[参考译文] SN74HC245:输入电压是否超过电源电压会损坏 IC?
Guru**** 2933630 points
Other Parts Discussed in Thread: SN74AHC245
https://e2e.ti.com/support/logic-group/logic/f/logic-forum/849701/sn74hc245-does-voltage-of-inputs-exceed-the-power-supply-damage-the-ic
器件型号:SN74HC245
主题中讨论的其他器件:SN74AHC245
如下所示,在 VCC_3V8_VGB 上电之前、SD0&SD1已经变为高电平、如果这种情况会损坏 IC?
非常感谢!
