[参考译文] CODECOMPOSER:CCS 安装问题
Guru**** 2914030 points
https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/1360893/codecomposer-problems-install-ccs
器件型号:CODECOMPOSER
Installing the CCS, when it reaches 98%, a window appears with the following error:
CCS_ERROR: Unable to install executable /tmp/ccs_6b967a63-9b74-4aa9-739d-8ea2a95a892c/EMU_BH/bh_emupack_setup64_9.0.0.002.bin: Error running /tmp/ccs_6b967a63-9b74-4aa9-739d-8ea2a 95a892c/EMU_BH/bh_emupack_setup64_9.0.0. 002.bin --prefix /root/ti/ccs1271/ccs --eclipseprefix /root/ti/ccs1271/ccs/eclipse --mode unattended --installer-log /root/ti/ccs1271/ccs/install_logs/20240513091243 -- ccs true: child process exited abnormally. Do you want to retry?
I try again but nothing. How can I solve it?
    您正在使用哪种 Linux 发行版(和版本)?
    您能否提供 /ccs/install_logs?
