[参考译文] 编译器/处理器 SDK-AM437X:Linux 编译错误- hexpru 具有内部不一致并中止
Guru**** 2387830 points
Other Parts Discussed in Thread: REMOTI
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/669856/compiler-processor-sdk-am437x-linux-build-error---hexpru-had-an-internal-inconsistency-and-aborted
器件型号:PROCESSOR-SDK-AM437X
工具/软件:TI C/C++编译器
我将按照网站文档中描述的流程测试为 AM437x 入门套件构建 Linux 的过程。
我运行命令 machine=AM437X-EVM bitbake Arago-core-tisdk-image 以开始该过程。  在下载软件包的过程中、我确实遇到了问题、我通过更新镜像和下载软件包来解决该问题、但该问题仍然存在。
当前的问题是我遇到以下错误:
错误:ICSS-EMAC-LLD-RTOS-01.00.00.10A-r0.0 DO 编译:函数失败:DO 编译(日志文件位于/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/temp/log.do_compile.23585上)
错误:故障日志文件存储在:/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/temp/log.do_compile.23585中
当我查看引用的日志文件时、我看到最下面的内容:
编号
#将输出接头生成到 AM437X:PRU_0:ICSS_dualemac 到/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.bin...
编号
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/pruss/PRU0_REV1_to_ARM.cmd /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0.out -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.bin
*** Error in `/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru:free():invalid next size (Fast):0x09753010***
内部错误:/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru 存在内部不一致并中止
这是由 TI 十六进制转换器中的缺陷导致的。
TI 客户支持可能会建议解决方法来避免这种情况。
升级到编译器的最新版本可能会解决此问题。
在 E2E 支持论坛中联系 TI、网址 为 http://e2e.ti.com 、位于
"开发工具"、"TI C/C++编译器"。 请参阅标题为的链接
"提交问题"。
我们需要看到整个错误消息和完整的可重现性
包括所有命令行选项的测试用例。
我曾看到过其他几个错误情况,但情况不同。  我的同事在专用的 Linux 盒上构建此套件、没有这些问题。  我在 Windows 托管的 VM 上运行、我们都有 Ubuntu 16.04 +最新更新。
设置和准备环境的过程涉及多个 TI 文档、因此可能会错过该过程中的一个步骤、因此我希望此特定错误会指向最佳查看位置。
我将粘贴下面 log.do_compile.23585的整个内容以完成。  由于这需要一段时间、我将开始构建基本映像的过程、并查看结果是否相同。
谢谢、Pete
log.do_compile.23585的内容:
调试:执行 shell 函数 DO 编译
使 libcore SOC=AM437X
make[1]:输入目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac
使 lib_allenaans core=a9host build_profile_a9host=release
make[2]:输入目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac
使 COMP_LIBS ENDIAN=LIT
make[3]:输入目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac
使-C /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac -f build/makefile.mk
make[4]:输入目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps
#编译 AM437X:a9host:release:ICSS_EMAC:src/ICSS_emacDrv.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacDrv.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-ti-pdk/build-linux/rtos-r-r-linux/em-linux-rec-r-r-r-r.prue/em-linux-uni-r.pr-linux/am-r437x-pru/am-un-pru.prue-pr-r-linux/am-linux-pru.pru./am-r./am-linux-un-pru.prue-prue-prui-linux-pru.pru.pru.pru.pru.prue/em-linux/am-linux-pru.pru.pru.pru.pru.pru.pr-/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacDrv.oa9fg
#编译 AM437x:a9host:release:ICSS_EMAC:src/ICSS_emacFwInit.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacFwInit.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-ti-pdk/build-linux/rtos/ina-pr-linux/ine-pr-linux/em-uniec-pr-linux/am-pr-un-prue/em-linux-pr-un-prue/em-prue-prue-prue/em-r.prue-linux-r4pk/am-linux-un-pru.pru.pru./am-r.pru.pru.prue-pr-r-linux/am-r.pru.pru.pru.prue-linux/am-linux/am-un-pru.pru.pru.pru.pru.pru.//home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacFwInit.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC:src/ICSS_emacLearning.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacLearning.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437x-evms/share/ti-tisdk-tree/packages -i/home/armac/em-linux-r-linux/em-r-r-linux/em-board-em-em-linux/em-un-r.pr-em-linux/em-em-un-r-r.pr-em-uni-sdk/em-r-r-r-r./am-linux/em-un-r.pr-em-linux/em-em-em-un-r.pr-em-un-r-r.pr-linux/em-r.pr-r.ec/em-r./am-r-r.pr-un-sdk/am-r /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacLearning.oa9fg
#编译 AM437x:a9host:release:ICSS_EMAC:src/ICSS_emacStatistic.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacStatistics.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437x-evms/share/ti-tisdk-tree/packages -i/home/arm-linux/em-linux-outi-pr-linux/em-pr-em-un-r.prue/em-linux-em-em-un-pr-un-r.prue/em-linux-em-em-un-pruat/am-un-pr-em-un-un-r.pr-sdk/am-r-r./am-r.pr-linux/am-un-un-r.pr-un-r.pr-r.pr-linux/am-r.pr-un-em-r.pr-un-r.pr-uni-r.ec /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacStatistics.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC:src/ICSS_emacStormControl.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacStormControl.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-外部 linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-pdk-tree/packages -i/home/arm-linux/rtos-r-r-linux/em-r-r-r-rec-r-r-r-linux/em-r.pru/am-linux/em-un-pr-r4p-rk/em-r-r-r-r-linux/em-r-rk/em-r-r-r.pr-r-linux/em-un-linux/em-un-r.pr-r.pr-r.pr-r.pr-linux/em-r-r-r.pr-r.ec/em-r-r-r-r-r-r.pr-r./home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacStormControl.oa9fg
#编译 AM437x:a9host:release:ICSS_EMAC:src/ICSS_emacLoc.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacLoc.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437x-evms/share/ti-tisdk-tree/packages -i/home/arm-linux/rtos-linux-linux/em-linux-r-r-r.pr-un-prue/em-linux-un-pr-prue/em-un-pr-r.pr-r.prue/em-r-r-linux/am-linux-un-pr-r4pk/am-un-sdk/am-un-r.pr-linux-r.pr-un-pr-un-pr-un-pr-r.pr-am-r.pr-un-r./am-r.ec/am-un-sdk/am-am-am-r /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacLoc.oa9fg
#编译 AM437X:a9HOST:release:ICSS_EMAC:SoC/AM437X/ICSS_em375.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacSoc.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -isc -isOC -emi/ubuntue/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/am437x-evms/ti/ti-dpdk/ti-tree/packages -i/home/arm-linux-out-linux/rtos-r-r-linux/em-r-r-r-r-r-r-r-linux/em-linux/em-uni-linux/em-un-rk/em-linux-r-r-r-rk/em-un-un-r-un-rk/em-r-linux-r-r-r-r-rk/em-un-rk/em-r4pi-f-r-un-r.ec/em-r-r-r-r-rk/em-r-r-r-r-r-r-/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacSoc.oa9fg
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/am437x/a9/release
编号
#存档 AM437X:a9host: release:ICSS_EMAC 到/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/am437x/a9/release/ti.drv.icss_emac.aa9fg ...
编号
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar CR /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/am437x/a9/release/ti.drv.icss_emac.aa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacDrv.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacFwInit.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacLearning.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacStatistics.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacStormControl.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacLoc.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacSoc.oa9fg
make[4]:离开目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac
使-C /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac -f build/makefile_indp.mk
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps
#编译 AM437X:a9host:release:ICSS_EMAC_indp:src/ICSS_emacDrv.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacDrv.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -isrc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-pdk-tree/packages -i/build-/ti-linux/ti-processor-linux/em-out-linux/em-sdk/inc/inc/inc/inc-pr-linux-linux-out/em-linux-sdk/em-linux-out/em-linux/em-linux-out-linux/em-/em-linux-out-rpm-01.00.01.00/em-linux/em-linux/em-memb./em-membr/em-linux/em-linux/em-memb./em-linux/em-linux-linux-memb./em-linux/em-memb.ecs/em-linux/em-em-em-em-memb.ecs/em-em-em-em-linux-sdk/em-em-/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacDrv.oa9fg
#编译 AM437x:a9host:release:ICSS_EMAC_indp:src/ICSS_emacFwInit.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacFwInit.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -irc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/am437x-evm/usr/share/ti-pdk-tree/packages -i/build/ti-linux/ti-processor-linux/em-out-pr-linux/em-out-linux-linux/em-sdk/em-out-linux/inc/inc/em-linux-out-linux-linux-out-remapps/inc/inc/inc/inc/ina-remapps-01.000/em-linux-linux-pr-linux-pr-em-linux-em-em-em-em-pr-em-em-em-out/em-linux/inc/inc/inc/inc/inc/inc/in-linux-pr-pr-sdk/em-pr-linux-sdk/em-linux-pr-pr-linux-em-em-pr-em-em-pr-sdk/em-em-em-em /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacFwInit.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC_indp:src/ICSS_emacLearning.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacLearning.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -irc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/am437x-evm/usr/share/ti-pdk-tree/packages -i/build/ti-linux/ti-board-linux-board-linux/em-linux/em-out-linux-memors/em-linux-board/em-memb-01.000/em-linux-em-em-em-em-board/inc/inc/inc/inc/inc/inc/inc-linux-linux-em-linux-memb.pr-em-em-sdk/em-em-em-em-em-em-em-linux/em-linux-em-em-em-linux-em-out/em-sdk/em-board/em-em-em-em-linux-em-em-em-em-em-em-em-em-linux/em-sdk/em-em-em-em-linux /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacLearning.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC_indp:src/ICSS_emacStatistics
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacStatistics.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -isrc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-pdk-tree/packages -i/build/ti-linux/ti-processor-linux-out/em-linux-out/em-linux-membr/em-ecs/em-linux-out/em-out-linux/em-out-linux/em-membr/em-ecs/em-/em-linux-out-mem/em-linux-out-mem/em-linux-mem/em-out-mem/em-linux-mem/em-linux-out-mem/em-pr-mem/em-linux-out-mem/em-r.01.000/em-mem/em-mem/em-linux/em-em-em-em-mem/em-em-memb.pr-memb./em-em-mem/em-linux/em-mem /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacStatistics.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC_indp:src/ICSS_emacStormControl.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacStormControl.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -isrc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-pdk-tree/packages -i/build/ti-linux/ti-processor-linux-out/em-linux-board/em-linux-memb-01.000/em-em-linux/inc/intrads/em-linux-em-em-membr/em-linux-em-linux/em-em-linux/em-em-em-em-linux/em-em-em-em-memb-01.000/em-em-memb.ecs/em-linux-em-em-em-em-em-linux/inc/inc/inc/inc/intrab-linux-em-linux-em-em-em-sdk/em-em-em-em-em-em-em-em-em-em-pr-linux-em-em-em-em-/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacStormControl.oa9fg
#编译 AM437x:a9host:release:ICSS_EMAC_indp:src/ICSS_emacLoc.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacLoc.P -DMakEFILE_Build -Wintime-Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtetex=cortex-A9 -ex-exampl=armv7-a -mfpu -mpu-abi-floate-s/sec-linux-remoti/linux-board-remotie-from-board-remotie-from-linux-remotie/tex-linux-board-remoti-remotie-from-linux-remotie/tex-remotie-from-linux-remotie-from-board-remotie-from-linux-remotie/tex-remoti-remoti-remotie-linux-remotie-from-linux-remotie/tex-remotie-from-remotie-from-linux-remotie-from-remotie-from-board -irc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/ti-pdk-tree/packages -i/home/ubuart/ti-linux-processor-linux-out/em-linux-linux-out/em-linux-linux-out/em-linux-remapps/em-out-linux-out-linux-out-linux/em-linux-out-out-sdk/em-/em-linux-remapps/inc/inc/inc/inc/-linux-linux-linux-pr-out-pr-sdk/em-pr-pr-/em-linux-/em-out-linux-out-pr-pr-/em-/em-sdk/em-linux-/em-/em-linux-out-/em-pr-/em-linux-linux-out-pr-/em-pr-pr-linux-/em-/em /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacLoc.oa9fg
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/a9/release
编号
#存档 AM437X:a9host:release:ICSS_EMAC_indp 到/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/a9/release/ti.drv.icss_emac.aa9fg ...
编号
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar CR /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/a9/release/ti.drv.icss_emac.aa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacDrv.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacFwInit.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacLearning.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacStatistics.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacStormControl.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacLoc.oa9fg
使-C /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac -f build/makefile_profile.mk
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps
#编译 AM437X:a9host:release:ICSS_EMAC_profile:src/ICSS_emacDrv.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacDrv.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-ti-pdk/build-linux/rtos-r-r-linux/em-linux-rec-r-r-r-r.prue/em-linux-uni-r.pr-linux/am-r437x-pru/am-un-pru.prue-pr-r-linux/am-linux-pru.pru./am-r./am-linux-un-pru.prue-prue-prui-linux-pru.pru.pru.pru.pru.prue/em-linux/am-linux-pru.pru.pru.pru.pru.pru.pr-/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacDrv.oa9fg
#编译 AM437x:a9host:release:ICSS_EMAC_profile:src/ICSS_emacFwInit.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacFwInit.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-ti-pdk/build-linux/rtos/ina-pr-linux/ine-pr-linux/em-uniec-pr-linux/am-pr-un-prue/em-linux-pr-un-prue/em-prue-prue-prue/em-r.prue-linux-r4pk/am-linux-un-pru.pru.pru./am-r.pru.pru.prue-pr-r-linux/am-r.pru.pru.pru.prue-linux/am-linux/am-un-pru.pru.pru.pru.pru.pru.//home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacFwInit.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC_profile:src/ICSS_emacLearning.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacLearning.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437x-evms/share/ti-tisdk-tree/packages -i/home/armac/em-linux-r-linux/em-r-r-linux/em-board-em-em-linux/em-un-r.pr-em-linux/em-em-un-r-r.pr-em-uni-sdk/em-r-r-r-r./am-linux/em-un-r.pr-em-linux/em-em-em-un-r.pr-em-un-r-r.pr-linux/em-r.pr-r.ec/em-r./am-r-r.pr-un-sdk/am-r /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacLearning.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC_profile:src/ICSS_emacStatistics
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacStatistics.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437x-evms/share/ti-tisdk-tree/packages -i/home/arm-linux/em-linux-outi-pr-linux/em-pr-em-un-r.prue/em-linux-em-em-un-pr-un-r.prue/em-linux-em-em-un-pruat/am-un-pr-em-un-un-r.pr-sdk/am-r-r./am-r.pr-linux/am-un-un-r.pr-un-r.pr-r.pr-linux/am-r.pr-un-em-r.pr-un-r.pr-uni-r.ec /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacStatistics.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC_profile:src/ICSS_emacStormControl.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacStormControl.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-外部 linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-pdk-tree/packages -i/home/arm-linux/rtos-r-r-linux/em-r-r-r-rec-r-r-r-linux/em-r.pru/am-linux/em-un-pr-r4p-rk/em-r-r-r-r-linux/em-r-rk/em-r-r-r.pr-r-linux/em-un-linux/em-un-r.pr-r.pr-r.pr-r.pr-linux/em-r-r-r.pr-r.ec/em-r-r-r-r-r-r.pr-r./home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacStormControl.oa9fg
#编译 AM437x:a9host:release:ICSS_EMAC_profile:src/ICSS_emacLoc.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacLoc.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -irc -isoc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437x-evms/share/ti-tisdk-tree/packages -i/home/arm-linux/rtos-linux-linux/em-linux-r-r-r.pr-un-prue/em-linux-un-pr-prue/em-un-pr-r.pr-r.prue/em-r-r-linux/am-linux-un-pr-r4pk/am-un-sdk/am-un-r.pr-linux-r.pr-un-pr-un-pr-un-pr-r.pr-am-r.pr-un-r./am-r.ec/am-un-sdk/am-am-am-r /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacLoc.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC_profile:SoC/AM437X/ICSS_emac3.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacSoc.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -isc -isOC -emi/ubuntue/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/am437x-evms/ti/ti-dpdk/ti-tree/packages -i/home/arm-linux-out-linux/rtos-r-r-linux/em-r-r-r-r-r-r-r-linux/em-linux/em-uni-linux/em-un-rk/em-linux-r-r-r-rk/em-un-un-r-un-rk/em-r-linux-r-r-r-r-rk/em-un-rk/em-r4pi-f-r-un-r.ec/em-r-r-r-r-rk/em-r-r-r-r-r-r-/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacSoc.oa9fg
编号
#存档 AM437X:a9host:release:ICSS_EMAC_profile 到/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/am437x/a9/release/ti.drv.icss_emac.profiling.aa9fg ...
编号
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar CR /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/am437x/a9/release/ti.drv.icss_emac.profiling.aa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacDrv.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacFwInit.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacLearning.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacStatistics.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacStormControl.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacLoc.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacSoc.oa9fg
使-C /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac -f build/makefile_profile_indp.mk
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps
#编译 AM437X:a9host:release:ICSS_EMAC_PROFILE_INTP:src/ICSS_emacDrv.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacDrv.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -isrc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-pdk-tree/packages -i/build-/ti-linux/ti-processor-linux/em-out-linux/em-sdk/inc/inc/inc/inc-pr-linux-linux-out/em-linux-sdk/em-linux-out/em-linux/em-linux-out-linux/em-/em-linux-out-rpm-01.00.01.00/em-linux/em-linux/em-memb./em-membr/em-linux/em-linux/em-memb./em-linux/em-linux-linux-memb./em-linux/em-memb.ecs/em-linux/em-em-em-em-memb.ecs/em-em-em-em-linux-sdk/em-em-/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacDrv.oa9fg
#编译 AM437x:a9host:release:ICSS_EMAC_PROFILE_INPP:src/ICSS_emacFwInit.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacFwInit.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -irc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/am437x-evm/usr/share/ti-pdk-tree/packages -i/build/ti-linux/ti-processor-linux/em-out-pr-linux/em-out-linux-linux/em-sdk/em-out-linux/inc/inc/em-linux-out-linux-linux-out-remapps/inc/inc/inc/inc/ina-remapps-01.000/em-linux-linux-pr-linux-pr-em-linux-em-em-em-em-pr-em-em-em-out/em-linux/inc/inc/inc/inc/inc/inc/in-linux-pr-pr-sdk/em-pr-linux-sdk/em-linux-pr-pr-linux-em-em-pr-em-em-pr-sdk/em-em-em-em /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacFwInit.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC_PROFILE_INTP:src/ICSS_emacLearning.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacLearning.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -irc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/am437x-evm/usr/share/ti-pdk-tree/packages -i/build/ti-linux/ti-board-linux-board-linux/em-linux/em-out-linux-memors/em-linux-board/em-memb-01.000/em-linux-em-em-em-em-board/inc/inc/inc/inc/inc/inc/inc-linux-linux-em-linux-memb.pr-em-em-sdk/em-em-em-em-em-em-em-linux/em-linux-em-em-em-linux-em-out/em-sdk/em-board/em-em-em-em-linux-em-em-em-em-em-em-em-em-linux/em-sdk/em-em-em-em-linux /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacLearning.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC_PROFILE_INTP:src/ICSS_emacStatistics
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacStatistics.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -isrc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-pdk-tree/packages -i/build/ti-linux/ti-processor-linux-out/em-linux-out/em-linux-membr/em-ecs/em-linux-out/em-out-linux/em-out-linux/em-membr/em-ecs/em-/em-linux-out-mem/em-linux-out-mem/em-linux-mem/em-out-mem/em-linux-mem/em-linux-out-mem/em-pr-mem/em-linux-out-mem/em-r.01.000/em-mem/em-mem/em-linux/em-em-em-em-mem/em-em-memb.pr-memb./em-em-mem/em-linux/em-mem /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacStatistics.oa9fg
#编译 AM437X:a9host:release:ICSS_EMAC_PROFILE_INTP:src/ICSS_emacStormControl.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacStormControl.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -isrc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/usr/share/ti-pdk-tree/packages -i/build/ti-linux/ti-processor-linux-out/em-linux-board/em-linux-memb-01.000/em-em-linux/inc/intrads/em-linux-em-em-membr/em-linux-em-linux/em-em-linux/em-em-em-em-linux/em-em-em-em-memb-01.000/em-em-memb.ecs/em-linux-em-em-em-em-em-linux/inc/inc/inc/inc/intrab-linux-em-linux-em-em-em-sdk/em-em-em-em-em-em-em-em-em-em-pr-linux-em-em-em-em-/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacStormControl.oa9fg
#编译 AM437x:a9host:release:ICSS_EMAC_PROFILE_INTP:src/ICSS_emacLoc.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -md -mf /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacLoc.P -DMakEFILE_Build -Wintent -Wall -Wunused -Wunknown-pragma -ffunion-SECTIONS -mlong-calls -fdata-c -mcpu=cortex-A9 -g -mtex=cortex-A9 -March =armv7-a -mfpuart=mfloate-SECTIONS -mex-mex-linux-data-remotie/armboti-ex-linux-data-from-remotie-from-remoti/linux-data-from-remotie-from-remoti-remoti-remotie/arm-linux-core-from-remotie-from-remotie-from-corpf-ne-from-cortex-core-from-ec-core-from-core/tex-cortex-cortex-ex-ex-ex-ex-ex-ex-cortex-ex-ex-mex-ex-ex-ex-ex-ex-cortex-m -irc -i/home/ubuntuart/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-external_linaro-toolchain/sysroot/AM437X-evm/ti-pdk-tree/packages -i/home/ubuart/ti-linux-processor-linux-out/em-linux-linux-out/em-linux-linux-out/em-linux-remapps/em-out-linux-out-linux-out-linux/em-linux-out-out-sdk/em-/em-linux-remapps/inc/inc/inc/inc/-linux-linux-linux-pr-out-pr-sdk/em-pr-pr-/em-linux-/em-out-linux-out-pr-pr-/em-/em-sdk/em-linux-/em-/em-linux-out-/em-pr-/em-linux-linux-out-pr-/em-pr-pr-linux-/em-/em /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacLoc.oa9fg
编号
#存档 AM437X:a9host:release:ICSS_EMAC_PROFILE_INPP 到/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/a9/release/ti.drv.icss_emac.profiling.aa9fg ...
编号
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar CR /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/a9/release/ti.drv.icss_emac.profiling.aa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacDrv.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacFwInit.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacLearning.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacStatistics.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacStormControl.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacLoc.oa9fg
make[3]:离开目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac
make[2]:离开目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac
make[1]:离开目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac
使固件内核 SOC=AM437X
make[1]:输入目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac
使 firm_allhostcores core=PRU_0
make[2]:输入目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac
使 fire_allversion HOSTCORe=a9host
make[3]:输入目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac
使 COMP_FIRM PRUVERSION=REV1
使-C /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac -f ./../build/makefile_icss_dualemac.mk 成为文件
make[5]:输入目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/.deps
#编译 AM437X:PRU_0:ICSS_DUALUemac:src/micro_scheduler.asm
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru -DMakEFILE_Build -v3 -g -endian=little -DICSS_REV1 --diag_wrap=off --diag_warning=225 --display_error_number --hardware_mac=on --predk_with_compile -eo.op.op.opu -dpruu0-dpruuat_-dicu.micro-linux/remoti_super -linux/doctex-super -superver/spru.micro-linux/linux-superver.micro-board/docs/-superver.micro-linux/linux-superver/spru.micro-superver/spru.micro-linux/linux-superver.micro-board/linux-superver/spru.micro-r.micro-rfr -superver/spru.micro-superver/spru.micro-linux/linux/docs -r.micro-r.micro-r.micro-superver/spru.micro-dr -r.micro-r.micro-rfr -r /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0
#编译 AM437X:PRU_0:ICSS_dualemac:src/EMAC_MII_Rcv.asm
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru -DMakEFILE_Build -v3 -g -endian=little -DICSS_REV1 --diag_wrap=off --diag_warning=225 --display_error_number --hardware_mac=on --predk_with_compile -eo.op.opu -dpru0 -dpru0 -dicu_runtime_linux/remoti_dex-supervisu.micro-linux/docs/subtrack-linux-supervisor/linux-supervisor.micro-supervisor/cc-rf.micro-linux/cc64_remoti_demv-linux-rfr -super -linux/cc-supervisor.micro-linux-r.micro-supervisor/cc-super -linux-rf.micro-super -super -super -super -linux/cc-super -super -super -rfr -rf.micro-rfr -linux/rtspru.micro-r.micro-r.micro-r.micro-r /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0
#编译 AM437X:PRU_0:ICSS_dualemac:src/EMAC_MII_XMT.asm
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru -DMakEFILE_Build -v3 -g -endian=little -DICSS_REV1 --diag_wrap=off --diag_warning=225 --display_error_number --hardware_mac=on --predk_with_compile -eo.op.opu -dpru0 -dpru0 -dicu0=-dcs_remoti_linux/remoti_linux-super -supervisor/cc6_demtex-linux/linux-supervisori_dembr/linux-supervisor/cc-super -super -linux/docs -linux-super -supervisor/linux-supervisor/docs -linux-supervisor/linux-supervisor/docs -supervisor/linux-supervisor/linux-supervisor/docs -supervisor/linux-super -supervisor/docs -supervisor/linux-supervisor/linux-super -supervisor/rtspru.pr /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0
#编译 AM437X:PRU_0:ICSS_dualemac:src/emac_statistic.asm
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru -DMakEFILE_Build -v3 -g -endian=little -DICSS_REV1 --diag_wrap=off --diag_warning=225 --display_error_number --hardware_mac=on --predk_with_compile -eo.op.opu -dpru0 -dpru0 -dicu0=-225 -display_error_example_linux/docs/subtradem-linux-supervisdspirtisdc/包含-statistic/cc-linux-statistics/r-supervisdcp./linux-supervisdr -supervisdr -linux/docs/linux-statistic/linux-statistic/docs/r.pru.ts/spru.ts=-super /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 -super -linux-super /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 -super -super -super -supervisors/spru.pru.pru.pru.pruatures/spru./linux/linux/linux-statistic/linux-statistic/linux-super -sup
#编译 AM437X:PRU_0:ICSS_dualemac:src/EMAC_TTS.asm
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru -DMakEFILE_Build -v3 -g -endian=little -dicss_REV1 -diag_wrap=off -diag_warning=225 -display_error_number -hardware_mac=on -predk_with_compile -eo.op.opu -dpru0 -dpru0 -dicu0=-225 -display_error_ex-processor_linux/remoti_super -cc6_linux/rts/srma-board-super -linux/docs/subtrack-supervisdspirdsp/linux-super -super -super -super -super -dsp/rts/spru.pru.pru.pru.pru.pru.pru.pruat/linux/linux-super -super -super -super -super -super -dc/docs/rfr -dtrab-dsp/linux/linux-super -super -super -super -dsp/rts/spru.pru.tdsp /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0
编号
#链接到 AM437X:PRU_0:ICSS_dualemac 到/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0/icss_dualemac_PRU0.out...
编号
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/micro_scheduler.opru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/emac_MII_Rcv.opru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/emac_MII_Xmt.opru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/emac_statistics.opru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/emac_tts.opru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/src/pru.cmd /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0.map -v3 -g -endian=little-define=AM437X --diag_wrap=off --diag_warning=225 --display_error_number --hardware_mac=on -z --stack_size=0 --heap_size=0 --reread_lib-warn_sections -i/home/rtisore-linux/linux-board-board-linux-board-board/linux-remoti-06_board-linux-board-line-board/rtsum-linux-board-linux-board-board-board-board-board-linux/rtsum-board-board-linux-board-board-board-board-linux/linux-board-board-board-board-board-board-board-board-rand-linux-board-board-board-outi/tex-linux/rtsep/linux-r.micro-board-board-board-linux-board-board-board-board-board-r.micro-linux-board-infotr.micro-board-linux/linux-board-board-board-r.micro-board-board//home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0_linkInfo.xml /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0.out
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1
编号
#将输出接头生成到 AM437X:PRU_0:ICSS_dualemac 到/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.bin...
编号
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/pruss/PRU0_REV1_to_ARM.cmd /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0.out -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.bin
*** Error in `/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru:free():invalid next size (Fast):0x09753010***
内部错误:/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru 存在内部不一致并中止
这是由 TI 十六进制转换器中的缺陷导致的。
TI 客户支持可能会建议解决方法来避免这种情况。
升级到编译器的最新版本可能会解决此问题。
在 E2E 支持论坛中联系 TI、网址 为 http://e2e.ti.com 、位于
"开发工具"、"TI C/C++编译器"。 请参阅标题为的链接
"提交问题"。
我们需要看到整个错误消息和完整的可重现性
包括所有命令行选项的测试用例。
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/makerules/rules_pru.mk:125:目标"/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.h "的配方失败
maked[5]:***[/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.h 错误2.
make[5]:离开目录'/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/comp_top.mk:317:目标'ICSS_dualemac'的配方失败
make[4]:***[ICSS_dualemac]错误2.
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/comp_top.mk:181:目标're_fire'的配方失败
maked[3]:***[REV1_FIRST]错误2.
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/comp_top.mk:178:目标'a9host_fire'的配方失败
make[2]:***[a9host_fire]错误2.
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/comp_top.mk:175:目标'PRU_0_fire'的配方失败
maked[1]:***[PRU_0_fire]错误2.
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/comp_top.mk:172:目标'AM437X_FIRST'的配方失败
制造:***[AM437X_FIRST]错误2.
警告:/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/temp/run.do_compile.23585:1从'make release limit_SoC="AM437x" limit_boards="evmAM437x idkAM437x skAM437x" limit_cores="a15_0 ipu1_0 ipu1_1 ipu2_0 ipu2_1 ipu_1 c66x c66xdsp_0_pru_a8u_a0_host1
错误:函数失败:DO 编译(日志文件位于/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/temp/log.do_compile.23585)
    调用 hexpru 的问题...
    [引用用户="Pete Dombrowski"]/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/pruss/PRU0_REV1_to_ARM.cmd /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0.out -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.bin
    (笑声) 很难读取。  它简化为...
    path1/hexpru path2/PRU0_REV1_TO_ARM.cmd PATH3/ICSS_DUALEMAC_PRU0.out -o PATH4/icss_dualemac_PRU0.bin
    每个 pathN 都是不同的目录路径。  如果您愿意发送测试案例、我将不胜感激。  我需要知道您使用的是哪个版本的 hexpru。 将文件 PRU0_REV1_TO_ARM.cmd 和 ICSS_DUELEMAC_PRU0.out 压缩、并将其附加到您的下一个帖子。  我将尝试重现此问题。  我怀疑这对我来说是可行的。  即使如此、我也会要求开发团队在调试工具的控制下尝试该测试用例、以在执行期间查找内存分配问题。  我相信他们会发现一些值得解决的问题。
    谢谢、此致、
    乔治
    George、感谢您这么快地查看这个问题。
    我附加了一个包含两个文件副本的 zip 文件。  PRU0.out 具有来自今天下午的时间戳、因为我再次重新运行构建。
    请告诉我这些是否是我可以提供的任何内容。  希望这能为我们提供一些见解。
    Petee2e.ti.com/.../TI_5F00_E2E_5F00_Issue_5F00_07MAR2018.zip
    感谢您的测试案例。  正如我怀疑的那样、它对我来说是可以的。  尽管如此、我还是在 SDOWP 系统中提交了 CodeGen-4568以进行调查。  虽然我不确定、但我相信我们可以使用此测试案例来发现一些值得解决的内存分配问题。  欢迎您在我的签名中使用下面的 SDOWP 链接关注此条目。
    谢谢、此致、
    乔治
    好的、George、我发现了这个问题、并将在这个系统中关注这个问题。 我是否需要选择一个答案、如"这未解决我的问题"或现在就将其保持打开状态?
    Pete
    现在只需将其保持打开状态即可。
    谢谢、此致、
    乔治
    乔治,我不知道有没有人有机会看我的问题,在这个问题上取得地位的最好办法是什么?
    Pete
    没有取得任何进展。  工作完成后 、SDOWP 条目中的字段 将开始显示信息。
    谢谢、此致、
    乔治
    [引用 user="George mock]然后、我会要求开发团队在调试工具的控制下尝试该测试案例、以查找执行期间的内存分配问题。  我相信他们会发现一些值得解决的问题。[/引述]
    不幸的是、我弄错了。  当开发团队在调试工具的控制下尝试测试案例时、未发现任何问题。  因此、我们不知道问题的原因。
    请考虑升级到最新的 PRU 编译器工具、并使用该版本的 hexpru。  请参阅 TI 编译器下载页面
    谢谢、此致、
    乔治
