主题中讨论的其他器件:MCT8316A、MCT8329A
您好、TI 专家!
我正在使用评估板来评估 MCT8329。 我看到对速度输入命令的响应相当慢。 Kp 和 ki 增益均处于最高配置。 关闭加速度设置为最高。 请告诉我需要哪些其他参数来进一步描述我的问题。
PS:我评估了 MCT8316A、速度命令响应非常快。 但由于转速较高时功率耗散会变得较高、因此这一步没有成功。
您好、TI 专家!
你好、Joshua、
1.寄存器设置添加为代码,无法附加文件。
2.我没有电机数据表。 测量的电机参数为: RS:0.16 Ω、Ls:8.9uH、额定磁通:0.00144V/Hz
3.当前电机最大速度设置为1750Hz。 当从48%变为51%速度输入命令时、所需的时间大约为500ms。 我希望它大约为100ms。
"signature": "oneui-register-data",
"data": [
"idx": 0,
"id": "isd_config",
"value": "0x7EC04D02"
"idx": 1,
"id": "motor_startup1",
"value": "0x4806C577"
"idx": 2,
"id": "motor_startup2",
"value": "0x33653815"
"idx": 3,
"id": "closed_loop1",
"value": "0x1F7F4C00"
"idx": 4,
"id": "closed_loop2",
"value": "0x23A1A498"
"idx": 5,
"id": "closed_loop3",
"value": "0x34C92001"
"idx": 6,
"id": "closed_loop4",
"value": "0x001AC953"
"idx": 7,
"id": "const_speed",
"value": "0x30010001"
"idx": 8,
"id": "const_pwr",
"value": "0x36B00640"
"idx": 9,
"id": "150_deg_two_ph_profile",
"value": "0x24DB7200"
"idx": 10,
"id": "150_deg_three_ph_profile",
"value": "0x48DB6946"
"idx": 11,
"id": "ref_profiles1",
"value": "0x032184A6"
"idx": 12,
"id": "ref_profiles2",
"value": "0x34C80AFC"
"idx": 13,
"id": "ref_profiles3",
"value": "0x4787D70C"
"idx": 14,
"id": "ref_profiles4",
"value": "0x000C9932"
"idx": 15,
"id": "ref_profiles5",
"value": "0x1F6BF200"
"idx": 16,
"id": "ref_profiles6",
"value": "0x00708000"
"idx": 0,
"id": "algo_ctrl1",
"value": "0x00000000"
"idx": 1,
"id": "device_ctrl",
"value": "0x00008000"
"idx": 0,
"id": "ana_trim3",
"value": "0x48004800"
"idx": 1,
"id": "ana_trim4",
"value": "0x4800000000"
"idx": 2,
"id": "ana_trim5",
"value": "0x00000048"
"idx": 3,
"id": "ana_trim6",
"idx": 4,
"id": "ana_trim7",
"value": "0x00F5A964"
"idx": 5,
"id": "ana_trim8",
"value": "0x00005E84"
"idx": 6,
"id": "ana_trim9",
"value": "0x00A9C81F"
"idx": 7,
"id": "ana_trim10",
"value": "0x53720F3C"
"idx": 0,
"id": "fault_config1",
"value": "0x71783604"
"idx": 1,
"id": "fault_config2",
"value": "0x7A85C00A"
"idx": 0,
"id": "gate_driver_fault_status",
"idx": 1,
"id": "controller_fault_status",
"idx": 0,
"id": "gd_config1",
"value": "0x000600FC"
"idx": 1,
"id": "gd_config2",
"idx": 0,
"id": "pin_config1",
"value": "0x20600004"
"idx": 1,
"id": "pin_config2",
"value": "0x3E0020AA"
"idx": 2,
"id": "device_config",
"value": "0x27104005"
"idx": 0,
"id": "sys_status1",
"value": "0x00520000"
"idx": 1,
"id": "sys_status2",
"value": "0x60010000"
"idx": 2,
"id": "sys_status3",
