[参考译文] CCS/CODECOMPOSER:CODECMOSER
Guru**** 2616395 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/649863/ccs-codecomposer-codecomposer
器件型号:CODECOMPOSER
工具/软件:Code Composer Studio
我正在尝试在我的计算机中安装 Code Composer 软件、但无论我尝试使用联机还是脱机软件包、我始终会得到相同的结果、这是安装失败。 我附加了我每次收到的消息和日志。
!会议2017-12-13 17:36:17.320 ---------------
Eclipse.buildId=
java.version=1.8.0_112
java.vendor=Oracle Corporation
引导加载程序常量:OS=Win32、ARCH=x86、WS=Win32、NL=ES_ES
框架参数:-application org.eclipse.equinox.p2.director -存储库文件:/c:/ti/ccsv7/eclipse/downloads/featurerepo、software-dl.ti.com/.../eclipserepo -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group,org.eclipse.gmf.runtime.thirdparty.feature.group -roaming -uninstalliu org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group,org.eclipse.gmf.runtime.thirdparty.feature.group
命令行参数:-OS Win32 -ws Win32 -arch x86 -data C:/Users/NICO/AppData/Local/Temp/ccs_1fc4474e-0575-4ddb-616d-26818acf662c/workspace -application org.eclipse.equinox.p2.director -repository file:/c:/ti/ccsv7/eclipse/downloads/featurerepo、software-dl.ti.com/.../eclipserepo -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group,org.eclipse.gmf.runtime.thirdparty.feature.group -roaming -uninstalliu org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group,org.eclipse.gmf.runtime.thirdparty.feature.group
!entry org.eclipse.equinox.app 0 2017-12-13 17:36:21.364
!找不到产品消息。
!entry org.eclipse.equinox.p2.director.app 4 0 2017-12-13 17:36:26.202
!消息“The installable unit org.eclipse.platform.ide has not been found (未找到可安装单元)”。
!会议2017-12-13 17:36:37.283 ------------------
Eclipse.buildId=
!entry org.eclipse.equinox.app 0 2017-12-13 17:36:40.352
!找不到产品消息。
!entry org.eclipse.equinox.p2.director.app 4 0 2017-12-13 17:36:42.710
    尊敬的 David:
    您能否提供安装日志?
    processors.wiki.ti.com/.../Troubleshooting_CCSv7
    此外、您尝试安装的是哪个确切版本的 CCS? 您将会对哪些主机操作系统进行分级(我看到了一些 Windows 版本)?
    Ki
    尊敬的 David:
    另一件事是、似乎您没有在清理文件夹中安装 CCS (看起来您尝试在预先存在的安装尝试的位置安装 CCS)。 如果是这种情况、您能否确保您尝试在全新的位置安装?
    Ki
    您好 Ki、
    实际上、正如您所说的、它可以正常工作、因为我尝试将程序安装在一个旧文件夹中。
    感谢你的帮助
    David
    很高兴听到它正在工作。 感谢您的更新!
    Ki
