[参考译文] CCS/CC3200:An error has occured,see the log file null
Guru**** 2543810 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/810872/ccs-cc3200-an-error-has-occured-see-the-log-file-null
器件型号:CC3200
工具/软件:Code Composer Studio
当我尝试打开我的 CCS 时出现错误、这是日志
!会议2019-06-13 20:36:26.628 ------------------------
Eclipse.buildId=4.7.3.M20180301-0715
java.version=1.8.0_112
java.fendor=Oracle Corporation
bootloader constants:os=Win32、arch=x86、WS=Win32、NL=zh_CN
!entry org.eclipse.OSG4 0 0:3-27:27.413\X\clipoundMessage
Error reading configuration:ring\langeclipse\jape\jape\jape\emine.org.cc014.e\r 拒绝访问。
文件!recho\r jape\r jave\emo\r jave\r jave\r 拒绝访问。文件\r jape\r jape\r 文件\r jape\g.cc014.e\r jape\r jape\r jape\r 文件\r 文件\r 文件\r 文件\r jape\r 文件\r jape\r 文件\r jap.cc8:open.cpip.cc\r 文件\r jape\r 文件 (RandomAccessFile.Java:243)
位于 org.eclipse.osgi.internal.location.Locker_JavaNio.lock(Locker_JavaNio.java:36)
位于 org.eclipse.OSGi.StorageManager.StorageManager.lock (StorageManager.Java:388)
位于 org.eclipse.OSGi.StorageManager.StorageManager.open (StorageManager.Java:701)
位于 org.eclipse.storage.Storage.Storage.getStorage.g.gm.gor.g.gor.g.gor.g.gor.StorageManager.g.g.g.g.g.g.g.g.golip.g.g.g.g.e.g.g.g.g.storage.e.g.g.g.gor.g.g.g.
(storage.java:132)
at org.eclipse.OSGi.storage.Storage.createStorage(Storage.java:85)
at org.eclipse.osgi.internal.framework.EquinoxContainer。 (EquinoxContainer.Java:68)
at org.eclipse.OSGi.launch.Equinox。 (Equinox.java:31)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:303)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:239
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62
) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43
at java.lang.reflect.Method.invoke(Method.java:498) at)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653
at org.eclipse.equinox.launcher.main.basicRun (Main.java:590
) at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
但我不知道它有什么问题。感谢您的帮助。
