主题中讨论的其他器件:MATHLIB
工具/软件:TI C/C++编译器
你(们)好
由于 C6000 Code Composer 编译器7.4.12版、我遇到了段错误。
名为 SBM_inc_init.c 的编译文件、错误为:
编译 SBM\inc_target\SBM_inc_init.c -> build\release_cc_c66x\_pooma\cp_fdsp\SBM_inc_init.obj 时
命令:'mkdir "Build\release_cc_c66x\_pooma\cp_fdsp"2>nPL 和 C:\ti\ccsv6\tools\compiler\c6000_7.4.12\bin\c6x -cmd_file=build/release_cc_c66x/compiler.op--6600_error=-mabet-symbi-display-degetel_-ma-dim-mag-ment-degetel-a-configk_beck-dim-mag-mag-ment-degreal-a=
l -O1 -i"C:\ti/ccsv6/tools/compiler/c6000_7.4.12/include"-i"C:\ti/BIOS_6_41_00_26/packages/ti/BIOS/include"-i"d:\repo\tsw\converter\CubePower_appl\build/release_cc_c66x/config10.2/mand_drivers/3_deb02_pru/sc/sc/sc/inc/inc1.0003/mand/config_1.0003/pruebackns/reguls\ch/inc/inc/inc/inc/inc/config02_pruebuls\ch/inc/inc
"-i"C:\ti/pdk_C6657_1_1_2_6/packages/ti/CSL"-i"C:\ti/pdk_C6657_1_2_6/packages/ti/drv/qms"-i"C:\ti/pdk_C6657_1_2_1/ti_2_6/packages/ti/dpdk_zh/cn/packages:-ti_1/dimes/ti_1/dimp1/ndc/k_zh_packages:-ti_1/dimpls/ti_1/dc/k_zh_zh_packages:-cn/packages 1-/ti_mspi_zh/inc"-cn/packages"/content/ti_zh_ms/ti_zh/cn/packages"-cn/dat_1/dc/pdk_zh-cn/packages"-cn/packages"/content/cn/zh-cn/dat_1/dc/pd
_0/packages/ti/mathlib"-i"C:\ti/mathlib_c66x_3_1_1/0/packages/"-i"C:\ti/xdctools_3_30_05_60_core/packages"-i. iAppl\ApplConfig -I...\SharedLibs\CtrlLib -I...\SignalBlockManager\SBM_Runtim\Include -I...\Conv_Framework\Services\AdvStreaming -I.\Conv
_Framework\Framework_Core -i. -I..... i...\ShareDBlocks -iSBM -iCommon -I...\MSC\MSC_CTRL -iSBM\CPL\PlatformSupport -iSBM\CPL\PlatformSupport\PlatformIO -iSBM\CPL\driver -iSBM\CPL -I...\Conv_Framework\Drivers\CT440 -I...\Conv_Framework\OS\DCT44
0 -I...\Conv_Framework\OS\DSPBIOS -I...\Conv_Framework\if\DSPBIOS -iSBM\SharedLib\CtrlLib -I...\Shareds\ConterPlatform\ConversionLayer\Conv.Conv_Framework\if -I...\Conv_Framework -I.\Conv_Framework\Conv.\Conversion_Framework\Common Services -I.\Conv.\Conv_Framework\Conv.\Conv.\Conv.\Conv.\Common\Conversion_Framework
..\Conv_Framework\Services\ParamManager -I...\Conv_Framework\Services\OPCNameSpace\OldLibs\CFC -I...\Conv_FramingRawData -dDATASPACE_Server -DGDS_replication_enabled -dBENCH_manual_controls-d_CT_440 -d_dspb_d -framework_d -框架
LE_random_PWM -fssbuild\release_cc_c66x\_pooma\cpofdsp -frbuild\release_cc_c66x\_pooma\cp_fdsp SBM \inc_target\SBM_init.c'
输出:'
"SBM\inc_target\SBM_inc_init.c"、第65379行:警告#190-D:与其他类型混合的枚举类型
内部错误:C:\ti\ccsv6\tools\compiler\c6000_7.4.12\bin\opt6x.exe 遇到段错误
处理函数 OnEnterLevel1文件 C:\\Users\tntgtr\\AppData\Local\\Temp\\ibC858AF\\3\\171482
这是一个严重的问题。 请通过此消息和输入文件的副本与客户支持联系
并帮助我们继续使工具更可靠。
>>编译失败
附加了 c 文件。 请帮助我如何继续
BR
TAM 变换
维斯塔斯风能系统
