[参考译文] MSP430F5172:如何为 MSP430F5172进行 OTA
Guru**** 2815505 points
Other Parts Discussed in Thread: MSP430F5172
https://e2e.ti.com/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/1109988/msp430f5172-how-to-ota-for-msp430f5172
器件型号:MSP430F5172
嗨、伙计。 我使用的是 MSP430F5172。  我需要按照以下说明为项目提供 OTA: https://github.com/rafaellcoellho/bsl-msp430
我的主程序位于0x8000 - 0xB250中
我编写文件 OTA 格式地址0xC500 -...
如何从地址0x8000开始更新文件 OTA?
还是可以直接将 OTA 文件写入地址0x8000?
谢谢您!
    请帮帮我。 请:(((((
    它看起来不像 BSL 问题。 这是与项目中的.cmd 相关的更多声音。 您可以在此处发送.cmd 文件吗?
    现金 Hao
    /* Copyright (c) 2019, Texas Instruments Incorporated                           */
    /*  All rights reserved.                                                        */
    /*  Redistribution and use in source and binary forms, with or without          */
    /*  modification, are permitted provided that the following conditions          */
    /*  are met:        */
    /*  *  Redistributions of source code must retain the above copyright           */
    /*     notice, this list of conditions and the following disclaimer.            */
    /*  *  Redistributions in binary form must reproduce the above copyright        */
    /*     notice, this list of conditions and the following disclaimer in the      */
    /*     documentation and/or other materials provided with the distribution.     */
    /*  *  Neither the name of Texas Instruments Incorporated nor the names of      */
    /*     its contributors may be used to endorse or promote products derived      */
    /*     from this software without specific prior written permission.            */
    /*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" */
    /*  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,       */
    /*  THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR      */
    /*  PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR            */
    /*  CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,       */
    /*  EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,         */
    /*  PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; */
    /*  OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,    */
    /*  WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR     */
    /*  OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,              */
    /*  EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.                          */
    /* lnk_msp430f5172.cmd - LINKER COMMAND FILE FOR LINKING MSP430F5172 PROGRAMS     */
    /*   Usage:  lnk430 <obj files...>    -o <out file> -m <map file> lnk.cmd     */
    /*           cl430  <src files...> -z -o <out file> -m <map file> lnk.cmd     */
    /* These linker options are for command line linking only.  For IDE linking,  */
    /* you should set your linker options in Project Properties                   */
    /* -c                                               LINK USING C CONVENTIONS  */
    /* -stack  0x0100                                   SOFTWARE STACK SIZE       */
    /* -heap   0x0100                                   HEAP AREA SIZE            */
    /* Version: 1.207                                                             */
    /* Specify the system memory map                                            */
    MEMORY
        SFR                     : origin = 0x0000, length = 0x0010
        PERIPHERALS_8BIT        : origin = 0x0010, length = 0x00F0
        PERIPHERALS_16BIT       : origin = 0x0100, length = 0x0100
        RAM                     : origin = 0x1C00, length = 0x0800
        INFOA                   : origin = 0x1980, length = 0x0080
        INFOB                   : origin = 0x1900, length = 0x0080
        INFOC                   : origin = 0x1880, length = 0x0080
        INFOD                   : origin = 0x1800, length = 0x0080
        FLASH                   : origin = 0x8000, length = 0x7F80
        INT00                   : origin = 0xFF80, length = 0x0002
        INT01                   : origin = 0xFF82, length = 0x0002
        INT02                   : origin = 0xFF84, length = 0x0002
        INT03                   : origin = 0xFF86, length = 0x0002
        INT04                   : origin = 0xFF88, length = 0x0002
        INT05                   : origin = 0xFF8A, length = 0x0002
        INT06                   : origin = 0xFF8C, length = 0x0002
        INT07                   : origin = 0xFF8E, length = 0x0002
        INT08                   : origin = 0xFF90, length = 0x0002
        INT09                   : origin = 0xFF92, length = 0x0002
        INT10                   : origin = 0xFF94, length = 0x0002
        INT11                   : origin = 0xFF96, length = 0x0002
        INT12                   : origin = 0xFF98, length = 0x0002
        INT13                   : origin = 0xFF9A, length = 0x0002
        INT14                   : origin = 0xFF9C, length = 0x0002
        INT15                   : origin = 0xFF9E, length = 0x0002
        INT16                   : origin = 0xFFA0, length = 0x0002
        INT17                   : origin = 0xFFA2, length = 0x0002
        INT18                   : origin = 0xFFA4, length = 0x0002
        INT19                   : origin = 0xFFA6, length = 0x0002
        INT20                   : origin = 0xFFA8, length = 0x0002
        INT21                   : origin = 0xFFAA, length = 0x0002
        INT22                   : origin = 0xFFAC, length = 0x0002
        INT23                   : origin = 0xFFAE, length = 0x0002
        INT24                   : origin = 0xFFB0, length = 0x0002
        INT25                   : origin = 0xFFB2, length = 0x0002
        INT26                   : origin = 0xFFB4, length = 0x0002
        INT27                   : origin = 0xFFB6, length = 0x0002
        INT28                   : origin = 0xFFB8, length = 0x0002
        INT29                   : origin = 0xFFBA, length = 0x0002
        INT30                   : origin = 0xFFBC, length = 0x0002
        INT31                   : origin = 0xFFBE, length = 0x0002
        INT32                   : origin = 0xFFC0, length = 0x0002
        INT33                   : origin = 0xFFC2, length = 0x0002
        INT34                   : origin = 0xFFC4, length = 0x0002
        INT35                   : origin = 0xFFC6, length = 0x0002
        INT36                   : origin = 0xFFC8, length = 0x0002
        INT37                   : origin = 0xFFCA, length = 0x0002
        INT38                   : origin = 0xFFCC, length = 0x0002
        INT39                   : origin = 0xFFCE, length = 0x0002
        INT40                   : origin = 0xFFD0, length = 0x0002
        INT41                   : origin = 0xFFD2, length = 0x0002
        INT42                   : origin = 0xFFD4, length = 0x0002
        INT43                   : origin = 0xFFD6, length = 0x0002
        INT44                   : origin = 0xFFD8, length = 0x0002
        INT45                   : origin = 0xFFDA, length = 0x0002
        INT46                   : origin = 0xFFDC, length = 0x0002
        INT47                   : origin = 0xFFDE, length = 0x0002
        INT48                   : origin = 0xFFE0, length = 0x0002
        INT49                   : origin = 0xFFE2, length = 0x0002
        INT50                   : origin = 0xFFE4, length = 0x0002
        INT51                   : origin = 0xFFE6, length = 0x0002
        INT52                   : origin = 0xFFE8, length = 0x0002
        INT53                   : origin = 0xFFEA, length = 0x0002
        INT54                   : origin = 0xFFEC, length = 0x0002
        INT55                   : origin = 0xFFEE, length = 0x0002
        INT56                   : origin = 0xFFF0, length = 0x0002
        INT57                   : origin = 0xFFF2, length = 0x0002
        INT58                   : origin = 0xFFF4, length = 0x0002
        INT59                   : origin = 0xFFF6, length = 0x0002
        INT60                   : origin = 0xFFF8, length = 0x0002
        INT61                   : origin = 0xFFFA, length = 0x0002
        INT62                   : origin = 0xFFFC, length = 0x0002
        RESET                   : origin = 0xFFFE, length = 0x0002
    /* Specify the sections allocation into memory                              */
    SECTIONS
        .bss        : {} > RAM                  /* Global & static vars              */
        .data       : {} > RAM                  /* Global & static vars              */
        .TI.noinit  : {} > RAM                  /* For #pragma noinit                */
        .sysmem     : {} > RAM                  /* Dynamic memory allocation area    */
        .stack      : {} > RAM (HIGH)           /* Software system stack             */
        .text       : {} > FLASH                /* Code                              */
        .cinit      : {} > FLASH                /* Initialization tables             */
        .const      : {} > FLASH                /* Constant data                     */
        .cio        : {} > RAM                  /* C I/O Buffer                      */
        .pinit      : {} > FLASH                /* C++ Constructor tables            */
        .binit      : {} > FLASH                /* Boot-time Initialization tables   */
        .init_array : {} > FLASH                /* C++ Constructor tables            */
        .mspabi.exidx : {} > FLASH              /* C++ Constructor tables            */
        .mspabi.extab : {} > FLASH              /* C++ Constructor tables            */
    #ifdef __TI_COMPILER_VERSION__
      #if __TI_COMPILER_VERSION__ >= 15009000
        #ifndef __LARGE_CODE_MODEL__
        .TI.ramfunc : {} load=FLASH, run=RAM, table(BINIT)
        #else
        .TI.ramfunc : {} load=FLASH | FLASH2, run=RAM, table(BINIT)
        #endif
      #endif
    #endif
        .infoA     : {} > INFOA              /* MSP430 INFO FLASH Memory segments */
        .infoB     : {} > INFOB
        .infoC     : {} > INFOC
        .infoD     : {} > INFOD
        /* MSP430 Interrupt vectors          */
        .int00       : {}               > INT00
        .int01       : {}               > INT01
        .int02       : {}               > INT02
        .int03       : {}               > INT03
        .int04       : {}               > INT04
        .int05       : {}               > INT05
        .int06       : {}               > INT06
        .int07       : {}               > INT07
        .int08       : {}               > INT08
        .int09       : {}               > INT09
        .int10       : {}               > INT10
        .int11       : {}               > INT11
        .int12       : {}               > INT12
        .int13       : {}               > INT13
        .int14       : {}               > INT14
        .int15       : {}               > INT15
        .int16       : {}               > INT16
        .int17       : {}               > INT17
        .int18       : {}               > INT18
        .int19       : {}               > INT19
        .int20       : {}               > INT20
        .int21       : {}               > INT21
        .int22       : {}               > INT22
        .int23       : {}               > INT23
        .int24       : {}               > INT24
        .int25       : {}               > INT25
        .int26       : {}               > INT26
        .int27       : {}               > INT27
        .int28       : {}               > INT28
        .int29       : {}               > INT29
        .int30       : {}               > INT30
        .int31       : {}               > INT31
        .int32       : {}               > INT32
        .int33       : {}               > INT33
        .int34       : {}               > INT34
        .int35       : {}               > INT35
        .int36       : {}               > INT36
        .int37       : {}               > INT37
        .int38       : {}               > INT38
        .int39       : {}               > INT39
        .int40       : {}               > INT40
        .int41       : {}               > INT41
        .int42       : {}               > INT42
        .int43       : {}               > INT43
        .int44       : {}               > INT44
        PORT2        : { * ( .int45 ) } > INT45 type = VECT_INIT
        PORT1        : { * ( .int46 ) } > INT46 type = VECT_INIT
        TIMER1_D1    : { * ( .int47 ) } > INT47 type = VECT_INIT
        TIMER1_D0    : { * ( .int48 ) } > INT48 type = VECT_INIT
        TEC1         : { * ( .int49 ) } > INT49 type = VECT_INIT
        DMA          : { * ( .int50 ) } > INT50 type = VECT_INIT
        TIMER0_A1    : { * ( .int51 ) } > INT51 type = VECT_INIT
        TIMER0_A0    : { * ( .int52 ) } > INT52 type = VECT_INIT
        ADC10        : { * ( .int53 ) } > INT53 type = VECT_INIT
        USCI_B0      : { * ( .int54 ) } > INT54 type = VECT_INIT
        USCI_A0      : { * ( .int55 ) } > INT55 type = VECT_INIT
        WDT          : { * ( .int56 ) } > INT56 type = VECT_INIT
        TIMER0_D1    : { * ( .int57 ) } > INT57 type = VECT_INIT
        TIMER0_D0    : { * ( .int58 ) } > INT58 type = VECT_INIT
        TEC0         : { * ( .int59 ) } > INT59 type = VECT_INIT
        COMP_B       : { * ( .int60 ) } > INT60 type = VECT_INIT
        UNMI         : { * ( .int61 ) } > INT61 type = VECT_INIT
        SYSNMI       : { * ( .int62 ) } > INT62 type = VECT_INIT
        .reset       : {}               > RESET  /* MSP430 Reset vector         */
    /* Include peripherals memory map                                           */
    -l msp430f5172.cmd
    感谢您的回复^^
    要升级软件、我必须修复 BSL、对吧? BSL 程序大小为2KB
    使用.cmd 文件、闪存从0x8000h 开始。 因此、软件应从0x8000h 开始。 这个.cmd 文件与你的项目中的文件相同。 如果是、就不会有问题。
    现金 Hao
