[FAQ] [参考译文] [常见问题解答] TI-API:库存 API 错误代码:ERR-TICOM-INV-API-1002
Guru**** 2195940 points
https://e2e.ti.com/support/enterprise-automation-integration-group/enterprise-automation-integration/f/enterprise-automation-integration-forum/1125202/faq-ti-api-inventory-api-error-code-err-ticom-inv-api-1002
    情况 错误详细信息 补救步骤
    目录 API 的 tiPartNumber 无效/格式错误
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    "errors": [
    "errorCode": "ERR-TICOM-INV-API-1002",
    "type": "ResourceNotFound",
    "section": "Path",
    "field": "tiPartNumber",
    "reason": "Resource could not be found",
    "message": "tiPartNumber ('DOESNOTEXIST') does not exist. Please correct the format (see https://e2e.ti.com/search?q=faq%3Atrue&category=forum&group=452&date=&customdaterange=0&startdate=&faq=true&sort=date%20desc&faq=true#) or verify that the part number is valid on TI.com and resubmit your request"
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    验证提供的器件型号的格式( FAQ 中提供了详细信息)、并验证 TI.com 上的器件型号是否有效。 然后重新提交请求
    tiPartNumber 无效或缺少订阅
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    "errors": [
    "section": "Path",
    "message": "No active subscriptions found for tiPartNumber ('DOESNOTEXIST'). Possible reasons: subscription was never created, subscription expired or was deleted, or part number is invalid or does not exist. Please verify the subscription details and resubmit your request."
    验证提供的器件型号的格式( 常见问题解答中提供了详细信息)、验证器件型号在 TI.com 上是否有效、并验证指定器件是否存在有效订阅。 更正器件型号或创建订阅
