[参考译文] DP83848I:在 AM5728上将收发器上传到 PRU MII 端口时遇到问题
Guru**** 2897200 points
Other Parts Discussed in Thread: AM5728
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1391213/dp83848i-encountering-issues-with-uploading-transceivers-as-pru-mii-ports-on-am5728
器件型号:DP83848I
主题中讨论的其他器件:AM5728
我目前在基于AM5728的开发板上使用了DP83848作为pru mii收发器、在系统启动中能正常识别到收发器。但是网口无法使用、通过ip addr命令看到网口状态一直为NO 载波、状态关闭、使用ifconfig命令分配ip地址后也无法通信、并且不能ping通自己。请协助检查一下pcb设计与设备树配置有无问题、给出解决问题的意见。原理图如下e2eti.com/.../1121.Schematic-Prints.pdf设备树中相关配置
 * Copyright (C) 2015-2016 Texas Instruments Incorporated - http://www.ti.com/
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
	model = "TI AM5728 IDK";
	//compatible = "ti,am572x-beagle-x15", "ti,am5728", "ti,dra742", "ti,dra74", "ti,dra7";
	//compatible = "ti,am5728-idk", "ti,am5728", "ti,dra742", "ti,dra74",
	//	     "ti,dra7";
	aliases {
		ethernet2 = &pruss2_emac0;
		ethernet3 = &pruss2_emac1;
	/* Dual-MAC Ethernet application node on PRU-ICSS2 */
	pruss2_eth {
		compatible = "ti,am57-prueth";
		pruss = <&pruss2>;
		sram = <&ocmcram1>;
		interrupt-parent = <&pruss2_intc>;
		pruss2_emac0: ethernet-mii0 {
			phy-handle = <&pruss2_eth0_phy>;
			phy-mode = "mii";
			interrupts = <20>, <22>;
			interrupt-names = "rx", "tx";
			/* Filled in by bootloader */
			local-mac-address = [00 00 00 00 00 00];
		pruss2_emac1: ethernet-mii1 {
			phy-handle = <&pruss2_eth1_phy>;
			phy-mode = "mii";
			interrupts = <21>, <23>;
&mac {
	status = "okay";
	dual_emac;
&cpsw_emac0 {
	phy_id = <&davinci_mdio>, <1>;
	phy-mode = "rgmii";
	dual_emac_res_vlan = <1>;
&cpsw_emac1 {
	phy_id = <&davinci_mdio>, <2>;
	phy-mode = "rgmii";
	dual_emac_res_vlan = <2>;
&gpio3 {
         status = "okay";
&gpio5 {
	status = "okay";
&pruss1 {
	status = "disable";
	pru1_0: pru0@4b234000 {
		interrupt-parent = <&pruss1_intc>;
		interrupts = <16>, <17>;
		interrupt-names = "vring", "kick";
		status = "okay";
	pru1_1: pru1@4b238000 {
		interrupts = <18>, <19>;
		status = "okay";
&pruss2 {
	status = "okay";
	pru2_0: pru0@4b2b4000 {
		status = "okay";
	pru2_1: pru1@4b2b8000 {
		status = "okay";
&pruss2_mdio {
	status = "okay";
	pinctrl-names = "default";
	pinctrl-0 = <&pru2_mii_pins_default>;
	pruss2_eth0_phy: ethernet-phy@0 {
		reg = <1>;
		interrupt-parent = <&gpio3>;
		interrupts = <26 IRQ_TYPE_EDGE_FALLING>;
	pruss2_eth1_phy: ethernet-phy@1 {
		reg = <3>;
		interrupt-parent = <&gpio5>;
		interrupts = <17 IRQ_TYPE_EDGE_FALLING>;
&pruss2_mdio {
	reset-gpios = <&gpio7 10 GPIO_ACTIVE_LOW>,
		      <&gpio3 25 GPIO_ACTIVE_LOW>;
	reset-delay-us = <2>;	/* PHY datasheet states 1uS min */
&dra7_pmx_core {
	gpio3_pins: gpio3_pins {
		pinctrl-single,pins = <
			DRA7XX_CORE_IOPAD(0x3548, (PIN_OUTPUT_PULLUP | MUX_MODE14)) /* vin1a_d21.gpio3_25 */
			DRA7XX_CORE_IOPAD(0x354c, PIN_INPUT_PULLUP | MUX_MODE14) /* vin1a_d22.gpio3_26 */
	gpio5_pins: gpio5_pins {
			DRA7XX_CORE_IOPAD(0x3644, (PIN_INPUT_PULLUP | MUX_MODE14)) /* RMII_MHZ_50_CLK.gpio5_17 */
	gpio7_pins: gpio7_pins {
			DRA7XX_CORE_IOPAD(0x37b0, (PIN_OUTPUT_PULLUP | MUX_MODE14))    /* spi1_cs0.gpio7_10 (A24) */
	pru2_mii_pins_default: pru2_mii_pins_default {
			DRA7XX_CORE_IOPAD(0x36b8, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr1.pr2_mii_mt_clk */
			DRA7XX_CORE_IOPAD(0x36d4, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr8.pr2_mii0_txen */
			DRA7XX_CORE_IOPAD(0x36e4, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr12.pr2_mii0_txd0 */
			DRA7XX_CORE_IOPAD(0x36e0, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr11.pr2_mii0_txd1 */
			DRA7XX_CORE_IOPAD(0x36dc, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr10.pr2_mii0_txd2 */
			DRA7XX_CORE_IOPAD(0x36d8, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr9.pr2_mii0_txd3 */
			DRA7XX_CORE_IOPAD(0x36e8, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr13.pr2_mii_mr0_clk */
			DRA7XX_CORE_IOPAD(0x36ec, (PIN_INPUT_PULLDOWN | SLEWCONTROL | MUX_MODE11)) /* mcasp1_axr14.pr2_mii0_rxdv */
			DRA7XX_CORE_IOPAD(0x36b4, (PIN_INPUT_PULLUP | SLEWCONTROL | MUX_MODE11)) /* mcasp1_axr0.pr2_mii0_rxer */
			DRA7XX_CORE_IOPAD(0x370c, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp2_axr2.pr2_mii0_rxd0 */
			DRA7XX_CORE_IOPAD(0x36f8, (PIN_INPUT_SLEW | MUX_MODE11))   /* mcasp2_fsx.pr2_mii0_rxd1 */
			DRA7XX_CORE_IOPAD(0x36f4, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp2_aclkx.pr2_mii0_rxd2 */
			DRA7XX_CORE_IOPAD(0x36f0, (PIN_INPUT_SLEW | MUX_MODE11))   /* mcasp1_axr15.pr2_mii0_rxd3 */
			DRA7XX_CORE_IOPAD(0x3724, (PIN_INPUT_PULLDOWN | MUX_MODE11))   /* mcasp3_aclkx.pr2_mii0_crs */
			DRA7XX_CORE_IOPAD(0x3728, (PIN_INPUT_SLEW | MUX_MODE11))   /* mcasp3_fsx.pr2_mii0_col */
			//DRA7XX_CORE_IOPAD(0x3710, (PIN_INPUT_PULLDOWN | SLEWCONTROL | MUX_MODE11))   /* mcasp2_axr3.pr2_mii0_rxlink */
			DRA7XX_CORE_IOPAD(0x3774, (PIN_INPUT_PULLUP | MUX_MODE11)) /* gpio6_10.pr2_mii_mt1_clk */
			DRA7XX_CORE_IOPAD(0x3778, (PIN_INPUT_PULLUP | MUX_MODE11)) /* gpio6_11.pr2_mii1_txen */
			DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_dat1.pr2_mii1_txd0 */
			DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_dat0.pr2_mii1_txd1 */
			DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLUP | MUX_MODE11))   /* mmc3_cmd.pr2_mii1_txd2 */
			DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLUP | MUX_MODE11))   /* mmc3_clk.pr2_mii1_txd3 */
			DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_dat2 .pr2_mii_mr1_clk */
			DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_dat3.pr2_mii1_rxdv */
			DRA7XX_CORE_IOPAD(0x372c, (PIN_INPUT_PULLUP | SLEWCONTROL | MUX_MODE11)) /* mcasp3_axr0.pr2_mii1_rxer */
			DRA7XX_CORE_IOPAD(0x37a0, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_dat7.pr2_mii1_rxd0 */
			DRA7XX_CORE_IOPAD(0x379c, (PIN_INPUT_PULLDOWN | MUX_MODE11))   /* mmc3_dat6.pr2_mii1_rxd1 */
			DRA7XX_CORE_IOPAD(0x3798, (PIN_INPUT_PULLDOWN | MUX_MODE11))   /* mmc3_dat5.pr2_mii1_rxd2 */
			DRA7XX_CORE_IOPAD(0x3794, (PIN_INPUT_PULLDOWN | MUX_MODE11))   /* mmc3_dat4.pr2_mii1_rxd3 */
			DRA7XX_CORE_IOPAD(0x3698, (PIN_INPUT_PULLDOWN | MUX_MODE11))   /* xref_clk1.pr2_mii1_crs */
			DRA7XX_CORE_IOPAD(0x3694, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* xref_clk0.pr2_mii1_col */
			//DRA7XX_CORE_IOPAD(0x3730, (PIN_INPUT_PULLUP | SLEWCONTROL | MUX_MODE11)) /* mcasp3_axr1.pr2_mii1_rxlink */
			DRA7XX_CORE_IOPAD(0x36a4, (PIN_INPUT_PULLDOWN | MUX_MODE11))   /* mcasp1_aclkx.pr2_mdio_mdclk */
			DRA7XX_CORE_IOPAD(0x36a8, (PIN_INPUT_SLEW | MUX_MODE11))   /* mcasp1_fsx.pr2_mdio_data */
