[参考译文] SN74S09:我们是否还有其他类似 SN74S09的器件、可以支持3.3V 高逻辑输入?
Guru**** 2943400 points
Other Parts Discussed in Thread: SN74ALS09, SN74LVC1G07, SN74LVC07A
https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1133632/sn74s09-do-we-have-other-device-similar-to-sn74s09-that-can-support-3-3v-high-logic-input
器件型号:SN74S09
主题中讨论的其他器件:SN74ALS09SN74LVC1G07SN74LVC07A
您好专家!
我们是否有任何具有 OC-OD 输出的多通道和门或门、可支持3.3V 高逻辑输入?
Shuai
