[参考译文] CCS/TMS320C5545:C5545 Booster Pack
Guru**** 2562740 points
Other Parts Discussed in Thread: CC3200
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/769807/ccs-tms320c5545-c5545-booster-pack
器件型号:TMS320C5545
工具/软件:Code Composer Studio
海 all、
   我正在‘C5545 Booster Pack 并遵循 C5545 BoosterPack 软件用户指南(www.ti.com/.../sprui92.pdf),当我尝试构建“boostc5545_diag_test”项目时,我会遇到以下错误
****为项目 boostc5545_diag_test 构建配置 SD_boot ****
"C:\\ti\\ccsv7\\utils\\bin\\gmake"-k all
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/src/audio_headset_loopback_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/src/audio_headset_loopback_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/src/audio_headset_loopback_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/src/audio_line_in_loopback_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/src/audio_line_in_loopback_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/src/audio_line_in_loopback_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/src/audio_mic_in_loopback_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/src/audio_mic_in_loopback_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/src/audio_mic_in_loopback_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/src/audio_playback_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/src/audio_playback_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/src/audio_playback_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/src/current_monitor_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/src/current_monitor_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/src/current_monitor_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/src/dsp_ble_interface_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/src/dsp_ble_interface_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/src/dsp_ble_interface_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/src/external_mic_in_loopback_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/src/external_mic_in_loopback_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/src/external_mic_in_loopback_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/src/gpio_dsp_to_lp_cc3200_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/src/gpio_dsp_to_lp_cc3200_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/src/gpio_dsp_to_lp_cc3200_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/src/gpio_dsp_to_lp_msp432_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/src/gpio_dsp_to_lp_msp432_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/src/gpio_dsp_to_lp_msp432_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/src/i2c_dsp_master_msp_slave.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/src/i2c_dsp_master_msp_slave.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/src/i2c_dsp_master_msp_slave.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/src/i2c_dsp_slave_msp_master.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/src/i2c_dsp_slave_msp_master.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/src/i2c_dsp_slave_msp_master.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/src/led_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/src/led_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/src/led_test.c
'生成文件:"./main.c"'
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完工建筑:"../main.c"'
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/src/oled_display_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/src/oled_display_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/src/oled_display_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/src/push_button_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/src/push_button_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/src/push_button_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/src/rtc_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/src/rtc_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
"C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/src/rtc_test.c、第249行:警告#179-D:函数"RTC_ALARM_INTERRUPT_TEST"已声明但从未引用
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/src/rtc_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/src/sd_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/src/sd_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/src/sd_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/src/spi_flash_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/src/spi_flash_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/src/spi_flash_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/src/uart_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/src/uart_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/src/uart_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/src/usb_test.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/src/usb_test.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/src/usb_test.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common/audio_common.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common/audio_common.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common/audio_common.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common/i2c_probe.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common/i2c_probe.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common/i2c_probe.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common/platform.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common/platform.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common/platform.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common/system_init.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common/system_init.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common/system_init.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/src/diag_config.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/src/diag_config.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/src/diag_config.c
'生成文件:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/src/framework.c "
'调用:C5500编译器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 -v5515 --memory_model=large -g --include_path="C:/ti/ccsv7/tools/compiler/c5500_4.4.1/include --include_path="C:/ti/c55_lp/c55_csl_3.08/inc --include_path="C:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_master_msp_slave/inc --include_path="c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/spi_flash_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/usb_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/led_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/external_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/dsp_ble_interface_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/i2c_dsp_msp_test/dsp_slave_msp_master/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/oled_display_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_msp432_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/uart_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_mic_in_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_line_in_loopback_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/rtc_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/gpio_dsp_to_lp_cc3200_test/inc:include_tr.com.cn"/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/push_button_test/inc --include_path=/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_headset_loopback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/audio_test/audio_playback_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/sd_test/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/src/framework.c /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag /ti/c55_lp/c55_csl_3.06/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/inc /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/current_monitor_test/inc:
'完成的建筑:"c:/ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/framework/boostC5545/src/framework.c
'构建目标:"boostc5545_diag_test.out"
'调用:C5500链接器'
"c:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55 /ti/ccsv7/tools/compiler/c5500_4.4.1/lib /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/build/boostC5545/diag_test -v5515 --memory_model=large -g -define=c5545 -define=use_serial_console -display_error_number -diag_warning=225 -ptrdiff_size=16 -z -m"boostc5545_diag_test.map"--stack_size=0x200 -exit_rom-"i-display_inexam -rom_ram_ram_zh-"-link_ines"-"-"-"-link_rom_intrack_ram_ins"-"-"-"-"-ins-intrack_ins-ins--intrack_ram_ram_zh-ins-ins-ins-ins--intrack_zh-link_ram_zh-out-link_ram_ins"-"-"-link_in /ti/c55_lp/c55_csl_3.06/ccs_v6.x_examples/C55XXCSL_LP/Debug /ti/ccsv7/tools/compiler/c5500_4.4.1/include sys_stacksize=0x200 -o "boostc5545_diag_test.out"../audi_header_loopback _test.obj "../audi_line_loopback _test.obj "../audi_mic_ime_in_in_test_test.obj "../audi_spi_test_out_spi_test_test_out./spi_spi_test_test_test_out.obj "./spi_test_test_test_rom_test_out.obj "./spi_test_test_test_in_test_out.obj "./spi_spi_test_test_test_out./spi_tobj /ti/c55_lp/rollbackBackupDirectory/C/ti/c55_lp/c5545bp_software_01.01.00.00/source_code/c55xx_diagnostics/board/diag/common/C5545BP.cmd /framework/boostC5545/src/framework.obj /framework/boostC5545/src/diag_config.obj /common/system_init.obj /common/platform.obj /common/i2c_probe.obj
错误#10008-D:找不到文件"C55XXCSL_LP.lib"
未定义的首次引用
符号
_GPIO_clearInt ./push_button_test.obj
_gpio_close ./led_test.obj
_GPIO_configBit ./DSP_BLE_INTERFIT_TEST.obj
_GPIO_enableInt ./push_button_test.obj
_GPIO_open ./dsp_ble_interface_test.obj
_gpio_read ./dsp_ble_interface_test.obj
_GPIO_reset ./dsp_ble_interface_test.obj
_gpio_statusBit ./push_button_test.obj
_GPIO_write ./dsp_ble_interface_test.obj
HID_Ctrl ./USB_TEST.obj
HID_Open ./USB_TEST.obj
HID_eventHandler ./USB_test.obj
HID_initDescriptors ./USB_test.obj
_HID_REreportHandler ./USB_TEST.obj
HID_REQHIDGetReport ./USB_TEST.obj
_I2C_CONFIG ./OLED_DISPLAY_TEST.obj
_i2C_init ./curry_monitor_test.obj
_i2C_read ./curry_monitor_test.obj
_i2C_setup ./curry_monitor_test.obj
_i2C_write ./curry_monitor_test.obj
_I2S_Close ./audio_header_loopback_test.obj
_I2S_open ./audio_common/audio_common.obj
_I2S_setup ./audio_common/audio_common.obj
_I2S_transEnable ./audio_common/audio_common.obj
_irq_clear ./push_button_test.obj
_IRQ_CLEARALL ./DSP_BLE_INTERFACE 测试.obj
_IRQ_disableAll ./DSP_BLE_interface_test.obj
_irq_enable ./push_button_test.obj
_IRQ_globalDisable ./DSP_ble_interface_test.obj
_IRQ_globalEnable ./push_button_test.obj
_irq_plug ./push_button_test.obj
_IRQ_setVecs ./DSP_BLE_INTERFIT_TEST.obj
_MMC_clearResponse ./sd_test.obj
_mmc_close ./sd_test.obj
MMC_deselecCard ./sd_test.obj
_MMC_getCardStatus ./sd_test.obj
_mmc_init ./sd_test.obj
_mmc_open ./sd_test.obj
_mmc_read ./sd_test.obj
_MMC_selectCard ./sd_test.obj
_mmc_sendCmd ./sd_test.obj
_MMC_sendOpCond ./sd_test.obj
_mmc_write ./sd_test.obj
rtc_config ./rtc_test.obj
RTC_eventEnable ./rtc_test.obj
rtc_getconfig ./rtc_test.obj
rtc_getDate ./rtc_test.obj
RTC_getEventId ./RTC_TEST.obj
rtc_getTime ./rtc_test.obj
rtc_reset ./rtc_test.obj
RTC_setCallback ./RTC_TEST.obj
rtc_setdate ./rtc_test.obj
RTC_setPeriodicInterval ./RTC_TEST.obj
RTC_setTime ./RTC_TEST.obj
rtc_start ./rtc_test.obj
rtc_stop ./rtc_test.obj
_sd_getCardCSd ./sd_test.obj
_sd_sendAllCID ./sd_test.obj
_sd_sendRca ./sd_test.obj
_sd_setBusWidth ./sd_test.obj
_spi_close ./dsp_ble_interface_test.obj
_spi_config ./dsp_ble_interface_test.obj
_spi_dataTransaction ./spi_flash_test.obj
_spi_deInit ./dsp_ble_interface_test.obj
_spi_init ./dsp_ble_interface_test.obj
_spi_open ./dsp_ble_interface_test.obj
_spi_read ./dsp_ble_interface_test.obj
_spi_write ./dsp_ble_interface_test.obj
_SYS_setEBSR ./AUDIO_HEETER_LOOP_TEST.obj
_UART_fputc ./common/platform.obj
_UART_fputs ./UART_TEST.obj
_UART_init ./UART_TEST.obj
_UART_READ ./UART_TEST.obj
_UART_setup ./UART_test.obj
_USB_clearEndptStall ./USB_test.obj
_USB_disconnectDev ./USB_test.obj
_USB_getEndptStall ./USB_test.obj
_USB_getRemoteWakeupStat ./USB_test.obj
_USB_postTransaction ./USB_test.obj
_USB_resetDev ./USB_test.obj
_USB_setDevAddr ./USB_test.obj
_USB_setRemoteWakeup ./USB_test.obj
_USB_stallEndpt ./USB_test.obj
_USB_suspendDevice ./USB_test.obj
_VECSTART ./DSP_BLE_INTERFIT_TEST.obj
_sysCtrlRegs ./usb_test.obj
_usbRegisters ./usb_test.obj
错误#10234-D:未解析的符号仍然存在
错误#10010:链接期间遇到错误;"boostc5545_diag_test.out"不存在
>>编译失败
Makefile:172:目标'boostc5545_diag_test.out'的配方失败
已构建
gmake:***[boostc5545_diag_test.out]错误1.
gmake:目标"全部"不会由于错误而重新生成。
****构建完成****
在“问题 ”窗口(已附)中显示92个错误,请指导我完成此操作
提前感谢
Hussain
    Hussain、
    当您遇到大量误差时、例如第一个误差。 在建立早期错误时、通常会导致许多其他错误。
    关键错误为"找不到文件 C55XXCSL_LP.lib"。 基本上、您的项目包含一个库、但构建系统无法找到它。 这是导致所有未解析符号错误的原因、因为应用程序代码在该库中调用 API。
    在您从 TI 下载的软件中查找 C55XXCSL_LP.lib。 它不是 Code Composer Studio 附带的、而是您为 Booster Pack 下载的软件的一部分。
    找到库后、您需要将路径添加到链接器库搜索路径。 打开项目的属性。 展开左侧树形结构中的 Build -> C5500 Linker -> File Search Path。 将库的位置添加到库搜索路径。
    John
