[参考译文] SN74LVC2G04:SN74LVC2G04和 SN74LVC2GU04之间有何差异
Guru**** 2837190 points
Other Parts Discussed in Thread: SN74LVC2GU04, SN74LVC2G04
https://e2e.ti.com/support/logic-group/logic/f/logic-forum/745075/sn74lvc2g04-what-is-the-difference-between-sn74lvc2g04-and-sn74lvc2gu04
器件型号:SN74LVC2G04
尊敬的先生:
 SN74LVC2G04和 SN74LVC2GU04之间有何区别
    尊敬的 Vincent:
    U 表示非缓冲反向器--非缓冲反向器的增益较低,通常用于需要反馈的应用,如振荡器或低增益放大器。
