[参考译文] DS125DF1610:DS125DF1610
Guru**** 2782615 points
Other Parts Discussed in Thread: DS125DF1610
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1255791/ds125df1610-ds125df1610
器件型号:DS125DF1610
您好
我们的设计中使用了四个 DS125DF1610。  如果我们  在不具有交叉点和电路板播的情况下使用它们、其中一个通道显示 CDR 处于未锁定状态。
输入数据来自其他边界的 FPGA。
我们测试了功率和输入时钟,功率噪声和时钟 的 ppm 可以。
寄存器值如下所示。 regisrer 集是否有任何问题? 为什么 CDR 处于解锁状态?
ds125SharedRegDump 偏差0
      0 1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
0x00:08 71 20 00 01 08 00 05 00 01 50 00 7a 00 ff
0x10:ff ds125ChannelRegDump dropd 0通道0
0x00:00 80直流00 01 01 01 60 00 10 6F 08 b4 93 69
0x10:3a 20 e0 90 00 12 7a 36 40 20 a0 03 90 00 E1 55
0x20:00 00 00 40 00 00 00 31 8a 40 30 0f f2 00 B6
0x30:00 20 11 88 bf 1f 30 00 10 00 33 8e 35 43 C7
0x40:00 01 04 10 40 08 80 03 0c 30 41 50 c0 60 90
0x50:88 82 a0 46 52 8c b0 C8 57 5d 69 75 D5 99 96 A5
0x60:00 00 00 00 00 00 20 00 0A 22 40 00 00 80
0x70:03 20 00 00 00 22 1a 30 10 00 00 00 48 13 3a
0x80:03 E4 00 00 00 00 00 00 00 00 00 25 00 02 1c 00
0x90:00 00 00 00 00 14 00 0c 3f 3f 00 D5 99 96 A5
ds125ChannelRegDump 偏离0通道1
0x20:00 00 00 40 00 00 32 87 40 30 0f f2 00 B6
0x30:00 20 11 88 bf 1f 30 00 10 00 33 8d 35 43 C7
0x80:03 E4 00 00 00 00 00 00 00 00 68 00 02 1c 00
0x90:00 00 00 00 00 15 00 0c 3f 3f 01 D5 99 96 A5
ds125ChannelRegDump 偏离0通道2
0x20:00 00 00 40 00 00 2e 87 40 30 0f f2 00 B6
0x80:03 E4 00 00 00 00 00 00 00 07 A9 00 02 1c 00
0x90:00 00 00 00 00 16 00 0c 3f 3f 02 D5 99 96 A5
ds125ChannelRegDump 偏离0通道3
0x20:00 00 00 40 00 00 30 87 40 30 0f f2 00 B6
0x80:02 E4 00 00 00 08 00 00 00 00 00 00 00 00 02 1c 00
0x90:00 00 00 00 00 17 00 0c 3f 3f 03 D5 99 96 A5
ds125ChannelRegDump 偏离0通道4
0x20:00 00 00 40 00 00 00 31 84 40 30 0f f2 00 B6
0x80:02 E4 00 00 00 00 00 00 00 00 00 00 00 00 02 1c 00
ds125ChannelRegDump 偏离0通道5
0x20:00 00 00 40 00 00 00 34 96 40 30 0f f2 00 B6
0x80:03 E4 00 00 00 00 00 00 00 07 F5 00 00 02 1c 00
ds125ChannelRegDump 偏离0通道6
0x20:00 00 00 40 00 00 00 34 8d 40 30 0f f2 00 B6
0x80:02 E4 00 00 00 00 00 00 00 00 4F 00 00 02 1c 00
ds125ChannelRegDump 偏离0通道7
0x20:00 00 00 40 00 00 00 34 87 40 30 0f f2 00 B6
0x80:03 E4 00 00 00 00 00 00 00 07 9e 00 02 1c 00
ds125ChannelRegDump 偏离0通道8
0x00:00 80 9c 00 01 01 01 60 00 10 6F 08 b4 93 69
0x20:00 00 00 40 00 00 00 33 8d 40 30 0f f2 00 B6
0x80:03 E4 00 00 00 00 00 00 00 00 7e 00 02 1c 00
ds125ChannelRegDump 偏离0通道9
0x20:00 00 00 40 00 00 00 31 87 40 30 0f f2 00 B6
0x80:03 E4 00 00 00 00 00 00 00 07 e0 00 02 1c 00
ds125ChannelRegDump 偏离0通道10
0x20:00 00 00 40 00 00 00 33 87 40 30 0f f2 00 B6
0x30:00 20 11 88 bf 1f 30 01 10 00 33 8e 35 43 C7
0x80:02 E4 00 00 00 00 00 00 00 00 3a 00 02 1c 01
ds125ChannelRegDump 偏离0通道11
0x20:00 00 00 40 00 00 00 30 84 40 30 0f f2 00 B6
0x80:03 E4 00 00 00 00 00 00 00 00 00 00 00 00 02 1c 00
ds125ChannelRegDump 偏离0通道12
0x80:03 E4 00 00 00 00 00 00 00 00 13 00 02 1c 00
ds125ChannelRegDump 0通道13
0x20:00 00 00 40 00 00 00 35 7e 40 30 0f f2 00 B6
0x80:02 E4 00 07 ff 00 00 00 00 07 97 00 02 1c 00
ds125ChannelRegDump 偏离0通道14
0x20:00 00 00 40 00 00 00 35 84 40 30 0f f2 00 B6
0x80:03 E4 00 00 00 00 00 00 00 00 1f 00 02 1c 00
ds125ChannelRegDump 偏离0通道15
0x80:02 E4 00 00 00 00 00 00 00 00 1c 00 02 1c 00
    Michael、您好!
    您能否说明一下您是如何观察到在某些通道上 CDR 处于解锁状态的? 对于 CDR 锁定状态、我可以看到所有16个通道都指示 CDR 已锁定(对于所有通道、0x78 = 0x30)。
    如果可能、请在 CDR 解锁时共享寄存器转储、以便我可以进一步进行故障排除。
    埃文
    您好,Evan
    感谢您的答复。
    我们读取0x02[4]来监控 CDR 锁定状态。 ZHCAA42的文件显示 CDR 锁定状态可以通过0x02[4]读取。
    我们用脚本测试了函数。 很遗憾我们只有打印消息、在 CDR 解锁时没有保存寄存器值
    寄存器组是否有任何问题?
    Michael、您好!
    Unknown 说:
    当我们在  没有交叉点和板播功能的情况下使用它们时,其中一个显示 CDR 在一个通道上未锁定。
    我注意到、寄存器0x9B 和0x96在每个通道中都进行了修改以启用交叉点模式-这是预期设置吗?
    此 寄存器转储可能适用于启用了交叉点的工作案例。 如果未使用交叉点、寄存器0x96和0x9B 应保留为默认值。
    埃文
    您好,Evan
    感谢您的检查。
    我们不打算使用交叉点的功能。
    但我们发现如果将 0x96[4]设置为0,将0x96[3]设置为10,它将无法正常工作。
    如果我们 将 0x96[4]设置为 1,将0x96[3]设置为10,它将无法正常工作。
    Michael、您好!
    在这种情况下、我想知道某些通道的布线是否可以交换、并且只能在交叉点模式下工作。 您是否能够将原理图和方框图与从重定时器到 FPGA 的预期连接共享?
    埃文
    您好、Evan
    这是我们的测试数据路径。
    我们使用重计时器通道时、例如、通道0的 RX 连接到通道0的 TX。
    在这种情况下、应该将什么值设置为0x96和0x9B?
    Michael、您好!
    如果每个通道都有一个从 RX0->TX0、RX1->TX1、...直接路由的独立信号... ,则寄存器0x96和0x9B 应保留为默认值。
    如果您将这些寄存器保留为默认值、但将0x96[3]切换为1、您看到的行为是否发生了变化?
    埃文
    您好,偶数
    在我们通信时、我们读取0x02[4]来监控 CDR 锁定状态。 ZHCAA42的文件显示 CDR 锁定状态可以通过0x02[4]。读取
    可以吗? 或者我们应该读为 0x78[1]
    您好、Evan
     0x96和 0x9B 的缺省值为4和0。
    我查看了数据表上的图3、即交叉点开关图。 它显示了由寄存器0x96[1]:0控制的数据总线和由寄存器0x9B[1]:0控制的控制总线应该被置位。 例如、如果 CHB RX 到 CHB TX 的四路0、则将0xFC[1]设置为1、将0x96[1]设置为 01、将0x9B[1]设置为01 。
    如果 默认保留0x96和0x9B、我认为除 CHA 之外、其他信道将不起作用。
    Michael、您好!
    0x78[4]和0x02[4]都是 CDR 锁定状态的有效参考位。
    例如,如果 CHB RX 到 CHB TX 的四路0,则将0xFC[1]设置为1,将0x96[1]设置为 01,将0x9B[1]设置为 01,将0x9B[1:0]设置为01。
    您能否说明您是如何找到 CHB RX -> CHB TX 的此配置的? 这不符合我对交叉点模式的理解。
    当0x9B 和0x96保留为默认值时、请分享寄存器转储和测试结果。 如果信号从每个输入直接路由到输出(RX0->TX0、RX1->TX1、...),则此配置应该起作用。 。
    埃文
    您好、Evan
    如图所示、0x96[1]选择数据总线、0x9B[1]选择控制总线。 如果 信号直接路由、例如 CHB RX -> CHB TX、我们认为  应将0x96[1]和0x9B[1]:0]设置为01。
    我们将测试 0x9B 和0x96保留为默认值的情况、并为您提供反馈。
    非常感谢!
    Michael、您好!
    0x96[1]:0]和0x9B[1]:0]允许您为选定通道输出灵活选择通道的信号检测/EQ 控制、并且假定需要实现一定的交叉点开关。
    例如、如果要在启用交叉点的情况下写入通道寄存器 C、并将0x96[1]:0和0x9B[1]:0设置为01、则信号链将变为:
    RX (B)-> CTLE (B)->多点缓冲器(B)-> TX (C)
    如果不希望使用交叉点模式、则不需要修改这些寄存器。
    感谢您在默认值下执行测试。
    埃文
