[参考译文] CCS/CC2650STK:Project Zero 未从 Simplink Academy v1.11进行编译
Guru**** 2470720 points
Other Parts Discussed in Thread: CC2650, BLE-STACK
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/783971/ccs-cc2650stk-project-zero-not-compiling-from-simplink-academy-v1-11
器件型号:CC2650STK
Thread 中讨论的其他器件:CC2650BLE-STACK
工具/软件:Code Composer Studio
我一直在关注此文档并尝试学习如何为  CC2650 SensorTag  器件编写我自己的 GATT 服务、但在构建项目时遇到这些错误。 附加的是日志文件。
调用针对 project project_zero_stack_cc2650的配置调试****"C:\\ti\\ccsv8\\utils\bin\\gmake"-j -k -j 4 all -O "c:/ti/simplelink/ble_sdk_2_02_01_18/tools/lib_search/lib_search.exe /ti/simplelink/ble_sdk_2_02_01_18/blelib " C:/Users/Red /Users/Red Rose/documents\ccs_wrk-space/project_zero_stack_cc2650/build/build 4 unt <\ccs_documents /ti/simplelink/ble_sdk_2_02_01_18/tools/lib_search/params_split_cc2640.xml /Users/Red out_rebuilding</c2650:/cc2650_tools\cmware<\ccs_out_lib_out_prisd_linker.cpue_/cc2650</documents\cmware<\cmware<\cmware<\ccs_lib_build_lib_lib_prue_out_tools\cmware<\cmc2650:/cc2650</documents\cmware<\cmc堆 栈<\cmcout_lib_out_lib_prue_out_project_lib_project_lib_project_project_building</out_lib_out arm Linker
"C:/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.4.LTS/bin/armcl "-cmd_file="c:/ti/simplelink/ble_sdk_2_02_01_18/src/config/build_components.opt "-cmd_file="C:/Users/Red Rose/Documents/Clwrk-space/project_zero_stack_cc2650/tools/build_config.opt"-mv7M3 -code_state=16 -me -opt_for_speed=project_zero=v_define -define=v_define -define=rts=v_define -define -define = rts=x_define -define -define=v_define -define -define=v_define=v_define define=CC26XXWARE --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi -z -m"project_zero_stack_off-diag_zh-diag_id=102650_zh-display_info-display_zh-cn=d_guide-d_zh-cn_guide-d_zh-cn=dag_guide-d_zh-cn=dag_zh-cn_guide-d_guide-d_zh-out-d_guide-d_guide-cep-d_zh-d_guide-d_guide-d_zh-d_guide-d_guide-d_zh-d_guide-d_guide-d_zh-d_guide-d_guide-d_zh-d_guide-d=-d_/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.4.LTS/include /ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.4.LTS/lib entry_point=startup_entry --rom_model -o "project_zero_stack_cc265.out""./HAL/Common/hal_assert.obj "./HAL/Target/CC2650/Drivers/hal_flash_wrapper.obj "./HAL/Target/CC2650/Drivers/hal_trng_wrapper.obj "./HAL/Target/CC2650/_common/mb_patch.obj "./ICallBLE/ble_dispatch.obj "./NPI/npi.obj "./OSAL/osal.obj "./OSAL/osal_cbtimer.obj /PROFILES/gap.obj /Startup/ble_user_config.obj /Startup/osal_icall_ble.obj /Users/Red /ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/cc26xxware_2_24_02_17393/driverlib/bin/ccs/driverlib.lib ".cc2650"".c /HAL/Target/CC2650/Drivers/hal_rtc_wrapper.obj ".trads"/OSAL/osal_bufmgr.obj ".c .trl.c -cc2650 /OSAL/osal_clock.obj /OSAL/osal_memory_icall.obj /OSAL/osal_snv_wrapper.obj /PROFILES/gapbondmgr.obj /Startup/common_rom_init.obj /Startup/rom_init.obj /ti/simplelink/ble_sdk_2_02_01_18/src/rom/enc_lib/cc26xx_ecc_rom_api.a /Users/Red ".c -dl.c /OSAL/osal_pwrmgr.obj ".trads"/OSAL/osal_timers.obj -dl.c .c .c -dl.c /PROFILES/gattservapp_util.obj ".c -cc2650"/Startup/icall_startup.obj ".c -dl.c -ts"/TOOLS/onboard.obj /ti/simplelink/ble_sdk_2_02_01_18/src/rom/ble_rom_releases/04242014/ble_rom_patch.symbols /ti/simplelink/ble_sdk_2_02_01_18/src/common/cc26xx/ccs/cc26xx_stack.cmd
错误#10008-D:找不到文件"C:/Users/Red Rose/Documents/cs_wrk-space/project_zero_stack_cc2650/tools/lib_linker.cmd"
未定义 第一
个引用的符号 文件中
ATT_ErrorRsp
ATT_ExecuteWriteRsp
ATT_ReadBlobRsp
ATT_ReadRsp
ATT_WriteRsp
GAP_Authenticate
GAP_Bond
GAP_ConfigDeviceAddr
GAP_EndDiscoverable
GAP_GetParamValue
GAP_Init
GAP_MakeDiscoverable
GAP_NumActiveConnections
GAP_ParametsInit
GAP_PasscodeUpdate
GAP_PasskeyUpdate
GAP_PeriConnRegister
GAP_PeriDevMgrInit
GAP_PrivacyInit
GAP_ProcessEvent
GAP_RegisterBondMgrCBs
GAP_RegisterForMsgs.
GAP_RemoveAdvToken
GAP_ResolvePrivateAddr
GAP_SecParamsInit
GAP_SendSlaveSecurityRequest
GAP_SetAdvToken
GAP_SetParamValue
GAP_Signable
GAP_TerminateAuth
GAP_TerminateLinkReq
GAP_UpdateAdvTokens
GAP_UpdateAddisingData
GAP_UpdateLinkParamReq
GAP_UpdateLinkParamReqReply
GATTServApp_AddService
GATTServApp_DeregisterService
GATTServApp_GetParameter
GATTServApp_Init
GATTServApp_ProcessEvent
GATTServApp_ReadAttr
GATTServApp_RegisterForMsg
GATTServApp_RegisterService
GATTServApp_SendCCCUpdateEvent
GATTServApp_SetParameter
GATTServApp_UpdateCharCfg
GATT_AppCompletedMsg
GATT_FindHandleUUID
GATT_FindNextAttr
GATT_GetNextHandle
GATT_Indication
GATT_Init
GATT_Notification
GATT_ProcessEvent
GATT_RegisterForMsgs
GATT_SendRsp
GATT_SetHostToAppFlowCtrl
GATT_BM_alloc
GATT_BM_FREE
GGS_AddService
GGS_GetParameter
GGS_RegisterAppCBs
GGS_SetParameter
HCI_EXT_ConnEventNoticeCmd
HCI_EXT_DelaySleep 命令
HCI_EXT_GetConnInfoCmd
HCI_EXT_ResetSystemCmd
HCI_Init
HCI_LE_ConnUpdateCmd
HCI_LE_ReadBufSizeCmd
HCI_LE_ReadRemoteUsedFeaturesCmd
HCI_LE_ReceiverTestCmd
HCI_LE_SetEventMaskCmd
HCI_LE_TransmitterTestCmd
HCI_NumOfCompletedPacketsEvent
HCI_ProcessEvent
HCI_ReadLocalSupportedCommandsCmd
HCI_ReadLocalVersionInfoCmd
HCI_ReadRssiCmd
HCI_ResetCmd
HCI_SetEventMaskPage2Cmd
HCI_ValidConnTimeParams
HCI_VendorSpecifcCommandCompleteEvent
L2CAP_ConnParamUpdateReq
L2CAP_Init
L2CAP_ProcessEvent
L2CAP_SetUserConfig
L2CAP_BM_alloc
LL_DirectTestEnd
LL_DirectTestRxTest
LL_DirectTestTxTest
LL_ENC_Decrypt
LL_ENC_Encrypt
LL_EXT_BuildRevision
LL_EXT_ConnEventNotice
LL_EXT_EndModemTest
LL_EXT_ModemHopTestTx
LL_EXT_ModemTestRx
LL_EXT_ModemTestTx
LL_EXT_ComplNumPktsLimit
LL_EXT_SetLocalSupportedFeatures
LL_EXT_SetMaxDtmTxPower
LL_EXT_SetTxPower
LL_EncLtkNegReply
LL_EncLtkReply
LL_Init
LL_PM_Enter_AES
LL_PM_Exit_AES
LL_PM_GetRfCoreState
LL_PM_PowerOffRfCore
LL_ProcessEvent
LL_ReadRemoteUsedFeatures
LL_ReadRemoteUsedCompleteFeaturesBack
LL_ReadSupportedStates
LL_ReadTxPowerLevel
LL_Reset
LL_RxDataCompleteBack
LL_SetAdvControl
LL_SetAdvParam
LL_TxData
RFHAL_AddTxDataEntry
RFHAL_InitRfHal
SM_Init
SM_ProcessEvent
SM_Response 初始化
SysBootMsg
WL_CLEAR
WL_ClearIgnoreList
WL_FindEntry
WL_GetNumFreeEntry
WL_SetWlIgnore
clientCharCfgUUID
hciGapTaskID
hciL2capTaskID
hciSmpTaskID
hciTaskID
hciTestTaskID
linkDB_find
linkDB_getinfo
LinkDB_NumActive
LinkDB_NumConns
LinkDB_State
llActiveTask
llAdv_TaskConnect
llAdv_TaskEnd
llAllConnlocId
llAllocTask
llCheckWhiteListUsage
llConfigTable
llConnCleanup
llDequeCtrlPkt
llDirAdv_TaskEnd
llGetCurrentTime
llGetMinCI
llGetNextConn
llGetNextDataChan
llGetTask
llGetTaskState
llGetTxPower
llHaltRadio
llHardwareError
llInitFeatureSet
llInitRAT
llProcessChanMap
llProcessSlaveControlPacket
llProcessSlaveControlProcedures
llProcessTxData
llRatChanCBack_A
llReplaceCtrlPKT
llRfInit
llRfStartFS
llScheduleTask
llSchedulerInit
llSetNextDataChan
llSetTxPower
llSetupConnRxDataEntryQueue
llSetupFeatureSetRsp
llSetupNextSlaveEvent
llSetupRatChanCompare
llSetupStartEncReq
llSetupTermInd
llSlave_TaskEnd
llUserConfig
llWriteTxData
LL_buildRevision
trngDrvTblPtr
错误#10234-D:未解析的符号仍
存在错误#10010:链接期间遇到错误;"project_zero_stack_cc260.out"未生成
>>编译失败
makefile:190:目标'project_zero_stack_cc260.out'的配方失败
gmake[2]:***[project_zero_stack_cc260.out]错误1
gmakefile:***[makefile.1]]
针对
目标生成错误2:maked[maked:gmaked:gmaked]
目标“全部”的配方失败
****构建完成****
提前感谢。
    这是我关注的文档、很抱歉、我错过了上面的内容
    software-dl.ti.com/.../overview.html
    您好,Faizan,
    1) 1)您能否确保 CCS 工作区名称中没有空格?
    2) 2)您使用的是 BLE-Stack 的哪个版本?
    3) 3)您使用的是哪个版本的 SimpleLink Academy?
    感谢 Marie 的回复。
    我使用的是 Simple Academy v1.11
    我使用的是 BLE 堆栈 v2.01.18、因为 v2.02.2.25无法与上述教程配合使用。
    工作区路径中的目录名中有一个空格。 谢谢 Marie。
