[参考译文] MSP430F5529:有关 MSP430 USB BSL 升级的问题发送密码
Guru**** 2589630 points
https://e2e.ti.com/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/597497/msp430f5529-a-question-about-msp430-usb-bsl-upgrade-send-password
器件型号:MSP430F5529
代码如下所示、如果发送失败的第一个密码、它将擦除闪存(密码也恢复为默认值?)、然后使用默认密码(这次在右侧?)。
如果是这种情况、您可以轻松地传递密码
// Send Password... Causes mass erase if password is wrong!
1
2.
3.
4.
5.
6.
7.
8.
reply = BSL_RX_Password(pass);
if(reply)
  // Wrong password provided.
  // Memory is being mass erased. Setting a 1sec delay.
  *massErased = true;
  worker->ReportProgress(5,"Mass erase occured!\r\n");
  Sleep(2000);
1
// Memory is blank now. Re-send blank password to access device.
1
2.
3.
4.
5.
6.
7.
8.
9.
10.
reply = BSL_RX_Password(blankPass);
   if(reply)
     worker->ReportProgress(10,"Password FAILED!\r\n");
     e->Result = false;
     returnfalse;
 worker->ReportProgress(10,"Password Sent Successfully\r\n");
