[参考译文] LM5025:在 PCB 上设计有关 LM5025#39解决方案的变压器是否有任何参考?
Guru**** 2731945 points
Other Parts Discussed in Thread: LM5025
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/831600/lm5025-is-there-any-reference-to-design-transformer-on-pcb-about-lm5025-s-solution
器件型号:LM5025
降级:
在 PCB 上设计有关 LM5025解决方案的变压器时是否有任何参考?
