[参考译文] SN54HC541:54HC 和74HC 系列之间的差异
Guru**** 2782615 points
Other Parts Discussed in Thread: CD74HC541, CD54HC541, SN74HC541, SN54HC541
https://e2e.ti.com/support/logic-group/logic/f/logic-forum/986863/sn54hc541-difference-between-the-54hc-and-74hc-families
器件型号:SN54HC541
主题中讨论的其他器件:CD74HC541CD54HC541SN74HC541
您好、TI 专家
我对 CD54HC541和 CD74HC541之间的差异以及 SN54HC541和 SN74HC541之间的差异特别感兴趣。
Thomas
