[参考译文] CCS/CC2640R2F:无法启动 TI 云代理:无法启动 TICloudAgent。
Guru**** 2531780 points
Other Parts Discussed in Thread: CC2640R2F
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/805056/ccs-cc2640r2f-could-not-launch-ti-cloud-agent-failed-to-start-ticloudagent
器件型号:CC2640R2F
工具/软件:Code Composer Studio
它安装了 ccs901/linux、运行良好。 但云代理在  使用 Firefox 打开时始终失败、同时启用 TI 云代理桥。
云代理将在几秒钟后通过命令行意外退出:
root@gentoo:/opt/ti/ccs901/ccs/ccs_base/cloudagent bash -x ./ti*sh no_chrome.
+导出 TI_DS_ENABLE_LOGIN=3.
+ TI_DS_ENABLE_LOGIN=3.
+导出 TI_DS_logging_output=/tmp/my.log
+ TI_DS_logging_output=/tmp/my.log
+回波'--./ticloudagent.sh args---非铬 合金'
++ dirname ./ticloudagent.sh
+推。
++正向
+ SCRIPTPATH=/opt/ti/ccs901/ccs/ccs_base/cloudagent
+弹出
+ CA_TempDir=/tmp/ticloudagent
+ ca_udev_link=/tmp/ticloudagent /libudev.so.0
++/sbin/ldconfig -p
++ grep 'libudev.so.0...*64'
+[[! -n   libidev.so.0 (libc6、x86-64)=>/usr/lib64/libudev.so.0 ]]
+"['-z /root ']'
+"['-z ']'
+导出 TMPDIR=/root/.ti/TICloudAgent/tmp
+ TMPDIR=/root/.ti/TICloudAgent/tmp
+ mkdir -p /root/.ti/TICloudAgent/tmp
+导出路径=/opt/ti/ccsv8/utils/bin:/opt/android-sdk-update-manager/tools:/opt/android-sdk-update-manager/platform-tools:/usr/lib/llvm/8/bin:/usr/lib/llvm/7/bin:/usr/lib/llvm/6/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/bin:/opt/android-sdk-update-manager/tools:/opt/android-sdk-update-manager/platform-tools:/root/.fzf/bin:/usr/sbin:/opt/ti/ccs901/ccs/ccs_base/cloudagent/util
+ path=/opt/ti/ccsv8/utils/bin:/opt/android-sdk-update-manager/tools:/opt/android-sdk-update-manager/platform-tools:/usr/lib/llvm/8/bin:/usr/lib/llvm/7/bin:/usr/lib/llvm/6/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/bin:/opt/android-sdk-update-manager/tools:/opt/android-sdk-update-manager/platform-tools:/root/.fzf/bin:/usr/sbin:/opt/ti/ccs901/ccs/ccs_base/cloudagent/util
+"['非铬=非铬']'
+/opt/ti/ccs901/ccs/ccs_base/cloudagent/node /opt/ti/ccs901/ccs/ccs_base/cloudagent/src/main.js
{"port":37683、"版本":"4.7"}
/tmp 中的日志文件显示:
root@gentoo:~# cat /tmp/my_ticld.log
2019-05-26T10:56:34.101Z:main:staring directory =/opt/ti/ccs901/ccs/ccs_base/cloudagent/src
2019-05-26T10:56:34.103Z:启动代理!
2019-05-26T10:56:34.171Z:MODUL( Agent )-> Web 套接字服务器已启动!
2019-05-26T10:56:35.961Z:覆盖的代理=
2019-05-26T10:56:35.982Z:Discovered Module:DeviceDetector
2019-05-26T10:56:35.984Z:Discovered Module:DS
2019-05-26T10:56:35.986Z:Discovered Module:EventBroker
2019-05-26T10:56:36.007Z:Discovered Module:File
2019-05-26T10:56:36.009Z:发现的模块:闪存
2019-05-26T10:56:36.012Z:ROV_server_redirect:查看:/opt/ti/ccs901/ccs/eclipse/dropins
2019-05-26T10:56:36.012Z:ROV_server_redirect:查看:/opt/ti/ccs901/ccs/eclipse/plugins
2019-05-26T10:56:36.015Z:ROV_server_redirect:found:/opt/ti/ccs901/ccs/eclipse/plugins/com.ti.rov_1.0.0.201902251325
2019-05-26T10:56:36.015Z:ROV_server_redirect:查看:/opt/ti/ccs901/ccs/eclipse/Eclipse.app/Contents/Eclipse/dropins
2019-05-26T10:56:36.015Z:ROV_server_redirect:查看:/opt/ti/ccs901/ccs/eclipse/Eclipse.app/Contents/Eclipse/plugins
2019-05-26T10:56:36.016Z:ROV_server_redirect:将 XDCTOOLS_Java_HOME 设置为/opt/ti/ccs901/ccs/eclipse/jre
2019-05-26T10:56:36.016Z:ROV_server_redirect:要求/opt/ti/ccs901/ccs/eclipse/plugins/com.ti.rov_1.0.0.201902251325/rov_server.js
2019-05-26T10:56:36.029Z:Discovered Module:ROVServer
2019-05-26T10:56:36.145Z:Discovered Module:Serial
2019-05-26T10:56:36.155Z:发现的模块:TargetSupport
2019-05-26T10:56:36.174Z:发现的模块:USB-HID
2019-05-26T10:56:36.174Z:在端口37683上运行的代理主模块
根@gentoo:~#
弹出的 Firefox 框显示以下消息:
无法启动 TI Cloud Agent:启动 TICloudAgent 失败。 请执行以下列出的操作并重试您的操作。(这是什么?)
    Ke、
    您正在运行什么 Linux 发行版?
    John
    Gentoo Linux,内核5.0.1
    Ke、
    很抱歉、我们需要设置 gentoo 机器。 这不是我们正式支持的发行版、但我将查看一下、因为我们最近有几个用户使用了它。
    John
    只需确认即可
    -您已安装 CCSv9.0.1。 它工作正常。
    -当您访问 dev.ti.com 时、即遇到云代理问题时
    有一点很奇怪、它是在 CCS 中使用云代理。 它应该安装自己的副本。
    John
    您是否已将/opt/ti/ccs901/ccs/ccs_base/cloudagent/util 添加到您的路径中? 如果是、您可以尝试删除它。
    John
    CCSv9.0.1与云代理一起安装、因此似乎不需要下载云代理的独立副本并进行安装、这可能会复制 udev 某些配置的配置。
    下载并安装另一个独立云代理、结果相同、问题仍然出现。
    路径中不包含/opt/ti/ccs901/ccs/ccs_base/cloudagent/util。
    在您的第一篇帖子中、您列出了该输出。  路径中列出了该位置。
    云代理将在几秒钟后通过命令行意外退出:
    +推。
    ++正向
    +弹出
    ++/sbin/ldconfig -p
    +"['-z /root ']'
    +"['-z ']'
    +"['非铬=非铬']'
    也许我应该后退一步。
    1. 您是否要访问 dev.ti.com、然后在云代理运行时遇到问题?  例如、dev.ti.com 会导致云代理运行以自动检测您的电路板?
    2. 还是您自己运行云代理?
    John
    我手动运行代理:
    CD //opt/ti/ccs901/ccs/ccs_base/cloudagent
    bash -x ticloudagent.sh no_chrome.
    ticloudagent.sh 将/opt/ti/ccs901/ccs/ccs_base/cloudagent/util 附加到路径和导出路径
    使用-x 显示 ticloudagent.sh 正在执行的操作,对于 Firefox 浏览器,则为 not _chromix
    然后节点 js 在几秒钟内运行并退出。 但作为代理、它不应退出。
    好的。 为什么要运行代理?
    它通常不会由用户运行。  您是否正在尝试调试其他问题?
    猜工程师应该正在运行、以便 Firefox 扩展正常工作。 运行尝试手动运行它。
    好的、有道理。 如果转到主目录、是否有/TIC扩音器 文件夹?
    我已使用用户 ti 安装了独立代理、它将创建/home/ti/TICloudAgent 并在那里安装代理。 但 dev.ti.com 无法检测连接到 cc2640r2f 模块的 xds110 (该模块不是 launchpad、CCS 可以检测并对其进行编程)。 如果手动启动独立业务代表,它将自动退出几秒钟。
    从 CCS 启动 Resource Explorer 时、代理将启动并保持运行。
    但是、在 Firefox 中打开 dev.ti.com/.../explore、然后按"检测我的板"按钮后、会弹出一个消息框、显示:
    TI Cloud Agent 设置
    无法启动 TI Cloud Agent:启动 TICloudAgent 失败。 请执行下列操作并重试您的操作。
    步骤1:
    下载并安装 TI Cloud Agent 应用程序
    步骤2:
    刷新页面
    Firefox 云扩展可能无法连接到 CCS 的运行代理。 由于端口号不是固定的,因此分机可能无法找到代理的端口号。
    工程师确实有问题。 但是、即使我们使其正常工作、它也不会提供太多帮助。 dev.ti.com 上的自动检测功能仅支持一组特定的 LaunchPad。 它当前正在读取 LaunchPad 本身上的 ID、以确定连接的设备。 当独立 XDS110连接到 CC2640R2模块时、只需知道110已连接即可。
    话虽如此、如果您想在未来使用 CCS Cloud、我们需要让工程师为您服务。
    Ke
    TIC扩音器 应用程序不是从命令提示符启动的、因此它在几秒钟后以这种方式启动时会退出。
    应该发生的情况是、浏览器扩展在首次加载 dev.ti.com 页面时启动主文件夹中的 TIC扩音器 脚本。 如果由于某种原因无法启动,您将收到一条要求安装它的消息。 我将假定浏览器扩展安装正确、并且启动 TIClougAgent 脚本时出现一些问题、或者脚本和浏览器之间的通信出现问题。
    您能否在编辑器中打开/home/ti/TICloudAgent/ticloudagent.sh 脚本并取消注释前三条注释行(两条"导出"命令和一条"回显")。 退出并重新启动 Firefox。 浏览至   并等待10秒钟左右。 您能否抓取在/tmp 中创建的两个日志文件并让我知道这些文件的内容是什么?
    独立代理由用户 ti 安装、然后由用户 ti 启动 Firefox、 代理工作、但未检测到电路板、代理可能无法重新使不是 launchpad 的 CC2640R2f 鼠标光标均匀。  当 Firefox 显示:
    串行:GY006945
    开始使用! 不适用
    不适用
    使用 Resource Explorer 浏览示例和文档
    从 GUI Composer 库运行交互式演示
    /tmp 中的日志读取:
    2019-06-01T02:41:20.209Z:MAIN_Chrome:staring 目录=/home/ti/TICloudAgent/src
    20-06-01T02:41:20.210Z:Starting Agent!
    2019-06-01T02:41:20.232Z:MODUL( Agent )-> Web 套接字服务器已启动!
    2019-06-01T02:41:20.599Z:覆盖的代理=
    2019-06-01T02:41:20.603Z:发现的模块:DeviceDetector
    2019-06-01T02:41:20.604Z:发现的模块:DS
    /home/eclipse/dropins
    块:202020-06-01V:/home/eclipse/plugins /home/eclipse/Eclipse.app/Contents/Eclipse/dropins:2060042_t02_T /home/eclipse/Eclipse.app/Contents/Eclipse/plugins:20606T::2060042_T:2060042_T:2060V: rov_server_redirect.js:错误:未找到 rov_server.js (这是云中的预期值)
    在对象上。 (/home/ti/TICloudAgent/src/modules/rov_server_redirect.js:65:11)
    在 Module._compile (module.js:652:30)
    在 Object.Module._extensions.js (module.js:663:10)
    在 Module.load (module.js:565:32)
    在 tryModuleLoad (module.js:505:12)
    在 Function.Module._load (module.js:497:3)
    在 Module.requires (module.js:596:17)
    需要时(internal/module.js:11:18)
    在 module_1.createModule.then (/home/ti/TICloudAgent/src/host_agent.js:22:42)
    在
    2019-06-01T02:41:20.644Z:Discovered Module:Serial
    2019-06-01T02:41:20.645Z:Discovered Module:TargetSupport
    2019-06-01T02:41:20.647Z:Discovered Module:USB
    2019-06-01T02:20652Z:
    2014.8T
    :01:2065042:20-02Z:t042:20-01:20-01641:20-01641:20-016-01:2065Z
    MODULE( Agent )->[started.onMessage]{"command":"addConfigProperty"、"id":2、"data":["cloudAgentInstallerServerURL"、"https://dev.ti.com/ticloudagent"]}
    2019-06-01T02:41:20:694Z: Setting Property ClouddAgentHandler InstallerURL: dev.ti.com/ticloudagent
    20-06-01T02:20-01T 模
    块()021:20-021:201-021:000200021:000200021:00021:00021:00021:201-0204Z:00021:00021:00021:00021:00021:0002000200021:00021:00020002+0002+00021:00021:0002+0002+0002+EMUTEX2+EMENT/0150002+EMENT/0150002+EMENT/0150002+(:0150002+0151:20-01:201-0002+01:0002+0150002+01:20-01:20-01:0002
    2019-06-01T02:41:20.703Z:Detected USB id ab12_34cd
    2019-06-01T02:41:20.703Z:Detected USB id 1d6b_0002
    20-01T02:41:20.704Z:Detected USB id 0b97_7772
    20-01T02:41:01d012_20-01t0002
    :20-0204b:20-020-020-01t0002:204b 20-020-020-01t0002:204b:204b:20-01t0002:204b 204b 20-01:204b 20-01:204b 20-01t0002
    Detected USB id 1d6b_0001
    2019-06-01T02:41:20.704Z:Detected USB id 1d6b_0001
    20-01T02:41:20.704Z:module (Agent)->[Response Handler]{"data":{"port:42095}、"Response:3}"2019-06"*
    DeviceList"、"ded"、"tDevice Subtractors"2[d"、"ded"(ded"derve2e.texector):"dT:"dT:2d"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debugetractor"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"、"Debug"
    pathinfo.ini","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/emulation/analysis/bin/libctools.so","version":"2019-02-07T21:26:32.598Z"},{"name":"ccs_base/emulation/analysis/xmldb/aet_config/aetdvrs.xml","version":"2017-04-04T19:46:12.029Z"},{"name":"ccs_base/emulation/drivers/cmapi.out","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/drivers/libcmapi.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/drivers/libprsc.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/FlashDLLDB.xml","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/DSLite","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libDebugProperties.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libXPCOMUtility.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libtiofr_gnu.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/components/components.txt","version":"2016-12-16T22:28:53.105Z"},{"name":"ccs_base/DebugServer/bin/libti_xpcom.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libtiofr11.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libtiofr_tial.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libDebugServer.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/propertyDB/FlashPropertiesTranslator.xml","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/propertyDB/PropertiesDB.xml","version":"2018-08-08T16:58:32.871Z"},{"name":"ccs_base/DebugServer/schemas/PropertiesDB.xsd","version":"2017-06-12T20:37:30.918Z"},{"name":"ccs_base/DebugServer/scripts/cc13xx-cc26xx-mass-erase.dsls","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/schemas/PropertiesSaveSetting.xsd","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/DebugServer/scripts/flash.dsls","version":"2018-10-30T14:04:14.809Z"},{"name":"ccs_base/DebugServer/scripts/help.dsls","version":"2016-08-22T18:04:31.070Z"},{"name":"ccs_base/DebugServer/scripts/load.dsls","version":"2018-10-30T14:04:14.809Z"},{"name":"ccs_base/DebugServer/scripts/memory.dsls","version":"2018-10-30T14:04:14.809Z"},{"name":"ccs_base/DebugServer/scripts/serial.dsls","version":"2018-10-30T14:04:14.809Z"},{"name":"ccs_base/common/bin/libCCReg.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/bin/libxerces-c.so.28","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/common/bin/libti_logger.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/bin/libMiniDump.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/bin/libxerces-c.so.28.0","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/common/bin/libfsutil.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/bin/libsetup_parser.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/bin/libxerces-c_2_8.so","version":"2018-04-26T19:26:26.530Z"},{"name":"ccs_base/common/targetdb/setup_parser.xsd","version":"2017-10-17T19:25:10.009Z"},{"name":"ccs_base/common/targetdb/setup_parser_cache.xsd","version":"2017-10-17T19:25:10.009Z"},{"name":"ccs_base/common/bin/libstdc++.so.6","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/common/bin/libstdc++.so","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/common/bin/libstdc++.so.6.0.19","version":"2018-04-26T19:26:26.530Z"},{"name":"ccs_base/common/targetdb/drivers/TI_reg_ids/regids.xsd","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/emulation/tpi/tpi.ini","version":"2019-02-07T21:26:32.598Z"}],"drivers":[]} dev.ti.com/.../getFilesByCategory
    MODULE (DeviceDetector)->[ResponseHandler]{"data":false、"Response":2}
    2019-06-01T02:41:21.785Z:MODUE (DeviceDetector)->[ws.onMessage]{"command":"detectDebug"DebugProbes "、"id":"data":[]
    :2019-01db.021"
    :tid.t021.021.20-01t/common 文件:tid.tid.tid.tid.t.tid.tid.tid.t021.2019-021"
    :t.t.tid.tid.t.tid.tid.tid.tid.tid.t.tid.tid.t.tid.t021.2019-01z":tid.t.t.t.t.tid.tid.tid.t.tid.t.tid.t.t.tid.t.t.tid.t021.2019-01b.tid.t.t.
    /dev/ttyACM0 pathinfo.ini","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/emulation/analysis/bin/libctools.so","version":"2019-02-07T21:26:32.598Z"},{"name":"ccs_base/emulation/analysis/xmldb/aet_config/aetdvrs.xml","version":"2017-04-04T19:46:12.029Z"},{"name":"ccs_base/emulation/drivers/cmapi.out","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/drivers/libcmapi.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/drivers/libprsc.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/FlashDLLDB.xml","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/DSLite","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libDebugProperties.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libXPCOMUtility.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libtiofr_gnu.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/components/components.txt","version":"2016-12-16T22:28:53.105Z"},{"name":"ccs_base/DebugServer/bin/libti_xpcom.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libtiofr11.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libtiofr_tial.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/libDebugServer.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/propertyDB/FlashPropertiesTranslator.xml","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/propertyDB/PropertiesDB.xml","version":"2018-08-08T16:58:32.871Z"},{"name":"ccs_base/DebugServer/schemas/PropertiesDB.xsd","version":"2017-06-12T20:37:30.918Z"},{"name":"ccs_base/DebugServer/scripts/cc13xx-cc26xx-mass-erase.dsls","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/schemas/PropertiesSaveSetting.xsd","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/DebugServer/scripts/flash.dsls","version":"2018-10-30T14:04:14.809Z"},{"name":"ccs_base/DebugServer/scripts/help.dsls","version":"2016-08-22T18:04:31.070Z"},{"name":"ccs_base/DebugServer/scripts/load.dsls","version":"2018-10-30T14:04:14.809Z"},{"name":"ccs_base/DebugServer/scripts/memory.dsls","version":"2018-10-30T14:04:14.809Z"},{"name":"ccs_base/DebugServer/scripts/serial.dsls","version":"2018-10-30T14:04:14.809Z"},{"name":"ccs_base/common/bin/libCCReg.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/bin/libxerces-c.so.28","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/common/bin/libti_logger.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/bin/libMiniDump.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/bin/libxerces-c.so.28.0","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/common/bin/libfsutil.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/bin/libsetup_parser.so","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/bin/libxerces-c_2_8.so","version":"2018-04-26T19:26:26.530Z"},{"name":"ccs_base/common/targetdb/setup_parser.xsd","version":"2017-10-17T19:25:10.009Z"},{"name":"ccs_base/common/targetdb/setup_parser_cache.xsd","version":"2017-10-17T19:25:10.009Z"},{"name":"ccs_base/common/bin/libstdc++.so.6","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/common/bin/libstdc++.so","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/common/bin/libstdc++.so.6.0.19","version":"2018-04-26T19:26:26.530Z"},{"name":"ccs_base/common/targetdb/drivers/TI_reg_ids/regids.xsd","version":"2016-05-17T14:20:06.063Z"},{"name":"ccs_base/emulation/tpi/tpi.ini","version":"2019-02-07T21:26:32.598Z"}],"drivers":[]}
    打开资源爆炸时、页面显示:
    选择"Board or Device"
    使用自动检测或从下面的下拉菜单中选择。
    未检测到板
    日志读取:
    2019-06-01T02:41:44.432Z:MODULE( Agent )->[wss.OnConnection]
    2019-06-01T02:41:44.438Z:MODULE( Agent )->[Cloud.onMessage]{"commands":"iverConfigCommands"、"id"data":[]] 2019-06-01dAgent"、
    "subtrackerPackage"
    "subtractors:"subtratemd2mesn:"subset"、"subtrates:"subtrates:"eback"、"subtrates:"subtratemd042"、"subtrates:"subtrates:"eback"、"subtrates:"subtrates:"subtrates:"subtrack"、"subtrates:"eback"、"subtratemd042"subtrates:"subtrates:"eback"、"subtrates:"subtrates:"subtrates:"eback"、"subtrack">dev.ti.com/ticloudagent"]}、"subtractors:"subtratemd2mesn:"subset"、"subtrates:"subtrates:"eback"、"subtrates:"subtratemd042"、"subtrates:"subtrates:"eback"、"subtrates:"subtrates:"subtrates:"subtrack"、"subtrates:"eback"、"subtratemd042"subtrates:"subtrates:"eback"、"subtrates:"subtrates:"subtrates:"eback"、"subtrack
    http://dev.ti.com/ticloudagent
    模块(DeviceDetector)->[ResponseHandler]{"data":{"commands":["listSubModules"、"createSubModule"、"ListCommands"、"detectDebugProbes "、"detectDevice"、"detectDeviceProbe Probe "、"libNeeed"、"populateDeviceList"]、"Response"
    、"file046"
    :t041:tid/t049041d":t2019-02019":tid" dev.ti.com/.../getFilesByCategory
    :t2t2tid/profiles":t041:tid" t0490152d":t2t2tid":tid/tid" t049041.t20192019":tid":tid":tid" tid/tid/t049041t:t2019-02019" t:t:t:tid" tid" t:t:tid" tid" t:t:t:tid.t015t:t:t:tid.t:t:t015t:
    MODULE (DeviceDetector)->[ws.onMessage]{"command":"detectDeviceWithProbe"、"id":4、"data":[{"connectionXml":"TIXDS110_Connection"、"id":"0"、"DEGYNumber":"45.006945"、"comports":["connectionXml":"/dev/ttyACM0
    :"02"、"Serial Device"、"4-2019"(模块编号:):"2"2"02"、"2"2"2"2"64"、"2"、"2"Debug"、"2"2"2"015"、"2019"、"2"64"、"T:"、"T:
    退出 Firefox 时,日志读为:
    2019-06-01T02:42:04.919Z:MODULE( Agent )->套接字关闭,wss.clients.size = 1
    2019-06-01T02:42:04.922Z:MODULE( DeviceDetector )->套接字关闭,wss.clients.size = 1
    套接字-06-01T02:42:04.923Z- MODULE:w042:wss.042:wss.042:2019-02-07:wss.07:wss.=器关闭的客户端
    但是,如果 Firefox 由 root 用户启动,则代理将不会启动,并且/tmp 中没有日志,并且代理不工作。
    因此、很明显
    1.安装独立代理的用户必须启动 Firefox,才能使云代理正常工作。 其他用户启动 firefix 将不起作用。
    工程师无法检测到 XDS110连接的非 Launchpad CC2640R2F 模块、
