[参考译文] 编译器:gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf
Guru**** 2538960 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/926346/compiler-gcc-arm-8-3-2019-03-x86_64-arm-linux-gnueabihf
Thread 中讨论的其他器件:SysConfig
工具/软件:TI C/C++编译器
1. PROCESSOR_SDK_VISION_03_08_00_00_setuplinux.bin 已安装--ok;
2.打造 Linux
按如下方式记录:
Hwo 解决问题,谢谢。
    您能否再次附上日志、我认为没有附加日志。
    Karan
    make[3]:离开目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/omap
    make[2]:离开目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/cmem/ludev/src/cmem/module
    make[1]:离开目录`/home/henry/tda2x/vision_sdk/build/hlos/makerules/linux
    Henry@Qingyuan - System-Product-Name:~/tda2x/vision_sdk/build$ make Linux
    使-C ./hlos/makerules/linux -f build_uboot.mk uboot
    make[1]:输入目录`/home/henry/tda2x/vision_sdk/build/hlos/makerules/linux
    make -fbuild_uboot.mk uboot_build uBoot_target=dra7xx_evm_vision_config
    make[2]:输入目录`/home/henry/tda2x/vision_sdk/build/hlos/makerules/linux
    使-C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/u-boot/u-boot arch=arm cross_compile=/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf- dra7xx_evm_vision_config
    make[3]:输入目录`/home/henry/tda2x/ti_components/os_tools/linux/u-boot/u-boot
    编号
    #配置写入.config
    编号
    make[3]:离开目录`/home/henry/tda2x/ti_components/os_tools/linux/u-boot/u-boot
    make[2]:离开目录`/home/henry/tda2x/vision_sdk/build/hlos/makerules/linux
    使-fbuild_uboot.mk uboot_build
    scripts/kconfig/Conf-- syncconfig Kconfig
     Chk    include/config.h
     CFG    u-boot.cfg
     生成    include/autoconf.mk
     Gen    include/autoconf.mk.dep
     cfg    spl/u-boot.cfg
     生成    spl/include/autoconf.mk
     chk    include/config/uboot.release
     CHK    包含/生成/ version_autogenerated.h
     CHK    包含/生成/ timestamp_autogenerated.h
     UPD    包含/生成/ timestamp_autogenerated.h
     CHK    包含/生成/ generic-asm-offsets.h
     CHK    包含/生成/ asm-offsets.h
     HOSTCC 工具/mkenviemmage.o
     HOSTLD 工具/mkenemmage
     HOSTCC 工具/fit_image.o
     HOSTCC 工具/image-host.o
     HOSTCC 工具/dumpimage.o
     HOSTLD 工具/双映像
     HOSTCC 工具/mkimage.o
     HOSTLD 工具/mkimage
     cc     cmd/version.o
     LD     cmd/built-in.o
     CC     common/main.o
     LD     common/built-in.o
     CC     驱动程序/fastboot/fb_getvar.o
     LD     驱动程序/fastboot/built-in.o
     LD     驱动程序/built-in.o
     CC     lib/efi_loader/efi_reloc.o
     CC     lib/efi_loader/helloworld.o
     LD     lib/efi_loader/helloworld_efi.so
     objcopy lib/efi_loader/helloworld.efi
    RM lib/efi_loader/helloworld_efi.so lib/efi_loader/helloworld.o
     CC     lib/SMBIOS.o
     CC     lib/display_options.o
     LD     lib/built-in.o
     LD     u-boot
     objcopy u-boot-nodtb.bin
    make[5]:`arch/arm/dts/dra7-evm.dtb'是最新的。
     MKIMAGE u-boot.img
     objcopy u-boot.srec
     CAT    u-boot-dtb.bin
     复制   u-boot.bin
     sym    u-boot.sym
     CC     spl/common/spl/spl.o
     LD     spl/common/spl/built-in.o
     CC     spl/lib/display_options.o
     LD     spl/lib/built-in.o
     LD     spl/u-boot-spl
     objcopy spl/u-boot-spl-nodtb.bin
    make[6]:`arch/arm/dts/dra7-evm.dtb'是最新的。
     MKIMAGE spl/u-boot-spl.multimdtb.fit
     CAT    spl/u-boot-spl-dtb.bin
     复制   spl/u-boot-spl.bin
     MKIMAGE MLO
     MKIMAGE u-boot-dtb.img
     CFG    u-boot.cfg
     CFGCHK u-boot.cfg
    创建-C ./hlos/makerules/linux -f build_kernel.mk 内核
    CD /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/omap;\
           ti_config_frages/defconfig_builder.sh -t ti_sdk_dra7x_release
    正在创建 defconfig 文件/home/henry/tda2x/ti_components/os_tools/linux/kernel/omap/arch/arm/configs/ti_sdk_dra7x_release_defconfig
    CD /home/henry/tda2x/vision_sdk;\
           使-C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/omap arch=arm ti_sdk_dra7x_release_defconfig
    make[2]:输入目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/omap
    编号
    #配置写入.config
    编号
    make[2]:离开目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/omap
    make -fbuild_kernel.mk kernel_build kernel_target=ti_sdk_dra7x_release_defconfig
    使-C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/omap arch=arm cross_compile=/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf- ti_sdk_dra7x_release_defconfig
    make[3]:输入目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/omap
    编号
    #配置写入.config
    编号
    生成-fbuild_kernel.mk dtb
    make -fbuild_kernel.mk kernel_build kernel_target="dra7-EVM-infoadas。dtb dra7-evm-infoadas - lcd.dtb"
    make[3]:输入目录`/home/henry/tda2x/vision_sdk/build/hlos/makerules/linux
    make -C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/omap arch=arm cross_compile=/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf- dra7-evm-infoadas。dtb dra7-evm-infoadas - lcd.dtb
    make[4]:输入目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/omap
    make[4]:离开目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/omap
    make[3]:离开目录`/home/henry/tda2x/vision_sdk/build/hlos/makerules/linux
    使-fbuild_kernel.mk kernel_build kernel_target=zImage
    使-C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/omap arch=arm cross_compile=/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf- zImage
     调用   脚本/checksyscalls.sh
     CHK    包含/生成/ compile.h
     gzip   内核/config_data.gz
     内核:arch/arm/boot/Image 已就绪
     内核:arch/arm/boot/zImage 已就绪
    使-fbuild_kernel.mk kernel_build kernel_target=modules
    使-C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/omap arch=arm cross_compile=/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf-模块
     构建模块、第2阶段。
     MODPOST 439模块
    使-C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/linux-kernel-addon/memcache/build 成为模块
    make[2]:输入目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/linux-kernel-addon/memcache/build
    # memcache:生成模块
    使-C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/omap m=`pwd` arch=arm cross_compile=/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf-模块
     构建模块、第2阶段。
     MODPOST 1模块
    make[2]:离开目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/linux-kernel-addon/memcache/build
    CD /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/cmem/ludev;\
           /configure --enable-shared --host=arm-linux-gnueabihf --prefix="/usr"
    配置:警告:如果要设置--build 类型,请不要使用--host。
       如果检测到交叉编译器、则将使用交叉编译模式。
    正在检查 BSD 兼容的安装... /usr/bin/install -c
    正在检查构建环境是否正常... 是的
    正在检查 gawk…… 嘎嘎
    正在检查 make 设置是否为$(make)... 是的
    正在检查 ARM-Linux-gnueabihf-strip ... arm-linux-gnueabihf-strip
    正在检查是否启用 Makefiles 的维护人员特定部分... 否
    正在检查构建系统类型... x86_64-未知-Linux
    正在检查主机系统类型... arm-unknown-linux-gnueabihf
    正在检查 make 使用的 include 样式... GNU
    正在检查 arm-linux-gnueabihf-gcc... arm-linux-gnueabihf-gcc
    正在检查 C 编译器默认输出文件名... A.输出
    正在检查 C 编译器是否正常工作... 是的
    正在检查我们是否正在交叉编译... 是的
    正在检查可执行文件的后缀...
    正在检查目标文件的后缀... o
    正在检查我们是否使用 GNU C 编译器... 是的
    检查 arm-linux-gnueabihf-gcc 是否接受-g。 是的
    检查 arm-linux-gnueabihf-gcc 选项以接受 ANSI C。 不需要
    正在检查 arm-linux-gnueabihf-gcc... Gcc3.
    正在检查未截断输出的已截断... /bin/sed
    正在检查 egrep ... grep -E
    正在检查 arm-linux-gnueabihf-gcc... /home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/bin/ld
    正在检查链接器(/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/bin/ld)是否为 GNU ld... 是的
    正在检查/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/bin/ld 选项以重新加载目标文件... -r
    正在检查 BSD 兼容的 N... /home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf-nm -B
    正在检查 ln -s 是否正常工作... 是的
    正在检查如何识别相关库... 全部通过
    正在检查如何运行 C 预处理器... arm-linux-gnueabihf-gcc -E
    正在检查 ANSI C 头文件... 是的
    正在检查 sys/types.h...是
    正在检查 sys/stat.h...是
    正在检查 stdlib.h...是
    正在检查 string.h...是
    正在检查 memory.h...是
    正在检查 strings.h...是
    正在检查 inttypes.h...是
    正在检查 stdint.h...是
    正在检查 unistd.h...是
    正在检查 dlfcn.h 可用性... 是的
    正在检查 dlfcn.h 状态... 是的
    正在检查 dlfcn.h...是
    正在检查 ARM-Linux-gnueabihf-g++…… arm-linux-gnueabihf-g++
    正在检查我们是否使用 GNU C++编译器... 是的
    检查 arm-linux-gnueabihf-g++是否接受-g。 是的
    正在检查 arm-linux-gnueabihf-g++的依赖关系样式... Gcc3.
    正在检查如何运行 C++预处理器... arm-linux-gnueabihf-g++-E
    正在检查命令行参数的最大长度... 32768
    正在检查用于解析 ARM-Linux-gnueabihf-gcc 对象的/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf-nm -B 输出的命令... 好的
    正在检查 objdir ... .libs
    正在检查 arm-linux-gnueabihf-ar... arm-linux-gnueabihf-ar
    正在检查 arm-linux-gnueabihf-ranlib... arm-linux-gnueabihf-ranlib
    正在检查 ARM-Linux-gnueabihf-strip ... (缓存) arm-linux-gnueabihf-strip
    正在检查 arm-linux-gnueabihf-gcc 是否支持-fno-rti -fno-exception... 否
    正在检查 ARM-Linux-gnueabihf-gcc 选项以生成 PIC... -FPIC
    正在检查 ARM-Linux-gnueabihf-gcc PIC 标志-FPIC 是否起作用... 是的
    正在检查 ARM-Linux-gnueabihf-gcc 静态标志-static 是否起作用... 是的
    检查 arm-linux-gnueabihf-gcc 是否支持-c -o file.O...是
    正在检查 ARM-Linux-gnueabihf-gcc 链接器(/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/bin/ld)是否支持共享库... 是的
    正在检查-lc 是否应显式链接... 否
    正在检查动态链接器特性... GNU/Linux ld.so
    正在检查如何将库路径硬编码到程序中... 立即
    正在检查是否可以去除库... 是的
    正在检查 libtool 是否支持共享库... 是的
    正在检查是否构建共享库... 是的
    正在检查是否构建静态库... 是的
    配置:创建 libtool
    将配置标签"CXX"附加到 libtool
    正在检查 arm-linux-gnueabihf-g++... /home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/bin/ld
    正在检查 ARM-Linux-gnueabihf-g++链接器(/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/bin/ld)是否支持共享库... 是的
    正在检查 ARM-Linux-gnueabihf-g++选项以生成 PIC... -FPIC
    正在检查 ARM-Linux-gnueabihf-g++ PIC 标志-FPIC 是否起作用... 是的
    正在检查 ARM-Linux-gnueabihf-g++静态标志-static 是否起作用... 是的
    检查 arm-linux-gnueabihf-g++是否支持-c -o file.O...是
    正在检查 arm-linux-gnueabihf-gcc... (缓存) arm-linux-gnueabihf-gcc
    正在检查我们是否使用 GNU C 编译器... (缓存)是
    检查 arm-linux-gnueabihf-gcc 是否接受-g。 (缓存)是
    检查 arm-linux-gnueabihf-gcc 选项以接受 ANSI C。 (缓存)不需要
    正在检查 arm-linux-gnueabihf-gcc... (缓存) gcc3
    正在检查 ANSI C 头文件... (缓存)是
    正在检查 fcntl.h 可用性... 是的
    正在检查 fcntl.h 状态... 是的
    正在检查 fcntl.h...是
    正在检查 string.h...(缓存)是
    正在检查 SYS/ioctl.h 的可用性... 是的
    正在检查 SYS/ioctl.h 是否存在... 是的
    正在检查 sys/ioctl.h...是
    正在检查 unistd.h...(缓存)是
    配置:创建./config.status
    config.status:创建 Makefile
    config.status:正在创建 src/cmem/api/Makefile
    config.status:正在创建 src/cmem/tests/Makefile
    config.status:执行 depfiles 命令
    感谢您安装 LinuxUtils 软件包
    安装目录前缀:'/usr'。
    编译命令:'arm-linux-gnueabihf-gcc -g -O2 '
    现在键入'make; sudo make install'以生成程序
    并将其安装到您的系统中。
    #生成与 cmem 相关的.so 文件
    使-C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/cmem/ludev/src/cmem/api 成为文件
    make[2]:输入目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/cmem/ludev/src/cmem/api
    make[2]:对于`all '没有要做的事情。
    make[2]:离开目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/cmem/ludev/src/cmem/api
    使-C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/cmem/ludev/src/cmem/module kernel_install_DIR=/home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/omap arch=arm toolchain_prefix=arm-linux-gnueabihf-发布
    make[2]:输入目录`/home/henry/tda2x/ti_components/os_tools/linux/kernel/cmem/ludev/src/cmem/module
    正在发布模块...
    make -C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/omap m=`pwd` arch=arm cross_compile=arm-linux-gnueabihf-\
                   Extra _CFLAGS="-I/home/Henry/tda2x/ti_compons/os_tools/linux/kernel/cmem/ludev/include"模块
     构建模块、第2阶段。
     MODPOST 1模块
    使-C ./hlos/makerules/linux -f build_SGX.mk SGX
    使-fbuild_SGX.mk SGX_Build SGX_target=SGX_Build
    使-C /home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/build/linux2/omap_linux arch=arm cross_compile=/home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf- KERNELDIR=/home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/kernel/omap DiscImage=/home/henry/tda2x/vision_sdk/../ti_components/os_tools/linux/targetfs build=release window_system=nulldrmws
    make[3]:输入目录`/home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/build/linux2/omap_linux
    /config/compiler.mk:96:主机 gcc
    /config/compiler.mk:185:Target /home/henry/tda2x/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc
    ***** Multiarch 版本:否
    ***** 主架构:   target_armhf
    ***** 次拱: 无
    /config/core.mk:513:$(KERNELDIR)/vmlinux 不存在。 Kbuild 可能会失败。
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/osfunc.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/mutils.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/mmap.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/module.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/pdump.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/proc.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/pvr_bridge_k.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/pvr_debug.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/mm.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/mutex.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/event.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/osperproc.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/buffer_manager.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/devicemem.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/handle.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/hash.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/lists.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/mem.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/mem_debug.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/metrics.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/osfunc_common.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/pdump_common.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/perproc.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/power.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/pvrsrv.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/ra.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/refcount.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/resman.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/bridged/bridged_support.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/bridged/bridged_pvr_bridge.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/system/omap/sysconfig.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/system/omap/sysutils.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/dmabuf.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/pvr_linux_fence.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/bridged/sgx/bridged_sgx_bridge.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxinit.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxpower.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxreset.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxutils.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxkick.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxtransfer.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/mmu.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/pb.o
     抄送[M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/pvr_drm.o
     LD [M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/pvrsrvkm.o
    RM /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/hash.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/lists.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxutils.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/bridged/sgx/bridged_sgx_bridge.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/pdump.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/devicemem.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/mem_debug.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/event.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/mutex.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/mem.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/dmabuf.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/refcount.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/osperproc.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/power.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/metrics.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/pvrsrv.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/proc.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/ra.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/pb.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxreset.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxpower.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/system/omap/sysconfig.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/pvr_linux_fence.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/mm.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxtransfer.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/buffer_manager.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/osfunc.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/system/omap/sysutils.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/perproc.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/pdump_common.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/mutils.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/pvr_bridge_k.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/osfunc_common.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/pvr_debug.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/module.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/mmap.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/handle.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/common/resman.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxinit.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/mmu.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/bridged/bridged_pvr_bridge.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/devices/sgx/sgxkick.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/env/linux/pvr_drm.c /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/services4/srvkm/bridged/bridged_support.c
     构建模块、第2阶段。
     MODPOST 1模块
     LD [M] /home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/binary_omap_linux_nulldrmws_release/target_armhf/kbuild/pvrsrvkm.ko
    make[3]:离开目录`/home/henry/tda2x/ti_components/os_tools/linux/sgx/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/build/linux2/omap_linux
    安装 VISION-SDK 后、您能否分享您遵循的步骤?
    加维拉尤
    构建 Linux
    使 Linux_install
    使-s -j 取决于
    使-s -j
    参考文档:Vision SDK (v03.08.00) Linux 用户指南
    2.4和3.1
    我遵循了以下步骤、并且能够运行其中一个 HLOS 用例。
    1) 1)下载 VISION SDK
    2) 2)构建所需的安装包( 第2.2.3章用于构建的其他必需软件包)
    3) 3)在 VISION_SDK/build/Rules.make 中进行以下更改
    MAKECONFIG?=tda2xx_EVM_Linux_ALL
    4) 4)按照 GIT 配置设置用户指南中提供的说明进行操作( 第2.4.1章一次性 PC 设置)
    5) 5) CD VISION_SDK/build/
    6) 6)从构建目录运行以下脚本、这将克隆内核、u-boot 等
    /hlos/scripts/linux/setup_linux.sh
    7)按照目标文件系统设置的用户指南中提供的说明进行操作(第  2.4.2.1.4章下载和重置文件系统)
    8)遵循 A15编译器设置的用户指南中提供的指令 (第 2.2.1章 A15编译器、链接器)
    9) 9)创建 Linux
    10) 10)使 Linux_install
    11) 11)使-s -j 取决于
    12) 12)使-s -j
    13) 13)将目标文件系统和引导映像、MLO 等复制到 SD 卡、然后将 SD 插入目标 SD 卡插槽。
    14) 14)在 UART 控制台中运行以下命令。
        CD /opt/vision_sdk
        资料来源:vision_sdk_load.sh
        /apps.out
    15) 15)您可以从菜单中选择要运行的用例。
    加维拉尤
    我  会将其作为您的回应。
