[参考译文] DLP2000:着陆镜是否返回到"flat"状态、如果它们要保持在当前状态和下一状态是相同的?
Guru**** 2576215 points
https://e2e.ti.com/support/dlp-products-group/dlp/f/dlp-products-forum/1446379/dlp2000-do-landed-mirrors-return-to-flat-state-if-they-are-to-remain-in-the-current-and-next-states-are-the-same
器件型号:DLP2000
出现"后视镜时钟脉冲"时、所有后视镜是否都恢复到"平面"状态? 或者、只有那些从"开"变为"关"或从反向转换到平坦状态的微镜吗?
