[参考译文] THVD1450:PLC 收发器解决方案(SSC P485 PL)
Guru**** 2930670 points
Other Parts Discussed in Thread: THVD8010, THVD8000
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1368315/thvd1450-plc-transceiver-solution-ssc-p485-pl
器件型号:THVD1450
主题中讨论的其他器件:THVD8010THVD8000
是否有任何 PLC 收发器解决方案,如 SSC P485 PL?
SSC P485 PL:https://www.alldatasheet.com/datasheet-pdf/pdf/95926/ETC/SSCP485PL.html;
