[参考译文] SN74LVC2G07:当设备被卸除时,"输出被关闭"是什么意思?
Guru**** 2943430 points
Other Parts Discussed in Thread: SN74LVC2G07
https://e2e.ti.com/support/logic-group/logic/f/logic-forum/663990/sn74lvc2g07-when-device-is-depowered-what-does-the-output-is-turned-off-mean
部件号:SN74LVC2G07
当SN74LVC2G07 设备断电时,设备进入“Ioff”模式,“the output is turned off”(输出已关闭)。  将会发生什么情况:输出将被拉低还是变为HiZ?
    输出被置于高阻抗模式,电气特性表中的"Ioff"规范指定了泄漏。
