[参考译文] 编译器:编译错误
Guru**** 2952510 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/963522/compiler-compilation-error
工具/软件:TI C/C++编译器
尊敬的所有人:
我在使用 GNU 编译器构建项目时遇到了困难。 下面是构建后的日志。 请告诉我这个问题吗?
'调用:GNU 连接器
"c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/stellaris-master/driverlib/gcc-cm3 /ti/StellarisWare/driverlib/gcc-cm3 /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/lib/gcc/arm-none-eabi/4.9.3 /ti/StellarisWare/driverlib/gcc-cm3 -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -ffunion-SECTIONS -fdata-g -gdwarf-3 -gstrict-dwarf -Wall -lm,-map -gncscale.map"-l"C:/StellarisWare/driverlib/gcc-cm3 /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/lib/gcc/arm-none-eabi/4.9.3 -"_task./cn"-tran.c/mctran./tran./cn"-mctran./task./cn"-mctran./cn"-mctran./cn"-tran./cn"-mctran./task./cn"-mctran./cn"-mctran./cn"-mctran./cn"-mccs./task./cn"-mctran./tor./cn"-mctran./tor.cn/zh-tran./cn"-tran./cn"-mctran./cn"-mccs./cn"-mctran./cn start-group -ldriver-cm3 -lm -LC -lgcov -lgcc -wl、--end-group ./libdriver-cm3.a
Makefile:168:目标'GNUScale.out'的配方失败
使用内置规格。
Collect_GCC=C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe
Collect_LTO_wraper=c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/lto-wrapper.exe
目标:arm-none-eabi
配置为:/home/build/work/GCC-4-9-build/src/gcc/configure --build=i686-linux-GNU --host=i686-w64-mingw32 --target=arm-no-eabi --prefix=/home/build/work/GCC-4-9-build/install-mingw --execdir=/home/build/work/GCC-4-9-build/install-mingw/lib /home/build/work/GCC-4-9-build/install-mingw/share/doc/gcc-arm-none-eabi/html /home/build/work/GCC-4-9-build/build-mingw/host-libs/usr /home/build/work/GCC-4-9-build/build-mingw/host-libs/usr --infodir=/home/build/work/GCC-4-9-build/install-mingw/share/doc/gcc-arm-none-eabi/info /home/build/work/GCC-4-9-build/install-mingw/share/doc/gcc-arm-none-eabi/pdf /home/build/work/GCC-4-9-build/build-mingw/host-libs/usr --mand-libmdir=/home/build/work/GCC-4-9-build/install-mingw/share/doc/gcc-arm-none-eabi/man /home/build/work/GCC-4-9-build/install-mingw/arm-none-eabi /home/build/work/GCC-4-9-build/build-mingw/host-libs/usr --glibmos=c=clus-dlib-glib-dc-disable-glibmos-glib-for-glibmos-c=ce-difate-dc-glib-glibmos-dlp-for-glib-c=c=c-glib-glib-ce-dip-c=ce-difate-dife-dife-mf-no-disable-glib-glib-glib-glib-dlp-for-glib-glib-c=gski-disable-dlp-for-ment-disable-dlp-for-ment-cc-glib-c-glib-glib-c=gski-disable-dlp-for-c-c-dlp-for-c-c-c-ment-disable-glib-dlp-/home/build/work/GCC-4-9-build/build-mingw/host-libs/usr /home/build/work/GCC-4-9-build/build-mingw/host-libs/usr /home/build/work/GCC-4-9-build/build-mingw/host-libs/usr
Thread 模型:单个
GCC 版本4.9.3 20150529 (版本)[ARM/embedded-4_9-branch 版本227977](用于 ARM 嵌入式处理器的 GNU 工具)
编译器_path=c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3;c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc;c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin
library_path=c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7-m;c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7-m;c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../arm-none-eabi/lib/armv7-m;c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3;c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc;c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib;c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../arm-none-eabi/lib
collect_gcc_options='-Mcpu=cortex-m3''-mthum''-D''part_LM3S9B92''-ffunion-sections ''-fdata-sections ''-g''-gdwarf-3''-gstrict-dwarf''-Wall ''-lc:/StellarisWare/driverlib/gcc-cm3 /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/lib/gcc/arm-none-eabi/4.9.3 '-clc-out ''-clc:/ti/stellaris-master/driverlib/gcc-cm3 /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/lib/gcc/arm-none-eabi/4.9.3 '-'-clc-'-'-ex'/ti/StellarisWare/driverlib/gcc-cm3 '-'-clc-'-'-out'/ti/StellarisWare/driverlib/gcc-cm3 '-'-'-clclc''-'-'-'-'-'-in'
C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/collect2.exe -plugin c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/liblto_plugin-0.dll -plugin-opt=c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/lto-wrapper.exe -plugin-opt=-fresolution=C:\Users\SAI\AppData\Local\Temp\ccGfMLCB.plugin-opt=-pass-through =-lgcc -plugin-opt=-pass-through =-LG -plugin-opt=-pass-through =-lc - sysroot=c:\ti\ccsv6\tools\compiler\gcc-arm-no-eabi-4_9-2015q3\bin\./arm-no-eabi -X -o gmuscale.out c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7-m/crti.o /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7-m/crtbegin.o c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7-m/crt0.o -lc-/StellarisWare/driverlib/gcc-cm3 -lc.task.o /ti/stellaris-master/driverlib/gcc-cm3 /ti/StellarisWare/driverlib/gcc-cm3 -lc.task.o /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/lib/gcc/arm-none-eabi/4.9.3 /ti/StellarisWare/driverlib/gcc-cm3 /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7-m /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../arm-none-eabi/lib/armv7-m /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib .ip.trad.o/soc.trad.o .trad.o .trab.o .trab.o .trab.trad.o /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/lib/gcc/arm-none-eabi/4.9.3 /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7-m /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3 /ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../arm-none-eabi/lib start-group -ldriver-cm3 -lm -lgcov -lgcc -end-group ./libdriver-cm3.a --start-group -lgcc -lgc -lend-group c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7-m/crtend.o c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7-m/crtn.o
C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7-m libc.a (lib_a-exit.o):在函数`exit'中:
exit.c:(.text.exit+0x16):未定义`_exit'的引用
collect2.exe:错误:LD 返回1退出状态
gmake:***[GNUScale.out]错误1
gmake:目标"全部"不会由于错误而重新生成。
****构建完成****
    ****为项目 GNUScale 构建配置 Debug_GNU ****
    "C:\\ti\\ccsv6\\utils\\bin\\gmake"-k all
    '生成文件:./adc.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gmP-strict-dwarf-mc"-mc"-dl"-mc"-mc-mc-dl"-mc.md -md -md -adc -md -md -md -md -md -md。
    '完成的建筑:./adc.c'
    '生成文件:./bmiptc.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe -c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gstrict -dwart"-mc"-bmco -md -iptm -md -mp4 -md -md -mpt"-md -iptm -mp4 -md -md -md -md -ipt"-md -md -md -md -md -mptm。
    ./bmiptc.c:44:12:警告:'bmipctm'已初始化并声明为'extern '
    extern int bmipctm[29][BMIPCT_SIZE]={
    ^μ A
    '完工建筑:./bmiptc.c'
    '生成文件:./cmdlin.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gmclus-dwarf-dlm -命令行-cmdlm -dlm -命令行-cmdlm -dlm -dlm -line -cmpine"-dlm -dlm -dlm -dlm -dlm -dline"-md -dline"-dline"-md -md -md -dlina.md -md -dlina.md -md -dlin
    '完成的建筑:./cmdlin.c'
    '生成文件:./control_task.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gmf-strict-dwarf"-task -mc"-control-mf_-task"-fl_md -md -task"-md -tandote_control-md -md -md -md -task"-md -task.control-md -md -md -md -task"-md -tandot_control -md -md
    '已完成构建:./control_task.c'
    '生成文件:./cpu.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gmclus-dwarf-mf-nst-mc"-mc"-mc"-dl"-mc"-mp.c"-mcf-nstepadic -mf"-mf -mf -mf -md -mf -md -mf -md -mf -md -mf -md -mp"-mf -mf -
    '完成的建筑:./cpu.c'
    '生成文件:./display_task.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gstrict-dwarf-md -display-md -task -mp"-display-mpeglmd -display_md -md -task -md -md -display.dlm -task -md -md -md。
    '已完成构建:./display_task.c'
    '生成文件:./flash.c'
    '调用:GNU 编译器'
    c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe -c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gmf-strict-dwarf"-md -fly"-dlm -md -md -md -mp"-fly"-md -md -md -mp.cn -md -dlm -md -md -md -fl"-md -md -md -fly.unic"-md -md -dlm。
    '完成的建筑:./flash.c'
    '生成文件:./gpio.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -DPART_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gstrict-dwarf-mf-ngpio -mpio-mpio-mgpio -mf.cn -mp"-mgpio-mf -mf -dlpio-mgpio-mf -mf -mf -mf -mf -mpintradic -gpio.cn -mf -mf -mf -gpio.
    '完成的建筑:./GPIC.c'
    '生成文件:./interrupt.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gmclus-dwarf-dwarf-ngmd -interrupt"-md -md -md -md -md -md interrupt"-md -md -md -dlm -md -md -md interrupt"-md -md -md -md -md -md -md -md -md
    '已完成构建:./interrupt.c'
    '生成文件:./key_task.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gstrict-dwarf-mc"-task-mf_-md -dlm -task -md -key"-task.c -md -md -md -task -md -key"-md。
    '已完成构建:./key_task.c'
    '生成文件:./led_task.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gstrict-dwarf-tand-md -task-md -md -md -task"-lmd -tand"-md -md -md -task -md -md -task -md -md -task"-dlm。
    '完成的构建:./led_task.c'
    '构建文件:./LM3S9B92_STARTUP_CCS_gcc.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -g -gdwarf-3 -gstrict-dwarf-gmcs"-i"-mcs"-gmccs_startup -g3cc_b92 -gmccs_stepar启动-md -gmd -gmd -gmd -gmd -gmd -stepic -md -gmd -md -md -md -md -premoti_stepic -md -md -md -md -md -md -t_stepar启动-gmd -md -md -md -md -mcs"-mccs_
    '已完成构建:./LM3S9B92_STARTUP_CCS_gcc.c'
    '生成文件:./main.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gmf-strict-dwarf-md -main-md -md -mp"-main.co -md -md -md -md -md -md -md -md -md -md -main.ilt.cn -md -md -md -md -md -md -md -md。
    '完工建筑:./main.c'
    '生成文件:./prt 任务.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gstrict-dwarf-mf-task -mf-dl"-task -mf -task -mp.cn -dlpremote_task -md -tf -task -mp.cn -dlm -task -mf -task -dlpremote_tf -mf -task -dlpt -mf -dlpremote_task -md -dlpremote_
    '已完成构建:./prt _task.c'
    '生成文件:./sample_task.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gstrict-dwarf-mc"-mc_task"-mf"-dlm -t_sample"-md -md -task"-mf_md -md -task"-mf_md -md -task"-mf_mf_md -md -task.dlm。
    '已完成构建:./sample_task.c'
    '构建文件:./ssi.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -DPART_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gmststrict-dwarf-ms"-ms"-mst-dlm -mc"-mf -dlm -mf -mf -mf -dlm -mf -mf -dlm -mf -mf -md stepic -md -mf -mf -mf -mf -mf -mf -mf -dl"-mf -
    '完成的建筑:./SSI.c'
    '生成文件:./state.c'
    '调用:GNU 编译器'
    c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe -c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gmP-strict-dwarf"-state"-md -md -static -md -md -md -md -md -md -state"-md -md -md -status.dlm。
    '已完工建筑:./state.c'
    '生成文件:./SysTick .c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gmP-strict -dwarf-ms"-md -mctradic -md -md -md -md -thickt"-md -md -md -md -md -stick -md -md -md -md -md -md -md -md -md -md -md -md -md -md
    '完成的建筑:./SysTick .c'
    '生成文件:./timer.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gstrict-dwarf-timer -md -md -md -timer -md -mp"-lmd -timpermd -md -md -md -timpermd -md -md -md -md -md。
    '完成的建筑:./timer.c'
    '生成文件:./uart.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -DPART_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gstrict -dwarf-mf-ntradot"-muart -dl"-mv-md -dlt -madot"-muart -dl"-m.c -md -g.c -md -md -md -dlt -md -madot"-md -muart -g.cn -dl"-md -md -
    '已完成构建:./uart.c'
    '生成文件:./uartstdio.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstdc-sections -g -gdwarf-3 -gstrict-dwarf-mc-dio -stario-md -stdio"-startdio -md -md -md -stdio -stdio"-stdio"-stdio.mdio -stdio.dlm -md -stdio -md -stdio.dlm -md -stdio -md -stdio.mdio -stdio.dlm .dlm .
    '完工建筑:./uartstdio.c'
    '生成文件:./ustdlib.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -g -gdwarf-3 -gstrict-dwarf-dmd -dmd -starithm"-dmd -dmd -strim -dlm -md -md -dmd -md -dmd -dlm -str"-dmd -dlm -md -dmd -dlm -md -md -dlm -dmd -dlm -md -dmd -dlm -md -dlm -dmd -
    '完成的建筑:./ustdlib.c'
    '生成文件:./utils.c'
    '调用:GNU 编译器'
    "c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-m3 -mthumb -dPT_LM3S9B92 -i"C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -i"C:/ti/stellaris-master -i"C:/ti/StellarisWare -i"C:/Users/Sai/workspace_v6_2/GNUScale -ffunstd-sections -fdata-sections -g -gdwarf-3 -gmP-strict-dwarf -md -utils"-md -md -md -utils -md -md -md -md -md -md -md -utilitr"-md -md -md -md -md -md -md -md -utils -md -md。
    '完成的建筑:./utils.c'
    '建筑目标:GNUScale.OUT"
    '调用:GNU 连接器'
    使用内置规格。
    目标:arm-none-eabi
    Thread 模型:单个
    ****构建完成****
    在此主题中检查答案:
    https://e2e.ti.com/support/tools/ccs/f/81/t/382293
