[参考译文] CCS/CC2640:gmake 错误
Guru**** 2529560 points
Other Parts Discussed in Thread: CC2640R2F
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/754610/ccs-cc2640-gmake-error
器件型号:CC2640
工具/软件:Code Composer Studio
大家好、我还面临这个问题 、我正在处理 cc2640r2f 和 CCS 8.2、
plz 帮助我
说明资源路径位置类型
说明资源路径位置类型
#35 #ERROR 指令:"***ERROR***指定的电路板无效! 有关选项、请参阅 board.h。" ccsproject /simple_peripheral_cc2640r2lp_app line 69、外部位置:C:\ti\simplelink_cc2640r2_sdk_2_30_00_28\source\ti\blestack\target\Board.h C/C++ problem
#35 #ERROR 指令:"***ERROR***指定的电路板无效! 有关选项、请参阅 board.h。" ccsproject /simple_peripheral_cc2640r2lp_app line 69、外部位置:C:\ti\simplelink_cc2640r2_sdk_2_30_00_28\source\ti\blestack\target\board.h C/C++ problem
#35 #ERROR 指令:"***ERROR***指定的电路板无效! 有关选项、请参阅 board.h。" Board.c /simple_peripheral_cc2640r2lp_app/启动行69 C/C++问题
gmake:***[All]错误2 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[Application/simple_peripheral.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[iCall/iCall.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[ICallBLE/ble_user_config.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_application/app_scheduler.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_application/heat_temp.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_application/led.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_application/motor.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_application/power_state.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_application/time.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_init/fitbelt_init.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_SERVICES/battery_service.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_services/bluetooth_service.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_SERVICES/button_service.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_services/motor_service.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_services/power_ctrl_service.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_SERVICES/serv_configurations.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_services/service_scheduler.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_SERVICES/temp_service.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[V2_services/watchdog_service.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[Startup/board.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:***[Startup/main.obj]错误1 simple_peripheral_cc2640r2lp_app C/C++问题
gmake[1]:不会由于错误而重做目标'main-build'。 simple_peripheral_cc2640r2lp_app C/C++问题
无效的工程路径:引用的工程不是 C/C++工程。 simple_peripheral_cc2640r2lp_app 路径入口路径问题
请回复我将采取哪些措施来解决此问题
    大家好、pooja、
    您是否正在使用 LAUNCHXL-CC2642R2? 如果是、则必须在项目设置中设置定义 CC2640R2_LAUNCHXL。
