[参考译文] TXS0102:申请具有更高容性负载驱动能力的 TXS0102 的替代产品
Guru**** 2925550 points
Other Parts Discussed in Thread: TXS0102, TXU0202
https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1645798/txs0102-requesting-alternative-for-txs0102-with-higher-capacitive-load-driving-capability
器件型号: TXS0102
主题中讨论的其他器件: TXU0202
",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-hveid="CAAIAxAA" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">尊敬的团队:
",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-hveid="CAAIBBAA" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">我们有一个客户目前将 ",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 600;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-sfc-cb="" data-sfc-root="c">",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 600;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 600;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="">TXS0102 电压电平转换器用于 ",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 600;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-sfc-cb="" data-sfc-root="c">I2C 和 UART 协议。
",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-hveid="CAAIBRAA" data-sfc-cb="" data-sfc-root="c" data-sfc-cp=""> ",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 600;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-sfc-cb="" data-sfc-root="c"> 由于以下限制、客户在其应用中遇到波形失真:
    ",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-sfc-cb="" data-sfc-root="c">
  • ",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px="" 12px;="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-sae="" data-complete="true" data-hveid="CAAIBhAA" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 600;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sfc-cb="" data-sfc-root="c">布线长度较长 、从而导致高寄生电容。
  • ",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px="" 12px;="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-sae="" data-complete="true" data-hveid="CAAIBhAB" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 600;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sfc-cb="" data-sfc-root="c"> MCU 侧的驱动能力较弱。
",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-hveid="CAAIBxAA" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">在这些条件下、TXS0102 的边沿速率加速器不足以维持信号完整性。 您能否推荐一种引脚对引脚或功能替代产品、它既支持 I2C、又可提供 ",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 600;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-sfc-cb="" data-sfc-root="c">更强的容性负载驱动能力
",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-hveid="CAAICBAA" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">此致、
",="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-hveid="CAAICRAA" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">Tony Liu
