[参考译文] DP83822IF:DP83822IF PHY 芯片是否支持100BASE-FX 模式下的 PROFINET?
Guru**** 2943430 points
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1426142/dp83822if-does-the-dp83822if-phy-chip-support-profinet-in-100base-fx-mode
器件型号:DP83822IF
