[参考译文] DP83848C:DP83848C 散热焊盘连接至接地引脚
Guru**** 2931100 points
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/738962/dp83848c-dp83848c-thermal-pad-connection-to-ground-pin
器件型号:DP83848C
DP83848的散热垫和接地之间是否有任何连接? 能否将散热焊盘连接到接地引脚?
    是的、散热焊盘也是接地引脚。
    GET
