[参考译文] MSP430FR5994:LEA 用于计算地球上2个点之间的距离
Guru**** 2563960 points
https://e2e.ti.com/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/971332/msp430fr5994-lea-for-calculate-the-distance-between-2-points-on-the-earth
器件型号:MSP430FR5994
LEA 是否可用于计算地球上2个点之间的距离? 如果这在单独的过程中运行、会非常有用。 TI 服务器上是否存在此任务的示例代码?
