[参考译文] 编译器:Code Composer Studio™︎论坛
Guru**** 3001220 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/923170/compiler-code-composer-studio-forum
工具/软件:TI C/C++编译器
我们已开始为 TSW14J56EVM 构建我们自己的固件。 首先、我们已获取现有固件并尝试使用所需的工具对其进行编译。
屏幕截图1构建项目
我们遇到错误:
在查看日志时,我们发现路径很长时出现错误,我们尝试了一个新路径,并得到了相同的错误:
资料来源
INFO:运行 Quartus Prime Shell
信息:版本18.0.0、内部版本614、04/24/2018 SJ 标准版
信息:处理已开始:Sun 2020年7月12日16:33:02
INFO:COMMAND:Quartus_sh --restore -output "C:/oa/TSW14J56RevD Respin FW_RESTORed/"-no_overwrite "C:\oa\TSW14J56RevD Respin FW.Qar"
信息:Quartus (args):-unqar -output{C:/oa/TSW14J56RevD Respin FW_RESERIED/}-no_overwrite{C:\oa\TSW14J56RevD Respin FW.Qar}
INFO:Qar.TCL 版本#1
错误(14989):无法创建文件(C:/oa/TSW14J56RevD Respin FW_RESERVE/Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/ariaVgzPHY/Native / Reconfig/reconfigtrles/JESD_SV_vr_en_rex_config_x_rex_tranu_sym_config_x_tran_tranu_sym_sym_config_tranue_x_tranue_sym_tranue_sym_config_tranue_sym_tranux.0_tran_sym_sym
错误(14989):无法创建文件(C:/oa/TSW14J56RevD Respin FW_RESERVE/Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/ariaVgzPHY/Native / Reconfig/reconfig_svr_svr_s_m_r_rex_mux_tran_config_tran_zh_tran_sym_ctran_sym_config_tran_ctranu_zh_tran_sym_ctran_sym_config_tran_ctran_sym_ctran_zh_sym_ctran
错误(14989):无法创建文件(C:/oa/TSW14J56RevD Respin FW_RESERVE/Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/ariaVgzPHY/Native / Reconfig/reconfig_svr_svr_r_gx_rex_r_tran_config_tranue_tranue_tranuanuel_recon_ctranue_ctranue_p_zh_config_tranue_tranue_tranuanuanue_connect_tran_r_config_r
错误(14989):无法创建文件(C:/oa/TSW14J56RevD Respin FW_RESERVE/Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/ariaVgzPHY/Native / Reconfig/reconfig_vr_svr_g_jvr_vr_gx_exclud_x_x002_r_config_trad_tran_tran_sym_tran_config_tran_tran_zh_tran_tranuel_config_tranuel_tranuel_recon_tranu_
错误(14989):无法创建文件(C:/oa/TSW14J56RevD Respin FW_RESERVE/Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/ariaVgzPHY/Native / Reconfig/reconfig_svr_svr_r_gx_r_envr_config_rex_tran_ctranue_ctranue_p_en_r_sym_cp_r_r_en_ench_cp_r_r_en_r_r_cp_r_en_ench_r_r_r_
错误(14989):无法创建文件(C:/oa/TSW14J56RevD Respin FW_RESERVE/Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/ariaVgzPHY/Native / Reconfig/reconfig_svr_svr_s_s_pru_mux_r_rx_tran_config_r_rx_rx_tranu_zh_tranu_rulation_sym_tran_config_tran_tran_sym_rx_tran_rx_rx_rx_tranu_rx_r
错误(14989):无法创建文件(C:/oa/TSW14J56RevD Respin FW_RESERVE/Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_EXTERNAL_MEMORY /ARRAY VGAT/reconfig_SV_gvr_en_rex_envr_config_cr_zh_resctranc)、因为它超出了 CONFIG_CONFIG_CONFIG_CONFIG_CONFIG_CONFIG_CONFIG_CONFIG_CONFIG_CONFIG_CONFIG_CONFIG_EN/RESTRIG_EN/RESTRIG_ENTREN/RES_ENTR
INFO:恢复的 Quartus 项目文件:Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/jesd204b.QPF
错误:以下文件未恢复
错误:Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/arriaVgzPHY/Native / Reconfig_avgx_reconfig_Cntrl_sim/alt_xcSV_reconfig_reconfig_0_cpu_interconnect_0_mux.cmd
错误:Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/arriaVgzPHY/Native / Reconfig_avgx_reconfig_Cntrl_sim/alt_xccs_reconfig_mu_mu_mu_0_互 连
错误:Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/ariaVgzPHY/Native / ReconfigureController/JESD_avgx_reconfig_Cntrl_sim/alt_xsvr_reconfig_r_r_cpu_r_0_router_reconfig_rulation_r_cpu_r_r_cpu_u_tranuanux.0_interconnect_cpu_r
错误:Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/ariaVgzPHY/Native / ReconfigureController/JESD_avgx_reconfig_Cntrl_sim/alt_xsvr_reconfig_002_r_router_reconfig_002_router_router_002_rinterconnect_cvr_002_ench_ench_en_ench_ench_ench_ench_
错误:Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/ariaVgzPHY/Native / ReconfigureController/JESD_avgx_reconfig_Cntrl_sim/alt_xsvr_reconfig_003_router_r_enu_reconfig_003_router_r_003_router_ecux.003_router_enu.pn_ench_ench_en_ench_en_
错误:Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/arriaVgzPHY/Native / Reconfig_avgx_reconfig_cntr_x_spr_reconfig_mu_r001_mu_rxvr_mu_r001
错误:Altera_JESD204B/jesd204b_refdesign/syn/AVGZ_gen_jesd204b_120_SP2_external_memory/ariaVgPHY/本机/重新配置控制器/JESD_enc_avgx_reconfig_Cntrl_sim/alt_xcSV_reconfig_data_scen_res_apver_data_zh_scen_en_res_en_apver_cr_ap_apvr_ap_ap_apvr_cor_cr
INFO (125069):Quartus Prime 软件的当前版本中更改了默认赋值--对默认赋值的更改包含在文件 d:/intelfpga/18.0/quartus/bin64/assignment_defaults.qdf 中
错误:无法还原 C:/oa/TSW14J56RevD 重新固定 FW.Qar
INFO:生成的报告'jesd204b.restore.rpt'
错误(23031):评估 Tcl 脚本 d:/intelfpga/18.0/quartus/common/tcl/apps/qpm/qar.tcl 失败
错误:Quartus Prime Shell 失败。 17个错误、0个警告
错误:峰值虚拟内存:4906 MB
错误:处理结束:Sun Jul 1216:33:45 2020
错误:经过的时间:00:00:43
错误:总 CPU 时间(在所有处理器上):00:00:09
雅龙
    我们在尝试恢复项目时尝试克服260个字符的错误。
    [引用用户="Yaron Addar"]
    [/报价]
    向 Intel/Altera 投诉--这是 Quartus 问题,而不是 TI CCS 问题。
