[参考译文] DP83867IR:在 IBIS 模型中、TD_P/M_A/B/C/D 等引脚为 NC
Guru**** 2587365 points
Other Parts Discussed in Thread: DP83867IR
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1539686/dp83867ir-pins-like-td_p-m_a-b-c-d-are-nc-in-ibis-model
器件型号:DP83867IR
对于 SI 仿真、我们涉及  DP83867IR 收发器、但引脚 TD_P/M_A/B/C/D 为 NC。
