifyTxCB
gattServerProcessMsgCB
gattServerStartTimer
GattServiceLastHandle
gattStartTimer
GattStopTimer
gattStoreServerInfo
Generate_子 项
hciGapTaskID
hciInitEventMasks
hciL2capTaskID
hciSmpTaskID
hciTaskID
hciTestTaskID
isLimitedDiscoverableMode
l2capAllocChannel
l2capAllocConnChannel
l2capBuildInfoReq
l2capBuildParamUpdateReq
l2capBuildSignalHdr
l2capDisconnectAllChannels
l2capEncapSendData
l2capFindLocalId
l2capFreeChannel
l2capFreePendingPkt
l2capHandleRxError
l2capHandleTimerCB
l2capNotifyData
l2capNotifyEvent
l2capNotifySignal
l2capParseCmd 拒绝
l2capParsePacket
l2capParseParamUpdateRsp
l2capParseSignalHdr
l2capProcessOSALMsg
l2capProcessReq
l2capProcessRsp
l2capProcessRxData
l2capProcessSignal
l2capSendCmd
l2capSendFCPkt
l2capSendPkt
l2capSendReq
l2capStartTimer
l2capStopTimer
l2capStoreFCPkt
leftshift_onebit
LinkDBNumConns
LinkDB_Add
LinkDB_Auten
linkDB_find
LinkDB_FindFirst
LinkDB_Init
LinkDB_MTU
LinkDB_NumActive
LinkDB_NumConns
LinkDB_Register
LinkDB_Remove
linkDB_role
LinkDB_SecurityModeSCOnly
LinkDB_State
LinkDB_Update
linkDB_UpdateMTU
LinkDB_reportStatusChange
llActiveTask
llAddTxDataEntry
llAlignToNextEvent_sPatch
llAllConnlocId
llAllocTask
ATllLeastTwoChans
llCBTimer_AptoExpiredBack
llCalcScaFactor
llCheckForLstoDuringSL
llCheckRxBuffers
llCheckWhiteListUsage
llConfigTable
llConnCleanup
ConnllExists
llConnTerminate
llConvertCtrlProcTimeoutToEvent
llConvertLstoToEvent
llCreateRxBuffer
llDataGetConnPtr
llDequeCtrlPkt
llEnqueueCtrlPkt
llEventDelta
llEventInRange
llFragmentPDU
llFreeTask
llGenerateCRC
llGetCurrentTask
llGetCurrentTime
llGetNextDataChan
llGetNumTasks
llGetTaskState
llGetTxPower
llHaltRadio
llHardwareError
llInitFeatureSet
llMemCopySrc
llMoveTempTxDataEntry
llOctets2Time
llPendingUpdateParam
llProcessChanMap
llProcessSlaveControlProcedures
llProcessTxData
llReleaseConnId
llReplaceCtrlPKT
llReplaceRxBuffers
llRfInit
llRfSetup
llRfStartFS
llScheduleTask
llScheduler
llSendReject
llSetNextDataChan
llSetTxPower
llSetupAdv
llSetupAdvDataEntryQueue
llSetupConn
llSetupConnParamReq
llSetupConnParamRsp
llSetupConnRxDataEntryQueue
llSetupEncRsp
llSetupFeatureSetReq
llSetupFeatureSetRsp
llSetupInit
llSetupInitDataEntryQueue
lSetupLenCtrlPKT_sPatch
llSetupNextSlaveEvent
llSetupPauseEncRsp
llSetupPingReq
llSetupPingRsp
llSetupRejectInd
llSetupReIndjectExt
llSetupScanDataEntryQueue
llSetupStartEncReq
llSetupStartEncRsp
llSetupTermInd
llSetupUnknownRsp
llSetupVersionIndReq
llTaskList
llTime2Octets
llTimeCompare
llTimeDelta
llUserConfig
llValidateConnParams
llVerifyConnParamReqParams
llWriteTxData
填充
rfCallback
sendAuthEvent
sendEstLinkEvent
sendTerminateEvent
sizeInfo
smAuthReqToUint8.
smdetermineIOCaps
smDetermineKeySize
smEncrypt
smEncryptLocal
smEndPairing
smF5Wrapper
smFinishPublicKeyExchange
smfreePairingParams
smGenerateAddrInput
smGenerateConfirm (smGenerateConfirm)
smGenerateDheyCheck
smGeneratePairingReqRsp
smGenerateRandBuf
smGenerateRandMsg
smGetECKeys
smIncrementEccKeyRecycleCount
smLinkCheck
smNextPairingState
smOobSCAuthentication
smPairingSendEncInfo
smPairingSendIdentityAddrInfo
smPairingSendIdentityInfo
smPairingSendMasterID
smPhairingSendSigningInfo
smProcessDataMsg
smProcessEncryptChange
smProcessHCIBLEEventCode
smProcessHCCIBLEMetaEventCode
smProcessOSALMsg
smProcessPairingReq
smRegisterResponse
smResponseAuthStageTwo
smSavePairInfo_sPatch
smSaveRemotePublicKeys
smSendDheyCheck
smSendFailAndEnd
smSendFailureEvt
smSendPublicKeys
smSendSMMsg
smSetPairingReqRsp
smStartEncryption
smStartRspTimer
smStopRspTimer
smTimedOut
smUint8ToAuthReq
SM_CMAC
sm_allocateSCParameters
SM_C1
sm_c1新
SM_computeDHKey
SM_F4
SM_F5
SM_F6
SM_G2
SM_s1.
SM_XOR
smpBuildEncInfo
smpBuildIdentityAddrInfo
smpBuildIdentityInfo
smpBuildMasterID
smpBuildPhairingConfirm
smpBuildPhairingDHKeyCheck
smpBuildPhairingFlail
smpBuildPairingPublicKey
smpBuildPhairingRandom
smpBuildPairingReq
smpBuildPairingReqRsp
smpBuildPhiringRsp
smpBuildSecurityReq
smpBuildSigningInfo
smpParseEncInfo
smpParseIdentityAddrInfo
smpParseIdentityInfo
smpParseKeypressNoti
smpParseMasterID
smpParsePairingConfirm (smpParsePairingConfirm)
smpParsePairingDHKeyCheck
smpParsePairingFlail
smpParsePairingPublicKey
smpParsePairingRandom
smpParsePairingReq
smpParseSecurityReq
smpParseSigningInfo
smpProcessInsing
smpResponseProcessEncryptionInformation
smpResponseProcessIdentityAddrInfo
smpResponseProcessIdentityInfo
smpResponseProcessMasterID
smpResponseProcessPairingConfirm (smpResponseerProcessPairingConfirm)
smpResponseProcessPairingDHKeyCheck
smpResponseProcessPairingPublicKey
smpResponseProcessPairingRandom
smpResponseProcessPairingReq_sPatch
smpResponseProcessSigningInfo
XOR_128
错误#10234-D:未解析的符号仍然存在
错误#10010:链接期间遇到错误;未构建"project_zero_cc2640r2lp_app.out"
>>编译失败
Makefile:187:目标'project_zero_cc2640r2lp_app.out'的配方失败
gmaked[1]:***[PROJECT_ZERO _cc2640r2lp_app.out]错误1.
gmake:***[全部]错误2.
Makefile:180:目标“全部”的配方失败
****构建完成****
    Giacomo、
    链接器未"查找"上述文件的原因可能是工作区路径中存在空格:
    能否在新的工作区路径中启动 CCS、该路径不包含任何空格(下划线正常)。 然后导入并构建项目、并告知我们是否仍然存在错误。
    谢谢 Aartis、这解决了我的问题。
