[参考译文] CCS/CC2640R2F:CCS 8.2
Guru**** 2540720 points
Other Parts Discussed in Thread: CC2640
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/754583/ccs-cc2640r2f-ccs-8-2
器件型号:CC2640R2F
主题中讨论的其他器件:CC2640
工具/软件:Code Composer Studio
我在编译工程时遇到一些问题、请帮助我解决这个问题...
我试了很多次,但没有解决
****为 simple_peripheral_cc2640r2lp_app 构建配置 FlashROM_StackLibrary ****
"C:\\ti\\ccsv8\\utils\\bin\\gmake"-k -j 4 all -O
C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/../../../tools/blestacklib_search/lib_search F:/pooja/simple_peripheral_cc2640r2lp_app/TOOLS/build_config.optC:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/blelib C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/FlashROM_Library/lib_linker.cmd cc2640 C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/../../../tools/blestack/lib_search/lib_search.xml C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/symbols
Makefile:243:目标"预编译"的配方失败
Process_begin:CreateProcess (NULL、C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/../../../tools/blestacklib_search/lib_search F:/pooja/simple_peripheral_cc2640r2lp_app/TOOLS/build_config.optC:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/blelib C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/FlashROM_Library/lib_linker.cmd cc2640 C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/../../../tools/blestack/lib_search/lib_search.xml C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/symbols、...) 失败。
gmaking[1]:[预编译]错误2 (忽略)
编译文件:"../Application/simple_peripheral.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TAGES=3 --define=ICALL_STACK_RECOVERSION_CONFIGRATE=END=ICALL_PRIVERSION_ING_INDIAG_END=ICALABLE_PRIVERSION_END-PRIVACT_PRIVERICALL_COMPIENTIESD-CONFIGRAME_ENTRIBRATION-END=2-END=2-END=ICALL_PRIVEND=ICALL_PRIVERSION_END=ICALL_PRIVERSION_ING_ING_RAME_COMPUTER-ING_RATION-END-CONFIGRATE_CONFIGRATE_CONFIGRATE_END-CONFIGRATION-EXTRIBRATION-EXTRIBRATE_CONFIGRATE_END=ICAL=ICALL_PRICALL_PRICALL_PRIVEND /Application/simple_peripheral.c
>>编译失败
application/subdir_rules.mk:9:目标'Application/simple_peripheral.obj'的配方失败
"C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target/board.h ",第69行:致命错误#35:#ERROR 指令:"***ERROR***指定的电路板无效! 有关选项、请参阅 board.h。"
1在编译"../Application/simple_peripheral.c 时检测到灾难性错误。
编译已终止。
gmake.1]:***[Application/simple_peripheral.obj]错误1.
编译文件:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/icall.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TASK=3 --define=ICALL_STACK_CONFIGRATE=END=ICALL_PRIVATE_CONFIGRAME_CONFIGRATE=ICALABLE_CONFIGRATE_END-IN_END=ICALABLE_CONFIGRAME_END-CONFIGRATE=2-END-CONFIGRAME_CONFIGRAME_CONFIGRATE_END-CONFIGRATE=ICALABLE_CONFIGRATE_END-CONFIGRATE_END-CONFIGRATE_END-CONFIGRATE=ICALABLE_CONFIGRAME_END-CONFIGRATE=ICALABLE_CONFIGRATE_END-CONFIGRATE_END-CONFIGRATE_CONFIGRATE_END-CONFIGRATE=ICALABLE_CONFIGRATE-EXPLICALABLE_CONFIGRATE_END-CONFIGRATE=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/icall.c
>>编译失败
iCall/subdir_rules.mk:9:目标'iCall/iCall.obj 的配方失败
1在编译"C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/icall.c "时检测到灾难性错误。
编译已终止。
gmake.1]:***[iCall/iCall.obj]错误1.
编译文件:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm/PWMTimerCC26XX.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_EVIES --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_CMD_TAGERES=3 --define=ICALL_STACK_DEV_PRIVACK-INDISABLEM=END=ICALL_RIBRATE=CN=CN-CONFIGRATE_CONFIGRATE_RATE_RIBRATE_END-CONFIGRATE=2-END-CONFIGRATE_CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE_END-CONFIGRATE=END-CONFIGRATE_CONFIGRATE_END-CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_RICALL_PRICALL_PRICALP=ENDE-CONFIGRAME_CONFIGRAME_CONFIGRAME_RICALP=END=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm/PWMTimerCC26XX.c
完工:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm/PWMTimerCC26XX.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc/ADCCC26XX.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TAGES=3 --define=ICALL_STACK_DEV_PRIVACK-ENTIM=ICALL_CL_CONFIGRATED-CONFIGRAME_CONFIGRATE=END-CONFIGRATE_RATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE_RATE=END-CONFIGRATE_CONFIGRATE_CONFIGRATE_RATE=END-CONFIGRATE_CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE_CONFIGRATE=END-CONFIGRATE=END-CONFIGRATE_CONFIDEND-CONFIGRATE_CONFIGRATE_CONFIGRATE_EXPLICALABLE-EXPLICALABLE_PRIDEND-CONFIGEND-CONFIGEND-CONFIGRAP=END-CONFIGRA /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc/ADCCC26XX.c
完工:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc/ADCCC26XX.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/app/ble_user_config.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TAGES=3 --define=ICALL_STACK_CONFIGRATE=ICALL_PRIVEND=ICALABLE_CONFIGRAME_END-CONFIGRAME_END-CONFIGRATE=ICALABLE_CONFIGRAME_END-CONFIGRATE_END-CONFIGRATE=ICALABLE_CONFIGRAME_END-CONFIGRAME_END-CONFIGRATE=ICALABLE_CONFIGRAME_END-CONFIGRATE_END-CONFIGRATE_END-CONFIGRATE_END-CONFIGRATE_CONFIGRAME_CONFIGRAME_CONFIGRATE=ICL=ICALABLE_CONFIG-END-CONFIGRATE-END-CONFIGRATE-END-CONFIGRATE-END-CONFIG_CONFIG_CONFIG/END-CONFIG_CONFIGRATED-CONFIGRA /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/app/ble_user_config.c
>>编译失败
ICallBLE/subdir_rules.mk:9:目标'ICallBLE/ble_user_config.obj'的配方失败
1在编译"C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/app/ble_user_config.c "时检测到灾难性错误。
编译已终止。
gmake.1]:***[ICallBLE/ble_user_config.obj]错误1.
编译文件:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/icall_user_config.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TASK=3 --define=ICALL_STACK_CONFIGRATE=ICALL_PRIVATE_CONFIGRAME_END-CONFIGRAME_CONFIGRAME_CONFIGRATE=ICALL_CONFIGRATE_END-CONFIGRATE=ICALABLE_CONFIGRATE_END-CONFIGRATE_END-CONFIGRATE_END-CONFIGRATE_END-CONFIGRATE_CONFIGRAME_CONFIGRAME_CONFIGRAME_END-CONFIGRATE=ICALABLE_CONFIGRATE_END-CONFIGRATE_END-CONFIGRATE=ICALABLE_CONFIG/END-CONFIGRATE_CONFIG_CONFIGRATE=ICALABLE_CONFIGRATE_CONFIGRAME_END-CONFIGRATE_END-CONFIGRATE_CONFIGRATE_CONFIGRATE /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/icall_user_config.c
完工:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/icall_user_config.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/app/icall_api_lite.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TASK=3 --define=ICALL_STACK_EXTERMINUTE=ICALL_RAM=ICALLM_ENTIFUNIT_END-CONFIGRATE_IN_CONFIGRATE=ICALABLE_PRIVER-END=ICALABLE_CONFIGRAME_END-CONFIGRAME_END-CONFIGRAME_RATE_END-CONFIGRAME_END-CONFIGRAME_END-CONFIGRATE=ICL=ICALABLE_CONFIGRATE_END-CONFIGRATE-EXPLICL=ICALABLE_CONFIGRATE_END-CONFIGRATE-EXPLICL=ICALABLE_CONFIGRATE_END-CONFIGRATE-EXPLICALABLE_PRIVER-EXPLICLICLICLICLICLICL=ICLICLICLICLICL /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/app/icall_api_lite.c
完工:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/app/icall_api_lite.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/rf/RFCC26XX_singleMode.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TAGES=3 --define=ICALL_STACK_DIAGNOTE=ICALL_PRIVATE_CONFIGRAME_CONFIGRAME_ENDE-CONFIGRATE=END=ICALL_RATED-CONFIGRAME_RATE=END-CONFIGRATE_RICALPULES=2-END=2-END=ICALPULES=2-END-CONFIGRATE_CONFIGRATE_RATE_RATE_CONFIGRATE_RICALP=2-END-CONFIGRATE_RATE_END=END=ICALPLE-EXIT_CONFIGRATE_CONFIGRATE_RATE_END-CONFIGRATE_CONFIGRATE_RICALP=ICALP=END-CONFIGRATE=END-CONFIGRATE_END-CONFIGRATE_END-CONFIGRA /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/rf/RFCC26XX_singleMode.c
完工:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/rf/RFCC26XX_singleMode.c
编译文件:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info/cc26xx/devinfoservice.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TAGES=3 --define=ICALL_STACK_DEV_PRIVACT_PRIVACK-END=ICALCC_CONFIGRAME_CONFIGRATE=END-CONFIGRAME_END-CONFIGRATE=END-CONFIGRAME_CONFIGRATE=END-CONFIGRATE_CONFIGRATION-EXTER-END-CONFIGRATE_CONFIGRAME_CONFIGRATE=END-CONFIGRAME_CONFIGRATE_EXTER-EXTER-END-CONFIGRATE=END-CONFIGRATION-EXTER-EXTER-EXTER-EXTER-END-CONFIGRATE=ICALABLE_CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONF /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info/cc26xx/devinfoservice.c
完工:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info/cc26xx/devinfoservice.c
构建文件:"../SANDPUPPY_FITBELT_V2_application/app_scheduler.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_任务=3 --define=ICALL_STACK_PRIVATE_END=ENTI_COMPLETE=ICALL_RATE_ENTITY_ENTITY=ICALBLE_PRIVATE_CONFIGRAME_ENTRIBRAME_END-PRIVER-END-PRIVE_CONFIGRAME_END-PRIVERICL=ENTRICALL_PRIVERICL_END-PRIVERICL=END-PRIVE_CONFIGRAME_ENTRICL_END-PRIVERICL=ENTRICL_END-PRIVERICL_END-PRIVERICL_END-PRIVE_CONFIGRAME_ENTRICL=END-PRIVERICLICL_ENTRICLICLICLICLICLICL_END-PRIVERICL_END_BY=END_BU
>>编译失败
SANDPUPPY_FITBELT_V2_application/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_application/app_scheduler.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_application/app_scheduler.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_application/app_scheduler.obj]错误1.
编译文件:"../PROFILES/simple_gatt_profile.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TAGES=3 --define=ICALL_STACK_CONFIGRATE=END=RATE_CONFIGRATE_CONFIGRATE_END-PRIVERSION_CONFIGRAME_CONFIGRATE=END-CONFIGRAME_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGEND-CONFIGRATE_CONFIG/ENCE_CONFIGRATE_CONFIGRATE=ENCE_CONFIGRATE_CONFIGRATE=ENCE_CONFIGRATE_CONFIGENCE_PROFILE-EXTRENCE_CONFIGRATION-EXTER-EXPLICALABLE_PROFILE-EXTER-END-PRECT_PRECT_PRECT_PRECT_PRIVENCE_CONFIGES=ICALABLE_PRIVENTRICALABLE_PRIVENCE_CONFIGES /PROFILES/simple_gatt_profile.c
已完成构建:"./PROFILES/simple_gatt_profile.c
编译文件:"../PROFILES/gattservapp_util.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_CMD_TAGERES=3 --define=ICALL_STACK_PRIVATE_CONFIGRAME_CONFIGRAME_END=END=XALL_PRIVERICALABLE_PRIVERICALL_PRIVERICL_ENDE-ENDICALABLE_CONFIGRAME_ENDE-ENDE-ENDE-ENDULES=2-END=2-ENDICALABLE_CONFIGRAME_CONFIGRAME=2-END=2-END=2-END=ICALABLE_PRIVER-ENDICALL_PRECISTER-ING_RAME_END=2-ENTRIBRATION-END=2-END=ICALL_PRIVER.ABLE_PRIVERICALL_PRIVERICALL_PRECISTER-ING_RAME_ENDICALL_PRIVERICALABLE_CONFIG /PROFILES/gattservapp_util.c
已完成构建:"./PROFILES/gattservapp_util.c
构建文件:"../SANDPUPPY_FITBELT_V2_application/Hear_temp.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_任务=3 --define=ICALL_STACK_PRIVATE_END=ICALL_PRIVATE_END=END_BUDL_COMPLETE_ENTITY=2-ENTI_ENTITY=ICALL_PRIVATE_CONFIGRATE_END-PRIVATE_CONFIGRAME_END_BUPRIVERICL=2-END_BY=2-END_BUPRIVATE_CONFIGRATE_ENDICL=2-ENABLE_PRIVATE_CONFIGRAME_END_BUPRIVATE_CONFIGRAME_END=2-END=END_BUPRIVATE_CONFIGRATE_END=2-ENDICL=ENTRICLICL=ENTRICLICLICLICLICLICLICL=END-PRIVATTRICL=END-PRIVATE_
>>编译失败
SANDPUPPY_FITBELT_V2_application/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_application/hear_temp.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_application/HEAT_TEMP.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_application/HEAT_TEMP.obj]错误1.
构建文件:"../SANDPUPPY_FITBELT_V2_application/power_state.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_任务=3 --define=ICALL_STACK_CONFIGRATE=END_BUDL_PRIVATE_CONFIGRAME_END=END-PRIVE_CONFIGRAME_END=ICALL_PRIVERICALL_PRIVERICL_END_BY=END_BUPRIVATE_CONFIGRAME_END=2-ENABLE_PRIVATE_CONFIGRAME_END=2-END_BUPRIVATE_CONFIGRAME_END=2-ENABLE_PRIVERICLICLICLICLICL=2-END_BY=END_BUPRIVATE_CONFIGRAME_ENDICL=2-END_BUPRIVATTRICLICLICLICLICLICLICLICLICL=2-ENTRICLICL=2-ENTRICLICLIC
>>编译失败
SANDPUPPY_FITBELT_V2_application/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_application/power_state.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_application/power_state.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_application/power_state.obj]错误1.
构建文件:"../SANDPUPPY_FITBELT_V2_application/moture.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_CMD_TAGRIC=3 --define=ICALL_STACK_CONFIGRATE=END_BY=ENTI_PRIVATE_CONFIGRAME_END_BUDL=ENDULEST-END=ENTI_END_BY=ICALTXT_PRIVATE_CONFIGRATE_END_BY=2-END_BY=END_BUPRIVATTRY_END_BY=END_BUDL_END=END_BUDL_END=END=END_BUDL=END_BY=END_BY=END_BUDL=END_BY=END_BUDL=END_BY=END_BUDL_PRIVATTRY_BIST_END_BUDL=END=END=END_BY=END_BUDL=END_BY=END_BUDL
>>编译失败
SANDPUPPY_FITBELT_V2_application/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_application/motor.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_application/moter.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_application/moter.obj]错误1.
编译文件:"../PROFILES/peripheral.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TRES=3 --define=ICALL_STACK_DISABLEMLE_PRIVATE_CONFIGRAME_ENDE-CONFIGRAME_END=ICALL_PRIVERICALL_PRIVERICALABLE_CONFIGRAME_ENDE-ENTRIBRAME_ENDE-ENDE-CONFIGRAME=2-ENDE-ENDULESD-CONFIGRAME_CONFIGRAME_END=2-END=2-END=2-END=ICALABLE_CONFIGRAME_CONFIGRATION-EXTRIBRATION-END=2-END=ICALL_PRIVER.ABLE_PRIVER.ABLE_CONFIGRAME_CONFIGRATION-EXTRIBRATION-END=ICALL_PRIVEND=ICALL_PRIVEND=ICALL_PRIVENDICALL_PREC /PROFILES/peripheral.c
已完成构建:"./PROFILES/peripheral.c
构建文件:"../SANDPUPPY_FITBELT_V2_application/led.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_CMD_TAGRIC=3 --define=ICALL_STACK_CONFIGRATE=END-PRIVE_CONFIGRAME_CONFIGRATE=END-END-IN_CONFIGRAME_CONFIGRATE=END_BUPRIVEREND_BY=END_BY=ENDULEST-CONFIGRATE_END_BUDL=END=END_BY=END_BUDL_CONFIGRATE_END_BUPRIVATTRY_END=END=END_BY=ENDULEST-END=END_BY=END_BUDL=END=END_BUDL=END_BUDL_PRIVATTRY_BIST_PRIVATTRICL=END=END_BY=END=END_BUDL=END_BUPLICALP=END_BUDL
>>编译失败
SANDPUPPY_FITBELT_V2_application/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_application/led.obj 的配方失败
"C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target/board.h ",第69行:致命错误#35:#ERROR 指令:"***ERROR***指定的电路板无效! 有关选项、请参阅 board.h。"
1在编译"./SANDPUPPY_FITBELT_V2_application/led.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_application/led.obj]错误1.
构建文件:"../SANDPUPPY_FITBELT_V2_init/fitbele_init.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_EVENTS-define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TRES=3 --define=ICALL_STACK_CONFIGRATE=END=END_BY=ENTI_PRIVATE_INIT_END=END_BY=ICALL_PRIVATE_INIT_END_BU2-ENDCM_END=END=ICALP=2-END_BY=END_BY=END_BY=END_BUIT_END_BY=END=END_BU2-PRIVAT_END=END_BY=END=ICALP=END_BY=END_BY=END_BY=END_BU2-END_BUIT_COMPU2-END=END=END_BU2-END=END=ICALP=END_BU2-END_BU2-END=END_BY=END_BUIT_COMP
>>编译失败
SANDPUPPY_FITBELT_V2_init/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_init/fitbele_init.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_init/fitbele_init.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_init/fitbele_init.obj]错误1
构建文件:"../SANDPUPPY_FITBELT_V2_application/time.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_CMD_TAGRIC=3 --define=ICALL_STACK_CONFIGRATE_ENDULES=END-PRIVE_CONFIGRAME_CONFIGRAME_CONFIGRATE=END-PRECT_PRIVERICL_END_BY=END_BY=ENABLE_PRIVATE_CONFIGRAME_END_BY=2-END_BUPRIVATTRY_ERICL=2-END_BUPRIVATTRICL=END_BUPRIVATE_CONFIGGICLICL=END_BUPRIVATTRICL=ENT-END=END_BUPRIVATTRICL=END_BUDL_END_BUPRIVATTRICL=END_BUDL_ENDICLICLICLICLICLICLICLICL --END_BUEE=ENT-EN
>>编译失败
SANDPUPPY_FITBELT_V2_application/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_application/time.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_application/time.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_application/time.obj]错误1.
构建文件:"../SANDPUPPY_FITBELT_V2_SERVICES/Bluetooth_SERVICE.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_任务=3 --define=ICALL_STACK_PRIVATE_CONFIGRAME_END=ICALL_PRIVATE_END=END_BY=ENDCMT_PRIVATE_CONFIGRAME_END=2-END_BUPRIVATE_CONFIGRATE_END=2-END_BY=ICALL_PRIVATTRICLICL=2-END_BY=ENDCM_PRIVATTRICL=2-END_BY=END_BY=ICLICLICLICLICLICLICLICLICLICL=END_BY=ENTI_PRIVATTRICL=END_BY=2-PRIVATTRICL_PRIVATTRICLICLICLICEND=END=END=ENT-END=END_BY=END_BY=EN
>>编译失败
SANDPUPPY_FITBELT_V2_SERVICES/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_SERVICES/Bluetooth_SERVICE.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_SERVICES/Bluetooth_SERVICES.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_SERVICES/Bluetooth_SERVICE.obj]错误1
构建文件:"../SANDPUPPY_FITBELT_V2_SERVICES/batter_service.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_任务=3 --define=ICALL_STACK_PRIVATE_CONFIGRAME_END=END_BY=ICALL_PRIVATE_CONFIGRAME_EXITECT_PRECTOR_END=END_BY=END_BY=ICALL_PRIVATE_CONFIGRATE_PRIVATE_END=2-END_BY=2-ENDICLICLICLICLICLICLICL=END_BY=ENTI_PRIVATTRY_ERICLICLICL=END_BY=2-PRIVATE_CONFIGRATE_PRIVATE_CONFIGRATE_PRECTOR-ENTRICL=2-END=2-PRIVERICLICL=2-ENDICLICLICLICLICLICEND_BY=END_BY=ENTRICEND_BY
>>编译失败
SANDPUPPY_FITBELT_V2_SERVICES/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_SERVICES/batter_service.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_SERVICES/battery_service.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_SERVICES/battery_service.obj]错误1.
构建文件:"../SANDPUPPY_FITBELT_V2_SERVICES/MOTOR_SERVICE.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_任务=3 --define=ICALL_STACK_PRIVATE_CONFIGRAME_END=ICALL_PRIVATE_END=END_BY=ENDCMT_PRIVATE_CONFIGRAME_END=2-END_BUPRIVATE_CONFIGRATE_PRECTOR-END=2-END=END_BY=ICALL_PRIVATTRICL=END_BY=END_BY=END_BY=ENDCM_PRIVATTRICL=END_BY=END_BY=END_BUDL_PRIVATTRICLICL=ENDICL=2-PRIVATTRICL=END_BY=END_BY=ENDICLICLICLICLICLICLICLICLICLICLICL_PRIVATTRICK=END
>>编译失败
SANDPUPPY_FITBELT_V2_SERVICES/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_SERVICES/MOTOR_SERVICE.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_SERVICES/MOTOR_SERVICE.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_SERVICES/MOTOR_SERVICE.obj]错误1.
构建文件:"../SANDPUPPY_FITBELT_V2_SERVICES/button_service.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_任务=3 --define=ICALL_STACK_PRIVATE_CONFIGRAME_END=END_BY=ICALL_PRIVATE_CONFIGRAME_PRIVERS-END=END_BUPRIVATE_CONFIGRATE_PRIVATE_END=2-ENABLE_PRIVATE_END=2-END_BUPRIVATE_CONFIGRAME_PRIVERS-END=END_BUPRIVATTRICL=2-END_BY=ICL=ICALL_PRIVERICLICLICLICLICLICL_PRIVATE_ENDICLICLICL=2-ENDICL_PRIVATE_CONFIGRAME_PRIVERICL=2-ENDICLICLICLICLICL=2-ENTRICL_PRIVERICLICLICL=
>>编译失败
SANDPUPPY_FITBELT_V2_SERVICES/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_SERVICES/button_service.obj'的配方失败
"C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target/Board.h ",第69行:致命错误#35:#ERROR 指令:"***ERROR***指定的电路板无效! 有关选项、请参阅 board.h。"
1在编译"./SANDPUPPY_FITBELT_V2_SERVICES/button_service.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_SERVICES/button_service.obj]错误1.
构建文件:"../SANDPUPPPY_FITBELT_V2_SERVICES/POWER_CTRL_SERVICE.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TRES=3 --define=ICALL_STACK_PRIVATE_CONFIGRAME_ENTRIBRAM=END-CONFIGRATE_PRIVE_CONFIGRAME_END=END-PRIVERICALL_PRIVERICALL_PRIVERICL=ENTRIBRAME_END-PRIVE_CONFIGRAME_END-PRIVE_CONFIGRAME_PRIVER-END-CONFIGRAME_END-CONFIGRAME_END-CONFIGRAME_PRIVER-ENTRIBRAME_END-CONFIGRAME=END-CONFIGRAME_END-CONFIGRAME_END-CONFIGRATE_END-CONFIGRATE_END-CONFIGRAP=END-CONFIGRAME_PRIVER-ENTRICALP=END-CONFIGRAP=END-CONFIGRAME_END-PR
>>编译失败
SANDPUPPY_FITBELT_V2_SERVICES/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_SERVICES/POWER_CTRL_SERVICE.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_SERVICES/POWER_CTRL_SERVICE.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_SERVICES/POWER_CTRL_SERVICE.obj]错误1.
构建文件:"../SANDPUPPY_FITBELT_V2_SERVICES/SERVICE_RETERS.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_任务=3 --define=ICALL_STACK_PRIVERICL_COMPLETE=ENTIES=-ENTITY_CONFIGRATE_RATE_END-PRIVE_CONFIGRAME_ENTRIBRATE=END-PRIVERICALL_PRIVERICALL_PRIVERICL=END_BY=END_BY=ENDCM_PRIVATTRICL=END_BY=END-PRIVATTRICL=END-PRIVATE_CONFIGRAME_PRIVERICL_PRIVERICL=END_BY=END_BY=ENDICL=END_BY=ENDICL_PRIVATTRICLICLICLICLICL=END_BY=ENDICLICLICLICLICLICLICL_PRIVATTRICL=EN
>>编译失败
SANDPUPPY_FITBELT_V2_SERVICES/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_SERVICES/SERVICE_SCRTER.obj'的配方失败
1在编译"../SANDPUPPY_FITBELT_V2_SERVICES/SERVICE_SCRLETER.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_SERVICES/SERVICE_scheduler.obj]错误1.
构建文件:"../SANDPUPPY_FITBELT_V2_SERVICES/temp_service.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_任务=3 --define=ICALL_STACK_PRIVATE_CONFIGRAME_END=ICALL_PRIVATE_CONFIGRAME_ENTRIBRAME=END-PRIVE_CONFIGRAME_END-PRIVE_CONFIGRAME_END=END-PRIVERICALL_PRIVERICL=END_BY=END_BY=ENDCM_PRIVATE_CONFIGRAME_PRIVE_CONFIGRAME_PRIVERICL=2-ENTRICL=END-PRIVERICL=ENTRICALL_PRIVEND-PRIVERICL=END_BUPRIVE_CONFIGRAME_END_BUTER_PRIVENTRICL=2-ENTRICLICLICLICLICLICLICL=2-END-PRIVE_CONFIGRAME_PRIVEND
>>编译失败
SANDPUPPY_FITBELT_V2_SERVICES/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_SERVICES/temp_service.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_SERVICES/temp_service.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_SERVICES/temp_service.obj]错误1.
生成文件:"../SANDPUPPY_FITBELT_V2_SERVICES/serv_configurations.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_任务=3 --define=ICALL_STACK_PRIVATE_CONFIGRAME_ENTRIBRAME=END-PRIVE_CONFIGRAME_END_BY=ICALL_PRIVATE_CONFIGRATE_ENTRIBRATE=END-PRIVERS-END_BY=END-PRIVATE_CONFIGRAME_END_BY=END_BY=END_BUPRIVATE_CONFIGRATE_PRIVE_CONFIGEST-END=END_BUPRIVERICL=END_BY=ICL=END_BY=END_BY=END_BUPRIVATTRY_PRIVATE_CONFIGING_WITWIT_PRIVERS-PRIVATE_CONFIGEST-END=2-END_BY=2-END_BY=ICL=ICLICLICL=EN
>>编译失败
SANDPUPPY_FITBELT_V2_SERVICES/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_SERVICES/serv_configurations.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_SERVICES/serv_configurations.c"时检测到灾难性错误。
编译已终止。
gmake[1]:***[SANDPUPPY_FITBELT_V2_SERVICES/serv_configurations.obj]错误1
编译文件:"c:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target/board.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TRES=3 --define=ICALL_STACK_CONFIGRATE=END-CONFIGRATE=RIBRATE_END-CONFIGRATE=END-CONFIGRATE_CONFIGRATE_RATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIGRATE=END-CONFIGRATE_CONFIG /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target/board.c
>>编译失败
Startup/subdir_rules.mk:9:目标'startup / board.obj 的配方失败
"C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target/board.c ",第69行:致命错误#35:#ERROR 指令:"***ERROR***指定的电路板无效! 有关选项、请参阅 board.h。"
1在编译"C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target/board.c "时检测到灾难性错误。
编译已终止。
gmake.1]:***[Startup/board.obj]错误1.
编译文件:"../Startup/main.c
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_TRES=3 --define=ICALL_STACK_CONFIGRATE=END=END=XALL_PRIVATE_CONFIGRAME_ENDE-CONFIGRAME_ENDE-CONFIGRATE=2-ENDE-CONFIGRATE=2-ENDE-CONFIGRATE=ENDE-CONFIGRATE_RATE_ENDE-CONFIGRATE=2-ENDE-CONFIGRATE_END=END=ICALABLE_PRIVER.ABLE_CONFIGRATE_ENDE-CONFIGRATE_ENDE-CONFIGRATE_ENDE-CONFIGRATE=2-END=2-ENDE-CONFIGRATE=2-END=2-END=ICALL_PRIVENDICALL_PRIVENDICALP=2-ENDICALAB-ENDICALL_PRIVENDICALABLE_CONF /Startup/main.c
>>编译失败
Startup/subdir_rules.mk:16:目标'startup / main.obj 的配方失败
1在编译"../Startup/main.c 时检测到灾难性错误。
编译已终止。
gmake.1]:***[Startup/main.obj]错误1.
构建文件:"../SANDPUPPY_FITBELT_V2_SERVICES/Watchdog_service.c"
调用:ARM 编译器
"c:/ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/bin/armcl "-cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/build_components.opt "--cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/config/factory_config.opt "-cmd_file="C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/TOOLS/build_config.opt /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /pooja/simple_peripheral_cc2640r2lp_app/Startup /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/controller/cc26xx_r2/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/common/cc26xx /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/dev_info "-mv7M3 "-code_state=16 -me -O4 -opt_for_speed=0 -include_path="F:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT -include_path=/pooja/simple_peripheral_cc2640r2lp_app /pooja/simple_peripheral_cc2640r2lp_app/PROFILES /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/examples/rtos/CC2640R2_LAUNCHXL/blestack/simple_peripheral/src/app /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles/cc26xx -include:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES -f_path=/pooja/simple_peripheral_cc2640r2lp_app/Application /pooja/simple_peripheral_cc2640r2lp_app/Include /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/rom /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/roles -include: include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile/cc26xx --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/profiles/simple_profile --include_path="C:/pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_INIT --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/heapmgr /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/saddr /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_APPLICATION /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/pwm --include_path="C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/target/_common/cc26xx --include_display_path=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/hal/src/inc --include_display_use_display_b包括/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/icall/src/inc --include_display_path=/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/services/src/sdata --include_display_ctrade_display_be-ctrad.com.cn"/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/osal/src/inc /ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/devices/cc26x0r2 /pooja/simple_peripheral_cc2640r2lp_app/SANDPUPPY_FITBELT_V2_SERVICES /ti/ccsv8/tools/compiler/ti-cgt-arm_16.9.9.LTS/include --include_display_display_use_display_trad.com.cn"--include_display_be-ctrad.com.cn_cn_display_cn_cn_be_display_cn_be_display_by"--include_display_cn_be_display_cn_be_display_cn_be_be_display_trad.com.-cn_cn_cn_cn_cn_cn=C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/drivers/adc ---cn_band_define_display_trad.com.cn-cn_be_display_be_display_bote_display_.com.-cn_b.com.cn_cn-cn-cn-cn-cn-cn_cn_cn=C: define=ICALL_Events --define=ICALL_JT --define=ICALL_Lite --define=ICALL_MAX_NUM_ENTIES=6 --define=ICALL_MAX_NUM_任务=3 --define=ICALL_STACK_PRIVATE_CONFIGRAME_END=ICALL_PRIVATE_END=END_BY=ICALL_PRIVATE_CONFIGRAME_END=2-END_BY=ENDCM_PRIVATE_CONFIGRATE_END=2-PRIVEND=END_BY=ICALL_PRECTOR_PRIVEND_BY=ENDICALL_PRIVATE_CONFIGRATE_PRIVEND=2-ENDICLICLICLICLICLICLICL=2-END_BY=ENDICLICL=ENDICL=ENDICL=END_BY=END_BY=END_BY=END_BUTER_PRIVATCHICLICLICLICL=END_BY=ENDIC
>>编译失败
SANDPUPPY_FITBELT_V2_SERVICES/subdir_rules.mk:9:目标'ANDPUPPY_FITBELT_V2_SERVICES/watchdog_service.obj'的配方失败
1在编译"./SANDPUPPY_FITBELT_V2_SERVICES/Watchdog_service.c"时检测到灾难性错误。
编译已终止。
gmaked[1]:***[SANDPUPPY_FITBELT_V2_SERVICES/Watchdog_service.obj]错误1
gmake[1]:不会由于错误而重做目标'main-build'。
gmake:***[全部]错误2.
Makefile:205:目标'all'的配方失败
****构建完成****
    Pooja、
    [引用 user="pooja shete">C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/../../../tools/blestacklib_search/lib_search F:/pooja/simple_peripheral_cc2640r2lp_app/TOOLS/build_config.optC:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/blelib C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/FlashROM_Library/lib_linker.cmd cc2640 C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/../../../tools/blestack/lib_search/lib_search.xml C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/symbols
    Makefile:243:目标"预编译"的配方失败
    Process_begin:CreateProcess (NULL、C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/../../../tools/blestacklib_search/lib_search F:/pooja/simple_peripheral_cc2640r2lp_app/TOOLS/build_config.optC:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/blelib C:/Users/Pooja1/work111/simple_peripheral_cc2640r2lp_stack_library/FlashROM_Library/lib_linker.cmd cc2640 C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/../../../tools/blestack/lib_search/lib_search.xml C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/symbols、...) 失败。
    对于此错误、我在您的另一个主题中发布了一条建议 。 请继续该主题中的讨论。
    [引用 user="pooja shete">>编译失败
    application/subdir_rules.mk:9:目标'Application/simple_peripheral.obj'的配方失败
    在编译"../Application/simple_peripheral.c 中检测到1个灾难性错误。[/quot]
    对于此错误、您似乎没有为 board.h 中定义的电路板类型提供可识别的#defines 之一
     C:/ti/simplelink_cc2640r2_sdk_2_30_00_28/source/ti/blestack/target 目录中的默认 board.h 包含基于电路板定义的适当头文件。 我看到 您的构建选项中有--define=CC2640_PCB,但这不是默认 board.h 中定义的板之一 由于这似乎是一个修改后的项目、而不是开箱即用示例、我建议您检查您的项目是否需要使用不同的/自定义的 board.h
    由于我没有听到您的反馈,我假设您能够解决这个问题。 如果不是、请随时发布带有更新的回复。 谢谢!
