[参考译文] MSP430FR59941:尝试使用 CCS 进行调试:获取错误"MSP430:在长度为0x354的第0页的0x1000处写入内存块时遇到问题:无法写入器件内存"
Guru**** 2503215 points
Other Parts Discussed in Thread: MSP430FR59941
https://e2e.ti.com/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/1178478/msp430fr59941-trying-to-debug-using-ccs-getting-error-msp430-trouble-writing-memory-block-at-0x1000-on-page-0-of-length-0x354-could-not-write-device-memory
器件型号:MSP430FR59941
我正在尝试调试程序、但遇到此错误。
MSP430: Trouble Writing Memory Block at 0x1000 on Page 0 of Length 0x354: Could not write device memory
MSP430: File Loader: Verification failed: Target failed to write 0x01000
MSP430: GEL: File: C:\sandbox\i4pd-Batteryless-EarDefender\EarDefender\Debug\amcu_EarDefender.out: Load failed.
0x1000是 BSL。  就我而言、我不想覆盖 BSL、通常情况下每次加载代码时都会写入 BSL 吗?
我看过这些论坛、唯一能找到的就是勾选"允许对 BSL 存储器进行读/写/擦除访问"框、我尝试过但没有帮助。
查看了项目属性、但看不到任何其他尝试
有什么想法要尝试什么?
Michael。
    您好、Michael、
    为了确切地说明您要问什么-您是否尝试写入 BSL? 这将改变误差的解释方式。
    最棒的
    Amruta
    否、我不会尝试写入 BSL。
    我正在尝试调试/加载应用程序。
    Michael
    明白了、这可能是您的链接器文件的问题。 您可以发送它吗?
    最棒的
    Amruta
    谢谢。  它只是器件的默认 cmd 文件、lnk_msp430fr59941.cmd。  仍插入以下内容:
    * Copyright (C) 2012 - 2021 Texas Instruments Incorporated - http://www.ti.com/
    * Redistribution and use in source and binary forms, with or without
    * modification, are permitted provided that the following conditions
    * are met:
    *  Redistributions of source code must retain the above copyright
    *  notice, this list of conditions and the following disclaimer.
    *  Redistributions in binary form must reproduce the above copyright
    *  notice, this list of conditions and the following disclaimer in the
    *  documentation and/or other materials provided with the
    *  distribution.
    *  Neither the name of Texas Instruments Incorporated nor the names of
    *  its contributors may be used to endorse or promote products derived
    *  from this software without specific prior written permission.
    * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    * Default linker command file for Texas Instruments MSP430FR59941
    /*   Usage:  lnk430 <obj files...>    -o <out file> -m <map file> lnk.cmd     */
    /*           cl430  <src files...> -z -o <out file> -m <map file> lnk.cmd     */
    /* These linker options are for command line linking only.  For IDE linking,  */
    /* you should set your linker options in Project Properties                   */
    /* -c                                               LINK USING C CONVENTIONS  */
    /* -stack  0x0100                                   SOFTWARE STACK SIZE       */
    /* -heap   0x0100                                   HEAP AREA SIZE            */
    /* 1.212 */
    /* SPECIFY THE SYSTEM MEMORY MAP                                            */
    MEMORY
        TINYRAM                 : origin = 0xA, length = 0x16
        BSL                     : origin = 0x1000, length = 0x800
        INFOD                   : origin = 0x1800, length = 0x80
        INFOC                   : origin = 0x1880, length = 0x80
        INFOB                   : origin = 0x1900, length = 0x80
        INFOA                   : origin = 0x1980, length = 0x80
        RAM                     : origin = 0x1C00, length = 0x1000
        FRAM                    : origin = 0x4000, length = 0xBF80
        FRAM2                   : origin = 0x10000,length = 0x33FF8 /* Boundaries changed to fix CPU47 */
        JTAGSIGNATURE           : origin = 0xFF80, length = 0x0004, fill = 0xFFFF
        BSLSIGNATURE            : origin = 0xFF84, length = 0x0004, fill = 0xFFFF
        IPESIGNATURE            : origin = 0xFF88, length = 0x0008, fill = 0xFFFF
        INT00                   : origin = 0xFF90, length = 0x0002
        INT01                   : origin = 0xFF92, length = 0x0002
        INT02                   : origin = 0xFF94, length = 0x0002
        INT03                   : origin = 0xFF96, length = 0x0002
        INT04                   : origin = 0xFF98, length = 0x0002
        INT05                   : origin = 0xFF9A, length = 0x0002
        INT06                   : origin = 0xFF9C, length = 0x0002
        INT07                   : origin = 0xFF9E, length = 0x0002
        INT08                   : origin = 0xFFA0, length = 0x0002
        INT09                   : origin = 0xFFA2, length = 0x0002
        INT10                   : origin = 0xFFA4, length = 0x0002
        INT11                   : origin = 0xFFA6, length = 0x0002
        INT12                   : origin = 0xFFA8, length = 0x0002
        INT13                   : origin = 0xFFAA, length = 0x0002
        INT14                   : origin = 0xFFAC, length = 0x0002
        INT15                   : origin = 0xFFAE, length = 0x0002
        INT16                   : origin = 0xFFB0, length = 0x0002
        INT17                   : origin = 0xFFB2, length = 0x0002
        INT18                   : origin = 0xFFB4, length = 0x0002
        INT19                   : origin = 0xFFB6, length = 0x0002
        INT20                   : origin = 0xFFB8, length = 0x0002
        INT21                   : origin = 0xFFBA, length = 0x0002
        INT22                   : origin = 0xFFBC, length = 0x0002
        INT23                   : origin = 0xFFBE, length = 0x0002
        INT24                   : origin = 0xFFC0, length = 0x0002
        INT25                   : origin = 0xFFC2, length = 0x0002
        INT26                   : origin = 0xFFC4, length = 0x0002
        INT27                   : origin = 0xFFC6, length = 0x0002
        INT28                   : origin = 0xFFC8, length = 0x0002
        INT29                   : origin = 0xFFCA, length = 0x0002
        INT30                   : origin = 0xFFCC, length = 0x0002
        INT31                   : origin = 0xFFCE, length = 0x0002
        INT32                   : origin = 0xFFD0, length = 0x0002
        INT33                   : origin = 0xFFD2, length = 0x0002
        INT34                   : origin = 0xFFD4, length = 0x0002
        INT35                   : origin = 0xFFD6, length = 0x0002
        INT36                   : origin = 0xFFD8, length = 0x0002
        INT37                   : origin = 0xFFDA, length = 0x0002
        INT38                   : origin = 0xFFDC, length = 0x0002
        INT39                   : origin = 0xFFDE, length = 0x0002
        INT40                   : origin = 0xFFE0, length = 0x0002
        INT41                   : origin = 0xFFE2, length = 0x0002
        INT42                   : origin = 0xFFE4, length = 0x0002
        INT43                   : origin = 0xFFE6, length = 0x0002
        INT44                   : origin = 0xFFE8, length = 0x0002
        INT45                   : origin = 0xFFEA, length = 0x0002
        INT46                   : origin = 0xFFEC, length = 0x0002
        INT47                   : origin = 0xFFEE, length = 0x0002
        INT48                   : origin = 0xFFF0, length = 0x0002
        INT49                   : origin = 0xFFF2, length = 0x0002
        INT50                   : origin = 0xFFF4, length = 0x0002
        INT51                   : origin = 0xFFF6, length = 0x0002
        INT52                   : origin = 0xFFF8, length = 0x0002
        INT53                   : origin = 0xFFFA, length = 0x0002
        INT54                   : origin = 0xFFFC, length = 0x0002
        RESET                   : origin = 0xFFFE, length = 0x0002
    /* Specify the LEA memory map                                               */
    #define LEASTACK_SIZE   0x138
    MEMORY
        LEARAM                  : origin = 0x2C00, length = 0x1000 - LEASTACK_SIZE
        LEASTACK                : origin = 0x3C00 - LEASTACK_SIZE, length = LEASTACK_SIZE
    /* SPECIFY THE SECTIONS ALLOCATION INTO MEMORY                              */
    SECTIONS
        GROUP(RW_IPE)
            GROUP(READ_WRITE_MEMORY)
                .TI.persistent : {}              /* For #pragma persistent            */
                .cio           : {}              /* C I/O Buffer                      */
                .sysmem        : {}              /* Dynamic memory allocation area    */
            } PALIGN(0x0400), RUN_START(fram_rw_start)
            GROUP(IPENCAPSULATED_MEMORY)
                .ipestruct     : {}              /* IPE Data structure             */
                .ipe           : {}              /* IPE                            */
                .ipe_const     : {}              /* IPE Protected constants        */
                .ipe:_isr      : {}              /* IPE ISRs                       */
            } PALIGN(0x0400), RUN_START(fram_ipe_start) RUN_END(fram_ipe_end) RUN_END(fram_rx_start)
        } > 0x4000
        .cinit            : {}  > FRAM          /* Initialization tables             */
        .binit            : {}  > FRAM          /* Boot-time Initialization tables   */
        .pinit            : {}  > FRAM          /* C++ Constructor tables            */
        .init_array       : {}  > FRAM          /* C++ Constructor tables            */
        .mspabi.exidx     : {}  > FRAM          /* C++ Constructor tables            */
        .mspabi.extab     : {}  > FRAM          /* C++ Constructor tables            */
        .text:_isr        : {}  > FRAM          /* Code ISRs                         */
    #ifndef __LARGE_DATA_MODEL__
        .const            : {} > FRAM           /* Constant data                     */
    #else
        .const            : {} >> FRAM | FRAM2  /* Constant data                     */
    #endif
    #ifndef __LARGE_CODE_MODEL__
        .text             : {} > FRAM           /* Code                              */
    #else
        .text             : {} >> FRAM2 | FRAM  /* Code                              */
    #endif
        #ifdef __TI_COMPILER_VERSION__
            #if __TI_COMPILER_VERSION__ >= 15009000
                    .TI.ramfunc : {} load=FRAM, run=RAM, table(BINIT)
                #else
                    .TI.ramfunc : {} load=FRAM | FRAM2, run=RAM, table(BINIT)
                #endif
            #endif
        #endif
        .jtagsignature      : {} > JTAGSIGNATURE
        .bslsignature       : {} > BSLSIGNATURE
        GROUP(SIGNATURE_SHAREDMEMORY)
            .ipesignature       : {}            /* IPE Signature                     */
            .jtagpassword       : {}            /* JTAG Password                     */
        } > IPESIGNATURE
        .bss        : {} > RAM                  /* Global & static vars              */
        .data       : {} > RAM                  /* Global & static vars              */
        .TI.noinit  : {} > RAM                  /* For #pragma noinit                */
        .stack      : {} > RAM (HIGH)           /* Software system stack             */
        .tinyram    : {} > TINYRAM              /* Tiny RAM                          */
        /* MSP430 INFO memory segments */
        .infoA : type = NOINIT{} > INFOA
        .infoB : type = NOINIT{} > INFOB
        .infoC : type = NOINIT{} > INFOC
        .infoD : type = NOINIT{} > INFOD
        .leaRAM      : {} > LEARAM               /* LEA RAM                           */
        .leaStack    : {} > LEASTACK (HIGH)      /* LEA STACK                         */
        /* MSP430 interrupt vectors */
        .int00       : {}               > INT00
        .int01       : {}               > INT01
        .int02       : {}               > INT02
        .int03       : {}               > INT03
        .int04       : {}               > INT04
        .int05       : {}               > INT05
        .int06       : {}               > INT06
        .int07       : {}               > INT07
        .int08       : {}               > INT08
        .int09       : {}               > INT09
        .int10       : {}               > INT10
        .int11       : {}               > INT11
        .int12       : {}               > INT12
        .int13       : {}               > INT13
        .int14       : {}               > INT14
        .int15       : {}               > INT15
        .int16       : {}               > INT16
        .int17       : {}               > INT17
        LEA          : { * ( .int18 ) } > INT18 type = VECT_INIT
        PORT8        : { * ( .int19 ) } > INT19 type = VECT_INIT
        PORT7        : { * ( .int20 ) } > INT20 type = VECT_INIT
        EUSCI_B3     : { * ( .int21 ) } > INT21 type = VECT_INIT
        EUSCI_B2     : { * ( .int22 ) } > INT22 type = VECT_INIT
        EUSCI_B1     : { * ( .int23 ) } > INT23 type = VECT_INIT
        EUSCI_A3     : { * ( .int24 ) } > INT24 type = VECT_INIT
        EUSCI_A2     : { * ( .int25 ) } > INT25 type = VECT_INIT
        PORT6        : { * ( .int26 ) } > INT26 type = VECT_INIT
        PORT5        : { * ( .int27 ) } > INT27 type = VECT_INIT
        TIMER4_A1    : { * ( .int28 ) } > INT28 type = VECT_INIT
        TIMER4_A0    : { * ( .int29 ) } > INT29 type = VECT_INIT
        AES256       : { * ( .int30 ) } > INT30 type = VECT_INIT
        RTC_C        : { * ( .int31 ) } > INT31 type = VECT_INIT
        PORT4        : { * ( .int32 ) } > INT32 type = VECT_INIT
        PORT3        : { * ( .int33 ) } > INT33 type = VECT_INIT
        TIMER3_A1    : { * ( .int34 ) } > INT34 type = VECT_INIT
        TIMER3_A0    : { * ( .int35 ) } > INT35 type = VECT_INIT
        PORT2        : { * ( .int36 ) } > INT36 type = VECT_INIT
        TIMER2_A1    : { * ( .int37 ) } > INT37 type = VECT_INIT
        TIMER2_A0    : { * ( .int38 ) } > INT38 type = VECT_INIT
        PORT1        : { * ( .int39 ) } > INT39 type = VECT_INIT
        TIMER1_A1    : { * ( .int40 ) } > INT40 type = VECT_INIT
        TIMER1_A0    : { * ( .int41 ) } > INT41 type = VECT_INIT
        DMA          : { * ( .int42 ) } > INT42 type = VECT_INIT
        EUSCI_A1     : { * ( .int43 ) } > INT43 type = VECT_INIT
        TIMER0_A1    : { * ( .int44 ) } > INT44 type = VECT_INIT
        TIMER0_A0    : { * ( .int45 ) } > INT45 type = VECT_INIT
        ADC12_B      : { * ( .int46 ) } > INT46 type = VECT_INIT
        EUSCI_B0     : { * ( .int47 ) } > INT47 type = VECT_INIT
        EUSCI_A0     : { * ( .int48 ) } > INT48 type = VECT_INIT
        WDT          : { * ( .int49 ) } > INT49 type = VECT_INIT
        TIMER0_B1    : { * ( .int50 ) } > INT50 type = VECT_INIT
        TIMER0_B0    : { * ( .int51 ) } > INT51 type = VECT_INIT
        COMP_E       : { * ( .int52 ) } > INT52 type = VECT_INIT
        UNMI         : { * ( .int53 ) } > INT53 type = VECT_INIT
        SYSNMI       : { * ( .int54 ) } > INT54 type = VECT_INIT
        .reset       : {}               > RESET  /* MSP430 reset vector         */
    /* MPU/IPE SPECIFIC MEMORY SEGMENT DEFINITONS                               */
    #ifdef _IPE_ENABLE
        #define IPE_MPUIPLOCK 0x0080
        #define IPE_MPUIPENA 0x0040
        #define IPE_MPUIPPUC 0x0020
        // Evaluate settings for the control setting of IP Encapsulation
        #if defined(_IPE_ASSERTPUC1)
            #if defined(_IPE_LOCK ) && (_IPE_ASSERTPUC1 == 0x08))
                fram_ipe_enable_value = (IPE_MPUIPENA | IPE_MPUIPPUC |IPE_MPUIPLOCK);
            #elif defined(_IPE_LOCK )
                fram_ipe_enable_value = (IPE_MPUIPENA | IPE_MPUIPLOCK);
            #elif (_IPE_ASSERTPUC1 == 0x08)
                fram_ipe_enable_value = (IPE_MPUIPENA | IPE_MPUIPPUC);
            #else
                fram_ipe_enable_value = (IPE_MPUIPENA);
            #endif
        #else
            #else
            #endif
        #endif
        // Segment definitions
        #ifdef _IPE_MANUAL                  // For custom sizes selected in the GUI
            fram_ipe_border1 = (_IPE_SEGB1>>4);
            fram_ipe_border2 = (_IPE_SEGB2>>4);
        #else                           // Automated sizes generated by the Linker
            fram_ipe_border2 = fram_ipe_end >> 4;
            fram_ipe_border1 = fram_ipe_start >> 4;
        #endif
        fram_ipe_settings_struct_address = Ipe_settingsStruct >> 4;
        fram_ipe_checksum = ~((fram_ipe_enable_value & fram_ipe_border2 & fram_ipe_border1) | (fram_ipe_enable_value & ~fram_ipe_border2 & ~fram_ipe_border1) | (~fram_ipe_enable_value & fram_ipe_border2 & ~fram_ipe_border1) | (~fram_ipe_enable_value & ~fram_ipe_border2 & fram_ipe_border1));
    #endif
    #ifdef _MPU_ENABLE
        #define MPUPW (0xA500)    /* MPU Access Password */
        #define MPUENA (0x0001)   /* MPU Enable */
        #define MPULOCK (0x0002)  /* MPU Lock */
        #define MPUSEGIE (0x0010) /* MPU Enable NMI on Segment violation */
        __mpu_enable = 1;
        #ifdef _MPU_MANUAL // For custom sizes selected in the GUI
            mpu_segment_border1 = _MPU_SEGB1 >> 4;
            mpu_segment_border2 = _MPU_SEGB2 >> 4;
            mpu_sam_value = (_MPU_SAM0 << 12) | (_MPU_SAM3 << 8) | (_MPU_SAM2 << 4) | _MPU_SAM1;
        #else // Automated sizes generated by Linker
            #ifdef _IPE_ENABLE //if IPE is used in project too
            //seg1 = any read + write persistent variables
            //seg2 = ipe = read + write + execute access
            //seg3 = code, read + execute only
        	       mpu_segment_border1 = fram_ipe_start >> 4;
        	       mpu_segment_border2 = fram_rx_start >> 4;
        	       mpu_sam_value = 0x1573; // Info R, Seg3 RX, Seg2 RWX, Seg1 RW
            #else
        	       mpu_segment_border1 = fram_rx_start >> 4;
        	       mpu_sam_value = 0x1513; // Info R, Seg3 RX, Seg2 R, Seg1 RW
            #endif
        #endif
        #ifdef _MPU_LOCK
            #ifdef _MPU_ENABLE_NMI
                mpu_ctl0_value = MPUPW | MPUENA | MPULOCK | MPUSEGIE;
            #else
                mpu_ctl0_value = MPUPW | MPUENA | MPULOCK;
            #endif
        #else
                mpu_ctl0_value = MPUPW | MPUENA | MPUSEGIE;
            #else
                mpu_ctl0_value = MPUPW | MPUENA;
            #endif
        #endif
    #endif
    /* INCLUDE PERIPHERALS MEMORY MAP                                           */
    -l msp430fr59941.cmd
    [引用 userid="37178" URL"~/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/1178478/msp430fr59941-trying-to-debug-using-ccs-getting-error-msp430-trouble-writing-memory-block-at-0x1000-on-page-0-of-length-0x354-could-not-write-device-memory ]0x1000是 BSL。  就我而言、我不想覆盖 BSL[/引述]
    您是否收到表单"创建输出段"的任何链接器警告 "没有章节 规范"?
    这种链接器警告意味着链接器可能会在 cmd 文件的 BSL 存储器区域中放置一些段。
    此外、链接器映射文件是否显示任何放置在 BSL 存储器区域中的内容?
    我找到了问题。 我有几个函数使用#pragma CODE_SECTION 放置在特定的存储器位置(位于上 fram 中)、但我忘记了将其添加到链接器文件中。  现在、感谢大家的帮助。
