[参考译文] MCF8316A:以固定速度旋转电机
Guru**** 2487425 points
https://e2e.ti.com/support/motor-drivers-group/motor-drivers/f/motor-drivers-forum/1134973/mcf8316a-rotate-the-motor-at-a-fixed-speed
器件型号:MCF8316A
您可以确定电机旋转速度吗? 目前、我发现一旦增加负载、速度会突然变大(有时速度变大、电流也变高、并将报告异常 BEMF 误差)。 这是我的参数 json 之一。 您能不能麻烦地提供一些建议。 非常感谢。
  "signature": "oneui-register-data",
  "data": [
        "idx": 0,
        "id": "isd_config",
        "value": "0x40000000"
        "idx": 1,
        "id": "rev_drive_config",
        "value": "0x2835917F"
        "idx": 2,
        "id": "motor_startup1",
        "value": "0x0B6A07D0"
        "idx": 3,
        "id": "motor_startup2",
        "value": "0x2B066A90"
        "idx": 4,
        "id": "closed_loop1",
        "value": "0x0C318134"
        "idx": 5,
        "id": "closed_loop2",
        "value": "0x1AADA57D"
        "idx": 6,
        "id": "closed_loop3",
        "value": "0x1C800003"
        "idx": 7,
        "id": "closed_loop4",
        "value": "0x0EA3831E"
        "idx": 8,
        "id": "speed_profiles1",
        "value": "0x00000000"
        "idx": 9,
        "id": "speed_profiles2",
        "idx": 10,
        "id": "speed_profiles3",
        "idx": 11,
        "id": "speed_profiles4",
        "idx": 12,
        "id": "speed_profiles5",
        "idx": 13,
        "id": "speed_profiles6",
        "idx": 0,
        "id": "fault_config1",
        "value": "0x5FE80204"
        "idx": 1,
        "id": "fault_config2",
        "value": "0x74000088"
        "idx": 0,
        "id": "pin_config",
        "value": "0x00000002"
        "idx": 1,
        "id": "device_config1",
        "value": "0x00100000"
        "idx": 2,
        "id": "device_config2",
        "value": "0x0000B000"
        "idx": 3,
        "id": "peri_config1",
        "idx": 4,
        "id": "gd_config1",
        "value": "0x00000100"
        "idx": 5,
        "id": "gd_config2",
        "value": "0x00200000"
        "idx": 0,
        "id": "ana_trim3",
        "value": "0x48004800"
        "idx": 1,
        "id": "ana_trim4",
        "idx": 2,
        "id": "ana_trim5",
        "value": "0x8000002A"
        "idx": 3,
        "id": "ana_trim6",
        "idx": 4,
        "id": "ana_trim7",
        "idx": 5,
        "id": "ana_trim8",
        "value": "0x00001433"
        "idx": 6,
        "id": "ana_trim9",
        "value": "0x0049F7E1"
        "idx": 7,
        "id": "ana_trim10",
        "value": "0x5374113C"
        "idx": 0,
        "id": "int_algo_1",
        "value": "0x00B9407D"
        "idx": 1,
        "id": "int_algo_2",
        "value": "0x000001A7"
        "idx": 0,
        "id": "gate_driver_fault_status",
        "idx": 1,
        "id": "controller_fault_status",
        "idx": 0,
        "id": "algo_status",
        "idx": 1,
        "id": "mtr_params",
        "idx": 2,
        "id": "algo_status_mpet",
        "value": "0x06000000"
        "idx": 0,
        "id": "dev_ctrl",
        "value": "0x20000000"
        "idx": 0,
        "id": "algo_ctrl1",
        "value": "0x9E8D0000"
        "idx": 1,
        "id": "algo_ctrl2",
        "idx": 2,
        "id": "current_pi",
        "value": "0x00053522"
        "idx": 3,
        "id": "speed_pi",
        "idx": 4,
        "id": "dac_1",
        "idx": 5,
        "id": "dac_2",
        "idx": 0,
        "id": "algorithm_state",
        "idx": 1,
        "id": "fg_speed_fdbk",
        "value": "0x7FFFFFFF"
        "idx": 2,
        "id": "bus_current",
        "idx": 3,
        "id": "phase_current_a",
        "idx": 4,
        "id": "phase_current_b",
        "idx": 5,
        "id": "phase_current_c",
        "idx": 6,
        "id": "csa_gain_feedback",
        "value": "0x00010003"
        "idx": 7,
        "id": "voltage_gain_feedback",
        "idx": 8,
        "id": "vm_voltage",
        "value": "0x01A14000"
        "idx": 9,
        "id": "phase_voltage_va",
        "idx": 10,
        "id": "phase_voltage_vb",
        "idx": 11,
        "id": "phase_voltage_vc",
        "idx": 12,
        "id": "sin_commutation_angle",
        "idx": 13,
        "id": "cos_commutation_angle",
        "idx": 14,
        "id": "ialpha",
        "idx": 15,
        "id": "ibeta",
        "idx": 16,
        "id": "valpha",
        "idx": 17,
        "id": "vbeta",
        "idx": 18,
        "id": "id",
        "idx": 19,
        "id": "iq",
        "idx": 20,
        "id": "vd",
        "idx": 21,
        "id": "vq",
        "idx": 22,
        "id": "iq_ref_rotor_align",
        "idx": 23,
        "id": "speed_ref_open_loop",
        "idx": 24,
        "id": "iq_ref_open_loop",
        "idx": 25,
        "id": "speed_ref_closed_loop",
        "idx": 26,
        "id": "id_ref_closed_loop",
        "idx": 27,
        "id": "iq_ref_closed_loop",
        "idx": 28,
        "id": "isd_state",
        "idx": 29,
        "id": "isd_speed",
        "idx": 30,
        "id": "ipd_state",
        "idx": 31,
        "id": "ipd_angle",
        "idx": 32,
        "id": "ed",
        "idx": 33,
        "id": "eq",
        "idx": 34,
        "id": "speed_fdbk",
        "idx": 35,
        "id": "theta_est",
Susan Ren
    您好 Susan、
    一般而言、当我们向电机添加负载时、速度会暂时下降、如果启用了 sped 环路、速度应恢复并稳定至所需速度。 当电机上的负载增加时、相电流增加是很常见的、但当负载增加时、电机速度增加是很奇怪的。 我检查了寄存器设置、并看到速度环路被启用、这很好。 我看到压摆率(在驱动器配置-栅极驱动器设置中)设置为25V/us。 您能否将其设置为200V/us。 这可能无法解决您的问题、但最好将压摆率设置为200V/us。 如果您没有看到速度稳定至所需速度、您能否尝试增大总线电压 VM 并查看这是否有帮助?
    Vishnu
    您好 Susan、
    您能告诉我们问题是否已解决?
    请告诉我们是否需要有关此问题的进一步支持。 谢谢
    Andrew
