[参考译文] MSP430F5529:CCS 中的链接错误
Guru**** 2930810 points
https://e2e.ti.com/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/1037261/msp430f5529-linking-error-in-ccs
器件型号:MSP430F5529
尝试在 CCS 中编译时出现此错误。 它看起来是一个链接错误、但我不确定如何修复它。 我卸载了软件并重新安装了两次、这对我没有任何帮助。
**** Build of configuration Debug for project SSLAB2.asm ****
"C:\\ti\\ccs1040\\ccs\\utils\\bin\\gmake" -k -j 12 all -O
Building target: "SSLAB2.asm.out"
Invoking: MSP430 Linker
"C:/ti/ccs1040/ccs/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --code_model=small --data_model=small --use_hw_mpy=F5 --advice:power=all --define=__MSP430F5529__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 -z -m"SSLAB2.asm.map" --heap_size=0 --stack_size=0 --cinit_hold_wdt=on -i"C:/ti/ccs1040/ccs/ccs_base/msp430/include" -i"C:/ti/ccs1040/ccs/ccs_base/msp430/lib/5xx_6xx_FRxx" -i"C:/ti/ccs1040/ccs/tools/compiler/ti-cgt-msp430_20.2.5.LTS/lib" -i"C:/ti/ccs1040/ccs/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --reread_libs --diag_wrap=off --display_error_number --warn_sections --xml_link_info="SSLAB2.asm_linkInfo.xml" --entry_point=RESET --use_hw_mpy=F5 -o "SSLAB2.asm.out" "./main.obj" "../lnk_msp430f5529.cmd" -llibmath.a -llibc.a
<Linking>
warning #10366-D: automatic library build: using library "C:\ti\ccs1040\ccs\tools\compiler\ti-cgt-msp430_20.2.5.LTS\lib\rts430x_sc_sd_eabi.lib" for the first time, so it must be built. This may take a few minutes.
'[' is not recognized as an internal or external command,
operable program or batch file.
Makefile:1133: recipe for target '/libcxx/iostream.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/iostream.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -o3 --rtti -fg -I -fe /libcxx/iostream.cpp.obj -fs -ft -ppa -ppd=/iostream.cpp.pp, ...) failed.
Makefile:1133: recipe for target '/libcxx/locale.cpp.obj' failed
gmake.exe[2]: *** [/libcxx/iostream.cpp.obj] Error 2
process_begin: CreateProcess(NULL, cl430 libcxx/locale.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -o3 --rtti -fg -I -fe /libcxx/locale.cpp.obj -fs -ft -ppa -ppd=/locale.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/locale.cpp.obj] Error 2
Makefile:1141: recipe for target '/printf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 printf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /printf.c.obj -fs -ft -ppa -ppd=/printf.c.pp, ...) failed.
gmake.exe[2]: *** [/printf.c.obj] Error 2
Makefile:1141: recipe for target '/fprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fprintf.c.obj -fs -ft -ppa -ppd=/fprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/fprintf.c.obj] Error 2
Makefile:1141: recipe for target '/_printfi.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _printfi.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_printfi.c.obj -fs -ft -ppa -ppd=/_printfi.c.pp, ...) failed.
gmake.exe[2]: *** [/_printfi.c.obj] Error 2
Makefile:1141: recipe for target '/_printfi_min.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _printfi_min.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_printfi_min.c.obj -fs -ft -ppa -ppd=/_printfi_min.c.pp, ...) failed.
gmake.exe[2]: *** [/_printfi_min.c.obj] Error 2
Makefile:1141: recipe for target '/_printfi_nf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _printfi_nf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_printfi_nf.c.obj -fs -ft -ppa -ppd=/_printfi_nf.c.pp, ...) failed.
gmake.exe[2]: *** [/_printfi_nf.c.obj] Error 2
Makefile:1141: recipe for target '/_printfi_vector.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _printfi_vector.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_printfi_vector.c.obj -fs -ft -ppa -ppd=/_printfi_vector.c.pp, ...) failed.
gmake.exe[2]: *** [/_printfi_vector.c.obj] Error 2
Makefile:1141: recipe for target '/snprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 snprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /snprintf.c.obj -fs -ft -ppa -ppd=/snprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/snprintf.c.obj] Error 2
Makefile:1141: recipe for target '/sprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 sprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /sprintf.c.obj -fs -ft -ppa -ppd=/sprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/sprintf.c.obj] Error 2
Makefile:1141: recipe for target '/vfprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vfprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /vfprintf.c.obj -fs -ft -ppa -ppd=/vfprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/vfprintf.c.obj] Error 2
Makefile:1141: recipe for target '/vprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /vprintf.c.obj -fs -ft -ppa -ppd=/vprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/vprintf.c.obj] Error 2
Makefile:1141: recipe for target '/vsnprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vsnprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /vsnprintf.c.obj -fs -ft -ppa -ppd=/vsnprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/vsnprintf.c.obj] Error 2
Makefile:1141: recipe for target '/vsprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vsprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /vsprintf.c.obj -fs -ft -ppa -ppd=/vsprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/vsprintf.c.obj] Error 2
Makefile:1141: recipe for target '/_scanfi.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _scanfi.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_scanfi.c.obj -fs -ft -ppa -ppd=/_scanfi.c.pp, ...) failed.
gmake.exe[2]: *** [/_scanfi.c.obj] Error 2
Makefile:1141: recipe for target '/_scanfi_min.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _scanfi_min.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_scanfi_min.c.obj -fs -ft -ppa -ppd=/_scanfi_min.c.pp, ...) failed.
gmake.exe[2]: *** [/_scanfi_min.c.obj] Error 2
Makefile:1141: recipe for target '/_scanfi_nf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _scanfi_nf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_scanfi_nf.c.obj -fs -ft -ppa -ppd=/_scanfi_nf.c.pp, ...) failed.
gmake.exe[2]: *** [/_scanfi_nf.c.obj] Error 2
Makefile:1141: recipe for target '/fscanf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fscanf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fscanf.c.obj -fs -ft -ppa -ppd=/fscanf.c.pp, ...) failed.
gmake.exe[2]: *** [/fscanf.c.obj] Error 2
Makefile:1141: recipe for target '/sscanf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 sscanf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /sscanf.c.obj -fs -ft -ppa -ppd=/sscanf.c.pp, ...) failed.
gmake.exe[2]: *** [/sscanf.c.obj] Error 2
Makefile:1141: recipe for target '/fclose.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fclose.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fclose.c.obj -fs -ft -ppa -ppd=/fclose.c.pp, ...) failed.
gmake.exe[2]: *** [/fclose.c.obj] Error 2
Makefile:1141: recipe for target '/feof.c.obj' failed
process_begin: CreateProcess(NULL, cl430 feof.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /feof.c.obj -fs -ft -ppa -ppd=/feof.c.pp, ...) failed.
gmake.exe[2]: *** [/feof.c.obj] Error 2
Makefile:1141: recipe for target '/ferror.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ferror.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ferror.c.obj -fs -ft -ppa -ppd=/ferror.c.pp, ...) failed.
gmake.exe[2]: *** [/ferror.c.obj] Error 2
Makefile:1141: recipe for target '/fflush.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fflush.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fflush.c.obj -fs -ft -ppa -ppd=/fflush.c.pp, ...) failed.
gmake.exe[2]: *** [/fflush.c.obj] Error 2
Makefile:1141: recipe for target '/fgetc.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fgetc.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fgetc.c.obj -fs -ft -ppa -ppd=/fgetc.c.pp, ...) failed.
gmake.exe[2]: *** [/fgetc.c.obj] Error 2
Makefile:1141: recipe for target '/fgetpos.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fgetpos.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fgetpos.c.obj -fs -ft -ppa -ppd=/fgetpos.c.pp, ...) failed.
gmake.exe[2]: *** [/fgetpos.c.obj] Error 2
Makefile:1141: recipe for target '/fgets.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fgets.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fgets.c.obj -fs -ft -ppa -ppd=/fgets.c.pp, ...) failed.
gmake.exe[2]: *** [/fgets.c.obj] Error 2
Makefile:1141: recipe for target '/fopen.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fopen.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fopen.c.obj -fs -ft -ppa -ppd=/fopen.c.pp, ...) failed.
gmake.exe[2]: *** [/fopen.c.obj] Error 2
Makefile:1141: recipe for target '/fputc.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fputc.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fputc.c.obj -fs -ft -ppa -ppd=/fputc.c.pp, ...) failed.
gmake.exe[2]: *** [/fputc.c.obj] Error 2
Makefile:1141: recipe for target '/fputs.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fputs.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fputs.c.obj -fs -ft -ppa -ppd=/fputs.c.pp, ...) failed.
gmake.exe[2]: *** [/fputs.c.obj] Error 2
Makefile:1141: recipe for target '/fread.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fread.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fread.c.obj -fs -ft -ppa -ppd=/fread.c.pp, ...) failed.
gmake.exe[2]: *** [/fread.c.obj] Error 2
Makefile:1141: recipe for target '/fseek.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fseek.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fseek.c.obj -fs -ft -ppa -ppd=/fseek.c.pp, ...) failed.
gmake.exe[2]: *** [/fseek.c.obj] Error 2
Makefile:1141: recipe for target '/fsetpos.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fsetpos.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fsetpos.c.obj -fs -ft -ppa -ppd=/fsetpos.c.pp, ...) failed.
gmake.exe[2]: *** [/fsetpos.c.obj] Error 2
Makefile:1141: recipe for target '/ftell.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ftell.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ftell.c.obj -fs -ft -ppa -ppd=/ftell.c.pp, ...) failed.
gmake.exe[2]: *** [/ftell.c.obj] Error 2
Makefile:1141: recipe for target '/fwrite.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fwrite.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fwrite.c.obj -fs -ft -ppa -ppd=/fwrite.c.pp, ...) failed.
gmake.exe[2]: *** [/fwrite.c.obj] Error 2
Makefile:1141: recipe for target '/_bufread.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _bufread.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_bufread.c.obj -fs -ft -ppa -ppd=/_bufread.c.pp, ...) failed.
gmake.exe[2]: *** [/_bufread.c.obj] Error 2
Makefile:1141: recipe for target '/_io_perm.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _io_perm.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_io_perm.c.obj -fs -ft -ppa -ppd=/_io_perm.c.pp, ...) failed.
gmake.exe[2]: *** [/_io_perm.c.obj] Error 2
Makefile:1141: recipe for target '/getenv.c.obj' failed
process_begin: CreateProcess(NULL, cl430 getenv.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /getenv.c.obj -fs -ft -ppa -ppd=/getenv.c.pp, ...) failed.
gmake.exe[2]: *** [/getenv.c.obj] Error 2
Makefile:1141: recipe for target '/getdevice.c.obj' failed
process_begin: CreateProcess(NULL, cl430 getdevice.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /getdevice.c.obj -fs -ft -ppa -ppd=/getdevice.c.pp, ...) failed.
gmake.exe[2]: *** [/getdevice.c.obj] Error 2
Makefile:1141: recipe for target '/setbuf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 setbuf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /setbuf.c.obj -fs -ft -ppa -ppd=/setbuf.c.pp, ...) failed.
gmake.exe[2]: *** [/setbuf.c.obj] Error 2
Makefile:1141: recipe for target '/setvbuf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 setvbuf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /setvbuf.c.obj -fs -ft -ppa -ppd=/setvbuf.c.pp, ...) failed.
gmake.exe[2]: *** [/setvbuf.c.obj] Error 2
Makefile:1141: recipe for target '/ungetc.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ungetc.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ungetc.c.obj -fs -ft -ppa -ppd=/ungetc.c.pp, ...) failed.
gmake.exe[2]: *** [/ungetc.c.obj] Error 2
Makefile:1157: recipe for target '/xlocale.c.obj' failed
process_begin: CreateProcess(NULL, cl430 xlocale.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /xlocale.c.obj -fs -ft -ppa -ppd=/xlocale.c.pp, ...) failed.
gmake.exe[2]: *** [/xlocale.c.obj] Error 2
Makefile:1157: recipe for target '/locale_inttypes.c.obj' failed
process_begin: CreateProcess(NULL, cl430 locale_inttypes.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /locale_inttypes.c.obj -fs -ft -ppa -ppd=/locale_inttypes.c.pp, ...) failed.
gmake.exe[2]: *** [/locale_inttypes.c.obj] Error 2
Makefile:1157: recipe for target '/locale_stdio.c.obj' failed
process_begin: CreateProcess(NULL, cl430 locale_stdio.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /locale_stdio.c.obj -fs -ft -ppa -ppd=/locale_stdio.c.pp, ...) failed.
gmake.exe[2]: *** [/locale_stdio.c.obj] Error 2
Makefile:1157: recipe for target '/locale_stdlib.c.obj' failed
process_begin: CreateProcess(NULL, cl430 locale_stdlib.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /locale_stdlib.c.obj -fs -ft -ppa -ppd=/locale_stdlib.c.pp, ...) failed.
gmake.exe[2]: *** [/locale_stdlib.c.obj] Error 2
Makefile:1157: recipe for target '/locale_string.c.obj' failed
process_begin: CreateProcess(NULL, cl430 locale_string.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /locale_string.c.obj -fs -ft -ppa -ppd=/locale_string.c.pp, ...) failed.
gmake.exe[2]: *** [/locale_string.c.obj] Error 2
Makefile:1157: recipe for target '/locale_strings.c.obj' failed
process_begin: CreateProcess(NULL, cl430 locale_strings.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /locale_strings.c.obj -fs -ft -ppa -ppd=/locale_strings.c.pp, ...) failed.
gmake.exe[2]: *** [/locale_strings.c.obj] Error 2
Makefile:1157: recipe for target '/locale_time.c.obj' failed
process_begin: CreateProcess(NULL, cl430 locale_time.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /locale_time.c.obj -fs -ft -ppa -ppd=/locale_time.c.pp, ...) failed.
gmake.exe[2]: *** [/locale_time.c.obj] Error 2
Makefile:1157: recipe for target '/locale_wchar.c.obj' failed
process_begin: CreateProcess(NULL, cl430 locale_wchar.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /locale_wchar.c.obj -fs -ft -ppa -ppd=/locale_wchar.c.pp, ...) failed.
gmake.exe[2]: *** [/locale_wchar.c.obj] Error 2
Makefile:1165: recipe for target '/stdlib_exception.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 stdlib_exception.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --preinclude __config_site --rtti -fg -I -fe /stdlib_exception.cpp.obj -fs -ft -ppa -ppd=/stdlib_exception.cpp.pp, ...) failed.
gmake.exe[2]: *** [/stdlib_exception.cpp.obj] Error 2
Makefile:1165: recipe for target '/stdlib_typeinfo.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 stdlib_typeinfo.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --preinclude __config_site --rtti -fg -I -fe /stdlib_typeinfo.cpp.obj -fs -ft -ppa -ppd=/stdlib_typeinfo.cpp.pp, ...) failed.
gmake.exe[2]: *** [/stdlib_typeinfo.cpp.obj] Error 2
Makefile:1173: recipe for target '/e_acosf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_acosf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_acosf.c.obj -fs -ft -ppa -ppd=/e_acosf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_acosf.c.obj] Error 2
Makefile:1173: recipe for target '/e_acoshf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_acoshf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_acoshf.c.obj -fs -ft -ppa -ppd=/e_acoshf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_acoshf.c.obj] Error 2
Makefile:1173: recipe for target '/e_asinf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_asinf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_asinf.c.obj -fs -ft -ppa -ppd=/e_asinf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_asinf.c.obj] Error 2
Makefile:1173: recipe for target '/e_atan2f.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_atan2f.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_atan2f.c.obj -fs -ft -ppa -ppd=/e_atan2f.c.pp, ...) failed.
gmake.exe[2]: *** [/e_atan2f.c.obj] Error 2
Makefile:1173: recipe for target '/e_atanhf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_atanhf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_atanhf.c.obj -fs -ft -ppa -ppd=/e_atanhf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_atanhf.c.obj] Error 2
Makefile:1173: recipe for target '/e_coshf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_coshf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_coshf.c.obj -fs -ft -ppa -ppd=/e_coshf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_coshf.c.obj] Error 2
Makefile:1173: recipe for target '/e_expf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_expf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_expf.c.obj -fs -ft -ppa -ppd=/e_expf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_expf.c.obj] Error 2
Makefile:1173: recipe for target '/e_fmodf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_fmodf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_fmodf.c.obj -fs -ft -ppa -ppd=/e_fmodf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_fmodf.c.obj] Error 2
Makefile:1173: recipe for target '/e_lgammaf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_lgammaf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_lgammaf.c.obj -fs -ft -ppa -ppd=/e_lgammaf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_lgammaf.c.obj] Error 2
Makefile:1173: recipe for target '/e_lgammaf_r.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_lgammaf_r.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_lgammaf_r.c.obj -fs -ft -ppa -ppd=/e_lgammaf_r.c.pp, ...) failed.
gmake.exe[2]: *** [/e_lgammaf_r.c.obj] Error 2
Makefile:1173: recipe for target '/e_log10f.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_log10f.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_log10f.c.obj -fs -ft -ppa -ppd=/e_log10f.c.pp, ...) failed.
gmake.exe[2]: *** [/e_log10f.c.obj] Error 2
Makefile:1173: recipe for target '/e_log2f.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_log2f.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_log2f.c.obj -fs -ft -ppa -ppd=/e_log2f.c.pp, ...) failed.
gmake.exe[2]: *** [/e_log2f.c.obj] Error 2
Makefile:1173: recipe for target '/e_logf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_logf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_logf.c.obj -fs -ft -ppa -ppd=/e_logf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_logf.c.obj] Error 2
Makefile:1173: recipe for target '/e_powf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_powf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_powf.c.obj -fs -ft -ppa -ppd=/e_powf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_powf.c.obj] Error 2
Makefile:1173: recipe for target '/e_remainderf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_remainderf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_remainderf.c.obj -fs -ft -ppa -ppd=/e_remainderf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_remainderf.c.obj] Error 2
Makefile:1173: recipe for target '/e_sinhf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_sinhf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_sinhf.c.obj -fs -ft -ppa -ppd=/e_sinhf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_sinhf.c.obj] Error 2
Makefile:1173: recipe for target '/e_sqrtf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_sqrtf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_sqrtf.c.obj -fs -ft -ppa -ppd=/e_sqrtf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_sqrtf.c.obj] Error 2
Makefile:1173: recipe for target '/k_cosf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 k_cosf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /k_cosf.c.obj -fs -ft -ppa -ppd=/k_cosf.c.pp, ...) failed.
gmake.exe[2]: *** [/k_cosf.c.obj] Error 2
Makefile:1173: recipe for target '/k_sinf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 k_sinf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /k_sinf.c.obj -fs -ft -ppa -ppd=/k_sinf.c.pp, ...) failed.
gmake.exe[2]: *** [/k_sinf.c.obj] Error 2
Makefile:1173: recipe for target '/k_tanf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 k_tanf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /k_tanf.c.obj -fs -ft -ppa -ppd=/k_tanf.c.pp, ...) failed.
gmake.exe[2]: *** [/k_tanf.c.obj] Error 2
Makefile:1173: recipe for target '/s_asinhf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_asinhf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_asinhf.c.obj -fs -ft -ppa -ppd=/s_asinhf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_asinhf.c.obj] Error 2
Makefile:1173: recipe for target '/s_atanf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_atanf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_atanf.c.obj -fs -ft -ppa -ppd=/s_atanf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_atanf.c.obj] Error 2
Makefile:1173: recipe for target '/s_cbrtf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cbrtf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cbrtf.c.obj -fs -ft -ppa -ppd=/s_cbrtf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cbrtf.c.obj] Error 2
Makefile:1173: recipe for target '/s_ceilf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_ceilf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_ceilf.c.obj -fs -ft -ppa -ppd=/s_ceilf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_ceilf.c.obj] Error 2
Makefile:1173: recipe for target '/s_cosf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cosf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cosf.c.obj -fs -ft -ppa -ppd=/s_cosf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cosf.c.obj] Error 2
Makefile:1173: recipe for target '/s_erff.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_erff.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_erff.c.obj -fs -ft -ppa -ppd=/s_erff.c.pp, ...) failed.
gmake.exe[2]: *** [/s_erff.c.obj] Error 2
Makefile:1173: recipe for target '/s_exp2f.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_exp2f.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_exp2f.c.obj -fs -ft -ppa -ppd=/s_exp2f.c.pp, ...) failed.
gmake.exe[2]: *** [/s_exp2f.c.obj] Error 2
Makefile:1173: recipe for target '/s_expm1f.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_expm1f.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_expm1f.c.obj -fs -ft -ppa -ppd=/s_expm1f.c.pp, ...) failed.
gmake.exe[2]: *** [/s_expm1f.c.obj] Error 2
Makefile:1173: recipe for target '/s_fabsf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_fabsf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_fabsf.c.obj -fs -ft -ppa -ppd=/s_fabsf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_fabsf.c.obj] Error 2
Makefile:1173: recipe for target '/s_fdim.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_fdim.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_fdim.c.obj -fs -ft -ppa -ppd=/s_fdim.c.pp, ...) failed.
gmake.exe[2]: *** [/s_fdim.c.obj] Error 2
Makefile:1173: recipe for target '/s_floorf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_floorf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_floorf.c.obj -fs -ft -ppa -ppd=/s_floorf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_floorf.c.obj] Error 2
Makefile:1173: recipe for target '/s_fmaf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_fmaf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_fmaf.c.obj -fs -ft -ppa -ppd=/s_fmaf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_fmaf.c.obj] Error 2
Makefile:1173: recipe for target '/s_frexpf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_frexpf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_frexpf.c.obj -fs -ft -ppa -ppd=/s_frexpf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_frexpf.c.obj] Error 2
Makefile:1173: recipe for target '/s_ilogbf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_ilogbf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_ilogbf.c.obj -fs -ft -ppa -ppd=/s_ilogbf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_ilogbf.c.obj] Error 2
Makefile:1173: recipe for target '/s_logbf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_logbf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_logbf.c.obj -fs -ft -ppa -ppd=/s_logbf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_logbf.c.obj] Error 2
Makefile:1173: recipe for target '/s_llrint.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_llrint.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_llrint.c.obj -fs -ft -ppa -ppd=/s_llrint.c.pp, ...) failed.
gmake.exe[2]: *** [/s_llrint.c.obj] Error 2
Makefile:1173: recipe for target '/s_llrintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_llrintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_llrintf.c.obj -fs -ft -ppa -ppd=/s_llrintf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_llrintf.c.obj] Error 2
Makefile:1173: recipe for target '/s_llrintl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_llrintl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_llrintl.c.obj -fs -ft -ppa -ppd=/s_llrintl.c.pp, ...) failed.
gmake.exe[2]: *** [/s_llrintl.c.obj] Error 2
Makefile:1173: recipe for target '/s_llround.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_llround.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_llround.c.obj -fs -ft -ppa -ppd=/s_llround.c.pp, ...) failed.
gmake.exe[2]: *** [/s_llround.c.obj] Error 2
Makefile:1173: recipe for target '/s_llroundf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_llroundf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_llroundf.c.obj -fs -ft -ppa -ppd=/s_llroundf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_llroundf.c.obj] Error 2
Makefile:1173: recipe for target '/s_llroundl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_llroundl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_llroundl.c.obj -fs -ft -ppa -ppd=/s_llroundl.c.pp, ...) failed.
gmake.exe[2]: *** [/s_llroundl.c.obj] Error 2
Makefile:1173: recipe for target '/s_lrint.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_lrint.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_lrint.c.obj -fs -ft -ppa -ppd=/s_lrint.c.pp, ...) failed.
gmake.exe[2]: *** [/s_lrint.c.obj] Error 2
Makefile:1173: recipe for target '/s_lrintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_lrintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_lrintf.c.obj -fs -ft -ppa -ppd=/s_lrintf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_lrintf.c.obj] Error 2
Makefile:1173: recipe for target '/s_lrintl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_lrintl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_lrintl.c.obj -fs -ft -ppa -ppd=/s_lrintl.c.pp, ...) failed.
gmake.exe[2]: *** [/s_lrintl.c.obj] Error 2
Makefile:1173: recipe for target '/s_lround.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_lround.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_lround.c.obj -fs -ft -ppa -ppd=/s_lround.c.pp, ...) failed.
gmake.exe[2]: *** [/s_lround.c.obj] Error 2
Makefile:1173: recipe for target '/s_lroundf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_lroundf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_lroundf.c.obj -fs -ft -ppa -ppd=/s_lroundf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_lroundf.c.obj] Error 2
Makefile:1173: recipe for target '/s_lroundl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_lroundl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_lroundl.c.obj -fs -ft -ppa -ppd=/s_lroundl.c.pp, ...) failed.
gmake.exe[2]: *** [/s_lroundl.c.obj] Error 2
Makefile:1173: recipe for target '/s_modff.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_modff.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_modff.c.obj -fs -ft -ppa -ppd=/s_modff.c.pp, ...) failed.
gmake.exe[2]: *** [/s_modff.c.obj] Error 2
Makefile:1173: recipe for target '/s_nearbyint.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_nearbyint.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_nearbyint.c.obj -fs -ft -ppa -ppd=/s_nearbyint.c.pp, ...) failed.
gmake.exe[2]: *** [/s_nearbyint.c.obj] Error 2
Makefile:1173: recipe for target '/s_nextafterf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_nextafterf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_nextafterf.c.obj -fs -ft -ppa -ppd=/s_nextafterf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_nextafterf.c.obj] Error 2
Makefile:1173: recipe for target '/s_nexttowardf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_nexttowardf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_nexttowardf.c.obj -fs -ft -ppa -ppd=/s_nexttowardf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_nexttowardf.c.obj] Error 2
Makefile:1173: recipe for target '/s_remquof.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_remquof.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_remquof.c.obj -fs -ft -ppa -ppd=/s_remquof.c.pp, ...) failed.
gmake.exe[2]: *** [/s_remquof.c.obj] Error 2
Makefile:1173: recipe for target '/s_rintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_rintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_rintf.c.obj -fs -ft -ppa -ppd=/s_rintf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_rintf.c.obj] Error 2
Makefile:1173: recipe for target '/s_roundf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_roundf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_roundf.c.obj -fs -ft -ppa -ppd=/s_roundf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_roundf.c.obj] Error 2
Makefile:1173: recipe for target '/s_scalbln.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_scalbln.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_scalbln.c.obj -fs -ft -ppa -ppd=/s_scalbln.c.pp, ...) failed.
gmake.exe[2]: *** [/s_scalbln.c.obj] Error 2
Makefile:1173: recipe for target '/s_scalbnf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_scalbnf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_scalbnf.c.obj -fs -ft -ppa -ppd=/s_scalbnf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_scalbnf.c.obj] Error 2
Makefile:1173: recipe for target '/s_sinf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_sinf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_sinf.c.obj -fs -ft -ppa -ppd=/s_sinf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_sinf.c.obj] Error 2
Makefile:1173: recipe for target '/s_tanf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_tanf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_tanf.c.obj -fs -ft -ppa -ppd=/s_tanf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_tanf.c.obj] Error 2
Makefile:1173: recipe for target '/s_tanhf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_tanhf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_tanhf.c.obj -fs -ft -ppa -ppd=/s_tanhf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_tanhf.c.obj] Error 2
Makefile:1173: recipe for target '/s_tgammaf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_tgammaf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_tgammaf.c.obj -fs -ft -ppa -ppd=/s_tgammaf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_tgammaf.c.obj] Error 2
Makefile:1173: recipe for target '/s_truncf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_truncf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_truncf.c.obj -fs -ft -ppa -ppd=/s_truncf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_truncf.c.obj] Error 2
Makefile:1181: recipe for target '/exception.c.obj' failed
process_begin: CreateProcess(NULL, cl430 exception.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /exception.c.obj -fs -ft -ppa -ppd=/exception.c.pp, ...) failed.
gmake.exe[2]: *** [/exception.c.obj] Error 2
Makefile:1181: recipe for target '/bad_alloc.c.obj' failed
process_begin: CreateProcess(NULL, cl430 bad_alloc.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /bad_alloc.c.obj -fs -ft -ppa -ppd=/bad_alloc.c.pp, ...) failed.
gmake.exe[2]: *** [/bad_alloc.c.obj] Error 2
Makefile:1189: recipe for target '/wcstof.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcstof.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcstof.c.obj -fs -ft -ppa -ppd=/wcstof.c.pp, ...) failed.
gmake.exe[2]: *** [/wcstof.c.obj] Error 2
Makefile:1189: recipe for target '/wcstod.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcstod.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcstod.c.obj -fs -ft -ppa -ppd=/wcstod.c.pp, ...) failed.
gmake.exe[2]: *** [/wcstod.c.obj] Error 2
Makefile:1189: recipe for target '/wcstold.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcstold.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcstold.c.obj -fs -ft -ppa -ppd=/wcstold.c.pp, ...) failed.
gmake.exe[2]: *** [/wcstold.c.obj] Error 2
Makefile:1189: recipe for target '/wcstol.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcstol.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcstol.c.obj -fs -ft -ppa -ppd=/wcstol.c.pp, ...) failed.
gmake.exe[2]: *** [/wcstol.c.obj] Error 2
Makefile:1189: recipe for target '/wcstoul.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcstoul.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcstoul.c.obj -fs -ft -ppa -ppd=/wcstoul.c.pp, ...) failed.
gmake.exe[2]: *** [/wcstoul.c.obj] Error 2
Makefile:1189: recipe for target '/wcstoll.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcstoll.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcstoll.c.obj -fs -ft -ppa -ppd=/wcstoll.c.pp, ...) failed.
gmake.exe[2]: *** [/wcstoll.c.obj] Error 2
Makefile:1189: recipe for target '/wcstoull.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcstoull.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcstoull.c.obj -fs -ft -ppa -ppd=/wcstoull.c.pp, ...) failed.
gmake.exe[2]: *** [/wcstoull.c.obj] Error 2
Makefile:1189: recipe for target '/wcstoimax.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcstoimax.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcstoimax.c.obj -fs -ft -ppa -ppd=/wcstoimax.c.pp, ...) failed.
gmake.exe[2]: *** [/wcstoimax.c.obj] Error 2
Makefile:1189: recipe for target '/wcstoumax.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcstoumax.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcstoumax.c.obj -fs -ft -ppa -ppd=/wcstoumax.c.pp, ...) failed.
gmake.exe[2]: *** [/wcstoumax.c.obj] Error 2
Makefile:1189: recipe for target '/wcsftime.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcsftime.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcsftime.c.obj -fs -ft -ppa -ppd=/wcsftime.c.pp, ...) failed.
gmake.exe[2]: *** [/wcsftime.c.obj] Error 2
Makefile:1189: recipe for target '/fwprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fwprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /fwprintf.c.obj -fs -ft -ppa -ppd=/fwprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/fwprintf.c.obj] Error 2
Makefile:1189: recipe for target '/fwscanf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fwscanf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /fwscanf.c.obj -fs -ft -ppa -ppd=/fwscanf.c.pp, ...) failed.
gmake.exe[2]: *** [/fwscanf.c.obj] Error 2
Makefile:1189: recipe for target '/swprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 swprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /swprintf.c.obj -fs -ft -ppa -ppd=/swprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/swprintf.c.obj] Error 2
Makefile:1189: recipe for target '/swscanf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 swscanf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /swscanf.c.obj -fs -ft -ppa -ppd=/swscanf.c.pp, ...) failed.
gmake.exe[2]: *** [/swscanf.c.obj] Error 2
Makefile:1189: recipe for target '/vwprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vwprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /vwprintf.c.obj -fs -ft -ppa -ppd=/vwprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/vwprintf.c.obj] Error 2
Makefile:1189: recipe for target '/vwscanf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vwscanf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /vwscanf.c.obj -fs -ft -ppa -ppd=/vwscanf.c.pp, ...) failed.
gmake.exe[2]: *** [/vwscanf.c.obj] Error 2
Makefile:1189: recipe for target '/wprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wprintf.c.obj -fs -ft -ppa -ppd=/wprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/wprintf.c.obj] Error 2
Makefile:1189: recipe for target '/wscanf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wscanf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wscanf.c.obj -fs -ft -ppa -ppd=/wscanf.c.pp, ...) failed.
gmake.exe[2]: *** [/wscanf.c.obj] Error 2
Makefile:1189: recipe for target '/wcscat.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcscat.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcscat.c.obj -fs -ft -ppa -ppd=/wcscat.c.pp, ...) failed.
gmake.exe[2]: *** [/wcscat.c.obj] Error 2
Makefile:1189: recipe for target '/wcschr.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcschr.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcschr.c.obj -fs -ft -ppa -ppd=/wcschr.c.pp, ...) failed.
gmake.exe[2]: *** [/wcschr.c.obj] Error 2
Makefile:1189: recipe for target '/wcscmp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcscmp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcscmp.c.obj -fs -ft -ppa -ppd=/wcscmp.c.pp, ...) failed.
gmake.exe[2]: *** [/wcscmp.c.obj] Error 2
Makefile:1189: recipe for target '/wcscpy.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcscpy.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcscpy.c.obj -fs -ft -ppa -ppd=/wcscpy.c.pp, ...) failed.
gmake.exe[2]: *** [/wcscpy.c.obj] Error 2
Makefile:1189: recipe for target '/wcscspn.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcscspn.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcscspn.c.obj -fs -ft -ppa -ppd=/wcscspn.c.pp, ...) failed.
gmake.exe[2]: *** [/wcscspn.c.obj] Error 2
Makefile:1189: recipe for target '/wcsdup.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcsdup.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcsdup.c.obj -fs -ft -ppa -ppd=/wcsdup.c.pp, ...) failed.
gmake.exe[2]: *** [/wcsdup.c.obj] Error 2
Makefile:1189: recipe for target '/wcslen.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcslen.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcslen.c.obj -fs -ft -ppa -ppd=/wcslen.c.pp, ...) failed.
gmake.exe[2]: *** [/wcslen.c.obj] Error 2
Makefile:1189: recipe for target '/wcsncat.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcsncat.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcsncat.c.obj -fs -ft -ppa -ppd=/wcsncat.c.pp, ...) failed.
gmake.exe[2]: *** [/wcsncat.c.obj] Error 2
Makefile:1189: recipe for target '/wcsncmp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcsncmp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcsncmp.c.obj -fs -ft -ppa -ppd=/wcsncmp.c.pp, ...) failed.
gmake.exe[2]: *** [/wcsncmp.c.obj] Error 2
Makefile:1189: recipe for target '/wcsncpy.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcsncpy.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcsncpy.c.obj -fs -ft -ppa -ppd=/wcsncpy.c.pp, ...) failed.
gmake.exe[2]: *** [/wcsncpy.c.obj] Error 2
Makefile:1189: recipe for target '/wcspbrk.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcspbrk.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcspbrk.c.obj -fs -ft -ppa -ppd=/wcspbrk.c.pp, ...) failed.
gmake.exe[2]: *** [/wcspbrk.c.obj] Error 2
Makefile:1189: recipe for target '/wcsrchr.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcsrchr.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcsrchr.c.obj -fs -ft -ppa -ppd=/wcsrchr.c.pp, ...) failed.
gmake.exe[2]: *** [/wcsrchr.c.obj] Error 2
Makefile:1189: recipe for target '/wcsspn.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcsspn.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcsspn.c.obj -fs -ft -ppa -ppd=/wcsspn.c.pp, ...) failed.
gmake.exe[2]: *** [/wcsspn.c.obj] Error 2
Makefile:1189: recipe for target '/wcsstr.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcsstr.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcsstr.c.obj -fs -ft -ppa -ppd=/wcsstr.c.pp, ...) failed.
gmake.exe[2]: *** [/wcsstr.c.obj] Error 2
Makefile:1189: recipe for target '/wcstok.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcstok.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcstok.c.obj -fs -ft -ppa -ppd=/wcstok.c.pp, ...) failed.
gmake.exe[2]: *** [/wcstok.c.obj] Error 2
Makefile:1189: recipe for target '/wmemchr.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wmemchr.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wmemchr.c.obj -fs -ft -ppa -ppd=/wmemchr.c.pp, ...) failed.
gmake.exe[2]: *** [/wmemchr.c.obj] Error 2
Makefile:1189: recipe for target '/wmemcpy.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wmemcpy.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wmemcpy.c.obj -fs -ft -ppa -ppd=/wmemcpy.c.pp, ...) failed.
gmake.exe[2]: *** [/wmemcpy.c.obj] Error 2
Makefile:1189: recipe for target '/wmemcmp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wmemcmp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wmemcmp.c.obj -fs -ft -ppa -ppd=/wmemcmp.c.pp, ...) failed.
gmake.exe[2]: *** [/wmemcmp.c.obj] Error 2
Makefile:1189: recipe for target '/wmemmove.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wmemmove.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wmemmove.c.obj -fs -ft -ppa -ppd=/wmemmove.c.pp, ...) failed.
gmake.exe[2]: *** [/wmemmove.c.obj] Error 2
Makefile:1189: recipe for target '/wmemset.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wmemset.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wmemset.c.obj -fs -ft -ppa -ppd=/wmemset.c.pp, ...) failed.
gmake.exe[2]: *** [/wmemset.c.obj] Error 2
Makefile:1189: recipe for target '/none_mb.c.obj' failed
process_begin: CreateProcess(NULL, cl430 none_mb.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /none_mb.c.obj -fs -ft -ppa -ppd=/none_mb.c.pp, ...) failed.
gmake.exe[2]: *** [/none_mb.c.obj] Error 2
Makefile:1189: recipe for target '/fgetwc.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fgetwc.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /fgetwc.c.obj -fs -ft -ppa -ppd=/fgetwc.c.pp, ...) failed.
gmake.exe[2]: *** [/fgetwc.c.obj] Error 2
Makefile:1189: recipe for target '/fgetws.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fgetws.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /fgetws.c.obj -fs -ft -ppa -ppd=/fgetws.c.pp, ...) failed.
gmake.exe[2]: *** [/fgetws.c.obj] Error 2
Makefile:1189: recipe for target '/fputws.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fputws.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /fputws.c.obj -fs -ft -ppa -ppd=/fputws.c.pp, ...) failed.
gmake.exe[2]: *** [/fputws.c.obj] Error 2
Makefile:1189: recipe for target '/vfwprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vfwprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /vfwprintf.c.obj -fs -ft -ppa -ppd=/vfwprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/vfwprintf.c.obj] Error 2
Makefile:1189: recipe for target '/vfwscanf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vfwscanf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /vfwscanf.c.obj -fs -ft -ppa -ppd=/vfwscanf.c.pp, ...) failed.
gmake.exe[2]: *** [/vfwscanf.c.obj] Error 2
Makefile:1189: recipe for target '/vswprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vswprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /vswprintf.c.obj -fs -ft -ppa -ppd=/vswprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/vswprintf.c.obj] Error 2
Makefile:1189: recipe for target '/vswscanf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vswscanf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /vswscanf.c.obj -fs -ft -ppa -ppd=/vswscanf.c.pp, ...) failed.
gmake.exe[2]: *** [/vswscanf.c.obj] Error 2
Makefile:1189: recipe for target '/wcscoll.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcscoll.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcscoll.c.obj -fs -ft -ppa -ppd=/wcscoll.c.pp, ...) failed.
gmake.exe[2]: *** [/wcscoll.c.obj] Error 2
Makefile:1189: recipe for target '/wcsxfrm.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wcsxfrm.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -DSTRIP_FBSDID -D_XOPEN_SOURCE=700 --diag_suppress=188 -I -fe /wcsxfrm.c.obj -fs -ft -ppa -ppd=/wcsxfrm.c.pp, ...) failed.
gmake.exe[2]: *** [/wcsxfrm.c.obj] Error 2
Makefile:1197: recipe for target '/decode.c.obj' failed
process_begin: CreateProcess(NULL, cl430 decode.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /decode.c.obj -fs -ft -ppa -ppd=/decode.c.pp, ...) failed.
gmake.exe[2]: *** [/decode.c.obj] Error 2
Makefile:1205: recipe for target '/c99_complex.c.obj' failed
process_begin: CreateProcess(NULL, cl430 c99_complex.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /c99_complex.c.obj -fs -ft -ppa -ppd=/c99_complex.c.pp, ...) failed.
gmake.exe[2]: *** [/c99_complex.c.obj] Error 2
Makefile:1213: recipe for target '/s_clog.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_clog.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_clog.c.obj -fs -ft -ppa -ppd=/s_clog.c.pp, ...) failed.
gmake.exe[2]: *** [/s_clog.c.obj] Error 2
Makefile:1213: recipe for target '/s_clogf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_clogf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_clogf.c.obj -fs -ft -ppa -ppd=/s_clogf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_clogf.c.obj] Error 2
Makefile:1213: recipe for target '/s_clogl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_clogl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_clogl.c.obj -fs -ft -ppa -ppd=/s_clogl.c.pp, ...) failed.
gmake.exe[2]: *** [/s_clogl.c.obj] Error 2
Makefile:1213: recipe for target '/s_cpow.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cpow.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cpow.c.obj -fs -ft -ppa -ppd=/s_cpow.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cpow.c.obj] Error 2
Makefile:1213: recipe for target '/s_cpowf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cpowf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cpowf.c.obj -fs -ft -ppa -ppd=/s_cpowf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cpowf.c.obj] Error 2
Makefile:1213: recipe for target '/s_cpowl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cpowl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cpowl.c.obj -fs -ft -ppa -ppd=/s_cpowl.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cpowl.c.obj] Error 2
Makefile:1221: recipe for target '/catrigf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 catrigf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /catrigf.c.obj -fs -ft -ppa -ppd=/catrigf.c.pp, ...) failed.
gmake.exe[2]: *** [/catrigf.c.obj] Error 2
Makefile:1221: recipe for target '/k_expf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 k_expf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /k_expf.c.obj -fs -ft -ppa -ppd=/k_expf.c.pp, ...) failed.
gmake.exe[2]: *** [/k_expf.c.obj] Error 2
Makefile:1221: recipe for target '/s_carg.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_carg.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_carg.c.obj -fs -ft -ppa -ppd=/s_carg.c.pp, ...) failed.
gmake.exe[2]: *** [/s_carg.c.obj] Error 2
Makefile:1221: recipe for target '/s_cargf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cargf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cargf.c.obj -fs -ft -ppa -ppd=/s_cargf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cargf.c.obj] Error 2
Makefile:1221: recipe for target '/s_cargl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cargl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cargl.c.obj -fs -ft -ppa -ppd=/s_cargl.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cargl.c.obj] Error 2
Makefile:1221: recipe for target '/s_ccoshf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_ccoshf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_ccoshf.c.obj -fs -ft -ppa -ppd=/s_ccoshf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_ccoshf.c.obj] Error 2
Makefile:1221: recipe for target '/s_cexpf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cexpf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cexpf.c.obj -fs -ft -ppa -ppd=/s_cexpf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cexpf.c.obj] Error 2
Makefile:1221: recipe for target '/s_cimag.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cimag.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cimag.c.obj -fs -ft -ppa -ppd=/s_cimag.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cimag.c.obj] Error 2
Makefile:1221: recipe for target '/s_cimagf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cimagf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cimagf.c.obj -fs -ft -ppa -ppd=/s_cimagf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cimagf.c.obj] Error 2
Makefile:1221: recipe for target '/s_cimagl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cimagl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cimagl.c.obj -fs -ft -ppa -ppd=/s_cimagl.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cimagl.c.obj] Error 2
Makefile:1221: recipe for target '/s_conj.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_conj.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_conj.c.obj -fs -ft -ppa -ppd=/s_conj.c.pp, ...) failed.
gmake.exe[2]: *** [/s_conj.c.obj] Error 2
Makefile:1221: recipe for target '/s_conjf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_conjf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_conjf.c.obj -fs -ft -ppa -ppd=/s_conjf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_conjf.c.obj] Error 2
Makefile:1221: recipe for target '/s_conjl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_conjl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_conjl.c.obj -fs -ft -ppa -ppd=/s_conjl.c.pp, ...) failed.
gmake.exe[2]: *** [/s_conjl.c.obj] Error 2
Makefile:1221: recipe for target '/s_cproj.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cproj.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cproj.c.obj -fs -ft -ppa -ppd=/s_cproj.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cproj.c.obj] Error 2
Makefile:1221: recipe for target '/s_cprojf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cprojf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cprojf.c.obj -fs -ft -ppa -ppd=/s_cprojf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cprojf.c.obj] Error 2
Makefile:1221: recipe for target '/s_cprojl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cprojl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cprojl.c.obj -fs -ft -ppa -ppd=/s_cprojl.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cprojl.c.obj] Error 2
Makefile:1221: recipe for target '/s_creal.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_creal.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_creal.c.obj -fs -ft -ppa -ppd=/s_creal.c.pp, ...) failed.
gmake.exe[2]: *** [/s_creal.c.obj] Error 2
Makefile:1221: recipe for target '/s_crealf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_crealf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_crealf.c.obj -fs -ft -ppa -ppd=/s_crealf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_crealf.c.obj] Error 2
Makefile:1221: recipe for target '/s_creall.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_creall.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_creall.c.obj -fs -ft -ppa -ppd=/s_creall.c.pp, ...) failed.
gmake.exe[2]: *** [/s_creall.c.obj] Error 2
Makefile:1221: recipe for target '/s_csinhf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_csinhf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_csinhf.c.obj -fs -ft -ppa -ppd=/s_csinhf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_csinhf.c.obj] Error 2
Makefile:1221: recipe for target '/s_csqrtf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_csqrtf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_csqrtf.c.obj -fs -ft -ppa -ppd=/s_csqrtf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_csqrtf.c.obj] Error 2
Makefile:1221: recipe for target '/s_ctanhf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_ctanhf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_ctanhf.c.obj -fs -ft -ppa -ppd=/s_ctanhf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_ctanhf.c.obj] Error 2
Makefile:1221: recipe for target '/w_cabs.c.obj' failed
process_begin: CreateProcess(NULL, cl430 w_cabs.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /w_cabs.c.obj -fs -ft -ppa -ppd=/w_cabs.c.pp, ...) failed.
gmake.exe[2]: *** [/w_cabs.c.obj] Error 2
Makefile:1221: recipe for target '/w_cabsf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 w_cabsf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /w_cabsf.c.obj -fs -ft -ppa -ppd=/w_cabsf.c.pp, ...) failed.
gmake.exe[2]: *** [/w_cabsf.c.obj] Error 2
Makefile:1221: recipe for target '/w_cabsl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 w_cabsl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /w_cabsl.c.obj -fs -ft -ppa -ppd=/w_cabsl.c.pp, ...) failed.
gmake.exe[2]: *** [/w_cabsl.c.obj] Error 2
Makefile:1221: recipe for target '/s_log1pf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_log1pf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_log1pf.c.obj -fs -ft -ppa -ppd=/s_log1pf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_log1pf.c.obj] Error 2
Makefile:1221: recipe for target '/e_hypotf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_hypotf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_hypotf.c.obj -fs -ft -ppa -ppd=/e_hypotf.c.pp, ...) failed.
gmake.exe[2]: *** [/e_hypotf.c.obj] Error 2
Makefile:1221: recipe for target '/s_copysignf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_copysignf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_copysignf.c.obj -fs -ft -ppa -ppd=/s_copysignf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_copysignf.c.obj] Error 2
Makefile:1229: recipe for target '/ti_fenv.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ti_fenv.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /ti_fenv.c.obj -fs -ft -ppa -ppd=/ti_fenv.c.pp, ...) failed.
gmake.exe[2]: *** [/ti_fenv.c.obj] Error 2
Makefile:1229: recipe for target '/ti_fmax.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ti_fmax.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /ti_fmax.c.obj -fs -ft -ppa -ppd=/ti_fmax.c.pp, ...) failed.
gmake.exe[2]: *** [/ti_fmax.c.obj] Error 2
Makefile:1229: recipe for target '/ti_nan.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ti_nan.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /ti_nan.c.obj -fs -ft -ppa -ppd=/ti_nan.c.pp, ...) failed.
gmake.exe[2]: *** [/ti_nan.c.obj] Error 2
Makefile:1237: recipe for target '/b_exp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 b_exp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /b_exp.c.obj -fs -ft -ppa -ppd=/b_exp.c.pp, ...) failed.
gmake.exe[2]: *** [/b_exp.c.obj] Error 2
Makefile:1237: recipe for target '/b_log.c.obj' failed
process_begin: CreateProcess(NULL, cl430 b_log.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /b_log.c.obj -fs -ft -ppa -ppd=/b_log.c.pp, ...) failed.
gmake.exe[2]: *** [/b_log.c.obj] Error 2
Makefile:1237: recipe for target '/b_tgamma.c.obj' failed
process_begin: CreateProcess(NULL, cl430 b_tgamma.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /b_tgamma.c.obj -fs -ft -ppa -ppd=/b_tgamma.c.pp, ...) failed.
gmake.exe[2]: *** [/b_tgamma.c.obj] Error 2
Makefile:1237: recipe for target '/e_acos.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_acos.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_acos.c.obj -fs -ft -ppa -ppd=/e_acos.c.pp, ...) failed.
gmake.exe[2]: *** [/e_acos.c.obj] Error 2
Makefile:1237: recipe for target '/e_acosh.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_acosh.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_acosh.c.obj -fs -ft -ppa -ppd=/e_acosh.c.pp, ...) failed.
gmake.exe[2]: *** [/e_acosh.c.obj] Error 2
Makefile:1237: recipe for target '/e_asin.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_asin.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_asin.c.obj -fs -ft -ppa -ppd=/e_asin.c.pp, ...) failed.
gmake.exe[2]: *** [/e_asin.c.obj] Error 2
Makefile:1237: recipe for target '/e_atan2.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_atan2.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_atan2.c.obj -fs -ft -ppa -ppd=/e_atan2.c.pp, ...) failed.
gmake.exe[2]: *** [/e_atan2.c.obj] Error 2
Makefile:1237: recipe for target '/e_atanh.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_atanh.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_atanh.c.obj -fs -ft -ppa -ppd=/e_atanh.c.pp, ...) failed.
gmake.exe[2]: *** [/e_atanh.c.obj] Error 2
Makefile:1237: recipe for target '/e_cosh.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_cosh.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_cosh.c.obj -fs -ft -ppa -ppd=/e_cosh.c.pp, ...) failed.
gmake.exe[2]: *** [/e_cosh.c.obj] Error 2
Makefile:1237: recipe for target '/e_exp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_exp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_exp.c.obj -fs -ft -ppa -ppd=/e_exp.c.pp, ...) failed.
gmake.exe[2]: *** [/e_exp.c.obj] Error 2
Makefile:1237: recipe for target '/e_fmod.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_fmod.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_fmod.c.obj -fs -ft -ppa -ppd=/e_fmod.c.pp, ...) failed.
gmake.exe[2]: *** [/e_fmod.c.obj] Error 2
Makefile:1237: recipe for target '/e_lgamma.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_lgamma.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_lgamma.c.obj -fs -ft -ppa -ppd=/e_lgamma.c.pp, ...) failed.
gmake.exe[2]: *** [/e_lgamma.c.obj] Error 2
Makefile:1237: recipe for target '/e_lgamma_r.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_lgamma_r.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_lgamma_r.c.obj -fs -ft -ppa -ppd=/e_lgamma_r.c.pp, ...) failed.
gmake.exe[2]: *** [/e_lgamma_r.c.obj] Error 2
Makefile:1237: recipe for target '/e_log.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_log.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_log.c.obj -fs -ft -ppa -ppd=/e_log.c.pp, ...) failed.
gmake.exe[2]: *** [/e_log.c.obj] Error 2
Makefile:1237: recipe for target '/e_log10.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_log10.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_log10.c.obj -fs -ft -ppa -ppd=/e_log10.c.pp, ...) failed.
gmake.exe[2]: *** [/e_log10.c.obj] Error 2
Makefile:1237: recipe for target '/e_log2.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_log2.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_log2.c.obj -fs -ft -ppa -ppd=/e_log2.c.pp, ...) failed.
gmake.exe[2]: *** [/e_log2.c.obj] Error 2
Makefile:1237: recipe for target '/e_pow.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_pow.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_pow.c.obj -fs -ft -ppa -ppd=/e_pow.c.pp, ...) failed.
gmake.exe[2]: *** [/e_pow.c.obj] Error 2
Makefile:1237: recipe for target '/e_remainder.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_remainder.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_remainder.c.obj -fs -ft -ppa -ppd=/e_remainder.c.pp, ...) failed.
gmake.exe[2]: *** [/e_remainder.c.obj] Error 2
Makefile:1237: recipe for target '/e_sinh.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_sinh.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_sinh.c.obj -fs -ft -ppa -ppd=/e_sinh.c.pp, ...) failed.
gmake.exe[2]: *** [/e_sinh.c.obj] Error 2
Makefile:1237: recipe for target '/e_sqrt.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_sqrt.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_sqrt.c.obj -fs -ft -ppa -ppd=/e_sqrt.c.pp, ...) failed.
gmake.exe[2]: *** [/e_sqrt.c.obj] Error 2
Makefile:1237: recipe for target '/k_cos.c.obj' failed
process_begin: CreateProcess(NULL, cl430 k_cos.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /k_cos.c.obj -fs -ft -ppa -ppd=/k_cos.c.pp, ...) failed.
gmake.exe[2]: *** [/k_cos.c.obj] Error 2
Makefile:1237: recipe for target '/k_sin.c.obj' failed
process_begin: CreateProcess(NULL, cl430 k_sin.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /k_sin.c.obj -fs -ft -ppa -ppd=/k_sin.c.pp, ...) failed.
gmake.exe[2]: *** [/k_sin.c.obj] Error 2
Makefile:1237: recipe for target '/k_tan.c.obj' failed
process_begin: CreateProcess(NULL, cl430 k_tan.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /k_tan.c.obj -fs -ft -ppa -ppd=/k_tan.c.pp, ...) failed.
gmake.exe[2]: *** [/k_tan.c.obj] Error 2
Makefile:1237: recipe for target '/s_asinh.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_asinh.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_asinh.c.obj -fs -ft -ppa -ppd=/s_asinh.c.pp, ...) failed.
gmake.exe[2]: *** [/s_asinh.c.obj] Error 2
Makefile:1237: recipe for target '/s_atan.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_atan.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_atan.c.obj -fs -ft -ppa -ppd=/s_atan.c.pp, ...) failed.
gmake.exe[2]: *** [/s_atan.c.obj] Error 2
Makefile:1237: recipe for target '/s_cbrt.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cbrt.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cbrt.c.obj -fs -ft -ppa -ppd=/s_cbrt.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cbrt.c.obj] Error 2
Makefile:1237: recipe for target '/s_ceil.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_ceil.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_ceil.c.obj -fs -ft -ppa -ppd=/s_ceil.c.pp, ...) failed.
gmake.exe[2]: *** [/s_ceil.c.obj] Error 2
Makefile:1237: recipe for target '/s_cos.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cos.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cos.c.obj -fs -ft -ppa -ppd=/s_cos.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cos.c.obj] Error 2
Makefile:1237: recipe for target '/s_erf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_erf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_erf.c.obj -fs -ft -ppa -ppd=/s_erf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_erf.c.obj] Error 2
Makefile:1237: recipe for target '/s_exp2.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_exp2.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_exp2.c.obj -fs -ft -ppa -ppd=/s_exp2.c.pp, ...) failed.
gmake.exe[2]: *** [/s_exp2.c.obj] Error 2
Makefile:1237: recipe for target '/s_expm1.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_expm1.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_expm1.c.obj -fs -ft -ppa -ppd=/s_expm1.c.pp, ...) failed.
gmake.exe[2]: *** [/s_expm1.c.obj] Error 2
Makefile:1237: recipe for target '/s_fabs.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_fabs.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_fabs.c.obj -fs -ft -ppa -ppd=/s_fabs.c.pp, ...) failed.
gmake.exe[2]: *** [/s_fabs.c.obj] Error 2
Makefile:1237: recipe for target '/s_floor.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_floor.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_floor.c.obj -fs -ft -ppa -ppd=/s_floor.c.pp, ...) failed.
gmake.exe[2]: *** [/s_floor.c.obj] Error 2
Makefile:1237: recipe for target '/s_fma.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_fma.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_fma.c.obj -fs -ft -ppa -ppd=/s_fma.c.pp, ...) failed.
gmake.exe[2]: *** [/s_fma.c.obj] Error 2
Makefile:1237: recipe for target '/s_frexp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_frexp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_frexp.c.obj -fs -ft -ppa -ppd=/s_frexp.c.pp, ...) failed.
gmake.exe[2]: *** [/s_frexp.c.obj] Error 2
Makefile:1237: recipe for target '/s_ilogb.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_ilogb.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_ilogb.c.obj -fs -ft -ppa -ppd=/s_ilogb.c.pp, ...) failed.
gmake.exe[2]: *** [/s_ilogb.c.obj] Error 2
Makefile:1237: recipe for target '/s_logb.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_logb.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_logb.c.obj -fs -ft -ppa -ppd=/s_logb.c.pp, ...) failed.
gmake.exe[2]: *** [/s_logb.c.obj] Error 2
Makefile:1237: recipe for target '/s_modf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_modf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_modf.c.obj -fs -ft -ppa -ppd=/s_modf.c.pp, ...) failed.
gmake.exe[2]: *** [/s_modf.c.obj] Error 2
Makefile:1237: recipe for target '/s_nextafter.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_nextafter.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_nextafter.c.obj -fs -ft -ppa -ppd=/s_nextafter.c.pp, ...) failed.
gmake.exe[2]: *** [/s_nextafter.c.obj] Error 2
Makefile:1237: recipe for target '/s_remquo.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_remquo.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_remquo.c.obj -fs -ft -ppa -ppd=/s_remquo.c.pp, ...) failed.
gmake.exe[2]: *** [/s_remquo.c.obj] Error 2
Makefile:1237: recipe for target '/s_rint.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_rint.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_rint.c.obj -fs -ft -ppa -ppd=/s_rint.c.pp, ...) failed.
gmake.exe[2]: *** [/s_rint.c.obj] Error 2
Makefile:1237: recipe for target '/s_round.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_round.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_round.c.obj -fs -ft -ppa -ppd=/s_round.c.pp, ...) failed.
gmake.exe[2]: *** [/s_round.c.obj] Error 2
Makefile:1237: recipe for target '/s_scalbn.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_scalbn.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_scalbn.c.obj -fs -ft -ppa -ppd=/s_scalbn.c.pp, ...) failed.
gmake.exe[2]: *** [/s_scalbn.c.obj] Error 2
Makefile:1237: recipe for target '/s_sin.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_sin.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_sin.c.obj -fs -ft -ppa -ppd=/s_sin.c.pp, ...) failed.
gmake.exe[2]: *** [/s_sin.c.obj] Error 2
Makefile:1237: recipe for target '/s_tan.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_tan.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_tan.c.obj -fs -ft -ppa -ppd=/s_tan.c.pp, ...) failed.
gmake.exe[2]: *** [/s_tan.c.obj] Error 2
Makefile:1237: recipe for target '/s_tanh.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_tanh.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_tanh.c.obj -fs -ft -ppa -ppd=/s_tanh.c.pp, ...) failed.
gmake.exe[2]: *** [/s_tanh.c.obj] Error 2
Makefile:1237: recipe for target '/s_trunc.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_trunc.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_trunc.c.obj -fs -ft -ppa -ppd=/s_trunc.c.pp, ...) failed.
gmake.exe[2]: *** [/s_trunc.c.obj] Error 2
Makefile:1245: recipe for target '/dtor_list.c.obj' failed
process_begin: CreateProcess(NULL, cl430 dtor_list.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /dtor_list.c.obj -fs -ft -ppa -ppd=/dtor_list.c.pp, ...) failed.
gmake.exe[2]: *** [/dtor_list.c.obj] Error 2
Makefile:1245: recipe for target '/error.c.obj' failed
process_begin: CreateProcess(NULL, cl430 error.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /error.c.obj -fs -ft -ppa -ppd=/error.c.pp, ...) failed.
gmake.exe[2]: *** [/error.c.obj] Error 2
Makefile:1245: recipe for target '/guard.c.obj' failed
process_begin: CreateProcess(NULL, cl430 guard.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /guard.c.obj -fs -ft -ppa -ppd=/guard.c.pp, ...) failed.
gmake.exe[2]: *** [/guard.c.obj] Error 2
Makefile:1245: recipe for target '/memzero.c.obj' failed
process_begin: CreateProcess(NULL, cl430 memzero.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /memzero.c.obj -fs -ft -ppa -ppd=/memzero.c.pp, ...) failed.
gmake.exe[2]: *** [/memzero.c.obj] Error 2
Makefile:1245: recipe for target '/newhandler.c.obj' failed
process_begin: CreateProcess(NULL, cl430 newhandler.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /newhandler.c.obj -fs -ft -ppa -ppd=/newhandler.c.pp, ...) failed.
gmake.exe[2]: *** [/newhandler.c.obj] Error 2
Makefile:1245: recipe for target '/pure_virt.c.obj' failed
process_begin: CreateProcess(NULL, cl430 pure_virt.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /pure_virt.c.obj -fs -ft -ppa -ppd=/pure_virt.c.pp, ...) failed.
gmake.exe[2]: *** [/pure_virt.c.obj] Error 2
Makefile:1245: recipe for target '/rtti.c.obj' failed
process_begin: CreateProcess(NULL, cl430 rtti.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /rtti.c.obj -fs -ft -ppa -ppd=/rtti.c.pp, ...) failed.
gmake.exe[2]: *** [/rtti.c.obj] Error 2
Makefile:1245: recipe for target '/typeinfo.c.obj' failed
process_begin: CreateProcess(NULL, cl430 typeinfo.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /typeinfo.c.obj -fs -ft -ppa -ppd=/typeinfo.c.pp, ...) failed.
gmake.exe[2]: *** [/typeinfo.c.obj] Error 2
Makefile:1245: recipe for target '/vars.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vars.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /vars.c.obj -fs -ft -ppa -ppd=/vars.c.pp, ...) failed.
gmake.exe[2]: *** [/vars.c.obj] Error 2
Makefile:1245: recipe for target '/vec_cctor.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vec_cctor.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /vec_cctor.c.obj -fs -ft -ppa -ppd=/vec_cctor.c.pp, ...) failed.
gmake.exe[2]: *** [/vec_cctor.c.obj] Error 2
Makefile:1245: recipe for target '/vec_newdel.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vec_newdel.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /vec_newdel.c.obj -fs -ft -ppa -ppd=/vec_newdel.c.pp, ...) failed.
gmake.exe[2]: *** [/vec_newdel.c.obj] Error 2
Makefile:1245: recipe for target '/vla_alloc.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vla_alloc.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg --building_runtime -DCHECKING=0 -I -fe /vla_alloc.c.obj -fs -ft -ppa -ppd=/vla_alloc.c.pp, ...) failed.
gmake.exe[2]: *** [/vla_alloc.c.obj] Error 2
Makefile:1253: recipe for target '/catrig.c.obj' failed
process_begin: CreateProcess(NULL, cl430 catrig.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /catrig.c.obj -fs -ft -ppa -ppd=/catrig.c.pp, ...) failed.
gmake.exe[2]: *** [/catrig.c.obj] Error 2
Makefile:1253: recipe for target '/k_exp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 k_exp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /k_exp.c.obj -fs -ft -ppa -ppd=/k_exp.c.pp, ...) failed.
gmake.exe[2]: *** [/k_exp.c.obj] Error 2
Makefile:1253: recipe for target '/s_ccosh.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_ccosh.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_ccosh.c.obj -fs -ft -ppa -ppd=/s_ccosh.c.pp, ...) failed.
gmake.exe[2]: *** [/s_ccosh.c.obj] Error 2
Makefile:1253: recipe for target '/s_cexp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_cexp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_cexp.c.obj -fs -ft -ppa -ppd=/s_cexp.c.pp, ...) failed.
gmake.exe[2]: *** [/s_cexp.c.obj] Error 2
Makefile:1253: recipe for target '/s_csinh.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_csinh.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_csinh.c.obj -fs -ft -ppa -ppd=/s_csinh.c.pp, ...) failed.
gmake.exe[2]: *** [/s_csinh.c.obj] Error 2
Makefile:1253: recipe for target '/s_csqrt.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_csqrt.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_csqrt.c.obj -fs -ft -ppa -ppd=/s_csqrt.c.pp, ...) failed.
gmake.exe[2]: *** [/s_csqrt.c.obj] Error 2
Makefile:1253: recipe for target '/s_ctanh.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_ctanh.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_ctanh.c.obj -fs -ft -ppa -ppd=/s_ctanh.c.pp, ...) failed.
gmake.exe[2]: *** [/s_ctanh.c.obj] Error 2
Makefile:1253: recipe for target '/s_log1p.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_log1p.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_log1p.c.obj -fs -ft -ppa -ppd=/s_log1p.c.pp, ...) failed.
gmake.exe[2]: *** [/s_log1p.c.obj] Error 2
Makefile:1253: recipe for target '/e_hypot.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_hypot.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /e_hypot.c.obj -fs -ft -ppa -ppd=/e_hypot.c.pp, ...) failed.
gmake.exe[2]: *** [/e_hypot.c.obj] Error 2
Makefile:1253: recipe for target '/s_copysign.c.obj' failed
process_begin: CreateProcess(NULL, cl430 s_copysign.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --c99 -I -fe /s_copysign.c.obj -fs -ft -ppa -ppd=/s_copysign.c.pp, ...) failed.
gmake.exe[2]: *** [/s_copysign.c.obj] Error 2
Makefile:1261: recipe for target '/libcxx/algorithm.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/algorithm.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/algorithm.cpp.obj -fs -ft -ppa -ppd=/algorithm.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/algorithm.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/bind.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/bind.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/bind.cpp.obj -fs -ft -ppa -ppd=/bind.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/bind.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/chrono.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/chrono.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/chrono.cpp.obj -fs -ft -ppa -ppd=/chrono.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/chrono.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/condition_variable.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/condition_variable.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/condition_variable.cpp.obj -fs -ft -ppa -ppd=/condition_variable.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/condition_variable.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/debug.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/debug.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/debug.cpp.obj -fs -ft -ppa -ppd=/debug.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/debug.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/exception.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/exception.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/exception.cpp.obj -fs -ft -ppa -ppd=/exception.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/exception.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/functional.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/functional.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/functional.cpp.obj -fs -ft -ppa -ppd=/functional.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/functional.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/hash.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/hash.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/hash.cpp.obj -fs -ft -ppa -ppd=/hash.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/hash.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/ios.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/ios.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/ios.cpp.obj -fs -ft -ppa -ppd=/ios.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/ios.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/memory.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/memory.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/memory.cpp.obj -fs -ft -ppa -ppd=/memory.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/memory.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/mutex.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/mutex.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/mutex.cpp.obj -fs -ft -ppa -ppd=/mutex.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/mutex.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/new.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/new.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/new.cpp.obj -fs -ft -ppa -ppd=/new.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/new.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/random.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/random.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/random.cpp.obj -fs -ft -ppa -ppd=/random.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/random.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/regex.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/regex.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/regex.cpp.obj -fs -ft -ppa -ppd=/regex.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/regex.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/stdexcept.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/stdexcept.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/stdexcept.cpp.obj -fs -ft -ppa -ppd=/stdexcept.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/stdexcept.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/string.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/string.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/string.cpp.obj -fs -ft -ppa -ppd=/string.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/string.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/strstream.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/strstream.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/strstream.cpp.obj -fs -ft -ppa -ppd=/strstream.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/strstream.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/system_error.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/system_error.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/system_error.cpp.obj -fs -ft -ppa -ppd=/system_error.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/system_error.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/typeinfo.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/typeinfo.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/typeinfo.cpp.obj -fs -ft -ppa -ppd=/typeinfo.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/typeinfo.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/utility.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/utility.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/utility.cpp.obj -fs -ft -ppa -ppd=/utility.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/utility.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/valarray.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/valarray.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/valarray.cpp.obj -fs -ft -ppa -ppd=/valarray.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/valarray.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/variant.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/variant.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/variant.cpp.obj -fs -ft -ppa -ppd=/variant.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/variant.cpp.obj] Error 2
Makefile:1261: recipe for target '/libcxx/vector.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 libcxx/vector.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -D_LIBCPP_BUILDING_LIBRARY --preinclude __config_site --rtti -fg -I -fe /libcxx/vector.cpp.obj -fs -ft -ppa -ppd=/vector.cpp.pp, ...) failed.
gmake.exe[2]: *** [/libcxx/vector.cpp.obj] Error 2
Makefile:1269: recipe for target '/tdeh_uwentry_msp430.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 tdeh_uwentry_msp430.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /tdeh_uwentry_msp430.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/tdeh_uwentry_msp430.asm.obj] Error 2
Makefile:1269: recipe for target '/asr16.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 asr16.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /asr16.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/asr16.asm.obj] Error 2
Makefile:1269: recipe for target '/asr32.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 asr32.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /asr32.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/asr32.asm.obj] Error 2
Makefile:1269: recipe for target '/div16s.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 div16s.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /div16s.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/div16s.asm.obj] Error 2
Makefile:1269: recipe for target '/div16u.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 div16u.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /div16u.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/div16u.asm.obj] Error 2
Makefile:1269: recipe for target '/div32s.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 div32s.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /div32s.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/div32s.asm.obj] Error 2
Makefile:1269: recipe for target '/div32u.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 div32u.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /div32u.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/div32u.asm.obj] Error 2
Makefile:1269: recipe for target '/epilog.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 epilog.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /epilog.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/epilog.asm.obj] Error 2
Makefile:1269: recipe for target '/cpy_util.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 cpy_util.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /cpy_util.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/cpy_util.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_add.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_add.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_add.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_add.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_cmp.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_cmp.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_cmp.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_cmp.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_div.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_div.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_div.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_div.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_itof.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_itof.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_itof.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_itof.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_ltof.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_ltof.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_ltof.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_ltof.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_mpy.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_mpy.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_mpy.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_mpy.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_neg.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_neg.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_neg.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_neg.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_toi.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_toi.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_toi.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_toi.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_tol.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_tol.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_tol.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_tol.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_tou.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_tou.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_tou.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_tou.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_toul.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_toul.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_toul.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_toul.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_ultof.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_ultof.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_ultof.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_ultof.asm.obj] Error 2
Makefile:1269: recipe for target '/fs_utof.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 fs_utof.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fs_utof.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/fs_utof.asm.obj] Error 2
Makefile:1269: recipe for target '/int00.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int00.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int00.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int00.asm.obj] Error 2
Makefile:1269: recipe for target '/int01.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int01.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int01.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int01.asm.obj] Error 2
Makefile:1269: recipe for target '/int02.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int02.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int02.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int02.asm.obj] Error 2
Makefile:1269: recipe for target '/int03.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int03.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int03.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int03.asm.obj] Error 2
Makefile:1269: recipe for target '/int04.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int04.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int04.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int04.asm.obj] Error 2
Makefile:1269: recipe for target '/int05.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int05.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int05.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int05.asm.obj] Error 2
Makefile:1269: recipe for target '/int06.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int06.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int06.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int06.asm.obj] Error 2
Makefile:1269: recipe for target '/int07.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int07.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int07.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int07.asm.obj] Error 2
Makefile:1269: recipe for target '/int08.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int08.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int08.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int08.asm.obj] Error 2
Makefile:1269: recipe for target '/int09.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int09.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int09.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int09.asm.obj] Error 2
Makefile:1269: recipe for target '/int10.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int10.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int10.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int10.asm.obj] Error 2
Makefile:1269: recipe for target '/int11.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int11.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int11.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int11.asm.obj] Error 2
Makefile:1269: recipe for target '/int12.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int12.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int12.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int12.asm.obj] Error 2
Makefile:1269: recipe for target '/int13.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int13.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int13.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int13.asm.obj] Error 2
Makefile:1269: recipe for target '/int14.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int14.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int14.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int14.asm.obj] Error 2
Makefile:1269: recipe for target '/int15.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int15.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int15.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int15.asm.obj] Error 2
Makefile:1269: recipe for target '/int16.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int16.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int16.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int16.asm.obj] Error 2
Makefile:1269: recipe for target '/int17.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int17.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int17.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int17.asm.obj] Error 2
Makefile:1269: recipe for target '/int18.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int18.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int18.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int18.asm.obj] Error 2
Makefile:1269: recipe for target '/int19.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int19.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int19.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int19.asm.obj] Error 2
Makefile:1269: recipe for target '/int20.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int20.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int20.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int20.asm.obj] Error 2
Makefile:1269: recipe for target '/int21.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int21.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int21.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int21.asm.obj] Error 2
Makefile:1269: recipe for target '/int22.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int22.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int22.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int22.asm.obj] Error 2
Makefile:1269: recipe for target '/int23.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int23.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int23.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int23.asm.obj] Error 2
Makefile:1269: recipe for target '/int24.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int24.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int24.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int24.asm.obj] Error 2
Makefile:1269: recipe for target '/int25.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int25.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int25.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int25.asm.obj] Error 2
Makefile:1269: recipe for target '/int26.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int26.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int26.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int26.asm.obj] Error 2
Makefile:1269: recipe for target '/int27.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int27.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int27.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int27.asm.obj] Error 2
Makefile:1269: recipe for target '/int28.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int28.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int28.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int28.asm.obj] Error 2
Makefile:1269: recipe for target '/int29.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int29.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int29.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int29.asm.obj] Error 2
Makefile:1269: recipe for target '/int30.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int30.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int30.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int30.asm.obj] Error 2
Makefile:1269: recipe for target '/int31.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int31.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int31.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int31.asm.obj] Error 2
Makefile:1269: recipe for target '/int32.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int32.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int32.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int32.asm.obj] Error 2
Makefile:1269: recipe for target '/int33.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int33.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int33.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int33.asm.obj] Error 2
Makefile:1269: recipe for target '/int34.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int34.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int34.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int34.asm.obj] Error 2
Makefile:1269: recipe for target '/int35.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int35.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int35.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int35.asm.obj] Error 2
Makefile:1269: recipe for target '/int36.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int36.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int36.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int36.asm.obj] Error 2
Makefile:1269: recipe for target '/int37.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int37.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int37.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int37.asm.obj] Error 2
Makefile:1269: recipe for target '/int38.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int38.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int38.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int38.asm.obj] Error 2
Makefile:1269: recipe for target '/int39.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int39.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int39.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int39.asm.obj] Error 2
Makefile:1269: recipe for target '/int40.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int40.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int40.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int40.asm.obj] Error 2
Makefile:1269: recipe for target '/int41.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int41.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int41.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int41.asm.obj] Error 2
Makefile:1269: recipe for target '/int42.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int42.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int42.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int42.asm.obj] Error 2
Makefile:1269: recipe for target '/int43.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int43.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int43.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int43.asm.obj] Error 2
Makefile:1269: recipe for target '/int44.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int44.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int44.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int44.asm.obj] Error 2
Makefile:1269: recipe for target '/int45.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int45.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int45.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int45.asm.obj] Error 2
Makefile:1269: recipe for target '/int46.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int46.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int46.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int46.asm.obj] Error 2
Makefile:1269: recipe for target '/int47.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int47.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int47.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int47.asm.obj] Error 2
Makefile:1269: recipe for target '/int48.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int48.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int48.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int48.asm.obj] Error 2
Makefile:1269: recipe for target '/int49.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int49.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int49.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int49.asm.obj] Error 2
Makefile:1269: recipe for target '/int50.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int50.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int50.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int50.asm.obj] Error 2
Makefile:1269: recipe for target '/int51.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int51.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int51.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int51.asm.obj] Error 2
Makefile:1269: recipe for target '/int52.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int52.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int52.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int52.asm.obj] Error 2
Makefile:1269: recipe for target '/int53.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int53.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int53.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int53.asm.obj] Error 2
Makefile:1269: recipe for target '/int54.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int54.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int54.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int54.asm.obj] Error 2
Makefile:1269: recipe for target '/int55.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int55.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int55.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int55.asm.obj] Error 2
Makefile:1269: recipe for target '/int56.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int56.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int56.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int56.asm.obj] Error 2
Makefile:1269: recipe for target '/int57.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int57.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int57.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int57.asm.obj] Error 2
Makefile:1269: recipe for target '/int58.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int58.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int58.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int58.asm.obj] Error 2
Makefile:1269: recipe for target '/int59.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int59.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int59.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int59.asm.obj] Error 2
Makefile:1269: recipe for target '/int60.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int60.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int60.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int60.asm.obj] Error 2
Makefile:1269: recipe for target '/int61.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int61.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int61.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int61.asm.obj] Error 2
Makefile:1269: recipe for target '/int62.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 int62.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /int62.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/int62.asm.obj] Error 2
Makefile:1269: recipe for target '/isr_trap.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 isr_trap.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /isr_trap.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/isr_trap.asm.obj] Error 2
Makefile:1269: recipe for target '/lsl16.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 lsl16.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /lsl16.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/lsl16.asm.obj] Error 2
Makefile:1269: recipe for target '/lsl32.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 lsl32.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /lsl32.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/lsl32.asm.obj] Error 2
Makefile:1269: recipe for target '/lsr16.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 lsr16.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /lsr16.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/lsr16.asm.obj] Error 2
Makefile:1269: recipe for target '/lsr32.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 lsr32.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /lsr32.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/lsr32.asm.obj] Error 2
Makefile:1269: recipe for target '/mult16.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult16.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult16.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult16.asm.obj] Error 2
Makefile:1269: recipe for target '/mult16_hw.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult16_hw.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult16_hw.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult16_hw.asm.obj] Error 2
Makefile:1269: recipe for target '/mult16_f5hw.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult16_f5hw.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult16_f5hw.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult16_f5hw.asm.obj] Error 2
Makefile:1269: recipe for target '/mult1632.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult1632.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult1632.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult1632.asm.obj] Error 2
Makefile:1269: recipe for target '/mult1632_f5hw.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult1632_f5hw.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult1632_f5hw.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult1632_f5hw.asm.obj] Error 2
Makefile:1269: recipe for target '/mult1632_hw.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult1632_hw.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult1632_hw.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult1632_hw.asm.obj] Error 2
Makefile:1269: recipe for target '/mult32.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult32.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult32.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult32.asm.obj] Error 2
Makefile:1269: recipe for target '/mult32_hw.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult32_hw.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult32_hw.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult32_hw.asm.obj] Error 2
Makefile:1269: recipe for target '/mult32_hw32.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult32_hw32.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult32_hw32.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult32_hw32.asm.obj] Error 2
Makefile:1269: recipe for target '/mult32_f5hw.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult32_f5hw.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult32_f5hw.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult32_f5hw.asm.obj] Error 2
Makefile:1269: recipe for target '/mult3264.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult3264.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult3264.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult3264.asm.obj] Error 2
Makefile:1269: recipe for target '/mult3264_f5hw.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult3264_f5hw.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult3264_f5hw.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult3264_f5hw.asm.obj] Error 2
Makefile:1269: recipe for target '/mult3264_hw.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult3264_hw.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult3264_hw.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult3264_hw.asm.obj] Error 2
Makefile:1269: recipe for target '/mult3264_hw32.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult3264_hw32.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult3264_hw32.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult3264_hw32.asm.obj] Error 2
Makefile:1269: recipe for target '/mult64.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult64.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult64.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult64.asm.obj] Error 2
Makefile:1269: recipe for target '/mult64_hw.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult64_hw.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult64_hw.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult64_hw.asm.obj] Error 2
Makefile:1269: recipe for target '/mult64_hw32.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult64_hw32.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult64_hw32.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult64_hw32.asm.obj] Error 2
Makefile:1269: recipe for target '/mult64_f5hw.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 mult64_f5hw.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mult64_f5hw.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/mult64_f5hw.asm.obj] Error 2
Makefile:1269: recipe for target '/rotl16.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 rotl16.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /rotl16.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/rotl16.asm.obj] Error 2
Makefile:1269: recipe for target '/rotl32.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 rotl32.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /rotl32.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/rotl32.asm.obj] Error 2
Makefile:1269: recipe for target '/setjmp.asm.obj' failed
process_begin: CreateProcess(NULL, cl430 setjmp.asm --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /setjmp.asm.obj -fs -ft, ...) failed.
gmake.exe[2]: *** [/setjmp.asm.obj] Error 2
Makefile:1278: recipe for target '/tdeh_pr_msp430.cpp.obj' failed
process_begin: CreateProcess(NULL, cl430 tdeh_pr_msp430.cpp --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --rtti -fg -I -fe /tdeh_pr_msp430.cpp.obj -fs -ft -ppa -ppd=/tdeh_pr_msp430.cpp.pp, ...) failed.
gmake.exe[2]: *** [/tdeh_pr_msp430.cpp.obj] Error 2
Makefile:1286: recipe for target '/boot.c.obj' failed
process_begin: CreateProcess(NULL, cl430 boot.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /boot.c.obj -fs -ft -ppa -ppd=/boot.c.pp, ...) failed.
gmake.exe[2]: *** [/boot.c.obj] Error 2
Makefile:1286: recipe for target '/autoinit.c.obj' failed
process_begin: CreateProcess(NULL, cl430 autoinit.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /autoinit.c.obj -fs -ft -ppa -ppd=/autoinit.c.pp, ...) failed.
gmake.exe[2]: *** [/autoinit.c.obj] Error 2
Makefile:1286: recipe for target '/copy_zero_init.c.obj' failed
process_begin: CreateProcess(NULL, cl430 copy_zero_init.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /copy_zero_init.c.obj -fs -ft -ppa -ppd=/copy_zero_init.c.pp, ...) failed.
gmake.exe[2]: *** [/copy_zero_init.c.obj] Error 2
Makefile:1286: recipe for target '/exit_gvars.c.obj' failed
process_begin: CreateProcess(NULL, cl430 exit_gvars.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /exit_gvars.c.obj -fs -ft -ppa -ppd=/exit_gvars.c.pp, ...) failed.
gmake.exe[2]: *** [/exit_gvars.c.obj] Error 2
Makefile:1286: recipe for target '/cpy_tbl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 cpy_tbl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /cpy_tbl.c.obj -fs -ft -ppa -ppd=/cpy_tbl.c.pp, ...) failed.
gmake.exe[2]: *** [/cpy_tbl.c.obj] Error 2
Makefile:1286: recipe for target '/mpu_init.c.obj' failed
process_begin: CreateProcess(NULL, cl430 mpu_init.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mpu_init.c.obj -fs -ft -ppa -ppd=/mpu_init.c.pp, ...) failed.
gmake.exe[2]: *** [/mpu_init.c.obj] Error 2
Makefile:1286: recipe for target '/asr64.c.obj' failed
process_begin: CreateProcess(NULL, cl430 asr64.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /asr64.c.obj -fs -ft -ppa -ppd=/asr64.c.pp, ...) failed.
gmake.exe[2]: *** [/asr64.c.obj] Error 2
Makefile:1286: recipe for target '/lsl64.c.obj' failed
process_begin: CreateProcess(NULL, cl430 lsl64.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /lsl64.c.obj -fs -ft -ppa -ppd=/lsl64.c.pp, ...) failed.
gmake.exe[2]: *** [/lsl64.c.obj] Error 2
Makefile:1286: recipe for target '/lsr64.c.obj' failed
process_begin: CreateProcess(NULL, cl430 lsr64.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /lsr64.c.obj -fs -ft -ppa -ppd=/lsr64.c.pp, ...) failed.
gmake.exe[2]: *** [/lsr64.c.obj] Error 2
Makefile:1286: recipe for target '/rotl64.c.obj' failed
process_begin: CreateProcess(NULL, cl430 rotl64.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /rotl64.c.obj -fs -ft -ppa -ppd=/rotl64.c.pp, ...) failed.
gmake.exe[2]: *** [/rotl64.c.obj] Error 2
Makefile:1286: recipe for target '/div64s.c.obj' failed
process_begin: CreateProcess(NULL, cl430 div64s.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /div64s.c.obj -fs -ft -ppa -ppd=/div64s.c.pp, ...) failed.
gmake.exe[2]: *** [/div64s.c.obj] Error 2
Makefile:1286: recipe for target '/div64u.c.obj' failed
process_begin: CreateProcess(NULL, cl430 div64u.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /div64u.c.obj -fs -ft -ppa -ppd=/div64u.c.pp, ...) failed.
gmake.exe[2]: *** [/div64u.c.obj] Error 2
Makefile:1286: recipe for target '/rem64s.c.obj' failed
process_begin: CreateProcess(NULL, cl430 rem64s.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /rem64s.c.obj -fs -ft -ppa -ppd=/rem64s.c.pp, ...) failed.
gmake.exe[2]: *** [/rem64s.c.obj] Error 2
Makefile:1286: recipe for target '/rem64u.c.obj' failed
process_begin: CreateProcess(NULL, cl430 rem64u.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /rem64u.c.obj -fs -ft -ppa -ppd=/rem64u.c.pp, ...) failed.
gmake.exe[2]: *** [/rem64u.c.obj] Error 2
Makefile:1286: recipe for target '/pre_init.c.obj' failed
process_begin: CreateProcess(NULL, cl430 pre_init.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /pre_init.c.obj -fs -ft -ppa -ppd=/pre_init.c.pp, ...) failed.
gmake.exe[2]: *** [/pre_init.c.obj] Error 2
Makefile:1286: recipe for target '/startup.c.obj' failed
process_begin: CreateProcess(NULL, cl430 startup.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /startup.c.obj -fs -ft -ppa -ppd=/startup.c.pp, ...) failed.
gmake.exe[2]: *** [/startup.c.obj] Error 2
Makefile:1286: recipe for target '/copy_decompress_none.c.obj' failed
process_begin: CreateProcess(NULL, cl430 copy_decompress_none.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /copy_decompress_none.c.obj -fs -ft -ppa -ppd=/copy_decompress_none.c.pp, ...) failed.
gmake.exe[2]: *** [/copy_decompress_none.c.obj] Error 2
Makefile:1286: recipe for target '/copy_decompress_rle.c.obj' failed
process_begin: CreateProcess(NULL, cl430 copy_decompress_rle.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /copy_decompress_rle.c.obj -fs -ft -ppa -ppd=/copy_decompress_rle.c.pp, ...) failed.
gmake.exe[2]: *** [/copy_decompress_rle.c.obj] Error 2
Makefile:1286: recipe for target '/copy_decompress_lzss.c.obj' failed
process_begin: CreateProcess(NULL, cl430 copy_decompress_lzss.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /copy_decompress_lzss.c.obj -fs -ft -ppa -ppd=/copy_decompress_lzss.c.pp, ...) failed.
gmake.exe[2]: *** [/copy_decompress_lzss.c.obj] Error 2
Makefile:1286: recipe for target '/pprof_cio.c.obj' failed
process_begin: CreateProcess(NULL, cl430 pprof_cio.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /pprof_cio.c.obj -fs -ft -ppa -ppd=/pprof_cio.c.pp, ...) failed.
gmake.exe[2]: *** [/pprof_cio.c.obj] Error 2
Makefile:1286: recipe for target '/pprof_user.c.obj' failed
process_begin: CreateProcess(NULL, cl430 pprof_user.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /pprof_user.c.obj -fs -ft -ppa -ppd=/pprof_user.c.pp, ...) failed.
gmake.exe[2]: *** [/pprof_user.c.obj] Error 2
Makefile:1286: recipe for target '/outprof.c.obj' failed
process_begin: CreateProcess(NULL, cl430 outprof.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /outprof.c.obj -fs -ft -ppa -ppd=/outprof.c.pp, ...) failed.
gmake.exe[2]: *** [/outprof.c.obj] Error 2
Makefile:1286: recipe for target '/atomic.c.obj' failed
process_begin: CreateProcess(NULL, cl430 atomic.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /atomic.c.obj -fs -ft -ppa -ppd=/atomic.c.pp, ...) failed.
gmake.exe[2]: *** [/atomic.c.obj] Error 2
Makefile:1286: recipe for target '/atomic_fence.c.obj' failed
process_begin: CreateProcess(NULL, cl430 atomic_fence.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /atomic_fence.c.obj -fs -ft -ppa -ppd=/atomic_fence.c.pp, ...) failed.
gmake.exe[2]: *** [/atomic_fence.c.obj] Error 2
Makefile:1286: recipe for target '/atomic_flag.c.obj' failed
process_begin: CreateProcess(NULL, cl430 atomic_flag.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /atomic_flag.c.obj -fs -ft -ppa -ppd=/atomic_flag.c.pp, ...) failed.
gmake.exe[2]: *** [/atomic_flag.c.obj] Error 2
Makefile:1286: recipe for target '/eqlf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 eqlf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /eqlf.c.obj -fs -ft -ppa -ppd=/eqlf.c.pp, ...) failed.
gmake.exe[2]: *** [/eqlf.c.obj] Error 2
Makefile:1286: recipe for target '/gef.c.obj' failed
process_begin: CreateProcess(NULL, cl430 gef.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /gef.c.obj -fs -ft -ppa -ppd=/gef.c.pp, ...) failed.
gmake.exe[2]: *** [/gef.c.obj] Error 2
Makefile:1286: recipe for target '/gtf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 gtf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /gtf.c.obj -fs -ft -ppa -ppd=/gtf.c.pp, ...) failed.
gmake.exe[2]: *** [/gtf.c.obj] Error 2
Makefile:1286: recipe for target '/lef.c.obj' failed
process_begin: CreateProcess(NULL, cl430 lef.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /lef.c.obj -fs -ft -ppa -ppd=/lef.c.pp, ...) failed.
gmake.exe[2]: *** [/lef.c.obj] Error 2
Makefile:1286: recipe for target '/ltf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ltf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ltf.c.obj -fs -ft -ppa -ppd=/ltf.c.pp, ...) failed.
gmake.exe[2]: *** [/ltf.c.obj] Error 2
Makefile:1286: recipe for target '/neqlf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 neqlf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /neqlf.c.obj -fs -ft -ppa -ppd=/neqlf.c.pp, ...) failed.
gmake.exe[2]: *** [/neqlf.c.obj] Error 2
Makefile:1286: recipe for target '/cvtdf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 cvtdf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /cvtdf.c.obj -fs -ft -ppa -ppd=/cvtdf.c.pp, ...) failed.
gmake.exe[2]: *** [/cvtdf.c.obj] Error 2
Makefile:1286: recipe for target '/fixflli.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fixflli.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fixflli.c.obj -fs -ft -ppa -ppd=/fixflli.c.pp, ...) failed.
gmake.exe[2]: *** [/fixflli.c.obj] Error 2
Makefile:1286: recipe for target '/fixfull.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fixfull.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fixfull.c.obj -fs -ft -ppa -ppd=/fixfull.c.pp, ...) failed.
gmake.exe[2]: *** [/fixfull.c.obj] Error 2
Makefile:1286: recipe for target '/fltllif.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fltllif.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fltllif.c.obj -fs -ft -ppa -ppd=/fltllif.c.pp, ...) failed.
gmake.exe[2]: *** [/fltllif.c.obj] Error 2
Makefile:1286: recipe for target '/fltullf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fltullf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fltullf.c.obj -fs -ft -ppa -ppd=/fltullf.c.pp, ...) failed.
gmake.exe[2]: *** [/fltullf.c.obj] Error 2
Makefile:1286: recipe for target '/frcaddf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 frcaddf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /frcaddf.c.obj -fs -ft -ppa -ppd=/frcaddf.c.pp, ...) failed.
gmake.exe[2]: *** [/frcaddf.c.obj] Error 2
Makefile:1286: recipe for target '/frcdivf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 frcdivf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /frcdivf.c.obj -fs -ft -ppa -ppd=/frcdivf.c.pp, ...) failed.
gmake.exe[2]: *** [/frcdivf.c.obj] Error 2
Makefile:1286: recipe for target '/frcmpyf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 frcmpyf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /frcmpyf.c.obj -fs -ft -ppa -ppd=/frcmpyf.c.pp, ...) failed.
gmake.exe[2]: *** [/frcmpyf.c.obj] Error 2
Makefile:1286: recipe for target '/frcmpyf_div.c.obj' failed
process_begin: CreateProcess(NULL, cl430 frcmpyf_div.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /frcmpyf_div.c.obj -fs -ft -ppa -ppd=/frcmpyf_div.c.pp, ...) failed.
gmake.exe[2]: *** [/frcmpyf_div.c.obj] Error 2
Makefile:1286: recipe for target '/renormf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 renormf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /renormf.c.obj -fs -ft -ppa -ppd=/renormf.c.pp, ...) failed.
gmake.exe[2]: *** [/renormf.c.obj] Error 2
Makefile:1286: recipe for target '/addd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 addd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /addd.c.obj -fs -ft -ppa -ppd=/addd.c.pp, ...) failed.
gmake.exe[2]: *** [/addd.c.obj] Error 2
Makefile:1286: recipe for target '/cmpd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 cmpd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /cmpd.c.obj -fs -ft -ppa -ppd=/cmpd.c.pp, ...) failed.
gmake.exe[2]: *** [/cmpd.c.obj] Error 2
Makefile:1286: recipe for target '/eqld.c.obj' failed
process_begin: CreateProcess(NULL, cl430 eqld.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /eqld.c.obj -fs -ft -ppa -ppd=/eqld.c.pp, ...) failed.
gmake.exe[2]: *** [/eqld.c.obj] Error 2
Makefile:1286: recipe for target '/ged.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ged.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ged.c.obj -fs -ft -ppa -ppd=/ged.c.pp, ...) failed.
gmake.exe[2]: *** [/ged.c.obj] Error 2
Makefile:1286: recipe for target '/gtd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 gtd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /gtd.c.obj -fs -ft -ppa -ppd=/gtd.c.pp, ...) failed.
gmake.exe[2]: *** [/gtd.c.obj] Error 2
Makefile:1286: recipe for target '/led.c.obj' failed
process_begin: CreateProcess(NULL, cl430 led.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /led.c.obj -fs -ft -ppa -ppd=/led.c.pp, ...) failed.
gmake.exe[2]: *** [/led.c.obj] Error 2
Makefile:1286: recipe for target '/ltd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ltd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ltd.c.obj -fs -ft -ppa -ppd=/ltd.c.pp, ...) failed.
gmake.exe[2]: *** [/ltd.c.obj] Error 2
Makefile:1286: recipe for target '/neqld.c.obj' failed
process_begin: CreateProcess(NULL, cl430 neqld.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /neqld.c.obj -fs -ft -ppa -ppd=/neqld.c.pp, ...) failed.
gmake.exe[2]: *** [/neqld.c.obj] Error 2
Makefile:1286: recipe for target '/cvtfd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 cvtfd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /cvtfd.c.obj -fs -ft -ppa -ppd=/cvtfd.c.pp, ...) failed.
gmake.exe[2]: *** [/cvtfd.c.obj] Error 2
Makefile:1286: recipe for target '/divd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 divd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /divd.c.obj -fs -ft -ppa -ppd=/divd.c.pp, ...) failed.
gmake.exe[2]: *** [/divd.c.obj] Error 2
Makefile:1286: recipe for target '/fixdi.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fixdi.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fixdi.c.obj -fs -ft -ppa -ppd=/fixdi.c.pp, ...) failed.
gmake.exe[2]: *** [/fixdi.c.obj] Error 2
Makefile:1286: recipe for target '/fixdli.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fixdli.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fixdli.c.obj -fs -ft -ppa -ppd=/fixdli.c.pp, ...) failed.
gmake.exe[2]: *** [/fixdli.c.obj] Error 2
Makefile:1286: recipe for target '/fixdlli.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fixdlli.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fixdlli.c.obj -fs -ft -ppa -ppd=/fixdlli.c.pp, ...) failed.
gmake.exe[2]: *** [/fixdlli.c.obj] Error 2
Makefile:1286: recipe for target '/fixdu.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fixdu.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fixdu.c.obj -fs -ft -ppa -ppd=/fixdu.c.pp, ...) failed.
gmake.exe[2]: *** [/fixdu.c.obj] Error 2
Makefile:1286: recipe for target '/fixdul.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fixdul.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fixdul.c.obj -fs -ft -ppa -ppd=/fixdul.c.pp, ...) failed.
gmake.exe[2]: *** [/fixdul.c.obj] Error 2
Makefile:1286: recipe for target '/fixdull.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fixdull.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fixdull.c.obj -fs -ft -ppa -ppd=/fixdull.c.pp, ...) failed.
gmake.exe[2]: *** [/fixdull.c.obj] Error 2
Makefile:1286: recipe for target '/fltid.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fltid.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fltid.c.obj -fs -ft -ppa -ppd=/fltid.c.pp, ...) failed.
gmake.exe[2]: *** [/fltid.c.obj] Error 2
Makefile:1286: recipe for target '/fltlid.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fltlid.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fltlid.c.obj -fs -ft -ppa -ppd=/fltlid.c.pp, ...) failed.
gmake.exe[2]: *** [/fltlid.c.obj] Error 2
Makefile:1286: recipe for target '/fltllid.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fltllid.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fltllid.c.obj -fs -ft -ppa -ppd=/fltllid.c.pp, ...) failed.
gmake.exe[2]: *** [/fltllid.c.obj] Error 2
Makefile:1286: recipe for target '/fltud.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fltud.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fltud.c.obj -fs -ft -ppa -ppd=/fltud.c.pp, ...) failed.
gmake.exe[2]: *** [/fltud.c.obj] Error 2
Makefile:1286: recipe for target '/fltuld.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fltuld.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fltuld.c.obj -fs -ft -ppa -ppd=/fltuld.c.pp, ...) failed.
gmake.exe[2]: *** [/fltuld.c.obj] Error 2
Makefile:1286: recipe for target '/fltulld.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fltulld.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fltulld.c.obj -fs -ft -ppa -ppd=/fltulld.c.pp, ...) failed.
gmake.exe[2]: *** [/fltulld.c.obj] Error 2
Makefile:1286: recipe for target '/frcaddd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 frcaddd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /frcaddd.c.obj -fs -ft -ppa -ppd=/frcaddd.c.pp, ...) failed.
gmake.exe[2]: *** [/frcaddd.c.obj] Error 2
Makefile:1286: recipe for target '/frcdivd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 frcdivd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /frcdivd.c.obj -fs -ft -ppa -ppd=/frcdivd.c.pp, ...) failed.
gmake.exe[2]: *** [/frcdivd.c.obj] Error 2
Makefile:1286: recipe for target '/frcmpyd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 frcmpyd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /frcmpyd.c.obj -fs -ft -ppa -ppd=/frcmpyd.c.pp, ...) failed.
gmake.exe[2]: *** [/frcmpyd.c.obj] Error 2
Makefile:1286: recipe for target '/frcmpyd_div.c.obj' failed
process_begin: CreateProcess(NULL, cl430 frcmpyd_div.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /frcmpyd_div.c.obj -fs -ft -ppa -ppd=/frcmpyd_div.c.pp, ...) failed.
gmake.exe[2]: *** [/frcmpyd_div.c.obj] Error 2
Makefile:1286: recipe for target '/mpyd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 mpyd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mpyd.c.obj -fs -ft -ppa -ppd=/mpyd.c.pp, ...) failed.
gmake.exe[2]: *** [/mpyd.c.obj] Error 2
Makefile:1286: recipe for target '/negd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 negd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /negd.c.obj -fs -ft -ppa -ppd=/negd.c.pp, ...) failed.
gmake.exe[2]: *** [/negd.c.obj] Error 2
Makefile:1286: recipe for target '/renormd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 renormd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /renormd.c.obj -fs -ft -ppa -ppd=/renormd.c.pp, ...) failed.
gmake.exe[2]: *** [/renormd.c.obj] Error 2
Makefile:1286: recipe for target '/subd.c.obj' failed
process_begin: CreateProcess(NULL, cl430 subd.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /subd.c.obj -fs -ft -ppa -ppd=/subd.c.pp, ...) failed.
gmake.exe[2]: *** [/subd.c.obj] Error 2
Makefile:1286: recipe for target '/e_rem_pio2.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_rem_pio2.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /e_rem_pio2.c.obj -fs -ft -ppa -ppd=/e_rem_pio2.c.pp, ...) failed.
gmake.exe[2]: *** [/e_rem_pio2.c.obj] Error 2
Makefile:1286: recipe for target '/e_rem_pio2f.c.obj' failed
process_begin: CreateProcess(NULL, cl430 e_rem_pio2f.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /e_rem_pio2f.c.obj -fs -ft -ppa -ppd=/e_rem_pio2f.c.pp, ...) failed.
gmake.exe[2]: *** [/e_rem_pio2f.c.obj] Error 2
Makefile:1286: recipe for target '/k_rem_pio2.c.obj' failed
process_begin: CreateProcess(NULL, cl430 k_rem_pio2.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /k_rem_pio2.c.obj -fs -ft -ppa -ppd=/k_rem_pio2.c.pp, ...) failed.
gmake.exe[2]: *** [/k_rem_pio2.c.obj] Error 2
Makefile:1286: recipe for target '/exit.c.obj' failed
process_begin: CreateProcess(NULL, cl430 exit.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /exit.c.obj -fs -ft -ppa -ppd=/exit.c.pp, ...) failed.
gmake.exe[2]: *** [/exit.c.obj] Error 2
Makefile:1286: recipe for target '/_data_synch.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _data_synch.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_data_synch.c.obj -fs -ft -ppa -ppd=/_data_synch.c.pp, ...) failed.
gmake.exe[2]: *** [/_data_synch.c.obj] Error 2
Makefile:1286: recipe for target '/_lock.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _lock.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_lock.c.obj -fs -ft -ppa -ppd=/_lock.c.pp, ...) failed.
gmake.exe[2]: *** [/_lock.c.obj] Error 2
Makefile:1286: recipe for target '/_ltoa.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _ltoa.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_ltoa.c.obj -fs -ft -ppa -ppd=/_ltoa.c.pp, ...) failed.
gmake.exe[2]: *** [/_ltoa.c.obj] Error 2
Makefile:1286: recipe for target '/_mutex.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _mutex.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_mutex.c.obj -fs -ft -ppa -ppd=/_mutex.c.pp, ...) failed.
gmake.exe[2]: *** [/_mutex.c.obj] Error 2
Makefile:1286: recipe for target '/_pthread.c.obj' failed
process_begin: CreateProcess(NULL, cl430 _pthread.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /_pthread.c.obj -fs -ft -ppa -ppd=/_pthread.c.pp, ...) failed.
gmake.exe[2]: *** [/_pthread.c.obj] Error 2
Makefile:1286: recipe for target '/args_main.c.obj' failed
process_begin: CreateProcess(NULL, cl430 args_main.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /args_main.c.obj -fs -ft -ppa -ppd=/args_main.c.pp, ...) failed.
gmake.exe[2]: *** [/args_main.c.obj] Error 2
Makefile:1286: recipe for target '/asctime.c.obj' failed
process_begin: CreateProcess(NULL, cl430 asctime.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /asctime.c.obj -fs -ft -ppa -ppd=/asctime.c.pp, ...) failed.
gmake.exe[2]: *** [/asctime.c.obj] Error 2
Makefile:1286: recipe for target '/assert.c.obj' failed
process_begin: CreateProcess(NULL, cl430 assert.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /assert.c.obj -fs -ft -ppa -ppd=/assert.c.pp, ...) failed.
gmake.exe[2]: *** [/assert.c.obj] Error 2
Makefile:1286: recipe for target '/atof.c.obj' failed
process_begin: CreateProcess(NULL, cl430 atof.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /atof.c.obj -fs -ft -ppa -ppd=/atof.c.pp, ...) failed.
gmake.exe[2]: *** [/atof.c.obj] Error 2
Makefile:1286: recipe for target '/atoi.c.obj' failed
process_begin: CreateProcess(NULL, cl430 atoi.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /atoi.c.obj -fs -ft -ppa -ppd=/atoi.c.pp, ...) failed.
gmake.exe[2]: *** [/atoi.c.obj] Error 2
Makefile:1286: recipe for target '/atol.c.obj' failed
process_begin: CreateProcess(NULL, cl430 atol.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /atol.c.obj -fs -ft -ppa -ppd=/atol.c.pp, ...) failed.
gmake.exe[2]: *** [/atol.c.obj] Error 2
Makefile:1286: recipe for target '/atoll.c.obj' failed
process_begin: CreateProcess(NULL, cl430 atoll.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /atoll.c.obj -fs -ft -ppa -ppd=/atoll.c.pp, ...) failed.
gmake.exe[2]: *** [/atoll.c.obj] Error 2
Makefile:1286: recipe for target '/bcmp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 bcmp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /bcmp.c.obj -fs -ft -ppa -ppd=/bcmp.c.pp, ...) failed.
gmake.exe[2]: *** [/bcmp.c.obj] Error 2
Makefile:1286: recipe for target '/bcopy.c.obj' failed
process_begin: CreateProcess(NULL, cl430 bcopy.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /bcopy.c.obj -fs -ft -ppa -ppd=/bcopy.c.pp, ...) failed.
gmake.exe[2]: *** [/bcopy.c.obj] Error 2
Makefile:1286: recipe for target '/bsearch.c.obj' failed
process_begin: CreateProcess(NULL, cl430 bsearch.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /bsearch.c.obj -fs -ft -ppa -ppd=/bsearch.c.pp, ...) failed.
gmake.exe[2]: *** [/bsearch.c.obj] Error 2
Makefile:1286: recipe for target '/bzero.c.obj' failed
process_begin: CreateProcess(NULL, cl430 bzero.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /bzero.c.obj -fs -ft -ppa -ppd=/bzero.c.pp, ...) failed.
gmake.exe[2]: *** [/bzero.c.obj] Error 2
Makefile:1286: recipe for target '/clearerr.c.obj' failed
Makefile:1286: recipe for target '/common_exit.c.obj' failed
process_begin: CreateProcess(NULL, cl430 clearerr.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /clearerr.c.obj -fs -ft -ppa -ppd=/clearerr.c.pp, ...) failed.
gmake.exe[2]: *** [/clearerr.c.obj] Error 2
process_begin: CreateProcess(NULL, cl430 common_exit.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /common_exit.c.obj -fs -ft -ppa -ppd=/common_exit.c.pp, ...) failed.
gmake.exe[2]: *** [/common_exit.c.obj] Error 2
Makefile:1286: recipe for target '/ctime_.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ctime_.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ctime_.c.obj -fs -ft -ppa -ppd=/ctime_.c.pp, ...) failed.
gmake.exe[2]: *** [/ctime_.c.obj] Error 2
Makefile:1286: recipe for target '/ctime64.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ctime64.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ctime64.c.obj -fs -ft -ppa -ppd=/ctime64.c.pp, ...) failed.
gmake.exe[2]: *** [/ctime64.c.obj] Error 2
Makefile:1286: recipe for target '/ctype.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ctype.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ctype.c.obj -fs -ft -ppa -ppd=/ctype.c.pp, ...) failed.
gmake.exe[2]: *** [/ctype.c.obj] Error 2
Makefile:1286: recipe for target '/defs.c.obj' failed
process_begin: CreateProcess(NULL, cl430 defs.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /defs.c.obj -fs -ft -ppa -ppd=/defs.c.pp, ...) failed.
gmake.exe[2]: *** [/defs.c.obj] Error 2
Makefile:1286: recipe for target '/difftime.c.obj' failed
process_begin: CreateProcess(NULL, cl430 difftime.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /difftime.c.obj -fs -ft -ppa -ppd=/difftime.c.pp, ...) failed.
gmake.exe[2]: *** [/difftime.c.obj] Error 2
Makefile:1286: recipe for target '/difftime64.c.obj' failed
process_begin: CreateProcess(NULL, cl430 difftime64.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /difftime64.c.obj -fs -ft -ppa -ppd=/difftime64.c.pp, ...) failed.
gmake.exe[2]: *** [/difftime64.c.obj] Error 2
Makefile:1286: recipe for target '/ecvt.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ecvt.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ecvt.c.obj -fs -ft -ppa -ppd=/ecvt.c.pp, ...) failed.
gmake.exe[2]: *** [/ecvt.c.obj] Error 2
Makefile:1286: recipe for target '/fcvt.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fcvt.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fcvt.c.obj -fs -ft -ppa -ppd=/fcvt.c.pp, ...) failed.
gmake.exe[2]: *** [/fcvt.c.obj] Error 2
Makefile:1286: recipe for target '/ffs.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ffs.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ffs.c.obj -fs -ft -ppa -ppd=/ffs.c.pp, ...) failed.
gmake.exe[2]: *** [/ffs.c.obj] Error 2
Makefile:1286: recipe for target '/gmtime.c.obj' failed
process_begin: CreateProcess(NULL, cl430 gmtime.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /gmtime.c.obj -fs -ft -ppa -ppd=/gmtime.c.pp, ...) failed.
gmake.exe[2]: *** [/gmtime.c.obj] Error 2
Makefile:1286: recipe for target '/gmtime64.c.obj' failed
process_begin: CreateProcess(NULL, cl430 gmtime64.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /gmtime64.c.obj -fs -ft -ppa -ppd=/gmtime64.c.pp, ...) failed.
gmake.exe[2]: *** [/gmtime64.c.obj] Error 2
Makefile:1286: recipe for target '/index.c.obj' failed
process_begin: CreateProcess(NULL, cl430 index.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /index.c.obj -fs -ft -ppa -ppd=/index.c.pp, ...) failed.
gmake.exe[2]: *** [/index.c.obj] Error 2
Makefile:1286: recipe for target '/isalnum.c.obj' failed
process_begin: CreateProcess(NULL, cl430 isalnum.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /isalnum.c.obj -fs -ft -ppa -ppd=/isalnum.c.pp, ...) failed.
gmake.exe[2]: *** [/isalnum.c.obj] Error 2
Makefile:1286: recipe for target '/isalpha.c.obj' failed
process_begin: CreateProcess(NULL, cl430 isalpha.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /isalpha.c.obj -fs -ft -ppa -ppd=/isalpha.c.pp, ...) failed.
gmake.exe[2]: *** [/isalpha.c.obj] Error 2
Makefile:1286: recipe for target '/isascii.c.obj' failed
process_begin: CreateProcess(NULL, cl430 isascii.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /isascii.c.obj -fs -ft -ppa -ppd=/isascii.c.pp, ...) failed.
gmake.exe[2]: *** [/isascii.c.obj] Error 2
Makefile:1286: recipe for target '/iscntrl.c.obj' failed
process_begin: CreateProcess(NULL, cl430 iscntrl.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /iscntrl.c.obj -fs -ft -ppa -ppd=/iscntrl.c.pp, ...) failed.
gmake.exe[2]: *** [/iscntrl.c.obj] Error 2
Makefile:1286: recipe for target '/isdigit.c.obj' failed
process_begin: CreateProcess(NULL, cl430 isdigit.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /isdigit.c.obj -fs -ft -ppa -ppd=/isdigit.c.pp, ...) failed.
gmake.exe[2]: *** [/isdigit.c.obj] Error 2
Makefile:1286: recipe for target '/isgraph.c.obj' failed
process_begin: CreateProcess(NULL, cl430 isgraph.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /isgraph.c.obj -fs -ft -ppa -ppd=/isgraph.c.pp, ...) failed.
gmake.exe[2]: *** [/isgraph.c.obj] Error 2
Makefile:1286: recipe for target '/islower.c.obj' failed
process_begin: CreateProcess(NULL, cl430 islower.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /islower.c.obj -fs -ft -ppa -ppd=/islower.c.pp, ...) failed.
gmake.exe[2]: *** [/islower.c.obj] Error 2
Makefile:1286: recipe for target '/isprint.c.obj' failed
process_begin: CreateProcess(NULL, cl430 isprint.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /isprint.c.obj -fs -ft -ppa -ppd=/isprint.c.pp, ...) failed.
gmake.exe[2]: *** [/isprint.c.obj] Error 2
Makefile:1286: recipe for target '/ispunct.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ispunct.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ispunct.c.obj -fs -ft -ppa -ppd=/ispunct.c.pp, ...) failed.
gmake.exe[2]: *** [/ispunct.c.obj] Error 2
Makefile:1286: recipe for target '/isspace.c.obj' failed
process_begin: CreateProcess(NULL, cl430 isspace.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /isspace.c.obj -fs -ft -ppa -ppd=/isspace.c.pp, ...) failed.
gmake.exe[2]: *** [/isspace.c.obj] Error 2
Makefile:1286: recipe for target '/isupper.c.obj' failed
process_begin: CreateProcess(NULL, cl430 isupper.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /isupper.c.obj -fs -ft -ppa -ppd=/isupper.c.pp, ...) failed.
gmake.exe[2]: *** [/isupper.c.obj] Error 2
Makefile:1286: recipe for target '/isxdigit.c.obj' failed
process_begin: CreateProcess(NULL, cl430 isxdigit.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /isxdigit.c.obj -fs -ft -ppa -ppd=/isxdigit.c.pp, ...) failed.
gmake.exe[2]: *** [/isxdigit.c.obj] Error 2
Makefile:1286: recipe for target '/localtim.c.obj' failed
process_begin: CreateProcess(NULL, cl430 localtim.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /localtim.c.obj -fs -ft -ppa -ppd=/localtim.c.pp, ...) failed.
gmake.exe[2]: *** [/localtim.c.obj] Error 2
Makefile:1286: recipe for target '/localtim64.c.obj' failed
process_begin: CreateProcess(NULL, cl430 localtim64.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /localtim64.c.obj -fs -ft -ppa -ppd=/localtim64.c.pp, ...) failed.
gmake.exe[2]: *** [/localtim64.c.obj] Error 2
Makefile:1286: recipe for target '/ltoa.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ltoa.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ltoa.c.obj -fs -ft -ppa -ppd=/ltoa.c.pp, ...) failed.
gmake.exe[2]: *** [/ltoa.c.obj] Error 2
Makefile:1286: recipe for target '/memccpy.c.obj' failed
process_begin: CreateProcess(NULL, cl430 memccpy.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /memccpy.c.obj -fs -ft -ppa -ppd=/memccpy.c.pp, ...) failed.
gmake.exe[2]: *** [/memccpy.c.obj] Error 2
Makefile:1286: recipe for target '/memchr.c.obj' failed
process_begin: CreateProcess(NULL, cl430 memchr.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /memchr.c.obj -fs -ft -ppa -ppd=/memchr.c.pp, ...) failed.
gmake.exe[2]: *** [/memchr.c.obj] Error 2
Makefile:1286: recipe for target '/memcmp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 memcmp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /memcmp.c.obj -fs -ft -ppa -ppd=/memcmp.c.pp, ...) failed.
gmake.exe[2]: *** [/memcmp.c.obj] Error 2
Makefile:1286: recipe for target '/memcpy.c.obj' failed
process_begin: CreateProcess(NULL, cl430 memcpy.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /memcpy.c.obj -fs -ft -ppa -ppd=/memcpy.c.pp, ...) failed.
gmake.exe[2]: *** [/memcpy.c.obj] Error 2
Makefile:1286: recipe for target '/memmov.c.obj' failed
process_begin: CreateProcess(NULL, cl430 memmov.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /memmov.c.obj -fs -ft -ppa -ppd=/memmov.c.pp, ...) failed.
gmake.exe[2]: *** [/memmov.c.obj] Error 2
Makefile:1286: recipe for target '/memory.c.obj' failed
process_begin: CreateProcess(NULL, cl430 memory.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /memory.c.obj -fs -ft -ppa -ppd=/memory.c.pp, ...) failed.
gmake.exe[2]: *** [/memory.c.obj] Error 2
Makefile:1286: recipe for target '/memset.c.obj' failed
process_begin: CreateProcess(NULL, cl430 memset.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /memset.c.obj -fs -ft -ppa -ppd=/memset.c.pp, ...) failed.
gmake.exe[2]: *** [/memset.c.obj] Error 2
Makefile:1286: recipe for target '/mktime.c.obj' failed
process_begin: CreateProcess(NULL, cl430 mktime.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mktime.c.obj -fs -ft -ppa -ppd=/mktime.c.pp, ...) failed.
gmake.exe[2]: *** [/mktime.c.obj] Error 2
Makefile:1286: recipe for target '/mktime64.c.obj' failed
process_begin: CreateProcess(NULL, cl430 mktime64.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /mktime64.c.obj -fs -ft -ppa -ppd=/mktime64.c.pp, ...) failed.
gmake.exe[2]: *** [/mktime64.c.obj] Error 2
Makefile:1286: recipe for target '/perror.c.obj' failed
process_begin: CreateProcess(NULL, cl430 perror.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /perror.c.obj -fs -ft -ppa -ppd=/perror.c.pp, ...) failed.
gmake.exe[2]: *** [/perror.c.obj] Error 2
Makefile:1286: recipe for target '/qsort.c.obj' failed
process_begin: CreateProcess(NULL, cl430 qsort.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /qsort.c.obj -fs -ft -ppa -ppd=/qsort.c.pp, ...) failed.
gmake.exe[2]: *** [/qsort.c.obj] Error 2
Makefile:1286: recipe for target '/quick_exit.c.obj' failed
process_begin: CreateProcess(NULL, cl430 quick_exit.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /quick_exit.c.obj -fs -ft -ppa -ppd=/quick_exit.c.pp, ...) failed.
gmake.exe[2]: *** [/quick_exit.c.obj] Error 2
Makefile:1286: recipe for target '/rand.c.obj' failed
process_begin: CreateProcess(NULL, cl430 rand.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /rand.c.obj -fs -ft -ppa -ppd=/rand.c.pp, ...) failed.
gmake.exe[2]: *** [/rand.c.obj] Error 2
Makefile:1286: recipe for target '/rewind.c.obj' failed
process_begin: CreateProcess(NULL, cl430 rewind.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /rewind.c.obj -fs -ft -ppa -ppd=/rewind.c.pp, ...) failed.
gmake.exe[2]: *** [/rewind.c.obj] Error 2
Makefile:1286: recipe for target '/rindex.c.obj' failed
process_begin: CreateProcess(NULL, cl430 rindex.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /rindex.c.obj -fs -ft -ppa -ppd=/rindex.c.pp, ...) failed.
gmake.exe[2]: *** [/rindex.c.obj] Error 2
Makefile:1286: recipe for target '/setlocale.c.obj' failed
process_begin: CreateProcess(NULL, cl430 setlocale.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /setlocale.c.obj -fs -ft -ppa -ppd=/setlocale.c.pp, ...) failed.
gmake.exe[2]: *** [/setlocale.c.obj] Error 2
Makefile:1286: recipe for target '/strcasecmp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strcasecmp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strcasecmp.c.obj -fs -ft -ppa -ppd=/strcasecmp.c.pp, ...) failed.
gmake.exe[2]: *** [/strcasecmp.c.obj] Error 2
Makefile:1286: recipe for target '/strcat.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strcat.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strcat.c.obj -fs -ft -ppa -ppd=/strcat.c.pp, ...) failed.
gmake.exe[2]: *** [/strcat.c.obj] Error 2
Makefile:1286: recipe for target '/strchr.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strchr.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strchr.c.obj -fs -ft -ppa -ppd=/strchr.c.pp, ...) failed.
gmake.exe[2]: *** [/strchr.c.obj] Error 2
Makefile:1286: recipe for target '/strcmp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strcmp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strcmp.c.obj -fs -ft -ppa -ppd=/strcmp.c.pp, ...) failed.
gmake.exe[2]: *** [/strcmp.c.obj] Error 2
Makefile:1286: recipe for target '/strcoll.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strcoll.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strcoll.c.obj -fs -ft -ppa -ppd=/strcoll.c.pp, ...) failed.
gmake.exe[2]: *** [/strcoll.c.obj] Error 2
Makefile:1286: recipe for target '/strcpy.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strcpy.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strcpy.c.obj -fs -ft -ppa -ppd=/strcpy.c.pp, ...) failed.
gmake.exe[2]: *** [/strcpy.c.obj] Error 2
Makefile:1286: recipe for target '/strcspn.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strcspn.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strcspn.c.obj -fs -ft -ppa -ppd=/strcspn.c.pp, ...) failed.
gmake.exe[2]: *** [/strcspn.c.obj] Error 2
Makefile:1286: recipe for target '/strdup.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strdup.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strdup.c.obj -fs -ft -ppa -ppd=/strdup.c.pp, ...) failed.
gmake.exe[2]: *** [/strdup.c.obj] Error 2
Makefile:1286: recipe for target '/strerror.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strerror.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strerror.c.obj -fs -ft -ppa -ppd=/strerror.c.pp, ...) failed.
gmake.exe[2]: *** [/strerror.c.obj] Error 2
Makefile:1286: recipe for target '/strftime.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strftime.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strftime.c.obj -fs -ft -ppa -ppd=/strftime.c.pp, ...) failed.
gmake.exe[2]: *** [/strftime.c.obj] Error 2
Makefile:1286: recipe for target '/strlen.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strlen.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strlen.c.obj -fs -ft -ppa -ppd=/strlen.c.pp, ...) failed.
gmake.exe[2]: *** [/strlen.c.obj] Error 2
Makefile:1286: recipe for target '/strncasecmp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strncasecmp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strncasecmp.c.obj -fs -ft -ppa -ppd=/strncasecmp.c.pp, ...) failed.
gmake.exe[2]: *** [/strncasecmp.c.obj] Error 2
Makefile:1286: recipe for target '/strncat.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strncat.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strncat.c.obj -fs -ft -ppa -ppd=/strncat.c.pp, ...) failed.
gmake.exe[2]: *** [/strncat.c.obj] Error 2
Makefile:1286: recipe for target '/strncmp.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strncmp.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strncmp.c.obj -fs -ft -ppa -ppd=/strncmp.c.pp, ...) failed.
gmake.exe[2]: *** [/strncmp.c.obj] Error 2
Makefile:1286: recipe for target '/strncpy.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strncpy.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strncpy.c.obj -fs -ft -ppa -ppd=/strncpy.c.pp, ...) failed.
gmake.exe[2]: *** [/strncpy.c.obj] Error 2
Makefile:1286: recipe for target '/strpbrk.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strpbrk.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strpbrk.c.obj -fs -ft -ppa -ppd=/strpbrk.c.pp, ...) failed.
gmake.exe[2]: *** [/strpbrk.c.obj] Error 2
Makefile:1286: recipe for target '/strrchr.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strrchr.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strrchr.c.obj -fs -ft -ppa -ppd=/strrchr.c.pp, ...) failed.
gmake.exe[2]: *** [/strrchr.c.obj] Error 2
Makefile:1286: recipe for target '/strspn.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strspn.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strspn.c.obj -fs -ft -ppa -ppd=/strspn.c.pp, ...) failed.
gmake.exe[2]: *** [/strspn.c.obj] Error 2
Makefile:1286: recipe for target '/strstr.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strstr.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strstr.c.obj -fs -ft -ppa -ppd=/strstr.c.pp, ...) failed.
gmake.exe[2]: *** [/strstr.c.obj] Error 2
Makefile:1286: recipe for target '/strtod.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strtod.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strtod.c.obj -fs -ft -ppa -ppd=/strtod.c.pp, ...) failed.
gmake.exe[2]: *** [/strtod.c.obj] Error 2
Makefile:1286: recipe for target '/strtof.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strtof.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strtof.c.obj -fs -ft -ppa -ppd=/strtof.c.pp, ...) failed.
gmake.exe[2]: *** [/strtof.c.obj] Error 2
Makefile:1286: recipe for target '/strtok.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strtok.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strtok.c.obj -fs -ft -ppa -ppd=/strtok.c.pp, ...) failed.
gmake.exe[2]: *** [/strtok.c.obj] Error 2
Makefile:1286: recipe for target '/strtol.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strtol.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strtol.c.obj -fs -ft -ppa -ppd=/strtol.c.pp, ...) failed.
gmake.exe[2]: *** [/strtol.c.obj] Error 2
Makefile:1286: recipe for target '/strtold.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strtold.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strtold.c.obj -fs -ft -ppa -ppd=/strtold.c.pp, ...) failed.
gmake.exe[2]: *** [/strtold.c.obj] Error 2
Makefile:1286: recipe for target '/strtoll.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strtoll.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strtoll.c.obj -fs -ft -ppa -ppd=/strtoll.c.pp, ...) failed.
gmake.exe[2]: *** [/strtoll.c.obj] Error 2
Makefile:1286: recipe for target '/strtoul.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strtoul.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strtoul.c.obj -fs -ft -ppa -ppd=/strtoul.c.pp, ...) failed.
gmake.exe[2]: *** [/strtoul.c.obj] Error 2
Makefile:1286: recipe for target '/strtoull.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strtoull.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strtoull.c.obj -fs -ft -ppa -ppd=/strtoull.c.pp, ...) failed.
gmake.exe[2]: *** [/strtoull.c.obj] Error 2
Makefile:1286: recipe for target '/strtoimax.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strtoimax.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strtoimax.c.obj -fs -ft -ppa -ppd=/strtoimax.c.pp, ...) failed.
gmake.exe[2]: *** [/strtoimax.c.obj] Error 2
Makefile:1286: recipe for target '/strtoumax.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strtoumax.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strtoumax.c.obj -fs -ft -ppa -ppd=/strtoumax.c.pp, ...) failed.
gmake.exe[2]: *** [/strtoumax.c.obj] Error 2
Makefile:1286: recipe for target '/strxfrm.c.obj' failed
process_begin: CreateProcess(NULL, cl430 strxfrm.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /strxfrm.c.obj -fs -ft -ppa -ppd=/strxfrm.c.pp, ...) failed.
gmake.exe[2]: *** [/strxfrm.c.obj] Error 2
Makefile:1286: recipe for target '/tmpfile.c.obj' failed
process_begin: CreateProcess(NULL, cl430 tmpfile.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /tmpfile.c.obj -fs -ft -ppa -ppd=/tmpfile.c.pp, ...) failed.
gmake.exe[2]: *** [/tmpfile.c.obj] Error 2
Makefile:1286: recipe for target '/tmpnam.c.obj' failed
process_begin: CreateProcess(NULL, cl430 tmpnam.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /tmpnam.c.obj -fs -ft -ppa -ppd=/tmpnam.c.pp, ...) failed.
gmake.exe[2]: *** [/tmpnam.c.obj] Error 2
Makefile:1286: recipe for target '/tmzone.c.obj' failed
process_begin: CreateProcess(NULL, cl430 tmzone.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /tmzone.c.obj -fs -ft -ppa -ppd=/tmzone.c.pp, ...) failed.
gmake.exe[2]: *** [/tmzone.c.obj] Error 2
Makefile:1286: recipe for target '/toascii.c.obj' failed
process_begin: CreateProcess(NULL, cl430 toascii.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /toascii.c.obj -fs -ft -ppa -ppd=/toascii.c.pp, ...) failed.
gmake.exe[2]: *** [/toascii.c.obj] Error 2
Makefile:1286: recipe for target '/tolower.c.obj' failed
process_begin: CreateProcess(NULL, cl430 tolower.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /tolower.c.obj -fs -ft -ppa -ppd=/tolower.c.pp, ...) failed.
gmake.exe[2]: *** [/tolower.c.obj] Error 2
Makefile:1286: recipe for target '/toupper.c.obj' failed
process_begin: CreateProcess(NULL, cl430 toupper.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /toupper.c.obj -fs -ft -ppa -ppd=/toupper.c.pp, ...) failed.
gmake.exe[2]: *** [/toupper.c.obj] Error 2
Makefile:1286: recipe for target '/wctype.c.obj' failed
process_begin: CreateProcess(NULL, cl430 wctype.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /wctype.c.obj -fs -ft -ppa -ppd=/wctype.c.pp, ...) failed.
gmake.exe[2]: *** [/wctype.c.obj] Error 2
Makefile:1286: recipe for target '/signal.c.obj' failed
process_begin: CreateProcess(NULL, cl430 signal.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /signal.c.obj -fs -ft -ppa -ppd=/signal.c.pp, ...) failed.
gmake.exe[2]: *** [/signal.c.obj] Error 2
Makefile:1286: recipe for target '/fenv.c.obj' failed
process_begin: CreateProcess(NULL, cl430 fenv.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /fenv.c.obj -fs -ft -ppa -ppd=/fenv.c.pp, ...) failed.
gmake.exe[2]: *** [/fenv.c.obj] Error 2
Makefile:1286: recipe for target '/abs.c.obj' failed
process_begin: CreateProcess(NULL, cl430 abs.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /abs.c.obj -fs -ft -ppa -ppd=/abs.c.pp, ...) failed.
gmake.exe[2]: *** [/abs.c.obj] Error 2
Makefile:1286: recipe for target '/labs.c.obj' failed
process_begin: CreateProcess(NULL, cl430 labs.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /labs.c.obj -fs -ft -ppa -ppd=/labs.c.pp, ...) failed.
gmake.exe[2]: *** [/labs.c.obj] Error 2
Makefile:1286: recipe for target '/llabs.c.obj' failed
process_begin: CreateProcess(NULL, cl430 llabs.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /llabs.c.obj -fs -ft -ppa -ppd=/llabs.c.pp, ...) failed.
gmake.exe[2]: *** [/llabs.c.obj] Error 2
Makefile:1286: recipe for target '/imaxabs.c.obj' failed
process_begin: CreateProcess(NULL, cl430 imaxabs.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /imaxabs.c.obj -fs -ft -ppa -ppd=/imaxabs.c.pp, ...) failed.
gmake.exe[2]: *** [/imaxabs.c.obj] Error 2
Makefile:1286: recipe for target '/imaxdiv.c.obj' failed
process_begin: CreateProcess(NULL, cl430 imaxdiv.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /imaxdiv.c.obj -fs -ft -ppa -ppd=/imaxdiv.c.pp, ...) failed.
gmake.exe[2]: *** [/imaxdiv.c.obj] Error 2
Makefile:1286: recipe for target '/asprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 asprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /asprintf.c.obj -fs -ft -ppa -ppd=/asprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/asprintf.c.obj] Error 2
Makefile:1286: recipe for target '/vasprintf.c.obj' failed
process_begin: CreateProcess(NULL, cl430 vasprintf.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /vasprintf.c.obj -fs -ft -ppa -ppd=/vasprintf.c.pp, ...) failed.
gmake.exe[2]: *** [/vasprintf.c.obj] Error 2
Makefile:1286: recipe for target '/div.c.obj' failed
process_begin: CreateProcess(NULL, cl430 div.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /div.c.obj -fs -ft -ppa -ppd=/div.c.pp, ...) failed.
gmake.exe[2]: *** [/div.c.obj] Error 2
Makefile:1286: recipe for target '/ldiv.c.obj' failed
process_begin: CreateProcess(NULL, cl430 ldiv.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /ldiv.c.obj -fs -ft -ppa -ppd=/ldiv.c.pp, ...) failed.
gmake.exe[2]: *** [/ldiv.c.obj] Error 2
Makefile:1286: recipe for target '/lldiv.c.obj' failed
process_begin: CreateProcess(NULL, cl430 lldiv.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /lldiv.c.obj -fs -ft -ppa -ppd=/lldiv.c.pp, ...) failed.
gmake.exe[2]: *** [/lldiv.c.obj] Error 2
Makefile:1286: recipe for target '/write.c.obj' failed
process_begin: CreateProcess(NULL, cl430 write.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /write.c.obj -fs -ft -ppa -ppd=/write.c.pp, ...) failed.
gmake.exe[2]: *** [/write.c.obj] Error 2
Makefile:1286: recipe for target '/unlink.c.obj' failed
process_begin: CreateProcess(NULL, cl430 unlink.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /unlink.c.obj -fs -ft -ppa -ppd=/unlink.c.pp, ...) failed.
gmake.exe[2]: *** [/unlink.c.obj] Error 2
Makefile:1286: recipe for target '/hostclock.c.obj' failed
process_begin: CreateProcess(NULL, cl430 hostclock.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /hostclock.c.obj -fs -ft -ppa -ppd=/hostclock.c.pp, ...) failed.
gmake.exe[2]: *** [/hostclock.c.obj] Error 2
Makefile:1286: recipe for target '/hostclose.c.obj' failed
process_begin: CreateProcess(NULL, cl430 hostclose.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /hostclose.c.obj -fs -ft -ppa -ppd=/hostclose.c.pp, ...) failed.
gmake.exe[2]: *** [/hostclose.c.obj] Error 2
Makefile:1286: recipe for target '/hostgetenv.c.obj' failed
process_begin: CreateProcess(NULL, cl430 hostgetenv.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /hostgetenv.c.obj -fs -ft -ppa -ppd=/hostgetenv.c.pp, ...) failed.
gmake.exe[2]: *** [/hostgetenv.c.obj] Error 2
Makefile:1286: recipe for target '/hostlseek.c.obj' failed
process_begin: CreateProcess(NULL, cl430 hostlseek.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /hostlseek.c.obj -fs -ft -ppa -ppd=/hostlseek.c.pp, ...) failed.
gmake.exe[2]: *** [/hostlseek.c.obj] Error 2
Makefile:1286: recipe for target '/hostopen.c.obj' failed
process_begin: CreateProcess(NULL, cl430 hostopen.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /hostopen.c.obj -fs -ft -ppa -ppd=/hostopen.c.pp, ...) failed.
gmake.exe[2]: *** [/hostopen.c.obj] Error 2
Makefile:1286: recipe for target '/hostread.c.obj' failed
process_begin: CreateProcess(NULL, cl430 hostread.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /hostread.c.obj -fs -ft -ppa -ppd=/hostread.c.pp, ...) failed.
gmake.exe[2]: *** [/hostread.c.obj] Error 2
Makefile:1286: recipe for target '/hostrename.c.obj' failed
process_begin: CreateProcess(NULL, cl430 hostrename.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /hostrename.c.obj -fs -ft -ppa -ppd=/hostrename.c.pp, ...) failed.
gmake.exe[2]: *** [/hostrename.c.obj] Error 2
Makefile:1286: recipe for target '/hosttime.c.obj' failed
process_begin: CreateProcess(NULL, cl430 hosttime.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /hosttime.c.obj -fs -ft -ppa -ppd=/hosttime.c.pp, ...) failed.
gmake.exe[2]: *** [/hosttime.c.obj] Error 2
Makefile:1286: recipe for target '/hostunlink.c.obj' failed
process_begin: CreateProcess(NULL, cl430 hostunlink.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /hostunlink.c.obj -fs -ft -ppa -ppd=/hostunlink.c.pp, ...) failed.
gmake.exe[2]: *** [/hostunlink.c.obj] Error 2
Makefile:1286: recipe for target '/hostwrite.c.obj' failed
process_begin: CreateProcess(NULL, cl430 hostwrite.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /hostwrite.c.obj -fs -ft -ppa -ppd=/hostwrite.c.pp, ...) failed.
gmake.exe[2]: *** [/hostwrite.c.obj] Error 2
Makefile:1286: recipe for target '/host_device.c.obj' failed
process_begin: CreateProcess(NULL, cl430 host_device.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /host_device.c.obj -fs -ft -ppa -ppd=/host_device.c.pp, ...) failed.
gmake.exe[2]: *** [/host_device.c.obj] Error 2
Makefile:1286: recipe for target '/trgmsg.c.obj' failed
process_begin: CreateProcess(NULL, cl430 trgmsg.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /trgmsg.c.obj -fs -ft -ppa -ppd=/trgmsg.c.pp, ...) failed.
gmake.exe[2]: *** [/trgmsg.c.obj] Error 2
Makefile:1286: recipe for target '/time.c.obj' failed
process_begin: CreateProcess(NULL, cl430 time.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /time.c.obj -fs -ft -ppa -ppd=/time.c.pp, ...) failed.
gmake.exe[2]: *** [/time.c.obj] Error 2
Makefile:1286: recipe for target '/time64.c.obj' failed
process_begin: CreateProcess(NULL, cl430 time64.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /time64.c.obj -fs -ft -ppa -ppd=/time64.c.pp, ...) failed.
gmake.exe[2]: *** [/time64.c.obj] Error 2
Makefile:1286: recipe for target '/rename.c.obj' failed
process_begin: CreateProcess(NULL, cl430 rename.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /rename.c.obj -fs -ft -ppa -ppd=/rename.c.pp, ...) failed.
gmake.exe[2]: *** [/rename.c.obj] Error 2
Makefile:1286: recipe for target '/remove.c.obj' failed
process_begin: CreateProcess(NULL, cl430 remove.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /remove.c.obj -fs -ft -ppa -ppd=/remove.c.pp, ...) failed.
gmake.exe[2]: *** [/remove.c.obj] Error 2
Makefile:1286: recipe for target '/remove_device.c.obj' failed
process_begin: CreateProcess(NULL, cl430 remove_device.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /remove_device.c.obj -fs -ft -ppa -ppd=/remove_device.c.pp, ...) failed.
gmake.exe[2]: *** [/remove_device.c.obj] Error 2
Makefile:1286: recipe for target '/read.c.obj' failed
process_begin: CreateProcess(NULL, cl430 read.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /read.c.obj -fs -ft -ppa -ppd=/read.c.pp, ...) failed.
gmake.exe[2]: *** [/read.c.obj] Error 2
Makefile:1286: recipe for target '/open.c.obj' failed
process_begin: CreateProcess(NULL, cl430 open.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /open.c.obj -fs -ft -ppa -ppd=/open.c.pp, ...) failed.
gmake.exe[2]: *** [/open.c.obj] Error 2
Makefile:1286: recipe for target '/lseek.c.obj' failed
process_begin: CreateProcess(NULL, cl430 lseek.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /lseek.c.obj -fs -ft -ppa -ppd=/lseek.c.pp, ...) failed.
gmake.exe[2]: *** [/lseek.c.obj] Error 2
Makefile:1286: recipe for target '/close.c.obj' failed
process_begin: CreateProcess(NULL, cl430 close.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /close.c.obj -fs -ft -ppa -ppd=/close.c.pp, ...) failed.
gmake.exe[2]: *** [/close.c.obj] Error 2
Makefile:1286: recipe for target '/clock.c.obj' failed
process_begin: CreateProcess(NULL, cl430 clock.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /clock.c.obj -fs -ft -ppa -ppd=/clock.c.pp, ...) failed.
gmake.exe[2]: *** [/clock.c.obj] Error 2
Makefile:1286: recipe for target '/add_device.c.obj' failed
process_begin: CreateProcess(NULL, cl430 add_device.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /add_device.c.obj -fs -ft -ppa -ppd=/add_device.c.pp, ...) failed.
gmake.exe[2]: *** [/add_device.c.obj] Error 2
Makefile:1286: recipe for target '/errno.c.obj' failed
process_begin: CreateProcess(NULL, cl430 errno.c --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 --abi=eabi -q --silicon_errata=CPU12 --silicon_errata=CPU13 --silicon_errata=CPU19 --silicon_errata=CPU40 -D_TI_USING_LIBCXX -c --ti_lib --keep_unneeded_types=false --diag_warning=225 --quiet -O4 -I -fe /errno.c.obj -fs -ft -ppa -ppd=/errno.c.pp, ...) failed.
gmake.exe[2]: *** [/errno.c.obj] Error 2
>> Compilation failure
makefile:142: recipe for target 'SSLAB2.asm.out' failed
gmake.exe[2]: Target 'library' not remade because of errors.
>> ERROR: mklib: gmake error during rts430x_sc_sd_eabi.lib build
warning #10207-D: automatic RTS selection: resolving index library "libc.a" to "rts430x_sc_sd_eabi.lib", but "rts430x_sc_sd_eabi.lib" was not found
"../lnk_msp430f5529.cmd", line 221: warning #10374-D: Interrupt vector "RTC" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 222: warning #10374-D: Interrupt vector "PORT2" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 223: warning #10374-D: Interrupt vector "TIMER2_A1" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 224: warning #10374-D: Interrupt vector "TIMER2_A0" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 225: warning #10374-D: Interrupt vector "USCI_B1" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 226: warning #10374-D: Interrupt vector "USCI_A1" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 227: warning #10374-D: Interrupt vector "PORT1" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 228: warning #10374-D: Interrupt vector "TIMER1_A1" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 229: warning #10374-D: Interrupt vector "TIMER1_A0" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 230: warning #10374-D: Interrupt vector "DMA" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 231: warning #10374-D: Interrupt vector "USB_UBM" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 232: warning #10374-D: Interrupt vector "TIMER0_A1" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 233: warning #10374-D: Interrupt vector "TIMER0_A0" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 234: warning #10374-D: Interrupt vector "ADC12" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 235: warning #10374-D: Interrupt vector "USCI_B0" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 236: warning #10374-D: Interrupt vector "USCI_A0" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 237: warning #10374-D: Interrupt vector "WDT" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 238: warning #10374-D: Interrupt vector "TIMER0_B1" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 239: warning #10374-D: Interrupt vector "TIMER0_B0" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 240: warning #10374-D: Interrupt vector "COMP_B" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 241: warning #10374-D: Interrupt vector "UNMI" does not have an interrupt handler routine.
"../lnk_msp430f5529.cmd", line 242: warning #10374-D: Interrupt vector "SYSNMI" does not have an interrupt handler routine.
undefined first referenced
symbol in file
__TI_int41
__TI_int42
__TI_int43
__TI_int44
__TI_int45
__TI_int46
__TI_int47
__TI_int48
__TI_int49
__TI_int50
__TI_int51
__TI_int52
__TI_int53
__TI_int54
__TI_int55
__TI_int56
__TI_int57
__TI_int58
__TI_int59
__TI_int60
__TI_int61
__TI_int62
error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "SSLAB2.asm.out" not built
gmake[1]: *** [SSLAB2.asm.out] Error 1
gmake: *** [all] Error 2
makefile:138: recipe for target 'all' failed
**** Build Finished ****
    [引用 userid="498834" URL"~/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/1037261/msp430f5529-linking-error-in-ccs ">>错误:mklib:rts430x_sc_sd_eabi.lib 编译期间的 gmake 错误[/quot]
      自动库构建过程失败并出现错误时、mklib 疑难解答会检查一些内容。 某些问题可能是由路径中的不兼容工具引起的。
    [请注意、该链接是现已删除的 TI 处理器 Wiki 的存档副本-我似乎无法找到信息迁移到的位置]
