[参考译文] SN74LVC1G125:Vcc = 3.3V 时的最小输出电压
Guru**** 2933120 points
https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1648819/sn74lvc1g125-minimum-output-voltage-at-vcc-3-3-v
器件型号: SN74LVC1G125
我检查了数据表、并且在 Vcc = 3.0V 时、最小输出电压为:–2.4V (I =–16mA)–2.3V (I =–24mA)
当 Vcc = 3.3V 时、相应的最小输出电压是多少?
