[参考译文] AFE4400:无法正常驱动光电二极管、无法正常读取血氧
Guru**** 2794765 points
Other Parts Discussed in Thread: AFE4400
https://e2e.ti.com/support/data-converters-group/data-converters/f/data-converters-forum/1486738/afe4400-unable-to-drive-the-photodiode-normally-unable-to-read-blood-oxygen-normally
器件型号:AFE4400
它会自动诊断错误0x1030、我无法理解为什么光电二极管会短路并再次开路、bit12表示
PD_ALM:断电警报状态诊断标志
该位指示 PD_ALM (和 PD_ALM 引脚)的状态。
我无法找到问题的根源、因为已在其他设备上确认光电二极管正常工作我无法找到问题的根源、因为已在其他设备上确认光电二极管正常工作
当前的 SPI 通信已经正常完成、我定义的寄存器配置如下:
#define TI_AFE4400_LED2STC_REG_VALUE (6050ul)
#define TI_AFE4400_LED2ENDC_REG_VALUE (7998ul)
#define TI_AFE4400_LED2LEDSTC_REG_VALUE (6000ul)
#define TI_AFE4400_LED2LEDENDC_REG_VALUE (7999ul)
#define TI_AFE4400_ALED2STC_REG_VALUE (50ul)
#define TI_AFE4400_ALED2ENDC_REG_VALUE (1998ul)
#define TI_AFE4400_LED1STC_REG_VALUE (2050ul)
#define TI_AFE4400_LED1ENDC_REG_VALUE (3998ul)
#define TI_AFE4400_LED1LEDSTC_REG_VALUE (2000ul)
#define TI_AFE4400_LED1LEDENDC_REG_VALUE (3999ul)
#define TI_AFE4400_ALED1STC_REG_VALUE (4050ul)
#define TI_AFE4400_ALED1ENDC_REG_VALUE (5998ul)
#define TI_AFE4400_LED2CONVST_REG_VALUE (4ul)
#define TI_AFE4400_LED2CONVEND_REG_VALUE (1999ul)
#define TI_AFE4400_ALED2CONVST_REG_VALUE (2004ul)
#define TI_AFE4400_ALED2CONVEND_REG_VALUE (3999ul)
#define TI_AFE4400_LED1CONVST_REG_VALUE (4004ul)
#define TI_AFE4400_LED1CONVEND_REG_VALUE (5999ul)
#define TI_AFE4400_ALED1CONVST_REG_VALUE (6004ul)
#define TI_AFE4400_ALED1CONVEND_REG_VALUE (7999ul)
#define TI_AFE4400_ADCRSTCT0_REG_VALUE (0ul)
#define TI_AFE4400_ADCRSTENDCT0_REG_VALUE (3ul)
#define TI_AFE4400_ADCRSTCT1_REG_VALUE (2000ul)
#define TI_AFE4400_ADCRSTENDCT1_REG_VALUE (2003ul)
#define TI_AFE4400_ADCRSTCT2_REG_VALUE (4000ul)
#define TI_AFE4400_ADCRSTENDCT2_REG_VALUE (4003ul)
#define TI_AFE4400_ADCRSTCT3_REG_VALUE (6000ul)
#define TI_AFE4400_ADCRSTENDCT3_REG_VALUE (6003ul)
#define TI_AFE4400_PRPCOUNT_REG_VALUE (7999ul)
#define TI_AFE4400_CONTROL1_REG_VALUE (0x102ul)
#define TI_AFE4400_TIA_AMB_GAIN_REG_VALUE (0x034143ul)
#define TI_AFE4400_LEDCNTRL_REG_VALUE (0x38F8Ful)
#define TI_AFE4400_CONTROL2_REG_VALUE (0x20100ul)
AFE4400提供的读取寄存器值如下所示
I:1 reg: 6050
I:2 reg: 7998
I:3 reg: 6000
I:4 reg: 7999
I:5 reg: 50
I:6 reg: 1998.
I:7 reg: 2050.
I:8 reg: 3998
I:9 reg: 2000
I:10 reg: 3999
I:11 reg: 4050
I:12 reg: 5998
I:13 reg: 4.
I:14 reg: 1999.
I:15 reg: 2004.
I:16 reg: 3999
I:17 reg: 4004
I:18 reg: 5999
I:19 reg: 6004
I:20 reg: 7999
I:21 reg: 0
I:22 reg: 3.
I:23 reg: 2000
I:24 reg: 2003.
I:25 reg: 4000
I:26 reg: 4003.
I:27 reg: 6000
I:28 reg: 6003.
I:29 reg: 7999
I:30寄存器:0x102
I:32寄存器:0
I:33 reg:213315
I:34 reg: 233359
I:35寄存器:0x20100
I:41寄存器:0
I:42 reg: 15229394.
I:43 reg: 15231217
I:44 reg: 15228770
I:45 reg: 15231188
I:46 reg: 16775722.
I:47寄存器:16774922
I:48 reg: 4144
EXTI4_15_IRQHandler PA9
pa9_______ 0X30:1030
AFE4400:的电路原理图
