器件型号:TI-API v2财务单据(发票) API 错误代码是什么意思?
| 场景 | 错误详细信息 | 补救步骤 |
| 输入缺失 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0016",
"type": "ERROR",
"reason": "Missing Input",
"message": "Input cannot be null or empty. Enter a valid input."
输入缺失、不能为空或为空。 请输入有效的输入。 如果需要更多帮助、请通过 api-portal.ti.com/support 联系 TI API 支持 |
| 缺少客户 GlobalIdentifier | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0010",
"type": "ERROR",
"reason": "Missing CustomerGlobalIdentifier",
"message": " CustomerGlobalIdentifier is required. Contact TI API Support https://api-portal.ti.com/support for assistance."
CustomerGlobalIdentifier 为必填项,不能为空或空。 如需帮助、请联系 TI API 支持 api-portal.ti.com/support。 |
| 缺少 soldToAccountNumber 或其无效 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0020",
"type": "ERROR",
"reason": "ERROR",
"message": " soldToAccountNumber cannot be null or empty or is not valid. Enter a valid soldToAccountNumber and resubmit request."
soldToAccountNumber 无效或缺失、不能为空或空。 输入有效的 soldToAccountNumber、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| soldToAccountNumber 无效 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0021",
"type": "ERROR",
"reason": "ERROR",
"message": " soldToAccountNumber cannot exceed 17 characters in length. Enter a valid soldToAccountNumber up to 17 characters and resubmit request."
SoldToAccountNumber 的最大长度超过17个字符。 输入不超过17个字符的有效 soldToAccountNumber、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| 所需的标识符之一 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0030",
"type": "ERROR",
"reason": "One Identifier required",
"message": "One of the following identifiers orderNumber or financialDocumentNumber or deliveryNumber or customerPurchaseOrderNumber is required. Enter one of the valid Identifiers and resubmit request. "
只有一个字段是必填字段。 输入以下有效字段之一:OrderNumber 或 financialDocumentNumber deliveryNumber 或 customerPurchaseOrderNumber、然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| 仅填充一个标识符 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0031",
"type": "ERROR",
"reason": "Populate only one Identifier",
"message": "Only one of the following identifiers orderNumber or financialDocumentNumber or deliveryNumber or customerPurchaseOrderNumber can be provided. Enter one of the valid Identifiers and resubmit request. "
只能填充一个字段。 输入以下有效字段之一:OrderNumber 或 financialDocumentNumber 或 deliveryNumber 或 customerPurchaseOrderNumber、然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| financialDocumentNumber 无效 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0040",
"type": "ERROR",
"reason": "Invalid financialDocumentNumber",
"message": " financialDocumentNumber cannot exceed 10 characters in length. Enter a valid financialDocumentNumber up to 10 characters and resubmit request."
financialDocumentNumber 不能超过10个字符的最大长度。 输入不超过10个字符的有效的 financialDocumentNumber、然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| 订单号无效 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0041",
"type": "ERROR",
"reason": "ERROR",
"message": " orderNumber cannot exceed 10 characters in length. Enter a valid orderNumber up to 10 characters and resubmit request."
OrderNumber 不能超过10个字符的最大长度。 输入不超过10个字符的有效 OrderNumber、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| 无效的 deliveryNumber | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0042",
"type": "ERROR",
"reason": "Invalid deliveryNumber",
"message": " deliveryNumber cannot exceed 10 characters in length. Enter a valid deliveryNumber up to 10 characters and resubmit request.."
deliveryNumber 不能超过10个字符的最大长度。 输入不超过10个字符的有效交货编号、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| customerPurchaseOrderNumber 无效 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0043",
"type": "ERROR",
"reason": "Invalid customerPurchaseOrderNumber",
"message": " customerPurchaseOrderNumber cannot exceed 35 characters in length. Enter a valid customerPurchaseOrderNumber up to 35 characters and resubmit request."
customerPurchaseOrderNumber 超过35个字符的最大长度。 输入不超过35个字符的有效 customerPurchaseOrderNumber、然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| 无效状态 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0044",
"type": "ERROR",
"reason": "Invalid status",
"message": " status cannot exceed 10 characters in length. Enter a valid status up to 10 characters and resubmit request."
状态超过10个字符的最大长度。 输入不超过10个字符的有效状态、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| 无效的起始日期 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0045",
"type": "ERROR",
"reason": "Invalid startDate",
"message": " startDate does not have a valid date format. Verify and correct the startDate format to YYYY-MM-DD and resubmit request."
startDate 的日期格式无效。 将有效的 startDate 格式输入到 YYY-MM-DD、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| 无效结束日期 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0046",
"type": "ERROR",
"reason": "Invalid endDate",
"message": " endDate does not have a valid date format. Verify and correct the endDate format to YYYY-MM-DD and resubmit request."
结束日期的日期格式无效。 将有效的结束日期格式输入到 YYY-MM-DD 并重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| requestInvoicePDF 必须有值 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0047",
"type": "ERROR",
"reason": "requestInvoicePDF must have valid value",
"message": "Pass "true" as the value if a PDF is desired. Otherwise the field should be blank.. Otherwise the field should be blank or false."
如果需要 PDF、则 RequestInvoicePDF 值必须为 true 或 false。 输入 X 以接收 PDF;否则该字段将默认为 false。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| 不是有效编号 financialDocumentNumber | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0048",
"type": "ERROR",
"reason": "financialDocumentNumber is not a Invalid Number",
"message": " financialDocumentNumber does not have a valid numeric format. Verify and correct the financialDocumentNumber format to contain numeric digits and resubmit request."
financialDocumentNumber 不是有效的数字。 输入包含数字的有效 financialDocumentNumber,然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| 不是有效的编号 OrderNumber | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0049",
"type": "ERROR",
"reason": "orderNumber is not a Invalid Number",
"message": " orderNumber does not have a valid numeric format. Verify and correct the orderNumber format to contain numeric digits and resubmit request."
OrderNumber 不是有效的数字。 输入包含数字的有效 OrderNumber、然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| 不是有效的数字 deliveryNumber | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0050",
"type": "ERROR",
"reason": "deliveryNumber is not a Invalid Number",
"message": " deliveryNumber does not have a valid numeric format. Verify and correct the deliveryNumber format to contain numeric digits and resubmit request."
deliveryNumber 不是有效的数字。 输入包含数字的有效交付编号并重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support |
| 发生 TI API 系统错误连接被拒绝(连接被拒绝) | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0500",
"type": "ERROR",
"reason": "TI API system error occurred Connection refused",
"message": " Contact TI API Support https://api-portal.ti.com/support with the following details: error code, error message and API endpoint."
发生系统错误或连接被拒绝。 联系 TI API 支持 api-portal.ti.com/support、了解所有详细信息、例如错误消息、错误代码、API 端点和遇到的任何其他错误。 |
| TI API 不可用于计划的系统维护 | {
"errors": [
"errorCode": "ERR-BKG-FIR-API-0510",
"type": "ERROR",
"reason": "TI API unavailable for scheduled maintenance",
"message": "This TI API is currently unavailable between $OutageStart and $OutageEnd $timeZoneStr for scheduled system maintenance. Resubmit request after maintenance has ended."
由于计划的系统维护、TI API 系统当前不可用。 在维护结束后重新提交您的请求。 如果在计划维护结束后仍然遇到问题、请联系 TI API 支持 api-portal.ti.com/support |
