Other Parts Discussed in Thread: DRV8376-Q1
器件型号: DRV8376-Q1
",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-hveid="CAAIAhAA" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-subtree="aimfl">尊敬的团队:
",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-hveid="CAAIAxAA" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">我对该驱动器的 MODE 引脚配置有疑问、请参阅数据表 DRV8376-Q1(SLVS102.pdf、2025 年 5 月)的第 17 页。
- ",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-sfc-cb="" data-sfc-root="c">
- ",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px="" 12px;="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-sae="" data-complete="true" data-hveid="CAAIBBAA" data-sfc-cb="" data-sfc-root="ep" data-sfc-cp="">",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">MODE_SR 锁存状态的显式时序
",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sfc-cb="" data-sfc-root="c">数据表指出、MODE_SR 引脚 在上电期间为只读。 但是、没有时序图准确说明此采样的时间以及采样是否相对于哪个电源轨或控制信号。
- ",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-processed="true" data-sfc-cb="" data-sfc-root="c">
- ",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px="" 12px;="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-sae="" data-complete="true" data-hveid="CAAIBRAA" data-sfc-cb="" data-sfc-root="ep" data-sfc-cp="">",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">该器件是否会在 VM 超过 UVLO 阈值时对 MODE_SR 进行采样?
- ",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px="" 12px;="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-sae="" data-complete="true" data-hveid="CAAIBRAA" data-sfc-cb="" data-sfc-root="ep" data-sfc-cp="">",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">器件是否在创建 GVDD 后一次对 MODE_SR 进行采样?
- ",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px="" 12px;="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-sae="" data-complete="true" data-hveid="CAAIBRAB" data-sfc-cb="" data-sfc-root="ep" data-sfc-cp="">",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">它是否与 nSLEEP 的上升沿同步? 或 DRVOFF?
- ",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px="" 12px;="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sae="" data-hveid="CAAIBRAC" data-sfc-cb="" data-sfc-root="ep" data-sfc-cp="">",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">向 nSLEEP 施加短路逻辑复位脉冲时、器件是否会重新读取/重新锁存 MODE_SR 引脚状态?
- ",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px="" 12px;="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sae="" data-hveid="CAAIBRAC" data-sfc-cb="" data-sfc-root="ep" data-sfc-cp="">",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 0px;="" text-decoration:="" none;="" border-bottom:="" 0px="" rgb(10,="" 10,="" 10);"="" data-complete="true" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">而在另一个相关数据表中、以类似的方式连续对 MODE 引脚进行采样。
",="" roboto,="" arial,="" sans-serif;="" font-size:="" 16px;="" font-weight:="" 400;="" margin:="" 12px="" 0px="" text-decoration:="" none;="" border-bottom:="" rgb(10,="" 10,="" 10);"="" data-processed="true" data-complete="true" data-hveid="CAAICBAA" data-sfc-cb="" data-sfc-root="c" data-sfc-cp="">提前感谢您的澄清!
