[参考译文] SN75158:SN75158的|VOD1|差分输出电压
Guru**** 2893300 points
Other Parts Discussed in Thread: SN75158
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1018906/sn75158-vod1-differential-output-voltage-for-sn75158
器件型号:SN75158
如果 VCC =5V 且高电平输入电压 VIH=5V、SN75158的|VOD1|差分输出电压是多少?  什么是最大限制 |VOD1|差分输出电压?
