[参考译文] CCS/CC2640R2F:发生错误[Build-908420769]错误2的原因是什么? 无法构建项目
Guru**** 2979400 points
Other Parts Discussed in Thread: CC2640R2F
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/943999/ccs-cc2640r2f-what-is-the-cause-for-the-error-occurring-build-908420769-error-2-project-could-not-built
器件型号:CC2640R2F
工具/软件:Code Composer Studio
有人可以澄清这个错误吗? 我会问很多与构建错误编号相关的问题。
是否有关于所有类型的构建错误编号的任何文档来澄清这一点?
****项目 zcart_scanner_app 的配置 multimple_FlashOnly 纯净构建****
"C:\\ti\\ccs930\\ccs\\utils\bin\\gmake"-k -j 4 clean -o
del /F "zcart_scanner_app.hex""configPkg\linker.cmd""configPkg\compiler.opt""zcart_scanner_app.out"
del /F "Application\board_key.obj""Application\util.obj""Application\zan_bcast_scan.obj""Application\zan_config.obj""Application\zan_console.obj""Application\zan_controller.obj""Drivers\TI_AES_128.obj""\common\hal_boot_console.obj""\ustack.obj "\chobj "u.obj "ustack.obj "\config.obj "u.obj "u.obj "uor.obj "uor.obj 启动"\config"
del /F "Application\board_key.d""Application\util.d""Application\zan_bcast_scan.d""Application\zan_config.d""Application\zan_console.d""Application\zan_controller.d""Drivers\TI_AES_128.d""HAL\Common\hal_d_Startup_console.d""Application \zan_controller.d""ud\zu1.d""ustack_1.d""u1.d""u.ap_u.puble\u.u.u.u.u.u.u.u.启动"u.u.u.stack"
rmdir /S/Q "configPkg\"
无法找到 E:\WorkFromHome\Beacon Scanner \V3_Beacon_workbench\V3_Beacon_t1\zcart_scanner_app\multimple_FlashOnly" Application\board_key.obj
无法找到 E:\WorkFromHome\Beacon Scanner \V3_Beacon_workbench\V3_Beacon_t1\zcart_scanner_app\multimple_FlashOnly"驱动程序\TI_AES_128.obj
无法找到 E:\WorkFromHome\Beacon Scanner \V3_Beacon_workbench\V3_Beacon_t1\zcart_scanner_app\multimple_FlashOnly" HAL\Common\hal_dassert.obj
无法找到 E:\WorkFromHome\Beacon Scanner \V3_Beacon_workbench\V3_Beacon_t1\zcart_scanner_app\multimple_FlashOnly"堆栈\port.obj
无法找到 E:\WorkFromHome\Beacon Scanner \V3_Beacon_workbench\V3_Beacon_t1\zcart_scanner_app\multimple_FlashOnly"启动\board.obj
无法找到 E:\WorkFromHome\Beacon Scanner \V3_Beacon_workbench\V3_Beacon_t1\zcart_scanner_app\multimple_FlashOnly" Application\board_key.d
无法找到 E:\WorkFromHome\Beacon Scanner \V3_Beacon_workbench\V3_Beacon_t1\zcart_scanner_app\multimple_FlashOnly"驱动程序\TI_AES_128.d
无法找到 E:\WorkFromHome\Beacon Scanner \V3_Beacon_workbench\V3_Beacon_t1\zcart_scanner_app\multimple_FlashOnly" HAL\Common\hal_dassert.d
无法找到 E:\WorkFromHome\Beacon Scanner \V3_Beacon_workbench\V3_Beacon_t1\zcart_scanner_app\multimple_FlashOnly"堆栈\port.d
无法找到 E:\WorkFromHome\Beacon Scanner \V3_Beacon_workbench\V3_Beacon_t1\zcart_scanner_app\multimple_FlashOnly"启动板.d
已完成清理
****构建完成****
****为项目 zcart_scanner_app 构建多模式 FlashOnly 配置****
"C:\\ti\\ccs930\\ccs\\utils\\bin\\gmake"-k -j 4 all -O
编译文件:"../TOOLS/app_ble.cfg
调用:XDCtools
"c:/ti/xdctools_3_51_03_28_core/xs "--xdcpath="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack;C:/ti/bios_6_53_02_00/packages;C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source;C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/kernel/tirtos/packages /WorkFromHome/Beacon /WorkFromHome/Beacon;" xdc.tools.configuro configPkg -t ti.targets.elf.M3 -p ti.platforms.simplelink:CC2640R2F /WorkFromHome/Beacon /WorkFromHome/Beacon -r 版本-c "C:/ti/ccs930/ccs/tools/compiler/ti-cgt-arm_18.12.4.LTS /ti/simplelink_cc2640r2_sdk_3_40_00_10 -compileOptions "-mv7M3 -code_state=16 Beacon_trads/excart_v3\-it_tracon_tradcs_trads/it_trace\-trap_v3/excart_trace\-tradcs_v3/e\-trap_trace\-trace\-tracon_v3/excart_tradcs_tradcs_trap_v3/e\-trap_v3/e\-trap_trace\-trace\-trap_v3/excart_trads/v3/e\-trap_trace\-trap_v3/tracon_tradcs_trap_trap_tradcs_trap_v3/e\-trap_trads/v3//ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/controller/cc26xx_r2/inc /WorkFromHome/Beacon include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/boards -"--include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/common/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/target /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/devices/cc26x0r2 --include_path="C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/profiles/roles/cc26xx /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/saddr /ti/ccs930/ccs/tools/compiler/ti-cgt-arm_18.12.4.LTS/include --include_display_cart.com.cn=cn_display_cart.com.cn=cn_cart.com.cn=cn_display_cart.com.cn_cn=cn_display_.com.cn_cn_cn_cn=cn_cn_display_.com.cn_.com.cn_.com.cn_cn_.com.cn_cn_cn_cn_cn_.com.cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_.com.cn_.com.cn_.com.cn_.com.cn_.com.cn_cn_.com.cn_cn_cn_.com.cn_cn_.com.cn_cn_.com.cn_cn_.com.cn_cn_.com.cn_cn_cn_cn_.com.cn_cn_cn_cn_cn_cn_cn_.com.cn=C:/ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/icall/src/inc /ti/simplelink_cc2640r2_sdk_3_40_00_10/source/ti/blestack/services/src/sdata -cn_.com.cn_.com.cn_cn_.com.cn_cn_cn_cn_cn= define=feature_advertiser --define=feature_broadcaster --define=feature_static_ADDR --define=feature_scanner --define=HEAPMGR_size=0 --define=ICALL_events --define=power_saving=rf_multimulation=c=tbm_active_items=hex-ex-us_rand_de=xabi_rand_di=xrand_di_isecon_ise-control-ex-us=us=xrand_di_ise_display_en_isecon_isdag=us-us-us_en_isdag=us-us_en_en_isdag=us_rand-us_isdag=xines=xines=us_en_en_en_isdic-us_is /TOOLS/app_ble.cfg
正在制作 package.mak (由于 package.bld)...
正在为软件包 configPkg 生成接口(因为 package/package.xdc.inc 比 package.XDC 旧)...
从 package/cfg/app_ble_pem3.cfg 配置 app_ble.xem3 ...
正在生成自定义 ROM 库 makefile ...
正在开始构建库源...
库构建失败。
tools/subdir_rules.mk:12:目标'Build-908420769-InProc '的配方失败
gmake:e:/WorkFromHome/Beacon:无此类文件或目录
gmake:***没有将目标设为'E:/WorkFromHome/Beacon 的规则。 停下。
错误:xdc.cfg.SourceDir:"c:/ti/xdctools_3_51_03_28_core/packages/xdc/cfg/SourceDir.xs,第209行:xdc.cfg.SourceDir:生成的源库生成失败:退出状态= 2:
JS:"c:/ti/xdctools_3_51_03_28_core/packages/xdc/cfg/Main.xs、第160行:错误:配置失败!
gmake.exe:***[package.mak:202:package/cfg/app_ble_pem3.xdl]错误1
gmake.exe:***删除文件'package/cfg/app_ble_pem3.xdl'
gmake.exe:***[package/cfg/app_ble_pem3.xdl]删除文件'package/cfg/app_ble_pem3.h'
gmake.exe:***[package/cfg/app_ble_pem3.xdl]删除文件'package/cfg/app_ble_pem3.c'
JS:"c:/ti/xdctools_3_51_03_28_core/packages/xdc/tools/Cmdr.xs、第52行:错误:xdc.tools.configuro:由于先前的错误(状态= 2)、配置失败;已删除'linker.cmd'。
gmaking[1]:***[Build-908420769-InProC]错误1.
gmake:***[Build-908420769]错误2.
tools/subdir_rules.mk:9:目标'build-908420769'的配方失败
gmake:目标"全部"不会由于错误而重新生成。
****构建完成****
说明资源路径位置类型
gmake:***[Build-908420769]错误2 zcart_scanner_app C/C++ problem
gmake:***没有将目标设为'E:/WorkFromHome/Beacon 的规则。 停下。 zcart_scanner_app C/C++ problem
gmake:目标"全部"不会由于错误而重新生成。 zcart_scanner_app C/C++ problem
gmake.exe:***[package.mak:202:package/cfg/app_ble_pem3.xdl]错误1 zcart_scanner_app C/C++ problem
gmake.exe:***[package/cfg/app_ble_pem3.xdl]删除文件'package/cfg/app_ble_pem3.c' zcart_scanner_app C/C++ problem
gmake.exe:***[package/cfg/app_ble_pem3.xdl]删除文件'package/cfg/app_ble_pem3.h' zcart_scanner_app C/C++ problem
gmake.exe:***删除文件'package/cfg/app_ble_pem3.xdl' zcart_scanner_app C/C++问题
gmake[1]:***[Build-908420769-InProC]错误1 zcart_scanner_app C/C++问题
xdc.cfg.SourceDir:"c:/ti/xdctools_3_51_03_28_core/packages/xdc/cfg/SourceDir.xs,第209行:xdc.cfg.SourceDir:生成的源库生成失败:退出状态= 2:app_ble.cfg /zcart_scanner_app/tools C/C++ problem
