[参考译文] MSP430G2755:是否可以将 UART 设置为反相信号线(低电平有效)
Guru**** 2812305 points
Other Parts Discussed in Thread: MSP430G2755
https://e2e.ti.com/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/1222564/msp430g2755-is-it-possible-to-setup-the-uart-to-inverted-signal-lines-nonactive-low
器件型号:MSP430G2755
我只是想知道是否可以反转 UART 线(非低电平有效)?
Christian
