[参考译文] DS250DF410:DS250DF410 EEPROM 图像
Guru**** 2928980 points
Other Parts Discussed in Thread: DS250DF410, USB2ANY
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1176910/ds250df410-ds250df410-eeprom-image
器件型号:DS250DF410
主题中讨论的其他器件: USB2ANY
我对 DS250DF410的 EEPROM 映像有一些疑问。 当前设备不工作。
(1)我们使用主模式、即 EN_SMB 引脚悬空。 我假设地址在主模式下无关紧要。
(2)我们将 ADAPT_MODE 更改为0x02、您是否会帮助检查我们的图像我还需要更改哪些内容?
没有上传 hex 文件的选项、我可以上传它供您查看吗? 谢谢。
    这是十六进制:
    :20000000700010003300003300003300003300000000000000000000000000000000000000000000000000000000000094
    :2000200000000000000000000000000000000000000000000000000000000000000000000000000073000630210F00A0F46D102DA9
    :20004000C9E5600015A2BB182A402310FC7B60001A40400040508090C0D0D1DD8EAF7FD6E
    20006000EEEFFF000000000034428000000521344813A9001F9FF12248C300900F000000D5
    :200080000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000060
    2000A00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000040
    :2000C0000000000000000000000000000000000000000000000000000000000000000000000000000000000020
    2000E00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
    :20010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000DF
    :200120000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000BF
    :200140000000000000000000000000000000000000000000000000000000000000000000000000000000000000009F
    2001600000000000000000000000000000000000000000000000000000000000000000000000000000000000000000007F
    :2001800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000005F
    2001年 A0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000003F
    2001年 C00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001F
    :2001E000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000FF
    20020000000000000000000000000000000000000000000000000000000000000000000000000000000000000000DE
    :2002200000000000000000000000000000000000000000000000000000000000000000000000BE
    :2002400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000009E
    :2002600000000000000000000000000000000000000000000000000000000000000000000000000000000000000000007E
    :2002800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000005E
    :2002A0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000003E
    :2002C0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001E
    :2002E00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000FE
    :200300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000DD
    :200320000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000BD
    :2003400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000009D
    :20036000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000007D
    :20038000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000005D
    :2003A0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000003D
    :2003C00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001D
    :2003E000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000005F8
    :00000001FF
    我发现在全局寄存器中、0xFC 应启用所有4个通道、
    我不确定 全局0xFF
    您是否曾尝试在 SMBus 目标/从模式下使用 SigCon architect 配置器件?  如果是、您是否能够观察 CDR 锁定?  系统中数据的数据速率是多少?
    此外、重定时器 SMBus 地址是什么?  这在控制器/主控模式下确实很重要。
    Drew
    您好、Drew、
    感谢您的回复!
    我将尝试更改全局0xFC 以首先启用所有4个通道、默认设置仅启用1个通道。
    410 SMBus 器件地址硬件捆绑为0x44、我只将410重定时器 SMBus 连接到 EEPROM。 410重定时器处于主控模式。
    我没有保留从模式自举、因此我想不能通过 USB 软件狗来访问410重定时器。
    我尝试保存全局0xFC、似乎无法保存。
    尊敬的 Gang:
    在尝试访问通道寄存器时、您能否确认是否遵循以下类似步骤?
    [引用 userid="522410" URL"~/support/interface-group/interface/f/interface-forum/1176910/ds250df410-ds250df410-eeprom-image/4430407 #4430407"]我没有保留从模式自举,因此我想不能通过 USB 软件狗访问410重定时器。[/quot]
    该器件可在加载 EEPROM 后访问。  我想我看到一个可能会带来挑战的问题。  EEPROM 十六进制文件取决于器件地址。  我们需要确保为地址0x44的器件配置 EEPROM。
    Drew
    您好、Drew、
    请让我重新安排我目前的情况。
    (1)我没有保留启用主/从的自举、它只能处于主模式、这意味着我无法使用 USB 软件狗来访问重定时器;
    (2)我卡在要使用 EEPROM 的阶段。 对于此修订版、如果重定时器可以从 EEPROM 成功引导、我不需要访问重定时器。
    以下是生成十六进制文件的步骤、您能帮助检查吗?e2e.ti.com/.../Steps.docx
    尊敬的 Gang:
    [引用 userid="522410" URL"~/support/interface-group/interface/f/interface-forum/1176910/ds250df410-ds250df410-eeprom-image/4441270 #4441270"](1)我没有保留启用主/从的自举,它只能处于主模式,这意味着我无法使用 USB 软件狗来访问重定时器;[/quot]
    我知道从机模式的自举不存在。  我强调在加载 EEPROM 后可以在从模式下访问器件的原因是、有时需要对器件进行调试。  例如、加载 EEPROM 后访问器件可确保 EEPROM 配置正确。
    关于这些步骤、我为您创建了一个十六进制文件、其中包含调整模式2以及执行此操作的步骤。  遗憾的是、在为0x30以外的地址放置地址标头时、Sigcon architect 出现错误、因此我们必须手动执行此操作。  我已为器件地址0x30和0x44附加了十六进制文件以进行比较。
    e2e.ti.com/.../addr_5F00_0x44.hex
    e2e.ti.com/.../addr_5F00_0x30.hex
    e2e.ti.com/.../eeprom_5F00_modification.docx
    Drew
    谢谢 Drew。
    我肯定会在下一个修订版中向重定时器添加从器件自举和 I2C 访问以进行监控
    我尝试了 addr_0x44.hex、但连接仍然断开。 您能否帮助查看原理图以找出问题?
    OUT 电容器位于另一侧、EEPROM 模型为 M24C08-RMN6TP
    www.digikey.com/.../1663582
    尊敬的 Gang:
    感谢您分享您的原理图。  为了启动 EEPROM 读取功能、应将 READ_EN 拉低。
    您能否确认您的应用中的数据速率?
    Drew
    您好、Drew、
    我休息了一周、这里是测量结果、似乎出了问题、EEPROM 加载从未发生。
    有25米时钟;
    即使 EN_SMB 悬空、也没有 I2C 切换、SDC 和 SDA 都始终为高电平;
    ALL_DONE_N 和 READ_EN_EN 连接在一起、高电平。
    您好、Drew、
    您可以建议采用 SO8封装的 I2C EEPROM 吗? EEPROM 是否可能未确认并且重定时器是否会停止通信?
    Gang:
      响应可能会由于假期而延迟。
    Brian
    我刚才了解 READ_EN 应该是 GND。
    由于我仅使用单个重定时器、并使 READ_EN_N 为实心 GND、并将 ALL_DONE_N 保持未连接状态。 这是可以的吗?
    您好、Drew、
    将 READ_EN_N 连接到 GND 后、0x44 EEPROM 加载完成、但链路仍处于关闭状态。
    我们尝试将链接降级到10G、但仍然没有帮助。
    您还有其他建议吗? 谢谢。
    尊敬的 Gang:
    很高兴听到 EEPROM 正在加载。  您使用的数据速率是多少?  您使用哪种测试模式?
    Drew
    您好、Drew、
    数据速率用于 EEPROM 侧还是数据链路侧?
    对于数据链路、我们尝试了10G 和25G、但都不起作用。 下面是我们的设置、我们从以太网交换机侧测试了链路状态。
    CPU TX =>0.22uF=>retimer=>0.1uF =>以太网交换机 RX
    CPU RX <=0.22uF<=retimer <=0.1uF <=以太网交换机 TX
    尊敬的 Gang:
    感谢您的更新。  我对数据链路端很好奇。  听起来您是在使用25.78125Gbps 和10.3125Gbps 进行测试。  在数据模式方面、您似乎使用的是标准以太网流量。
    我将对此进行研究、并将在第二天内再次向您介绍最新情况。
    Drew
    您好、Drew、
    让我解释一下我们的10G 和25G、我们只能控制以太网开关侧速度、默认情况下 CPU 侧为25G。
    例如、对于25G、我们将以太网交换机设置为25G、默认情况下 CPU 侧为25G、带或不带重定时器的链路为25G。
    对于10G、我们将以太网交换机设置为10G、CPU 端仍为25G。 如果中间没有重定时器、CPU 端将在自动协商后下降到10G。
    尊敬的 Gang:
    很抱歉、我没有意识到您正在使用以太网规范来实现自动协商。  自动协商通常以低于 CDR 支持的数据速率进行。  因此、为了支持自动协商、我们通常建议将重定时器配置为 传输"原始"(未重定时)数据、而数据不能锁定到。  这可以通过以下寄存器写入来实现、这是编程指南的摘录。
    或者、要测试自动协商是否会导致系统出现问题、您可以尝试禁用它并查看是否可以建立链接。  请尝试这些建议、并告诉我它们是否有帮助。
    Drew
    您好、Drew、
    我们对 EEPROM 更新所做的操作、我将在下星期一尝试:
    (1)在 EEPROM 页面中加载0x44.hex
    (2)转至低电平页面、对于所有4个通道、取消选中寄存器1E 中的位7、6、5
    (3)转至 EEPROM 页面、从器件更新插槽、然后写入 EEPROM
    尊敬的 Gang:
    感谢您的更新。  期待下周收听您的结果。
    Drew
    您好、Drew、
    我们尝试了修改后的 EEPROM、但链接仍处于关闭状态。 我们还尝试禁用以太网交换机上的自动协商、结果相同。
    请帮助您仔细检查以下图片是否正确?
    我无法将文件附加到该论坛、我粘贴修改后的图像并在此处选择原始图像:
    20004000C825600015A2BB182A202310FC7B60001A40400040508090C0D0D1DD8EAF7FD4F
    :2003E000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000002FB
    :00000001FF
    这是最初的0x44.hex、在第2、3行和32行中存在差异、我认为在将0x44.hex 加载到软件中之后没有包含"33"。
    :20002000000033000000000000000000000000000000000073000630200300A0F46D102D83
    :20004000C9C5600015A2BB182A402310FC7B60001A40400040508090C0D0D1DD8EAF7FD8E
    :2003E000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000FD
    :00000001FF
    尊敬的 Gang:
    我正在检查您的十六进制文件。  此外、我只需"单击并拖动"到论坛即可将文件上传到 E2E。
    Drew
    尊敬的 Gang:
    我认为有一个可能相关的问题。  如果这是25G-KR 链路、请同时禁用链路训练。  我们的重定时器不会通过链路训练系数。
    https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1188652/ds250df410-interface-forum
    Drew
    您好、Drew、
    Asok 是我的同事、我们在同一个板上工作。 我们尝试禁用训练和自动协商、但仍然无法正常工作。
    我们可以借用或租用 EVK 进行调试吗? 999美元对我们来说有点贵。
    尊敬的 Gang:
    您是否需要用于高速测试的 EVM、还是仅需要 USB2ANY?  请注意、EVM 需要 Huber+Suhner MXP 连接器才能进行高速评估。
    我们还有一个单独的 USB2ANY 适配器。
    https://www.ti.com/tool/USB2ANY
    Drew
    您好、Drew、
    无论您认为哪一项可以帮助我们跟踪我们的当前状态、我们都需要这样做。 我们目前被困在这里。
    您好、Drew、
    我们是否可以进行电话或 Google 会面讨论?
    尊敬的 Gang:
    是的、我们可以拨打电话。  我向您发送了一个 e2e"朋友请求"。  请接受此信息、以便我们可以交换联系信息。  我还有一个电路板、我可以让您借用。
    Drew
