[参考译文] MSP430FR6989:请参阅、在读取该芯片时、会发现以下显示内容、通常是什么导致调试接口锁定
Guru**** 2468610 points
Other Parts Discussed in Thread: MSP-FET
https://e2e.ti.com/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/1339944/msp430fr6989-consult-when-reading-this-chip-found-the-following-display-generally-what-causes-the-debugging-interface-to-be-locked
器件型号:MSP430FR6989
主题中讨论的其他器件:MSP-FET
请参阅、在读取该芯片后发现以下显示内容、通常是什么导致调试接口锁定
