[参考译文] DS90UB954-Q1EVM:当同轴电缆为15m DS90UB953 &DS90UB954时、无法从传感器获取流媒体。
Guru**** 2541160 points
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1339232/ds90ub954-q1evm-couldn-t-get-the-streaming-from-sensor-when-the-coax-cable-is-15m-ds90ub953-ds90ub954
器件型号:DS90UB954-Q1EVM
  我们能够使用串行器(DS90UB953)和解串器(DS90UB954)之间的5m 同轴电缆成功地从传感器获得流媒体。 不过、当尝试将电缆长度从5m 更改为15m 时、我们在通过串行器(DS90UB953)从传感器接收流媒体到解串器(DS90UB954)时遇到困难。  您能否建议对15m 设置所需的任何修改?
谢谢你。
    您好 Rathna:
    这可能是由于15m 电缆上的插入损耗较高。 为了确认这一点、您能否从 UB954提供寄存器转储、一个用于5m、一个用于15m。
    您好、Hamzeh:
      下面是5m 和15m 的转储。 请进行相应检查。
    /*****  5米 *** /
    >>>>> DESER (954):
    寄存器0x0 val = 0x6000
    寄存器0x1 val = 0x0
    寄存器0x2 val = 0x2e00
    寄存器0x3 val = 0x2000
    寄存器0x4 val = 0xdf00
    寄存器0x5 val = 0x100
    寄存器0x6 val = 0x0
    寄存器0x7 val = 0xfe00
    寄存器0x8 val = 0x1c00
    寄存器0x9 val = 0x1000
    寄存器0xA val = 0x1300
    寄存器0xb val = 0x2500
    寄存器0xc val = 0x8100
    寄存器0xd val = 0x900
    寄存器0xe val = 0x800
    寄存器0xF val = 0x7f00
    寄存器0x10 val = 0x0
    寄存器0x11 val = 0x0
    寄存器0x12 val = 0x0
    寄存器0x13 val = 0x0
    寄存器0x14 val = 0x0
    寄存器0x15 val = 0x0
    寄存器0x16 val = 0x0
    寄存器0x17 val = 0x0
    寄存器0x18 val = 0x0
    寄存器0x19 val = 0x0
    寄存器0x1a val = 0x0
    寄存器0x1b val = 0x0
    寄存器0x1c val = 0x0
    寄存器0x1d val = 0x0
    寄存器0x1E val = 0x400
    寄存器0x1F val = 0x200
    寄存器0x20 val = 0x2000
    寄存器0x21 val = 0x4400
    寄存器0x22 val = 0x100
    寄存器0x23 val = 0x0
    寄存器0x24 val = 0x0
    寄存器0x25 val = 0x0
    寄存器0x26 val = 0x0
    寄存器0x27 val = 0x0
    寄存器0x28 val = 0x0
    寄存器0x29 val = 0x0
    寄存器0x2a val = 0x0
    寄存器0x2b val = 0x0
    寄存器0x2C val = 0x0
    寄存器0x2D val = 0x0
    寄存器0x2e val = 0x0
    寄存器0x2F val = 0x0
    寄存器0x30 val = 0x0
    寄存器0x31 val = 0x0
    寄存器0x32 val = 0x0
    寄存器0x33 val = 0x100
    寄存器0x34 val = 0x4000
    寄存器0x35 val = 0x300
    寄存器0x36 val = 0x0
    寄存器0x37 val = 0x0
    寄存器0x38 val = 0x0
    寄存器0x39 val = 0x0
    寄存器0x3a val = 0x0
    寄存器0x3b val = 0x100
    寄存器0x3c val = 0x1400
    寄存器0x3D val = 0x6f00
    寄存器0x3E val = 0x0
    寄存器0x3f val = 0x4000
    寄存器0x40 val = 0x0
    寄存器0x41 val = 0xa700
    寄存器0x42 val = 0x7100
    寄存器0x43 val = 0x100
    寄存器0x44 val = 0x0
    寄存器0x45 val = 0x0
    寄存器0x46 val = 0x0
    寄存器0x47 val = 0x0
    寄存器0x48 val = 0x0
    寄存器0x49 val = 0x0
    寄存器0x4a val = 0x1000
    寄存器0x4b val = 0x1200
    寄存器0x4c val = 0x100
    寄存器0x4d val = 0x300
    寄存器0x4e val = 0x400
    寄存器0x4f val = 0x6400
    寄存器0x50 val = 0x0
    寄存器0x51 val = 0x0
    寄存器0x52 val = 0x0
    寄存器0x53 val = 0x300
    寄存器0x54 val = 0x0
    寄存器0x55 val = 0x0
    寄存器0x56 val = 0x0
    寄存器0x57 val = 0x0
    寄存器0x58 val = 0x9e00
    寄存器0x59 val = 0x400
    寄存器0x5a val = 0x0
    寄存器0x5b val = 0x3000
    寄存器0x5c val = 0x1800
    寄存器0x5d val =传感器 ID
    寄存器0x5e val = 0x0
    寄存器0x5f val = 0x0
    寄存器0x60 val = 0x0
    寄存器0x61 val = 0x0
    寄存器0x62 val = 0x0
    寄存器0x63 val = 0x0
    寄存器0x64 val = 0x0
    寄存器0x65 val = sensoralias
    寄存器0x66 val = 0x0
    寄存器0x67 val = 0x0
    寄存器0x68 val = 0x0
    寄存器0x69 val = 0x0
    寄存器0x6A val = 0x0
    寄存器0x6b val = 0x0
    寄存器0x6c val = 0x0
    寄存器0x6d val = 0xb400
    寄存器0x6e val = 0x8800
    寄存器0x6F val = 0x8800
    寄存器0x70 val = 0x1e00
    寄存器0x71 val = 0x1e00
    寄存器0x72 val = 0x400
    寄存器0x73 val = 0x200
    寄存器0x74 val = 0xd000
    寄存器0x75 val = 0xa00
    寄存器0x76 val = 0x0
    寄存器0x77 val = 0xc500
    寄存器0x78 val = 0x0
    寄存器0x79 val = 0x100
    寄存器0x7a val = 0x0
    寄存器0x7B val = 0x0
    寄存器0x7c val = 0x2000
    寄存器0x7d val = 0x0
    寄存器0x7E val = 0x0
    寄存器0x7f val = 0x0
    寄存器0xa0 val = 0x200
    寄存器0xa1 val = 0xf00
    寄存器0xa2 val = 0x0
    寄存器0xa3 val = 0x0
    寄存器0xa4 val = 0x800
    寄存器0xA5 val = 0x1900
    寄存器0xa6 val = 0x0
    寄存器0xa7 val = 0x0
    寄存器0xa8 val = 0x0
    寄存器0xa9 val = 0x0
    寄存器0xAA val = 0x0
    寄存器0xab val = 0x0
    寄存器0xac val = 0x0
    寄存器0xAD val = 0x0
    寄存器0xae val = 0x0
    寄存器0xaf val = 0x0
    寄存器0xb0 val = 0x400
    寄存器0xb1 val = 0x1400
    寄存器0xb2 val = 0x3f00
    寄存器0xb3 val = 0x800
    寄存器0xb4 val = 0x2500
    寄存器0xb5 val = 0x0
    寄存器0xb6 val = 0x1800
    寄存器0xb7 val = 0x0
    寄存器0xb8 val = 0x8c00
    寄存器0xb9 val = 0x3300
    寄存器0xba val = 0x8000
    寄存器0xbb val = 0x7400
    寄存器0xbc val = 0x8000
    寄存器0xbd val = 0x0
    寄存器0xbe val = 0x0
    寄存器0xbf val = 0x0
    寄存器0xd0 val = 0x0
    寄存器0xD1 val = 0x4300
    寄存器0xd2 val = 0x9400
    寄存器0xd3 val = 0x300
    寄存器0xd4 val = 0x6000
    寄存器0xd5 val = 0xf200
    寄存器0xd6 val = 0x0
    寄存器0xd7 val = 0x0
    寄存器0xd8 val = 0x0
    寄存器0xd9 val = 0x0
    寄存器0xda val = 0x0
    寄存器0xdb val = 0x0
    寄存器0xdc val = 0x0
    寄存器0xdd val = 0x0
    寄存器0xde val = 0x0
    寄存器0xdf val = 0x0
    寄存器0xf0 val = 0x5f00
    寄存器0xF1 val = 0x5500
    寄存器0xf2 val = 0x4200
    寄存器0xF3 val = 0x3900
    寄存器0xf4 val = 0x3500
    寄存器0xf5 val = 0x3400
    寄存器0xf6 val = 0x0
    寄存器0xf7 val = 0x0
    寄存器0xf8 val = 0x0
    寄存器0xf9 val = 0x0
    寄存器0xfa val = 0x0
    寄存器0xfb val = 0x0
    >>>>> 串行器(953)
    寄存器0x0 val = 0x3000
    寄存器0x1 val = 0x0
    寄存器0x2 val = 0x7300
    寄存器0x3 val = 0x4800
    寄存器0x4 val = 0x0
    寄存器0x5 val = 0x300
    寄存器0x6 val = 0x4100
    寄存器0x7 val = 0x2800
    寄存器0x8 val = 0xfe00
    寄存器0x9 val = 0x1e00
    寄存器0xA val = 0x1000
    寄存器0xb val = 0x7f00
    寄存器0xc val = 0x7f00
    寄存器0xd val = 0xF000
    寄存器0xe val = 0xf00
    寄存器0xF val = 0x0
    寄存器0x10 val = 0x0
    寄存器0x11 val = 0x0
    寄存器0x12 val = 0x0
    寄存器0x13 val = 0x0
    寄存器0x14 val = 0x0
    寄存器0x15 val = 0x2000
    寄存器0x16 val = 0x1800
    寄存器0x17 val = 0x3C00
    寄存器0x18 val = 0x8000
    寄存器0x19 val = 0x6200
    寄存器0x1a val = 0x6200
    寄存器0x1b val = 0x6200
    寄存器0x1c val = 0x0
    寄存器0x1d val = 0x0
    寄存器0x1E val = 0x0
    寄存器0x20 val = 0x0
    寄存器0x21 val = 0x0
    寄存器0x22 val = 0x0
    寄存器0x23 val = 0x0
    寄存器0x24 val = 0x0
    寄存器0x31 val = 0x2000
    寄存器0x32 val = 0x900
    寄存器0x33 val = 0x400
    寄存器0x34 val = 0x0
    寄存器0x35 val = 0x1000
    寄存器0x36 val = 0x800
    寄存器0x37 val = 0x6000
    寄存器0x38 val = 0x0
    寄存器0x39 val = 0x0
    寄存器0x3a val = 0x0
    寄存器0x3b val = 0x0
    寄存器0x3c val = 0x0
    寄存器0x3D val = 0x0
    寄存器0x3E val = 0x0
    寄存器0x3f val = 0x0
    寄存器0x40 val = 0x0
    寄存器0x41 val = 0x0
    寄存器0x42 val = 0x0
    寄存器0x43 val = 0x0
    寄存器0x44 val = 0x0
    寄存器0x45 val = 0x0
    寄存器0x46 val = 0x0
    寄存器0x47 val = 0x0
    寄存器0x48 val = 0x0
    寄存器0x49 val = 0x0
    寄存器0x50 val = 0x2000
    寄存器0x51 val = 0xc000
    寄存器0x52 val = 0x4500
    寄存器0x53 val = 0x0
    寄存器0x54 val = 0x0
    寄存器0x55 val = 0x0
    寄存器0x56 val = 0x0
    寄存器0x57 val = 0x0
    寄存器0x58 val = 0x700
    寄存器0x59 val = 0x700
    寄存器0x5a val = 0x700
    寄存器0x5b val = 0x0
    寄存器0x5c val = 0x0
    寄存器0x5d val = 0x0
    寄存器0x5e val = 0x0
    寄存器0x5f val = 0x0
    寄存器0x60 val = 0x0
    寄存器0x61 val = 0x1e00
    寄存器0x62 val = 0x0
    寄存器0x63 val = 0xa00
    寄存器0x64 val = 0x1100
    寄存器0xb0 val = 0x400
    寄存器0xb1 val = 0x4a00
    寄存器0xf5 val = 0x3300
    寄存器0xf6 val = 0x0
    寄存器0xf7 val = 0x0
    寄存器0xf8 val = 0x0
    寄存器0xf9 val = 0x0
    寄存器0xfa val = 0x0
    寄存器0xfb val = 0x0
    寄存器0xFC val = 0x0
    寄存器0xFD val = 0x0
    联合国大会议程项目3 15月 /
    >>>>> 德赛尔(954)
    寄存器0x0 val = 0x6000
    寄存器0x1 val = 0x0
    寄存器0x2 val = 0x2e00
    寄存器0x3 val = 0x2000
    寄存器0x4 val = 0xdf00
    寄存器0x5 val = 0x100
    寄存器0x6 val = 0x0
    寄存器0x7 val = 0xfe00
    寄存器0x8 val = 0x1c00
    寄存器0x9 val = 0x1000
    寄存器0xA val = 0x1300
    寄存器0xb val = 0x2500
    寄存器0xc val = 0x8100
    寄存器0xd val = 0x900
    寄存器0xe val = 0x800
    寄存器0xF val = 0x7f00
    寄存器0x10 val = 0x0
    寄存器0x11 val = 0x0
    寄存器0x12 val = 0x0
    寄存器0x13 val = 0x0
    寄存器0x14 val = 0x0
    寄存器0x15 val = 0x0
    寄存器0x16 val = 0x0
    寄存器0x17 val = 0x0
    寄存器0x18 val = 0x0
    寄存器0x19 val = 0x0
    寄存器0x1a val = 0x0
    寄存器0x1b val = 0x0
    寄存器0x1c val = 0x0
    寄存器0x1d val = 0x0
    寄存器0x1E val = 0x400
    寄存器0x1F val = 0x200
    寄存器0x22 val = 0x0
    寄存器0x23 val = 0x0
    寄存器0x24 val = 0x0
    寄存器0x25 val = 0x0
    寄存器0x26 val = 0x0
    寄存器0x27 val = 0x0
    寄存器0x28 val = 0x0
    寄存器0x29 val = 0x0
    寄存器0x2a val = 0x0
    寄存器0x2b val = 0x0
    寄存器0x2C val = 0x0
    寄存器0x2D val = 0x0
    寄存器0x2e val = 0x0
    寄存器0x2F val = 0x0
    寄存器0x30 val = 0x0
    寄存器0x31 val = 0x0
    寄存器0x32 val = 0x0
    寄存器0x33 val = 0x4100
    寄存器0x35 val = 0x100
    寄存器0x36 val = 0x0
    寄存器0x37 val = 0x0
    寄存器0x38 val = 0x0
    寄存器0x39 val = 0x0
    寄存器0x3a val = 0x0
    寄存器0x3b val = 0x100
    寄存器0x3E val = 0x0
    寄存器0x40 val = 0x0
    寄存器0x43 val = 0x100
    寄存器0x44 val = 0x0
    寄存器0x45 val = 0x0
    寄存器0x46 val = 0x0
    寄存器0x47 val = 0x0
    寄存器0x48 val = 0x0
    寄存器0x49 val = 0x0
    寄存器0x4c val = 0x100
    寄存器0x4d val = 0x300
    寄存器0x4e val = 0x400
    寄存器0x50 val = 0xFF00
    寄存器0x51 val = 0x0
    寄存器0x52 val = 0x0
    寄存器0x53 val = 0x300
    寄存器0x54 val = 0x0
    寄存器0x55 val = 0x0
    寄存器0x56 val = 0x0
    寄存器0x57 val = 0x0
    寄存器0x59 val = 0x400
    寄存器0x5a val = 0x0
    寄存器0x5d val =传感器地址
    寄存器0x5e val = 0x0
    寄存器0x5f val = 0x0
    寄存器0x60 val = 0x0
    寄存器0x61 val = 0x0
    寄存器0x62 val = 0x0
    寄存器0x63 val = 0x0
    寄存器0x64 val = 0x0
    寄存器0x65 val =传感器别名地址
    寄存器0x66 val = 0x0
    寄存器0x67 val = 0x0
    寄存器0x68 val = 0x0
    寄存器0x69 val = 0x0
    寄存器0x6A val = 0x0
    寄存器0x6b val = 0x0
    寄存器0x6c val = 0x0
    寄存器0x6d val = 0xbc00
    寄存器0x72 val = 0x400
    寄存器0x73 val = 0x0
    寄存器0x74 val = 0x0
    寄存器0x75 val = 0x0
    寄存器0x76 val = 0x0
    寄存器0x78 val = 0x0
    寄存器0x79 val = 0x100
    寄存器0x7a val = 0x0
    寄存器0x7B val = 0x0
    寄存器0x7d val = 0x0
    寄存器0x7E val = 0x0
    寄存器0x7f val = 0x0
    寄存器0xa0 val = 0x200
    寄存器0xa1 val = 0xf00
    寄存器0xa2 val = 0x0
    寄存器0xa3 val = 0x0
    寄存器0xa4 val = 0x800
    寄存器0xa6 val = 0x0
    寄存器0xa7 val = 0x0
    寄存器0xa8 val = 0x0
    寄存器0xa9 val = 0x0
    寄存器0xAA val = 0x0
    寄存器0xab val = 0x0
    寄存器0xac val = 0x0
    寄存器0xAD val = 0x0
    寄存器0xae val = 0x0
    寄存器0xaf val = 0x0
    寄存器0xb0 val = 0x400
    寄存器0xb3 val = 0x800
    寄存器0xb5 val = 0x0
    寄存器0xb7 val = 0x0
    寄存器0xbd val = 0x0
    寄存器0xbe val = 0x0
    寄存器0xbf val = 0x0
    寄存器0xd0 val = 0x0
    寄存器0xd3 val = 0x1f00
    寄存器0xd6 val = 0x0
    寄存器0xd7 val = 0x200
    寄存器0xd8 val = 0x0
    寄存器0xd9 val = 0x0
    寄存器0xda val = 0x0
    寄存器0xdb val = 0x0
    寄存器0xdc val = 0x0
    寄存器0xdd val = 0x0
    寄存器0xde val = 0x0
    寄存器0xdf val = 0x0
    寄存器0xf6 val = 0x0
    寄存器0xf7 val = 0x0
    寄存器0xf8 val = 0x0
    寄存器0xf9 val = 0x0
    寄存器0xfa val = 0x0
    寄存器0xfb val = 0x0
    寄存器0xFC val = 0x0
    寄存器0xFD val = 0x0
    寄存器0xFE val = 0x0
    >>>>> 串行器(953)
    寄存器0x0 val = 0x3000
    寄存器0x1 val = 0x0
    寄存器0x2 val = 0x7300
    寄存器0x3 val = 0x4800
    寄存器0x4 val = 0x0
    寄存器0x5 val = 0x300
    寄存器0x6 val = 0x4100
    寄存器0x7 val = 0x2800
    寄存器0x8 val = 0xfe00
    寄存器0x9 val = 0x1e00
    寄存器0xA val = 0x1000
    寄存器0xb val = 0x1300
    寄存器0xc val = 0x2600
    寄存器0xd val = 0xF000
    寄存器0xe val = 0xf00
    寄存器0xF val = 0x0
    寄存器0x10 val = 0x0
    寄存器0x11 val = 0x0
    寄存器0x12 val = 0x0
    寄存器0x13 val = 0x0
    寄存器0x14 val = 0x0
    寄存器0x1c val = 0x0
    寄存器0x1d val = 0x0
    寄存器0x1E val = 0x0
    寄存器0x1F val = 0x0
    寄存器0x20 val = 0x0
    寄存器0x21 val = 0x0
    寄存器0x22 val = 0x0
    寄存器0x23 val = 0x0
    寄存器0x24 val = 0x0
    寄存器0x25 val = 0x200
    寄存器0x26 val = 0x0
    寄存器0x27 val = 0x0
    寄存器0x28 val = 0x6700
    寄存器0x29 val = 0x3300
    寄存器0x2A val = 0x100
    寄存器0x2b val = 0x0
    寄存器0x2C val = 0x0
    寄存器0x2D val = 0x0
    寄存器0x2e val = 0x0
    寄存器0x2F val = 0x0
    寄存器0x30 val = 0x0
    寄存器0x32 val = 0x900
    寄存器0x33 val = 0x400
    寄存器0x34 val = 0x0
    寄存器0x36 val = 0x800
    寄存器0x38 val = 0x0
    寄存器0x39 val = 0x0
    寄存器0x3a val = 0x0
    寄存器0x3b val = 0x0
    寄存器0x3c val = 0x0
    寄存器0x3D val = 0x0
    寄存器0x3E val = 0x0
    寄存器0x3f val = 0x0
    寄存器0x40 val = 0x0
    寄存器0x41 val = 0x0
    寄存器0x42 val = 0x0
    寄存器0x43 val = 0x0
    寄存器0x44 val = 0x0
    寄存器0x45 val = 0x0
    寄存器0x46 val = 0x0
    寄存器0x47 val = 0x0
    寄存器0x48 val = 0x0
    寄存器0x49 val = 0x0
    寄存器0x4a val = 0x0
    寄存器0x4b val = 0x0
    寄存器0x4c val = 0x0
    寄存器0x4d val = 0x0
    寄存器0x4e val = 0x0
    寄存器0x4f val = 0x0
    寄存器0x53 val = 0x0
    寄存器0x54 val = 0x0
    寄存器0x55 val = 0x0
    寄存器0x56 val = 0x0
    寄存器0x57 val = 0x0
    寄存器0x58 val = 0x700
    寄存器0x59 val = 0x700
    寄存器0x5a val = 0x700
    寄存器0x5b val = 0x0
    寄存器0x5c val = 0x0
    寄存器0x5d val = 0x0
    寄存器0x5e val = 0x0
    寄存器0x5f val = 0x0
    寄存器0x60 val = 0x0
    寄存器0x61 val = 0x0
    寄存器0x62 val = 0x0
    寄存器0x63 val = 0x0
    寄存器0x64 val = 0x0
    寄存器0xb0 val = 0x400
    寄存器0xb3 val = 0x0
    寄存器0xb4 val = 0x0
    您好 Rathna:
    我已经查看了所提供的寄存器转储、以下是我的结果。 似乎图像传感器可能没有获得足够的电流来运行、或在其电源引脚上产生高噪声。 请进行测量、并确保运行正确。
    设计:
    寄存器0x73、74、75、76全为0表示在 DES RX 端口上没有接收到数据。
    寄存器0xD3 - 15M 的 AEQ Valeo 为0x1F、这是一个非常高的值。
    串行器:
    为什么在寄存器0x0B 和0x0C 上有不同的 I2C 时序设置?
    5m 内显示接收传感器数据类型的寄存器0x61为 YUV422 8位。 但在15m 远距离没有接收到数据。
    5m 字计数中的寄存器0x62是0x0a、在15m 中是0x00
    注意:请根据数据表建议将寄存器0x41从 A7更改为 A9。
