我们一直在尝试使用速度为1.6Gbps 的4通道配置、以 YUV422格式以1920x1080和1280x720的分辨率以60fps 传输视频。 然而、尽管在 YUV422格式下以30 fps 的分辨率成功进行流式传输、但我们仍然难以实现所需的60 fps 流式传输。
您好、Hamzeh:
1、我们仅将一个摄像头连接到954。
2、它是四通道和连续时钟、 下面我将附加30fps (流式)和60fps (不流式)串行器和解串器转储、供您参考。
3、即25 MHz。
4、我们没有收到任何缓冲器。
5、是的、我们收到长度和校验和错误。
30 fps:
>>>>> DESER (954):
寄存器0x0 val = 0x6000
寄存器0x1 val = 0x0
寄存器0x2 val = 0x2e00
寄存器0x3 val = 0x2000
寄存器0x4 val = 0xdf00
寄存器0x5 val = 0x100
寄存器0x6 val = 0x0
寄存器0x7 val = 0xfe00
寄存器0x8 val = 0x1c00
寄存器0x9 val = 0x1000
寄存器0xA val = 0x1300
寄存器0xb val = 0x2500
寄存器0xc val = 0x8100
寄存器0xd val = 0x900
寄存器0xe val = 0x800
寄存器0xF val = 0x7f00
寄存器0x10 val = 0x0
寄存器0x11 val = 0x0
寄存器0x12 val = 0x0
寄存器0x13 val = 0x0
寄存器0x14 val = 0x0
寄存器0x15 val = 0x0
寄存器0x16 val = 0x0
寄存器0x17 val = 0x0
寄存器0x18 val = 0x0
寄存器0x19 val = 0x0
寄存器0x1a val = 0x0
寄存器0x1b val = 0x0
寄存器0x1c val = 0x0
寄存器0x1d val = 0x0
寄存器0x1E val = 0x400
寄存器0x1F val = 0x200
寄存器0x20 val = 0x2000
寄存器0x21 val = 0x4400
寄存器0x22 val = 0x100
寄存器0x23 val = 0x0
寄存器0x24 val = 0x0
寄存器0x25 val = 0x0
寄存器0x26 val = 0x0
寄存器0x27 val = 0x0
寄存器0x28 val = 0x0
寄存器0x29 val = 0x0
寄存器0x2a val = 0x0
寄存器0x2b val = 0x0
寄存器0x2C val = 0x0
寄存器0x2D val = 0x0
寄存器0x2e val = 0x0
寄存器0x2F val = 0x0
寄存器0x30 val = 0x0
寄存器0x31 val = 0x0
寄存器0x32 val = 0x0
寄存器0x33 val = 0x100
寄存器0x34 val = 0x4000
寄存器0x35 val = 0x300
寄存器0x36 val = 0x0
寄存器0x37 val = 0x0
寄存器0x38 val = 0x0
寄存器0x39 val = 0x0
寄存器0x3a val = 0x0
寄存器0x3b val = 0x100
寄存器0x3c val = 0x1400
寄存器0x3D val = 0x6f00
寄存器0x3E val = 0x0
寄存器0x3f val = 0x4000
寄存器0x40 val = 0x0
寄存器0x41 val = 0xa700
寄存器0x42 val = 0x7100
寄存器0x43 val = 0x100
寄存器0x44 val = 0x0
寄存器0x45 val = 0x0
寄存器0x46 val = 0x0
寄存器0x47 val = 0x0
寄存器0x48 val = 0x0
寄存器0x49 val = 0x0
寄存器0x4a val = 0x1000
寄存器0x4b val = 0x1200
寄存器0x4c val = 0x100
寄存器0x4d val = 0x300
寄存器0x4e val = 0x400
寄存器0x4f val = 0x6400
寄存器0x50 val = 0x0
寄存器0x51 val = 0x0
寄存器0x52 val = 0x0
寄存器0x53 val = 0x300
寄存器0x54 val = 0x0
寄存器0x55 val = 0x0
寄存器0x56 val = 0x0
寄存器0x57 val = 0x0
寄存器0x58 val = 0x9e00
寄存器0x59 val = 0x400
寄存器0x5a val = 0x0
寄存器0x5b val = 0x3000
寄存器0x5c val = 0x1800
寄存器0x5d val =传感器 ID
寄存器0x5e val = 0x0
寄存器0x5f val = 0x0
寄存器0x60 val = 0x0
寄存器0x61 val = 0x0
寄存器0x62 val = 0x0
寄存器0x63 val = 0x0
寄存器0x64 val = 0x0
寄存器0x65 val = sensoralias
寄存器0x66 val = 0x0
寄存器0x67 val = 0x0
寄存器0x68 val = 0x0
寄存器0x69 val = 0x0
寄存器0x6A val = 0x0
寄存器0x6b val = 0x0
寄存器0x6c val = 0x0
寄存器0x6d val = 0xb400
寄存器0x6e val = 0x8800
寄存器0x6F val = 0x8800
寄存器0x70 val = 0x1e00
寄存器0x71 val = 0x1e00
寄存器0x72 val = 0x400
寄存器0x73 val = 0x200
寄存器0x74 val = 0xd000
寄存器0x75 val = 0xa00
寄存器0x76 val = 0x0
寄存器0x77 val = 0xc500
寄存器0x78 val = 0x0
寄存器0x79 val = 0x100
寄存器0x7a val = 0x0
寄存器0x7B val = 0x0
寄存器0x7c val = 0x2000
寄存器0x7d val = 0x0
寄存器0x7E val = 0x0
寄存器0x7f val = 0x0
寄存器0xa0 val = 0x200
寄存器0xa1 val = 0xf00
寄存器0xa2 val = 0x0
寄存器0xa3 val = 0x0
寄存器0xa4 val = 0x800
寄存器0xA5 val = 0x1900
寄存器0xa6 val = 0x0
寄存器0xa7 val = 0x0
寄存器0xa8 val = 0x0
寄存器0xa9 val = 0x0
寄存器0xAA val = 0x0
寄存器0xab val = 0x0
寄存器0xac val = 0x0
寄存器0xAD val = 0x0
寄存器0xae val = 0x0
寄存器0xaf val = 0x0
寄存器0xb0 val = 0x400
寄存器0xb1 val = 0x1400
寄存器0xb2 val = 0x3f00
寄存器0xb3 val = 0x800
寄存器0xb4 val = 0x2500
寄存器0xb5 val = 0x0
寄存器0xb6 val = 0x1800
寄存器0xb7 val = 0x0
寄存器0xb8 val = 0x8c00
寄存器0xb9 val = 0x3300
寄存器0xba val = 0x8000
寄存器0xbb val = 0x7400
寄存器0xbc val = 0x8000
寄存器0xbd val = 0x0
寄存器0xbe val = 0x0
寄存器0xbf val = 0x0
寄存器0xd0 val = 0x0
寄存器0xD1 val = 0x4300
寄存器0xd2 val = 0x9400
寄存器0xd3 val = 0x300
寄存器0xd4 val = 0x6000
寄存器0xd5 val = 0xf200
寄存器0xd6 val = 0x0
寄存器0xd7 val = 0x0
寄存器0xd8 val = 0x0
寄存器0xd9 val = 0x0
寄存器0xda val = 0x0
寄存器0xdb val = 0x0
寄存器0xdc val = 0x0
寄存器0xdd val = 0x0
寄存器0xde val = 0x0
寄存器0xdf val = 0x0
寄存器0xf0 val = 0x5f00
寄存器0xF1 val = 0x5500
寄存器0xf2 val = 0x4200
寄存器0xF3 val = 0x3900
寄存器0xf4 val = 0x3500
寄存器0xf5 val = 0x3400
寄存器0xf6 val = 0x0
寄存器0xf7 val = 0x0
寄存器0xf8 val = 0x0
寄存器0xf9 val = 0x0
寄存器0xfa val = 0x0
寄存器0xfb val = 0x0
>>>>> 串行器(953)
寄存器0x0 val = 0x3000
寄存器0x1 val = 0x0
寄存器0x2 val = 0x7300
寄存器0x3 val = 0x4800
寄存器0x4 val = 0x0
寄存器0x5 val = 0x300
寄存器0x6 val = 0x4100
寄存器0x7 val = 0x2800
寄存器0x8 val = 0xfe00
寄存器0x9 val = 0x1e00
寄存器0xA val = 0x1000
寄存器0xb val = 0x7f00
寄存器0xc val = 0x7f00
寄存器0xd val = 0xF000
寄存器0xe val = 0xf00
寄存器0xF val = 0x0
寄存器0x10 val = 0x0
寄存器0x11 val = 0x0
寄存器0x12 val = 0x0
寄存器0x13 val = 0x0
寄存器0x14 val = 0x0
寄存器0x15 val = 0x2000
寄存器0x16 val = 0x1800
寄存器0x17 val = 0x3C00
寄存器0x18 val = 0x8000
寄存器0x19 val = 0x6200
寄存器0x1a val = 0x6200
寄存器0x1b val = 0x6200
寄存器0x1c val = 0x0
寄存器0x1d val = 0x0
寄存器0x1E val = 0x0
寄存器0x20 val = 0x0
寄存器0x21 val = 0x0
寄存器0x22 val = 0x0
寄存器0x23 val = 0x0
寄存器0x24 val = 0x0
寄存器0x31 val = 0x2000
寄存器0x32 val = 0x900
寄存器0x33 val = 0x400
寄存器0x34 val = 0x0
寄存器0x35 val = 0x1000
寄存器0x36 val = 0x800
寄存器0x37 val = 0x6000
寄存器0x38 val = 0x0
寄存器0x39 val = 0x0
寄存器0x3a val = 0x0
寄存器0x3b val = 0x0
寄存器0x3c val = 0x0
寄存器0x3D val = 0x0
寄存器0x3E val = 0x0
寄存器0x3f val = 0x0
寄存器0x40 val = 0x0
寄存器0x41 val = 0x0
寄存器0x42 val = 0x0
寄存器0x43 val = 0x0
寄存器0x44 val = 0x0
寄存器0x45 val = 0x0
寄存器0x46 val = 0x0
寄存器0x47 val = 0x0
寄存器0x48 val = 0x0
寄存器0x49 val = 0x0
寄存器0x50 val = 0x2000
寄存器0x51 val = 0xc000
寄存器0x52 val = 0x4500
寄存器0x53 val = 0x0
寄存器0x54 val = 0x0
寄存器0x55 val = 0x0
寄存器0x56 val = 0x0
寄存器0x57 val = 0x0
寄存器0x58 val = 0x700
寄存器0x59 val = 0x700
寄存器0x5a val = 0x700
寄存器0x5b val = 0x0
寄存器0x5c val = 0x0
寄存器0x5d val = 0x0
寄存器0x5e val = 0x0
寄存器0x5f val = 0x0
寄存器0x60 val = 0x0
寄存器0x61 val = 0x1e00
寄存器0x62 val = 0x0
寄存器0x63 val = 0xa00
寄存器0x64 val = 0x1100
寄存器0xb0 val = 0x400
寄存器0xb1 val = 0x4a00
寄存器0xf5 val = 0x3300
寄存器0xf6 val = 0x0
寄存器0xf7 val = 0x0
寄存器0xf8 val = 0x0
寄存器0xf9 val = 0x0
寄存器0xfa val = 0x0
寄存器0xfb val = 0x0
寄存器0xFC val = 0x0
寄存器0xFD val = 0x0
60 FPS
>>>>> 。 德赛尔(954)
寄存器0x0 val = 0x6000
寄存器0x1 val = 0x0
寄存器0x2 val = 0x2e00
寄存器0x3 val = 0x2000
寄存器0x4 val = 0xdf00
寄存器0x5 val = 0x100
寄存器0x6 val = 0x0
寄存器0x7 val = 0xfe00
寄存器0x8 val = 0x1c00
寄存器0x9 val = 0x1000
寄存器0xA val = 0x1300
寄存器0xb val = 0x2500
寄存器0xc val = 0x8100
寄存器0xd val = 0x900
寄存器0xe val = 0x800
寄存器0xF val = 0x7f00
寄存器0x10 val = 0x0
寄存器0x11 val = 0x0
寄存器0x12 val = 0x0
寄存器0x13 val = 0x0
寄存器0x14 val = 0x0
寄存器0x15 val = 0x0
寄存器0x16 val = 0x0
寄存器0x17 val = 0x0
寄存器0x18 val = 0x0
寄存器0x19 val = 0x0
寄存器0x1a val = 0x0
寄存器0x1b val = 0x0
寄存器0x1c val = 0x0
寄存器0x1d val = 0x0
寄存器0x1E val = 0x400
寄存器0x1F val = 0x200
寄存器0x22 val = 0x100
寄存器0x23 val = 0x0
寄存器0x24 val = 0x0
寄存器0x25 val = 0x0
寄存器0x26 val = 0x0
寄存器0x27 val = 0x0
寄存器0x28 val = 0x0
寄存器0x29 val = 0x0
寄存器0x2a val = 0x0
寄存器0x2b val = 0x0
寄存器0x2C val = 0x0
寄存器0x2D val = 0x0
寄存器0x2e val = 0x0
寄存器0x2F val = 0x0
寄存器0x30 val = 0x0
寄存器0x31 val = 0x0
寄存器0x32 val = 0x0
寄存器0x33 val = 0x100
寄存器0x35 val = 0x300
寄存器0x36 val = 0x0
寄存器0x37 val = 0x0
寄存器0x38 val = 0x0
寄存器0x39 val = 0x0
寄存器0x3a val = 0x0
寄存器0x3b val = 0x100
寄存器0x3E val = 0x0
寄存器0x40 val = 0x0
寄存器0x43 val = 0x100
寄存器0x44 val = 0x0
寄存器0x45 val = 0x0
寄存器0x46 val = 0x0
寄存器0x47 val = 0x0
寄存器0x48 val = 0x0
寄存器0x49 val = 0x0
寄存器0x4c val = 0x100
寄存器0x4d val = 0x300
寄存器0x4e val = 0xc00
寄存器0x50 val = 0x0
寄存器0x51 val = 0x0
寄存器0x52 val = 0x0
寄存器0x53 val = 0x300
寄存器0x54 val = 0x0
寄存器0x55 val = 0x0
寄存器0x56 val = 0x0
寄存器0x57 val = 0x0
寄存器0x59 val = 0x400
寄存器0x5a val = 0x0
寄存器0x5d val =传感器 ID
寄存器0x5e val = 0x0
寄存器0x5f val = 0x0
寄存器0x60 val = 0x0
寄存器0x61 val = 0x0
寄存器0x62 val = 0x0
寄存器0x63 val = 0x0
寄存器0x64 val = 0x0
寄存器0x65 val =传感器别名
寄存器0x66 val = 0x0
寄存器0x67 val = 0x0
寄存器0x68 val = 0x0
寄存器0x69 val = 0x0
寄存器0x6A val = 0x0
寄存器0x6b val = 0x0
寄存器0x6c val = 0x0
寄存器0x72 val = 0x400
寄存器0x73 val = 0x200
寄存器0x75 val = 0xa00
寄存器0x76 val = 0x0
寄存器0x78 val = 0x0
寄存器0x79 val = 0x100
寄存器0x7a val = 0xc00
寄存器0x7B val = 0x800
寄存器0x7d val = 0x0
寄存器0x7E val = 0x0
寄存器0x7f val = 0x0
寄存器0xa0 val = 0x200
寄存器0xa1 val = 0xf00
寄存器0xa2 val = 0x0
寄存器0xa3 val = 0x0
寄存器0xa4 val = 0x800
寄存器0xa6 val = 0x0
寄存器0xa7 val = 0x0
寄存器0xa8 val = 0x0
寄存器0xa9 val = 0x0
寄存器0xAA val = 0x0
寄存器0xab val = 0x0
寄存器0xac val = 0x0
寄存器0xAD val = 0x0
寄存器0xae val = 0x0
寄存器0xaf val = 0x0
寄存器0xb0 val = 0x400
寄存器0xb3 val = 0x800
寄存器0xb5 val = 0x0
寄存器0xb7 val = 0x0
寄存器0xbd val = 0x0
寄存器0xbe val = 0x0
寄存器0xbf val = 0x0
寄存器0xd0 val = 0x0
寄存器0xd3 val = 0x300
寄存器0xd6 val = 0x0
寄存器0xd7 val = 0x0
寄存器0xd8 val = 0x0
寄存器0xd9 val = 0x0
寄存器0xda val = 0x0
寄存器0xdb val = 0x6800
寄存器0xdc val = 0x0
寄存器0xdd val = 0x0
寄存器0xde val = 0x0
寄存器0xdf val = 0x0
寄存器0xf6 val = 0x0
寄存器0xf7 val = 0x0
寄存器0xf8 val = 0x0
寄存器0xf9 val = 0x0
寄存器0xfa val = 0x0
寄存器0xfb val = 0x0
>>>>> 串行器(953)
寄存器0x0 val = 0x3000
寄存器0x1 val = 0x0
寄存器0x2 val = 0x7300
寄存器0x3 val = 0x4800
寄存器0x4 val = 0x0
寄存器0x5 val = 0x300
寄存器0x6 val = 0x4100
寄存器0x7 val = 0x2800
寄存器0x8 val = 0xfe00
寄存器0x9 val = 0x1e00
寄存器0xA val = 0x1000
寄存器0xb val = 0x7f00
寄存器0xc val = 0x7f00
寄存器0xd val = 0xF000
寄存器0xe val = 0xf00
寄存器0xF val = 0x0
寄存器0x10 val = 0x0
寄存器0x11 val = 0x0
寄存器0x12 val = 0x0
寄存器0x13 val = 0x0
寄存器0x14 val = 0x0
寄存器0x1c val = 0x0
寄存器0x1d val = 0x0
寄存器0x1E val = 0x0
寄存器0x20 val = 0x0
寄存器0x21 val = 0x0
寄存器0x22 val = 0x0
寄存器0x23 val = 0x0
寄存器0x24 val = 0x0
寄存器0x25 val = 0x200
寄存器0x26 val = 0x0
寄存器0x27 val = 0x0
寄存器0x28 val = 0x6700
寄存器0x29 val = 0x3300
寄存器0x2A val = 0x100
寄存器0x2b val = 0x0
寄存器0x2C val = 0x0
寄存器0x2D val = 0x0
寄存器0x2e val = 0x0
寄存器0x2F val = 0x0
寄存器0x30 val = 0x0
寄存器0x32 val = 0x900
寄存器0x33 val = 0x400
寄存器0x34 val = 0x0
寄存器0x36 val = 0x800
寄存器0x38 val = 0x0
寄存器0x39 val = 0x0
寄存器0x3a val = 0x0
寄存器0x3b val = 0x0
寄存器0x3c val = 0x0
寄存器0x3D val = 0x0
寄存器0x3E val = 0x0
寄存器0x3f val = 0x0
寄存器0x40 val = 0x0
寄存器0x41 val = 0x0
寄存器0x42 val = 0x0
寄存器0x43 val = 0x0
寄存器0x44 val = 0x0
寄存器0x45 val = 0x0
寄存器0x46 val = 0x0
寄存器0x47 val = 0x0
寄存器0x48 val = 0x0
寄存器0x49 val = 0x0
寄存器0x4a val = 0x0
寄存器0x4b val = 0x0
寄存器0x4c val = 0x0
寄存器0x4d val = 0x0
寄存器0x4e val = 0x0
寄存器0x4f val = 0x0
寄存器0x53 val = 0x0
寄存器0x54 val = 0x0
寄存器0x55 val = 0x0
寄存器0x56 val = 0x0
寄存器0x57 val = 0x0
寄存器0x58 val = 0x700
寄存器0x59 val = 0x700
寄存器0x5a val = 0x700
寄存器0x5b val = 0x0
寄存器0x5c val = 0x0
寄存器0x5d val = 0x0
寄存器0x5e val = 0x0
寄存器0x5f val = 0x0
寄存器0x60 val = 0x0
寄存器0x62 val = 0x0
寄存器0x63 val = 0xa00
寄存器0xb0 val = 0x400
您好 Rathna:
我已经比较了这两个寄存器转储。 我可以看到的唯一区别是、在60fps 的情况下存在 CSI 错误;长度错误和校验和错误。
其他一切都是相同的。 DES 已锁定、并且在 DES 中接收到相同的线数和线长。 此外、DES 在其 CSI-2 Tx 端口具有有效的 CSI 数据。
4,我们没有收到任何缓冲区。
您能解释一下吗?
